- are 4.10 gears too much for road racing?
- brake cooler ducts
- Autocross Cam and header clearance questions
- Is there a better bang for the buck all around tire than Yokohoma AVS intermmediate?
- Helmet clearance
- 4th gen vs. 3rd gen handling
- Track days at Bragg-Smith (Pahrump, Nevada)
- 4th gen BBK
- Insurance for track days and driving schools
- Solo2 Racing School May 4th
- Nitto question?
- Can i be competetive with an A4?
- Solo2 style track as retail business?
- Tire Wobble..Help
- Torino style seats from Espeed racing?
- Z28 front end alignment specs
- Corvette hubs on a Z28?
- Bilstien front shocks
- Alignment specs..max camber
- High Stall Converter with AUTO X, does it work?
- Brake Upgrade Options?
- Suspension material
- Dunlop 8000s
- What is wrong with my LCA's????please help
- Which Vette rims?
- Belt popped off during SCCA today, is that normal?
- Tire question Auto X
- tires rubbing on semi hard turns
- Will completely removing my exhaust bump me out of f-stock?
- Set of Bilstiens for $300 shipped, any good?
- Anyone with Eibachs, HELP. Having probs with my shocks!
- Mazda Racing School Weekends $39
- FS: Kumho Victoracer RR tires
- Hydraulic system discussion was LS1/LT1 MC exchange
- Daily drivers with rollbars
- I want to lower my car do I need...
- Poll: STB or SFC which made more of a difference?
- Can't get enough preload on the springs?
- Will I feel the difference?
- Subframe Connectors
- Zexel Torsen Differential Question
- carbon metallic pads
- Koni adjusting
- Car Books
- Will an LS1 master cyl work better than one from an LT1?
- BMR K member
- Is there any way to “lock” our seatbelts?
- Dimesions on boxed LCAs
- NCRC Track Days - Laguna Seca
- UPPER PHR? Anyone boxed this in?
- Teach me suspension...
- Anyone Using higher stall with a4 for Autox
- Azenis Sports?
- FS: Koni Double adjustable shocks and Global West Suspension Parts
- Coil over problems.....need some ideas.
- What is weight of 96 WS6 Wheel?
- Rear end noise.....suspension noise
- Pan Hard Rod relocation brackets? (PHR brackets)
- Suspension cannot be brought into spec(alignment)?
- New Camaro owner AutoX questions
- Last chance to get C5/ZO6 brake conversion brackets...ever!
- Questions on install & adjustment on panhard rod...
- anyone with c5 wheels, 17 in front and 18 in back?
- Does Torsen make a T2R for 12-bolts or 9" rears?
- the real deal on strut tower braces
- Koni and Pro-Kit installed....Have ????
- Need a quality rod-end... and some tips on what is excessive
- Bad understeer - tips appreciated
- What pressure should I run NITTOS at??
- handling
- Brake Ducts
- Front end rebuild-what needs to be replaced?
- Ride height differences LT1 and LS1
- handling comparison
- 95 Formula Road Racer
- New one..BAD break...possibly caused by hard cornering???
- '99+ Zexel Torsen Diff in '94?
- Horsepower or Torque???
- considering front sway bar ...
- need advice setting up my QA1 shocks
- People with BMR upper and lower a-arms...
- Just Ordered Spohn LCA's, LCAckets, and Panhard bar. Am i doing it right?
- The Great Spring Debate
- SpeedTrialUSA track day @ GingerMan Raceway April 19
- Where can I get Z06 brake conversion kit-->
- 315/35/17 Sumitumo HTRZ's
- 315's all the way around
- Z06 Brake Conversion
- Yokohama Avs es100
- toyo tires??
- 4th Gen Owners Who Removed Ac
- BFG DR's on turns?
- Suspension parts
- Tire question / Goodyear Eagle 255/50/ZR16?
- Attn: Road racers
- Electronically Adjustable Shocks
- How can I determine the spring rate on my new Eibachs?
- EBC Greenstuff Pads- Where to buy?
- What swaybars and SFC , street car
- Spring Install
- Alignment Specs
- Firestone Firehawk SZ50 EP
- Sitting High
- D.O.T. Race Tire impressions
- Koni DA Bump Stops
- Has anyone put 275's on there 11" rims
- Correct way to center rear axle
- bilsteins still on backorder?
- Pics of my TA with 11s and 315s
- Bushings and Endlinks
- Initial handling improvements...
- SLP or KB SFC?
- New to auto-x/racing..when and where are the events???
- what bolts to use on when replacing stock lca and panhard bar
- sway bars and such
- Baer Track Kit, fit on Enkei Winn 17" Wheels
- GW upper control arm bushings??
- Bridgestone RE730's verses...
- 11s and 315s on all 4 corners ...
- FYI - Big MSCC event April 12, 2003
- ABS and bigger brakes
- Tranny tuning for autox, LT1 Edit
- I did a search but didn't find what I was looking for
- goodyear F1 GS-D3 tires
- smaller diameter tire in front
- Best Victoracer size for 16x8 (did search)
- bilstein coilovers and general?
- lowering springs
- Suspension newbie. What bushings should I replace w/ poly ?
- Brake opinions
- Does anyone have the link to the braking comparisons????
- Rear Calipers
- Torsen available on 97 non SS cars??
- Your opinions on ceramic brake pad material
- Will 285/35/18's fit under all four corners?
- Panhard rod & control arms
- Dr. Mudge you have too much fun
- Graduated from an LT1 Z/28 to a LS1 SS, WOW
- stock rims
- Goldline Coil Spring 1.5" Drop
- Will Eibach spring coilovers + KYB shocks = wheel hop?
- rubbing tires
- Anyone who has swapped from LT1 brakes to LS1 check in.
- C5 brakes upgrade
- VGX brake pads?
- Opinion on RKsports adjustable springs?
- global west traclink
- Tire and wheel width
- Cutting rear stock springs?
- 3.8 Vs a Mustang GT
- C5 upgrade, do LS1 brake lines fit? (or are C5 lines required as well)
- 1LE suspension
- Porsche GT3 conversion kit for 93-02 fbody
- 315's in front
- What Suspension Parts Interchange On 3rd and 4th Gen Cars?
- rear coil over
- suspension parts
- Circle Wheels.. Anyone -->
- Are the Front and Rear End Links the Same Length? (4th Gen)
- EBC Green Stuff good for a DD car??
- Anyone in dallas texas area
- Good replacement shocks- please reply!!!
- wheel offset
- good brand of sfc
- Newbie that needs.....
- Putting in new Canton Oil Pan with motor in car
- coilover help
- Opinions on energy supension end links
- Re-Valved Bilstein question..
- A4 Auto x ers using LT1 Edit
- why is my can showing me the service engine soon light?
- How long does it take to install.....
- improved handeling?
- Will my brakes survive a track school?
- another brake question(sorry)
- are rk sports double diamond sfcs very good?better than tubular from spohns?
- Teach me Coil-overs
- Other sources than Baer for replacement pads/rotors?
- Computer straightening
- How hard is it to change wheel studs?
- Noise Limit
- Recommended BFG KD Pressure?
- Details and how to K-member install please....
- Water cooled brakes?
- Spindle Question
- DMS or BMR LOWERING SPRINGS??
- Suspension Install
- P-Zero Slicks
- Went to my first AutoX the other day, need some advice!!
- My dad claims that his stock WS6 handles as well as a Vette
- Why Does SLP not use Bilstein HD's?
- HELP! Steering linkage hits headers after BMR k-member install!!!
- What Kind of Brake Fluid Do YOU Use?
- Torsen T2R Installation Difficulty Level?
- How much can you compensate for a bent frame :P ?
- traction off line and in corners compromise
- Big wheel?&Control arm ?
- Tires
- Prospeed Motorsport
- Wilwood vs Baer... Opinions!
- Frame bent?
- Bilstein vs KYB Gas-A-Just
- 305 v. 350?
- I need suspension help
- Doing a C5 brake Conversion, Have a few Questions.
- Newbie Qs: Which springs are gray?
- Tires
- Hawk Vs. EBC brake pads.
- Real bad luck in Florida's Best Driving Season
- clunk from koni double adjustable?
- Cutting Stock Springs! Need help
- Gen 1 or gen 2 for for killer street canyon runner?
- Difference between1LE and BMR
- Which combo shall I consider?
- Auto-X Wheel Question
- alignment recomindations(sp?)
- do Camaros/trans am's make good auto-x cars? how do they compete?
- Best Place to Buy Shocks/Spring
- autoX with coilovers
- wheel help
- Pedals for heel-and-toe
- Central Flordia
- Spindle = Steering Knucke?
- Someone tell me if the fitting on the top if this shock comes off, pic inside
- Tires Hitting well when hit bumps
- tire width
- Best rear brakes w/ ls1 fronts and bleeding problem
- Suspension Mods
- Alignment needed after shock install ?
- What class is LS1 Z28 in Autocross?
- Sportline Kit on fbody?
- Brake problem, please help
- First time to auto cross
- anyone here with HAL shocks / springs ? need some opinions
- best tubular k for the street
- why coil overs? adv or dis-adv?
- Spring install
- Can I JUST do lowering springs??
- removing welded subframe connectors
- Front Strut
- First $500 should go to what suspension?
- Road Atlanta in May
- wtb shocks struts 3gen
- Are these the right Bilsteins?
- Help!! Problems after attempted lowering spring install!
- cut bump stops & Eibach PK
- Anyone have some stock Upper control arms FS?
- Can i use my Eibach sportline front springs on a set of Hals ????
- Rear Suspension Creaking - 96 Convertible Z
- Does anyone make any 2 way diffs for our cars?...
