View Full Version : N2O Tech
- Can someone explain some things?
- pics of dedicated nitrous fuel system?
- wanna add N2O- need some advice
- have some "basic" questions about n2o......
- Anybody else here insulate their N2O/Fuel lines...
- SET GAP ON TR6 FOR 150 SHOT
- anybody use the NOS sneaky pete bottle or a 2.5 or 5lb bottle?
- Ran N2O for the first time yesterday
- best place for WOT sw for compucar kit?
- n2o plate?
- Is this gona go boom??
- Which ignition should I get for N20?
- Fuel Problems....HELP!!
- N.O.S. vs. NX
- Funny chopper sound after 75hp hit? any ideas?
- Buildup for the NOSzle kit... Some questions inside......
- nitrous...illegal?
- N20 guys, need some general advice
- Alright, I'm taking the plunge. What do I need?
- Anyone know the trhead size of a shark nozzle?
- Considering Nitrous..........a few questions.
- What needs to be changed to run a 200 shot on a Nitrous Xpress LT1 Kit?
- Will I be able to run a 150 shot on a heads and cam LT1 on pump gas? I did before.
- What rpm to set my window switch?
- new to nitrous
- Anyone with a nx remote bottle opener inside plesase. Need help
- Anyone spraying in 1st after 3k rpm?
- Mounting brackets for Bottle in wheel well
- N20 solenoid stuck open on me
- Need help plumbing a wet system please
- Who with an A4 is running nitrous w/o a Window Swith????
- plugs and gap
- WTB: NOS 5177 ls1 kit w/ 10lb polished bottle
- Thus nechanic told me to remove my rev limiter if im useing nitrous....
- want to learn more about n20
- I just got back from the local dyno
- Final line routing decison
- help: computer tuner for NOS engine
- wot switch?
- Any downside to N2O?
- What do you guys think of the new NOSzle?
- 5177 NOS LS1 kit for sale
- Accel plugs any good with n2o
- Opinions on N.O.S. Noszle Kits
- First time with NOS will it work with these mods??
- nozzle sizes for the ls1
- 3.8L Vacuum lines
- Testing the System
- Nitrous plate and aftermarket throttlebody
- 12.5:1 cr and n2o
- nozzles size?
- First time at the track with the squeeze, BAD news-GOOD news...
- Feels like car lost power with NGK TR6's
- a couple of nitrous install questions
- please look need help with Nx kit
- nx direct port shark nos kit
- Mechanical Pressure gauge
- My N2O Story, need troubleshooting
- TB Plate or Nozzle?
- AFR at WOT on the spray
- will a 103,000 mile engine hold a 100 shot of N2O
- Autolite 104's installed - now it's surging badly!
- best N2O gear
- This or That?
- FS: NITROUS EXPRESS KIT ON EBAY 20920
- What jets to run?
- Nos Bottle Life?
- Electrical Question for a Dry Kit - need advice!
- NOS 58mm Throttle Body - Good or bad?
- What parts do I need to turn a NOS dry 5176kit to Wet kit using NOS Fooger Nozzle?
- Bottle heater question
- what pressure to set fpss
- Venom Nitrous kit.
- F.A.S.T ECU and NOS, need tuning help...Highly Technical!!!!
- My purge pic..not the same person as last week.
- NX Digital Contoller
- NX line routing??
- Need instructions on how to wire in MSD retard box...
- Small Shot (35-50 hp) Questions...
- Spraying thru shifts?
- How Big Of A Hit Are You Using Through A LT1 Plate System?
- Help, owners of 5176 LT-1 dry kit
- Cant get N20 filter back together
- New to NOS
- Fuel preasure problems?
- what should i gap my ngk tr6 plugs at?????
- part # for colder plug
- What size jets for what horsepower levels?
- Which NX system is the "wet" one?....
- Zex??
- is this uncommon
- Need TNT NOS Kit - HELP
- Good or Bad? Spraying dry kit through the MAF
- fpss adjusting ?'s
- n2o cutting on and off........
- Can someone tell me what size the 75 shot jet is?
- clutch can't hold 100 shot
- n2o and 10.5:1 ?
- Stall and N20
- NOS improvement
- Leaving the bottle open
- Propane?
- is there anywhere else to mount a bottle in a 4th gen?
- How much should a zex kit installed run?
- Teflon tape
- NOS setup, what do you pros think???
- ? About false knock when juice hits
- what will a 75-100 shot do for a 14.sec car..and also a 5.0 stang?
- New to Nitrous, help me out, please.
- Separate fuel cell w/an inline fuel pump?
- DRY TO WET NOS'ed LS1
- nitrous switches(where to put them) Post Pics
- Pictures of TNT instalation
- NOS LS1 kit on a LT1?
- Descreened/Ported MAF meter , Would you spray a dry shot through it?
- What is a good price for nitrous express 16ft 4an line? please help asap
- Blower+NOS+FAST ECU.....need a starting point for the NOS
- Anyone use Silverstone Plugs?
- Help for a Friend
- What jet to use for a goal
- Can i run a mustang kit on my lt1?
- What fuel pressure should I run for 125 shot?
- copucar plate pills?
- lt4 km and nitrous
- Compucar ??
- Need Jet sizes for 100HP wet kit for an LT1
- What point needed for forged internals, and ? bout new ZEX kit.
- How long will a 10 pound bottle last?
- MSD6AL and window switch
- Problems with 5177..... please help!
- Nitrous Works Universal PowerWing kit
- Anyone running a CC305 cam and N2o?
- Which in-tank fuel pump?
- Anyone else have a lot of air blow out of the purge before you see nitrous?
- How does it feel?
- TNT bottle quality, TB plate fitment
- WTB: T/B Plate
- Which nitrous kit?
- finally, cheap, legal blow down tube
- n2o and compression ratios NEED HELP NOW
- Nos #5171 kit adapted for LT1
- 383 + Xe 236/242 cam + dry kit... good ?
- which is the smarter way to go before i get nitrous?
- Anyobdy use the new NOS 58TB with a drykit?
- Ran nitrous again today, but now car misfires
- help a new guy out with nitrous
- Anyone spraying with xe 224/230 cam?
- can u really use nitrous on the street?????
- NX wet kit....
- pulsating N2O & fuel noids
- Retard timming? Best way?
- Fuel pressure problems???
- need help new to nitrous
- Made a new switch plate :)
- Is the NX 20920 "Stage I" Kit good for an LT1?....
- Nitrous and Hypertech Chip
- Federal Mogul Power Forge Pistons any good??
- can ya remove the blowdown tube fitting....
- what size jets?
- Blow down tubes??
- N20 installed !! Wow..what a kick! Have a question...
- Building new LT1. What should I do for a 75-100 shot?
- Quick question about spark timing and N2O.
- problems with My NX, please read
- Edelbrock nitrous kit - blow down tube installation problems
- N20+Platinum plugs= ???
- Zex, and MSD window switch?
- Explanation needed!!!
- Stock elbow has a silencer - will this affect dry shot?
- nos dry kit
- My new purge pics:)
- Forged Pistons for a dry kit?
- Attn. S_Willis inside.....
- TNT Kit Jet Sizes?
- Who sells the NX kit for the cheapest?
- Do you have to relocate the air temp. sensor if....
- What sould I have done before nitrous install?
- ASR and Nitrous, what happens if???
- Few more N20 questions...
- used NOS dry kit???
- 150hp NX what fuel jets are you guys running?
- Why not spray below 3000?
- Compucar Dry Nitrous in a bag - good for beginners?
- What is the best nitrous kit for LT1?
- Need dry-kit recommendation...
- How much nitrous to beat an '03 Cobra? :)
- How hard is NOS on a tranny?
- did I wire it wrong????
- Is an aftermarket fule pump necassary w/nitrous?
- Question about fuel with dry kits???
- Anyone have a ecm pinout for a 98 fcar?
- jet size for 100 dry shot ls1
- What else do I need???
- Whats the most nitrous youve sprayed through a single dry nozzle?
- Help!!! Anyone with a Compucar plate system!!!
- where to mount solenoids
- Purge system hose size...
- Do fuel pressure safety switches break alot?
- Is the metal part in front of the LT1 MAF ok for an NX nozzle?
- Nitrous is Pulsing from 2nd gear on. What are some causes?
- Do you have your bottle mounted in the spare tire well?
- Getting NX Wet kit. What else do I need to be 100% safe?
- Do I HAVE to go colder plugs with nitrous?
- Programing and spray
- Do any of you have your timing retarded through the computer itself?
- window switch wiring? (did a search)
- angle of the bottle.......
- NOS on Stock
- 100 shot on a stock motor?
- Mounting a 10# bottle between the rear seats.
- Can I use blower programing for spray>
- NOS Remote Bottle Opener Switch Wiring
- Dual Stage NOS, How do I...
- NOS "Noszle" kits ???
- 97+ Dash Switch Panel
- 99 gt nos system wet for sale will it work on my 95 lt1
- What's the lowest rpm you can spray...
- Who dosent run a nitrous filter? How much better is the NX white filter?
- Someone set the record straight
- N.O.S. Jets sizes for 75, 100, 125
- N2O activation ?
- where to mount msd?
- Retard/Igntion Controll Box for LS1
- Need Help With Trivia Question
- Timing w/ LT4 KM & Digital 6 Box?
- NOS question - do you recommend?
- N02 Bottle Overheating Question??
- gauge mounting?
- best dry nozzle brand/placement for LT1?
- WHAT PLUGS ??
- RPM switch install question.
- Can I run TR6 without Nitrous
- running rich on 150 shot, what size jet now?
- Routing of main N2O line...
- Fogger Placement
- where to set window sw. & shift lite rpm's
- help i have some questions please
- NX installation ?
- NX wet kit jet sizes for 200 shot?
- NOS 5177 vs. 5176 what's the difference?
- Dry 50hp shot on on ls1....?
- NOS Fuel Pressure Safety Switch Install?
- Best way with nitrous?
- Blower and nitrous
- Jet sizes needed for LT 1
- Verticle vs Horizontal bottle mounting
- water injection for nitrous?
- Yet another thing to worry about!!!!!!!!
- Mounting Of Bottle In Cockpit - Need Your Install Pics And Ideas ----->
