- gaining power from pcm tuning
- If You Have Had You Pcm Programmed Come In Here!
- security light on (all the time)
- .BIN to .LT1?
- OBD2 Data logging
- cc306 tuning ? changed cam now it wont idle
- Trouble code, and reading help
- AKM ALDL cable
- Idle in Park Great - not so in Drive
- tuning options for the LT1
- Tunercats questions
- 30 lb tuning question
- quick handheld question.....
- Pcm Tranny Tricker
- '93, DIY cable, did I use wrong design?
- Car not running
- 373 gear reprogram diablo programer
- help me understand computers
- How Do I Decode My Datamaster Findings?
- Factory alarm. I need to disable or get it working.
- Tuning Question!
- LT1 Edit Noob (HELP)
- Dyno Tune
- Too Rich in Closed Loop
- 1996 Caddy ECM w/ auto work in my 1996 z28 6 speed for tune? ---
- What is the computer on drivers side frame rail
- Code 55?
- Getting Data from my '95
- Cool - a Free Desktop PC is always welcome!
- Hypertech with cam/ or stock computer tuning
- backfire problems
- JET performance chip
- Need info on tuning trans tables
- Idle Open Loop Really Rich after BLM Locker
- Installing ported heads, do I need a retune?
- which mail order tune is the best?
- a scanner question
- LT1 aftermarket ECU users... need a little help.
- datamaster file
- OBD1 LT1Edit help/can't make changes
- O2 Sensor Reading? Open Loop Issue..
- DTC code 41
- ECM Port not working right
- buying a 94 - can I tell if PCM is correct to the VIN?
- is this normal?
- tuning help
- Hypertech verse pcmforless
- PCM Question
- 2nd Thoughts About My Tune
- obd1 code reader
- Good place to grab connectors?
- DFCO not disabling as expected
- Can VSS (circuit) be bad, but speedo still work?
- Shift Table for 3.73s
- Logging software and edit software(100% NEWBIE)
- Just DST some help please
- spankin new motor..code 42
- Hypertech Programmer Issues
- connecting akm cable
- ECM question
- wideband output into EGR input?
- hypertech
- N2) before MAF tunning.
- top end problem debugging
- throwing code, cheapest way to scan??
- PO335 and PO336?
- Datamaster Log Review
- LE1 heads and 230-236 cam bin.file for a 95
- Is LS1 Edit 'outdated'? Newb to tuning.. Couple Q's.
- Tunning for 37# lucas injectors?
- which plug (obd1 or 2) do i have?
- speedo tuning
- lean idle in closed loop?
- Which is better Tuner CATS or LT1/LS1/LS2 Edit???
- Dyno tunes
- Need GEN 6 DFI Tuning in New Jersey
- Quite pleased with the outcome
- PCM Programming Special from Trifecta
- Injectors still not grounding out...
- Can't connect to 97 TA?
- Speedometer background change
- Question about OBD I and II
- MAF sensor functioning
- Tuning Software that Tracks
- pcm reflash
- Desk top programming
- Looking for some steps.
- flash program
- madz28.com VS PCMforLess.com
- OBD II PCM interchange
- Air Bag light after programming! Please help!
- Changing Idle in CATS
- 93 LT1 Can I change tune myself?
- Innovative LC-1?
- tunercat OBDII Tuner / WinFlash Help
- Tuning question?
- A4 pcm vs. m6
- P0135...?
- what exactly is HP tuner?
- Have a mail order tune, what next
- Open Loop AFR vs Coolant Temp vs Map
- What's needed for lap top data logging?
- Aftermarket ECU geniuses in here please!
- Turn signal/Park lamp on '01 WS6
- How to calibrate speedometer
- timing tables? do they show advance or retard?
- Speedometer is incorrect
- Dash lights acting up
- Cable connection problem
- best programmer
- Looking for a bin file thats close
- A4-M6 swap - running problem - computer??
- 95 camaro z28 lt1 bin file
- Tunercat and Windows Vista
- Got a '95 AKM cable but a OBDII connector...
- Did my PCM blew a gasket?
- VE Master use
- deleting P0400?
- Need stock 94 M6 program.
- How to Lean Car using Tunercat?
- Est circuit code 41, 42
- Can I tune out EVAP without physically removing system?
- LT1 Edit guys in here! Tuning guys!
- HELP - Code 26, Code 77
- datamaster displaying wrong data
- ALDL Cable hookup....
- Software to delete SES codes?
- Deleted EGR on PCM - IF still plugged in will it still toss a SES?
- 12200411 PCM ('01+ LS1) conversion on an LT1? Links inside!
- ***USB Data CABLE***
- cam/383 tuning
- on the quest for a perfect tune...
- Valet tune suggestions?
- How do I change VIN# in the PCM.
- computer reprogram
- Switching to speed density 94 LT1
- I need the VATS programmed out...
- dyno programming
- 96-97 LT1 Question
- got my car scanned?
- Scanned Car showing a couple of codes
- Power programmer 3 ????
- retuning a car with lt1 edit
- datamaster+96 Camaro+Obd1 PCM+errors
- handheld tuner questions...
- shift firmness on pcmforless tune?
- 96 formula, what cable?
- lt1 edet
- Need QUICK advice re PCM flash please
- New to Tuning...Where to start?
- LS1 Edit
- Tuning Help!!!
- offset for A/C pressure sender
- Is it that easy ?
- VATS reset
- Tunercat connection issues...
- LT-1 Cam Sync Signal for Aftermarket PCM's
- Replacement LT4
- tuning of the stock computer.
- Got a new cam have some questions about lt1 edit
- '96up keyless on '95?
- Do Lt1's have a blackbox?
- Security Light on 96 Z
- Tuning using PE maxes out?
- Tuning and EGR will increasing the EGR effect at idle/part throttle increase mpg?
- Using TC With EPROMs
- Mat ?
- WOT Tuning without a Wideband - UPDATED
- Max line pressure constant?
- 93 Speedometer scalar Tunercat
- '95 With the OBDII body...but OBDI wiring...grrrr
- fuel inj. values/ handheld programmer?
- ignition control output waveform
- Need someone to check my datamaster logs
- DTC 83 code? Help needed.
- Tuning for 55lb injectors
- No Start Problem - Have data log
- 1/4 mile ET from GPS
- 1994 Harness into a 1995? Help!
- looking for wiring diagram
- JET Dynamic Spectrum Tuner
- ECM Programming
- code 43 and a code 29 ?
- Idling with big injectors
- Shift Point Tables for a 3.42
- Help with reading datamaster file
- 2.2L and Caddy V8 Coil Packs
- Switching to EDIS 8 Need help
- best datalogger for obd 1+2?
- Just recieved laptop off Ebay...now what?
- code 33
- ECM Options For Turbo
- shape of WOT timing advance curve
- Tech 2 air to fuel ratio
- burned up pcm
- F.a.s.t., Bg3, Accel Dfi Gen7?????
- banks read different
- Acceptable a/f at cruise (SD, open loop tune)
- freescan w/ vista
- going le-2
- computer swap
- Laptop OBD II Interface
- TTS Datamaster software
- Security light wont turn off
- 6.0 liter LS in place of LT1 (wiring)
- USB Cable Connection (laptop - port) problems
- OBD I conversion
- Vista and Datamaster
- Code 15, 1993 Z/28
- P0140
- ls computer and wiring
- Miss at 6,200 RPM, need help
- 1994 z28 58,000 miles question on tuning
- PE Tables in Open Loop tune (93 Car)
- OBDII Tuning and Emissions
- Speed Density tune, easy?
- Datamaster help!
- tuning help blinking ses
- bad extension cause heater code????
- SERVICE ENG. SOON light
- Tuning???
- Timing
- P0443
- Trans help needed
- whats up with my lt1 edit
- Another Datamaster file
- chip location
- MADZ28.com....Ion???
- what kind of chip should i get?
- 30 lbs injector tuning
- Datamaster File
- What determines the downshift?
- OBD I and II
- Retarding Cam
- Is this a Good Deal on a Dyno Tune?
- shoebox and others need help with fans
- p.c.m. tune,who's best/scanmaster
- obd1 vs obd2
- TTS Datamaster OBD1 Cable Tester Program
- New and I need some help with SES code.
- Transmission Tuning Tutorial
- veh. factory security
- Need help with tranny asap
- Need Help with MAF sensor calibration.
- Installing a Knock sensor light ??
- tried search: testing O2 sensors, which wires?
- PLEASE: Help me out
- Need stock 95 Z28 bin file for M6
- P0135 O2 heater causing SES... any ideas?
- SES and 5 codes,
