PDA
View Full Version : Computer Diagnostics and Tuning
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 [17] 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36
  1. Service Sengine Soon code 29
  2. Worth it to custom program a mostly stock '99 LS1?
  3. Service Engine Soon
  4. SD Mode and Fuel Trim
  5. Is -15.2 Long Term Fuel Trim Normal?
  6. Scanner cable... will it work??
  7. 1996 LT1/4L60e shifting problems...
  8. ALDL ports on V8 & V6 cars
  9. Had tunercat failure while programming 95 LT1. Now what?
  10. Knock Count
  11. Looking for 93 Lt1 .BIN's any kind
  12. Code P1131 - I need help
  13. adjusting fuel -tunercat question
  14. 94 Camaro RS PCM readin
  15. Long term fuel trim question...
  16. Need Auto (((HELP)))
  17. Security Light/No problems starting
  18. 381cu in stroker - tunercat newB.
  19. More knock after LT4 KM?
  20. Modifying ASR (Traction Control)
  21. Who Sells ALDL cables
  22. Compilation of Fixes for OBD1 High Stall problem
  23. Need a bit of advice on VE tables Vs. MAF tables
  24. Need a stock 95' Z28 M6 bin file please....
  25. MAF circuit? code38
  26. hotcam idle problems
  27. The most basic tuning questions
  28. OBD1 High Stall Problem
  29. code 24 (output speed low) & 34 (map low)
  30. FS NOKIA N91 AT JUST $230usd, MOTOROLA RAZR V3 AT JUST $140usd
  31. m6 swap programming & JET SCU ?'s
  32. tuning for fuel economy
  33. Code 410 questions
  34. I got code 43 and o2 sensor is reporting 200-600mVolts
  35. Data Login with TTS Datamaster
  36. knock retard
  37. changed O2's and still throwing a code?!?!
  38. Need help with Gen 7
  39. Whats better cutting fuel, or spark for rev limiter??
  40. Big cam and stock PCM?
  41. shifting woes with 4.88's
  42. looking for a 383 CC306 with 58mm tb tune
  43. Adjusting Fuel
  44. Code 33
  45. Quick question about o2 sensor readings....
  46. ALL VINs with LT1edit
  47. Low rpm stumble...Have Tunercat
  48. Can a predator tune for M6 swap??
  49. tuning for XE236/242, tips/suggestions appreciated
  50. Questions about pulling timing with the Traction Control tables
  51. What all does the PCM use the MPH reading for? My PCM is 5 time higher then my spedo
  52. Is it Legal to tune or not?
  53. maf/o2's
  54. How to run in open loop
  55. Camaro 3.4 and Firebird 3.4 Same PCM?
  56. code 29...fans on all the time
  57. Timing tables needed
  58. HPTuners and Superchips
  59. Shift points tunercat
  60. emissions question.
  61. Tunning Woes
  62. Reading Message 0, Word 52 (Knock Retard) from the ECM
  63. Running Rich?
  64. will this Moates product work with our Fbodies?
  65. LS1 edit
  66. free scan
  67. Freescan log
  68. Learn to tune
  69. tunercat/ Knock sensor
  70. Finally
  71. Wideband Accuracy? Which ones work the best?
  72. Help getting CATS going
  73. P0300 after Trex install, i've check about everything!
  74. Still having problems
  75. Question for tuners
  76. New to LT1s, Which tunning programs...
  77. Converting 1995 bin to 1993 bin
  78. PCM Bad?
  79. Caddy PCM Swap
  80. PCMforless + transgo shift kit problem
  81. Tuning Questions Please Help!!!
  82. PCM Problem
  83. Lean hesitation on '95 LT1 turbo
  84. Tunercats
  85. Lower Degree Thermo Without a Tune??
  86. tuning newbie...
  87. p1667
  88. LT1 Edit / Tunercat tunes
  89. are pcmforless and madz28 chips interchangeable?
  90. which cable do you guys recommend?
  91. Wideband o2
  92. Handheld Programmers for LS1
  93. newbie needs help please
  94. Keyless entry
  95. VE Tables and Big Cam Idle
  96. engine coolant temperature sensor..
  97. if your from il, please help
  98. no dyno tune close
  99. Does this look like Reversion???
  100. Computer won't connect to PCM
  101. programming for a m6
  102. a4 to m6 pcm question
  103. Help programming
  104. Quick Freescan Question
  105. TTS Datalog transmission question
  106. can someone convert a .lt1 to .cal file for me?
  107. tps code?
  108. Deleted the O2's
  109. IAT sensor questions
  110. obd2 cable
  111. Fried a PCM
  112. Usb and datamaster
  113. Can anyone look at these Datamaster logs?
  114. a4 to m6
  115. pcm question
  116. Another satisfied customer....
  117. 230/236 tune
  118. o2 sensor probs, and more........
  119. Good General GM Software
  120. codes for a '95
  121. What is the top of the line OBDII scanning software?
  122. AKM obd1 cable help
  123. OBD1 Free scanware for Laptops
  124. computer turned off while loading tune
  125. TunerCat Instructions
  126. Belkin USB to Serial Drivers
  127. How to identify different year PCM's?
  128. What laptop?
  129. tts datamaster
  130. can someone take a look at my log from my 383
  131. Open Loop Tune Verification
  132. HPP3 and MadWolf Tune
  133. TTS datamaster - com port locked?
  134. which scanmaster is needed for OBDII LT1?
  135. my pcm?
  136. Determining RWHP using datamaster...
  137. can someone send me a 383 tune
  138. free scanning program for DOS
  139. Iac zero,block learns at 160 at idle.
  140. What to get to scan a 97 for codes?
  141. help! 383 stumble putting in gear...got some Tech II scanner info included
  142. Autotap datalogs
  143. P0133
  144. **HELP**Even cylinders all misfiring
  145. Air/Fuel programming
  146. excellent work Ion (madwolf)
  147. scanner software for a 95 3.4 VIN S
  148. Does anyone in Austin area have akm or similiar cable I can use to download a tune
  149. hypertech programmer
  150. Electronic gauges on screen
  151. rear o2 sims change timing?
  152. anyone have a tune for a 383 M6
  153. Adapting OBD1 Connector to OBDII (95) ALDL for scanning
  154. Science behind O2 sims.
  155. Canister Purge effect on BLMs
  156. PDA to LT1
  157. Help! I'm looking for a 98 Edit file # 9365941
  158. Free real time diognostics?
  159. temp guage quiet
  160. Right Rear O2 sensor on 95 Vette
  161. Need help Excessive spark??
  162. Tunercat - Tuner, or Tuner RT? Can't figure it out.
  163. Tuning for blower and 42# injectors
  164. front 02s
  165. Tunercat Fuel tables
  166. really frustrated with o2 sensor problem. car has major power loss. seems to be rich
  167. making a cable, how to test
  168. 1995 PCM pin-out verification
  169. Another happy Ion cust.
  170. wiring up a standalone F.A.S.T.
  171. Turned my 8 into a 4!
  172. NEED HELP, laptop shut off during reprogram
  173. help with datalog questions
  174. Need Some Help
  175. 2k rpm surg
  176. EVAP solenoid
  177. Will changing the target AFR change gas mileage?
  178. reprograming
  179. TPI TroublingShooting
  180. tuning
  181. Tunercats Tables Menu Display
  182. Data Logs/Few Questions
  183. Hooking up a scan master on an OBD II connector.
  184. Anyway to permanetly disable VATS...need quick help...
  185. Idle too low after slowing down
  186. Will my shift point change if my gears arnt programed right
  187. code p1336 after pcm exchange
  188. dash all lit up HELP!
  189. engine swap
  190. How much spark advance?
  191. Can a 94/95 ECU be swapped in for a 93 car?
  192. can i check TPS voltage with engine off?
  193. Can anyone take a look at this DM log?
  194. Question for Autotap Users
  195. Advance Auto Parts scanner says I must plug device in....?!?!?
  196. 7000k stock PCM limit
  197. Code scanners
  198. a4 to m6 swap
  199. ? about OBD1 conversion
  200. C6-r
  201. Timing retard for nitrous
  202. Tune needed for new mods?
  203. RPM slow to come down at a stop
  204. lookin for info on tunercat
  205. Please look at my freescan log
  206. Is it safe to adjust the idle with freescan?
  207. OBDI vs OBDII; USB vs RS232
  208. LT1 Scanmaster?
  209. Help With Diablo Predator Tuning!
  210. P0430 TWC system low efficiency bank 2
  211. dyno tune or have garage scan car?
  212. readiness monitors - how long?
  213. open loop
  214. "HELP" tried to program ECM and now car wont run
  215. Factory Stereo Problems
  216. HP tuner to tunercat
  217. P1441 Code Evap ...Help?
  218. Dastek Unichip?
  219. trial version of TC
  220. Best Tuning Software/Hardware (Yes, did a search!)
  221. maf high code
  222. Bad Program?
  223. [B]Who burns 3rd Gen Proms?[/B]
  224. hitting rev limiter
  225. Is there a common problem with these codes...
  226. Can you make a tune to add "lope" with a stock cam?
  227. Question about A-Tap
  228. LT1 A4 shift point programmaing survey
  229. EFIlive or Autotap?
  230. Neutral Safety Switch Issue
  231. Can anybody take a look at my scan?
  232. Lost Speedo During Reflash
  233. Wdieband to datamaster
  234. Code 42, how do I fix?
  235. ABS INOP light coming on and car being weird..
  236. Need Copy lt1-edit
  237. mail order tune for STS kit
  238. New AftermarketComputer Needed
  239. Installing Infinity in-dash navigation into another vechile...
  240. Can somone look at my data logs? BLM's
  241. madz28 or pcmforless tuning
  242. I've tried everything! PCM: Invalid response!!!
  243. a4 shift point tuning help
  244. Open Loop part throttle tuning
  245. need someone with experience to look at this datamaster scan for me, injuneer?
  246. PCM Scanning
  247. Converting 93 to 94-94 pcm
  248. Is there a problem??????
  249. tuning the new TA with new mods
  250. 97 z28 will not start
