- Needed: Stock 96 or 97 bin for LT1 A4
- looking for
- looking for bin file
- PCMforless question?
- 383 stroker tuning
- Can someone look at my datamaster log?
- Want email f body tunercat/jet obd2 email buddy.
- Worth getting an OBD1 Conversion if I am getting the car dyno tuned?
- 93 to 94 Conversion Help No Communication
- chagning vin in obd1 pcm
- Back from the shop, 2 new codes
- 1994 Z28-ABS light
- VE tuning?
- tuning out 4l60e
- 93' chip worth it?
- Is AKM cables still around?
- 1985 Corvette computer chip
- Can I upload a tune to a 94 using tunerpro?
- 95 Z-28 Trouble code 16 Dist. Ign. System?
- Making changes to predator canned tune?
- Does PCMFORLESS lock the PCM?
- Bin or LT1 file wanted
- OBD1 Conversion ?
- My Scanmaster readings* [edited] Anyone? :)
- Tunercat/jet questions
- TRANS tuning w/VIG 2800
- Open Loop Tuning
- How much total timing with Madz28?
- Scanmaster LT1 Question that is not in search.
- MAF in open loop?
- Do i have a stock tune?
- Need some trouble shooting help PLEASE
- Tunercat newbie...Is there a document that explains all the parameters?
- BLM counts normal?
- Need lt1 edit file or programmer
- OK what better and what works?
- Closed loop question
- Logging wideband O2 with stock PCM and Datamaster – WRITEUP
- VEMASTER...where can I download it?
- thinking about getting XFI
- Anyone use tuner pro?
- LT1_Edit - 83lb Injectors - Stock PCM HELP
- Need help reading this data...
- Replace N/B o2's with output from wideband
- Auto - M6 program
- AKM cable software?
- PCM's dying!!
- LT1 96 Tune and fic or tune out trouble codes
- **!! Crazy MAF idea !!** closed loop to open loop on the fly with big boost
- bin file
- L Term Counts
- Do I need a Tune?
- 30# accel fuel injectors
- Tuning
- speedo change
- what table do i use
- shifting problems...TPS?
- I need a cable..
- Freescan cells from 0-15. Are they OK?
- i need to read my codes but my car is OBD-I
- Madz28
- TPS Voltage
- S Term Counts
- I can read DTC codes but cant read live data.
- Interface cable information
- help with obd1 tuning
- Help newbie at obd1 tuning
- Stock LT4/M6 program bin file
- odd malfunction.. where to start??
- Knock Counts
- Need custom programming?
- 96 camaro keyless remote programming
- Programmer Question
- Can't get knock to show on Freescan
- LM-1 but no rpm converter question.
- Handheld programmer for 90 TA?
- Email tuning? What do i need?
- LM-1 RPM Converter hook up, how you guys doin it.
- Narrowband data from a wideband sensor - LM-1
- Dyno Tuning & Catalytic converters
- GM's Programming to Half Lock the Converter?
- for those who want a cheap GOOD scanner
- Someone to look at Datamaster file
- Viewing a Datamaster File
- How to fix kinda miss or surge when hot with Tunercats
- Idel Adjusting
- Killed my ECM with Tunercat
- Dyno tune file
- DTC 66 - ABS Motor
- Which tuner would you recommend
- dyno tuning in or near atlanta ga
- Anyone running the old fast bank to bank with Fast track harness?
- Will this affect my Tune?? STS
- Datamaster logs, and tunercat questions
- FAST USERS: Base F.A.S.T LT1 tune?
- Shift point question
- shift points with tunercats
- 1994 tuner cats fan constant...where is it?
- New to tuning... had some basic Q's
- changing gear ratios, what to change in tune?
- Fuel Trims & MAF & Stuff...
- finding lt1 edit
- tuning the '93 Lt1
- Code Trouble PLEASE Help
- 94-95 - which byte changes Carline?
- %Change to Fuel/Air Ratio Vs. RPM at WOT
- what dose this mean?
- auto to manual conversion, but do i need...
- Diagnostic port
- air feuel ratio question?
- Tuner packages
- Ques about tps volt vs tps %
- Looking to go wideband, what is my best choice?
- P0336
- Can I run the spedo without a pcm?
- scanmaster lt1 question
- F.A.S.T B2B Tach signal?
- what is this wire?
- *ADVICE* - power programmer/performance chip
- chip burner?
- Actron scanner users - is knock retard displayed with tenths of a degree?
- Scanning/datalogging software help
- can a 96 pcm be reprogramed for my 95
- car pulling timing below 1500 rpm
- Normal knock count
- Can't create a good File with Tunerpro
- DataMaster Log; Need Help Diagnosing
- What's your EGT Temp?
- Replacing a 93 4l60 with a muncie 4 speed..what PCM changes needed and what effects?
- dyno tune in GA, savannah
- tuner cat questions! give me a hand guys and gals!
- TunerCat question
- WOT PE Tuning Questions
- VE tables in SD DA2 question.
- Need help with scan results!
- First Time Looking at Data, Help Please
- Removing PCM?
- line pressure offset,shifts hard at low tps
- LT1 Knock Sensor Electrical Specs
- Can anyone please HELP me?
- ABS delete...EBTCM module location?
- How long will the PCM hold a code after SES light?
- Which wire for tach signal on 93 LT1 with LTCC?
- whats this mean??
- If you were starting out?
- P0300
- L.A. Tuners?
- codes 26 and 46
- Oh my god im such a dummy (tunercats)
- Which Cable?
- Shift Firmness
- How much timing?
- Innovate wideband sensor connection?
- Causes of Knock?
- LS1 PCM conversion ?'s
- Setting fan on/off points in TunerCat
- DataMaster log reading?
- Scanmaster code 61
- rev limiter issues
- Coverting 96 LT4 vette, to 95 ODB1 PCM
- Datalogged the car and......
- Using A/C pressure PCM pin for wideband O2
- can anyone reccommend an LT1 dyno tuner near columbus, ohio?
- jet software tuning problems help!!!
- 1993 code 44 and poor fuel economy
- Manual fan switch no longer works after PCM retune.
- 94 Z28 ABS Codes
- Please take a look at 93 datalog
- LT1-Edit or Tunner Cat question?
- Problem with VATS
- trans tuning issue
- BLM are between 108-115 most of the time and the exhaust is back at WOT
- New Painless engine management
- SLP Shift Improvement Module
- Running rich please help
- FAST/Speed Pro (old version) vs. XFI
- Free Scan Log Question???
- cant connect with akm usb
- BLMs stuck at 128/128 in closed loop, no correction!
- PCM and volt meter reading???
- 94 lt-1 Auto to Manual
- Uugh, I need help!
- 1998 corvette pcm came as 1998 pcm?
- cant open .lt1 file
- $50 updates
- severe timing retard**file inside**
- 89 F-Body- which wire (a/c signal) alters iac signal?
- Egr Q
- Transmission DTC Codes
- Air bag light is on whats up?
- lose communication with PCM when car starts but have it when its off
- Help with TCC engage and release?
- failed Md emissions - need help
- can i keep the 93 tranny when switching to a 94 pcm?
- MADZ Tune ?
- rpm limitations on stock pcm
- how do i bypass vats in the PCM...
- 81 computer: info amnesty
- Wideband:single bank or double bank
- 383 le3.2 cam , le3 heads timing comparo
- Wake up PCM, wake up!
- f.a.s.t/ delteq
- tuning question
- what other software can I ise to log with autotap cable?
- Can someone with autotap check....
- Are Mail Orders Just A Band Aid?
- Does anybody sell a 'Bench' setup to program a LT1 PCM ?
- key cylinder problem
- 16 pin ALDL configuration
- PCM Expert Pls help
- need help on a code
- Ive got a headache, Why is 93 eprom confusing
- Could someone explain these codes???
- PCM is tuned - can it be copied and detailed?
- A cheap 93 z link cable?
- BLM locker
- dyno tuning near alpharetta GA
- Tunercat 273 rearend settings
- New 94 Z28 Owner
- Where can i buy LT1 edit
- Transmission Switch
- PCM for less question
- right side blm maxxed
- 93 LT1 datalogging
- How do you learn to tune?
- Changed Tune, Car hangs at high idle longer... Why?
- Tuning Help
- tuning for my 94LT1?
- Got your PCM tuned yet?
- Idle Air Control Defaults in LT1Edit?
- Would this work for a 95?
- Anyone else Zero out the PE vs RPM table?
- codes?
- Tunercat stock tranmission
- Stall wall
- Tuning MAF for leaner idle for large cam
- Need Corvette 94-95 M6 file please
- swaped a 97 computer into a 93, how do i set up the OBDII so i can scan it
- Turning off VATS in LT1Edit
- If I take out my wiper fluid tank will I throw a code?
- How do you get codes out of a 94z LT1???
- BLM question
- will this work
- What should spark advance be at idle?
- computer and wiring qustions
- What Pin at PCM for wideband to AC input?
- My ALDL cable won't work correctly!
- ECM Tuning
- Can I Pull my OBDII tune from PCM with this cable?
- Internal PCM Resistor Mod: OBDII to OBDI Conversion?
