- video , stock bottom end and 200 shot 10.26..looses roof
- Is this a good N20 kit?
- Spray advisors in here
- NA Tune + Nitrous......possible?
- Cmotorsports TS-221XL Question
- directport kit
- Need some help with TPI NX system hook up?
- 175+ shot or 10+ psi boost on Pink rods
- Spark plug problems...
- 12v source?
- 100 shot...can't feel any dif
- Opinions Needed From All N2o Users!
- Nitrous Jetting?
- Spark Plug ?'s
- I think I broke something? :(
- Autolie 605s or 103 or 104????
- Where is Harlan?
- Braided Line
- whats it like?
- 20% Off Everything!!!!
- got questions
- Car dies after using N2O??!! Help?
- can SRP "heavy duty" nitrous/blower/turbo pistons(-16cc) handle a 200+shot?
- anyone have the dyno tune kit?
- Best kit for an LT1
- Nitrous controller
- wat do yall think
- Ruptured AN line???
- Keith Black HYP.pistons and spray...
- Remote Opener Question
- 100-150 shot with 847 and ported heads?
- bottle temperature...
- How do you know your bottle is EMPTY?
- LT1 Nitrous Help Needed! Understanding Nitrous
- 50 shot with NGK TR55 Plat plugs
- how often do you guys check your plugs?
- Jet Sized
- is it true that n20 will mess up your motor
- purge output considerations...
- How much nitrous w/383 can i run
- Questions on ls1 cam and nitrous
- nitrous kit on basically stock LT1
- nitrous spark plugs
- 200HP NX= 10.17@133.6mph!
- the Dyno tune kit
- Built Internals
- Which is better- Dual Stage or Single Stage w/ Progressive Controller?
- i got my nitrous kit today..need some info:)
- N20 ?
- TB Plate or MAF Plate
- Cold Fusion Direct Port Kits?
- ZEX kit
- Safe to mount the solenoids on the intake manifold?
- MSD multi step retard
- Which Nitrous kit
- the button
- Fuel Pressure??????
- Cooling effect on direct port?
- nos brand instructions
- Do I need a fuel cell?
- Drilled hole in LT1 intake for NX kit ????'s
- Jet Sizes
- Realistic dyno numbers
- Timing with spray
- plumbing your own fogger?
- N2O...what else?
- what size shot if any to use
- building a 355, prep for n20
- i need yalls opinions, where did i go wrong?
- A4 durability on N20
- Someone give me some opinons on this N20 setup.
- what if you do both?
- installing autometer phantom n20 guage?
- Anyone know where I can find this part?
- What misc parts will i need to get the Malory 685 ignition box installed?
- What do I need??
- small dry shot on a modded lt1
- How safe would it be to spray my car?
- Ok to switch jets back and forth?
- Best match with the 6-AL
- Mad Z tuning plus 100 shot
- MSD 3 step retard? Need help.
- where to hide the bottle.....?
- "T" fitting or something else?
- Electric WOT switch
- dry shoot: bigger injestors+better fuel pump and what else???
- What fuel pump to run with the bottle?
- NOS fogger nozzle fitting size?
- whats the most i can spray ?
- Nos Set Up On An Lt1
- Window switch options for LT1
- Main feed line pics
- before or after?
- Who sells variety jet packs?
- Progressive Controller Help...
- lil nos queston
- Ngk Tr6
- help fast please!!!
- copper plugs?
- Head Gaskets
- Need Help...Nitrous Checklist
- nitrous motor with new exhuast, giving me problems
- N20 Questions
- Bad day at the dyno....
- dry kit to wet kit conversion....
- Spun Rod Bearing!! Now I Have A choice, Crate Motor
- Stand alone fuel system.
- Running FP guage and Nitrous.
- picked up a direct port fogger intake. ?s
- NOS Fogger jetting question...
- What do you need for a 150 wet shot????
- NX Wet Kit questions
- nos 5176
- Dry advantage over Wet advantage on install
- Installing the MSD 8982
- Tech Tip: Heaters (yes or no)
- 150 +?
- First venture into N20 and LT1's
- Fill Cost
- You guy running BIG shots of dope>>>
- Kind of interested in n2o lately.
- 10% off sale @ Harris Speed Works
- What is the weak link in my bottom end setup?
- Zex rapid Fire Purge Kit
- is this setup safe/worthwhile?
- nitrous quits at half track
- Spraying under 3000Rpm???
- 5176 dry kit with boost question...
- Juice ?
- what throttle spacer for a plate sys
- Autolite Plug (3 ranges colder)
- Biggest Shot on Powershot solenoids?
- Need some N2O basics
- Diagram for NOS bottle warmer
- Nitrous parts for sale...
- New Best with the help of NX 11.68@116
- Nitrous users...
- Safe to Run NOS on Stock LT1
- Octane Differential Factor
- What upgrades to use n20 safely?
- NX GENX II kit and accessories...
- nozzle on top?
- Show off your setup!!
- What plug to run with my setup + 100 shot NOS?
- Dry Ls1 shot
- Today's Dyno Numbers
- Peace of mind for parents and friends.
- Can I break into the 11's w/ 100 shot?
- n20 tune
- Anyone usind Mallory Window switch?
- nitrous ignition ???
- Electronic WOT switch
- Checking solenoids
- Fuel Puddle-ing Something to Think About
- Fuel Substitue?
- New dyno numbers and track times on the gas
- Zex systems Question? and Opinions?
- Fpss differences
- 150 Shot
- Shark Nozzel ???
- tr-6 Plug gap?
- LT1: Nozzle placed in Elbow in IAT provision?
- LT1 Direct Port Nozzle Pics?
- Nitrous Kit For Your Rc Car.
- Wet Kit minus Fuel
- Two-stage N2O
- xe230/236 with n20?
- How much timing retard with 13:1 and 110 oct.
- Nitrous Solenoid Expoled View.
- Over 300 shot
- Is there such a thing as progressive retard?
- NX 175HP= 10.23@132mph!
- ok how should i do this??
- Running 11's N/A & 10's N20 (Smog Legal/Kinda)
- Nitrous Cam?
- opinions on nitrous works kit
- LS1 full NX sys for sale
- Nitrous Express MAF ends
- Is this a good control for nitrous retard?
- need help with 396 NO2
- Few questions i want to double check before installing my N20!!
- Dicussion: Velocity of Purge
- What setup for a 300-350 shot?
- Im so confused about N20!!!
- How will my A4 handle a shot?
- Can I Go 200?
- Tech Tip: Fpss
- Want to purge but don't want to use
- Is purging a necessity?
- where to T my fuel line?
- nitrous with a goodwrench 350?
- LT1 plate for NO2?!?!
- "hidden" nitrous nozzle install pics?
- Best Nitrous system for my car?
- Nitrous in '87 TPI formula
- 125 dry shot for LT1
- is this a good motor for n20?
- nx maf kit ?
- 100 Octane fuel Shelf Life?
- nitrous timing question
- Leaking NX solonoid
- Puzzling question???
- purge lines?
- Spray during converter slip or lock-up?
- Balloon'd torque converter
- Tech Tip: BLow off Fitting
- Called NOS today
- What size fuel line ??
- nx bottle heater wiring
- bottle brackets
- sacarficing power
- Can you spray 200HP on the NX shark nozzle?
- window switch ??
- I Dont know a lick about Nos Help me!!!
- running nitrous line?
- nitrous bottle brackets
- NX Spray
- lil question
- Nitrous Systems Review!!!
- no2 question with an engine rebuild (lt1)
- Solenoid Wiring question
- Which DP kit, NX 80010 or 90006?
- dyno tune nitrous????
- Tech Tips
- Wiring Diagram Look Good??
- Which filter for NX 20920?
- Not your typical Multiple-Bottle Setup questions....
- NX kit 20920-10
- Nitrous On A 93 ????
- Jetting Questions
- Basic N20 questions ...
- Dry kit experts out there?
- NX universal kit
- 5176 jet question
- ARP Professional Series head bolts vs. studs?
- Spraying a 2 Bolt LT1 Block
- NOS 5176 relay question (Injuneer)
- How to disassemble an NX solonoid???
- What The Heck Is This Stuff?
- solid roller LT4 383, what type of N2O setup for a big shot...
- Accel 500+ ignition
- upgrading from single to dual stage
- Would it hurt to...
- NOS 5176 tips/trick/pics
- Looking for a specific wiring diagram
- LT-1 Microswitch
- Is this the right pin to wire the MSD window switch
- Needs opinions on Cold Fusion Nitrous please.
- If I went spray...
- How long will my auto tranny last with a 100 to 125 shot?
