View Full Version : N2O Tech
- what gear?
- M6 Or Stout 4l60E
- NXL "NEW" Direct Port System.....ISSUES????
- safe to run this combo?
- 100 shot
- tr6 plug questions
- some N2O questions
- wet or dry kit in third gen?
- Doing rebuild have n20 questions
- what other brands are compatable with compucar
- nitrous power down?
- mallory window switch ??
- spec me a cam....
- Solenoid wires get HOT - HOT!!
- throttle body with nitrous
- How to build up engine for high N20 shots
- Generic ebay kits?
- N2O : driveline limits
- Need some info on NX MAF system?
- SUMMIT Tech tells me only 75 shot max
- Are LTI/LSI/mustang kits comparable?
- NEED HELP: NX Kit
- How to retard timing
- n2o jet tuning questions...
- TNT Dyno Results
- rails for direct port
- I shot the gas, broke, now i got to pull the heads. Tell me what i may be dealin with
- anyone ever used this system?
- MSD Window Switch?
- What Autolight Plugs are best for nitrous use?
- Photos of Direct Port installed under the intake
- NOS wet kit fuel questions
- What is my motor's nitrous LIMIT???
- MSD Pills Less than 3000RPM
- Running 1.6 RRs(with stock heads/cam) and nitrous. Is it worth it???
- solid roller on a 300 shot questions
- can my clutch take it
- Solenoid setup questions
- with the MSD 6AL box would i still need a window switch to control the nitrous?
- How many ways can you inject nitrous?
- Thinking about nitrous
- How do you figure out what shot your spraying at a certain bottle temp?
- Swapping Blown setup for N2O
- is the nx kit a wet or dry kit?
- Hooking up NX kit
- 100 shot pills are??????
- wet or dry
- Nitrous guage adapter
- what gears for this setup?
- Evaluate dyno numbers on a 100 shot plz...
- Can I spray a 200 shot with this setup?
- Ls1 Nos Kit To Fit Lt1
- Nitrous/fuel line help
- NOS question
- fp regulator and nitrous?
- fuel pump question
- N2O regrets
- H/C + TNT 75 shot. Will i be safe?
- Help me pick a N20 gear for my ford 9"
- Where did you mount your bottle
- Tapping fuel rails for fuel connections
- Spark Plugs and Nitrous
- will the 4l60e holdup to the task
- N2O on a 6 speed
- Anyone running a CC306 cam and a big shot?
- A/F To Tune for with Nitrous?
- SVO injectors with nitrous....
- Anyone w/DP TNT
- help w/ mallory window switch
- Best way to retard timing
- Dedicated N20 fuel systems???
- Differences in fogger systems
- LT1 NOS proshot fogger installation guides?
- whats the max hp shot through a NX shark nozzle
- Looking for ways to shave a tenth off my current times
- N20 Cam??
- Direct port for
- Anyone has a NOS wet kit for LS1
- MSD digital window switch
- LT1 Ignition w/spray
- Mounting NOS bottle
- fuel pressure safety switch
- Solve my catalytic converter mystery...
- Safe shot of N20 on an LT1
- which plugs to use?
- Quick ? for those w/ fp gauge
- Nitrous install pictures
- how much spray
- Bottle Blanket
- dry kit for lt1, any advice on what jets to use?im trying to get a 75 shot
- great price/previously juiced
- Bottle pressure guage
- newbie needs advice on N2O ?'s
- MSD Retard Box work with Accel 300+
- Having a time determining which NX kit is for me...
- blow-down tube for street use
- Direct Port nitrous questions??
- Opinions on Tnt F2 kit.
- Cam to use with nitrous??
- Impala Head Gaskets For N20?
- labels
- NE1 using a 20lb bottle
- Homebrew 75hp Dry shot?
- progressive easier on engine parts?
- nos suggestions on 99ws6
- Gears for an automatic and spray?
- I have alot to learn by spring, who wants to help me out?
- Question hooking up the Bottle Heater
- What can I safely spray with a wetkit .
- is a Bottle blanket worth while??
- What all comes in the NOS 5177 kit?
- Need some N2o help
- keeping bottle temperture up?
- Hypereutectic Pistons not so bad?
- nitrous/fuel jet size???
- Set up for NA or Spray..or compromise.
- 50 shot on stock lt1?
- 50 shot kit
- anyone have a writeup on installing a purge kit?
- I need a diagram or schematic for wiring bottle heater...
- question about placement of gauge/filter
- NOS Systems Question
- All Hard core Nitrous guys inside
- how big of shot?need advice
- bottle warmer necessary?
- NOS 58MM TB - I have an idea
- post your nos pass vids
- Need help with Tps Switch
- TNT Kit on 97 SS
- What the REAL Difference Between Brands?
- Bottle pressure....
- Nitrous IMO is Safe
- Anybody running large cam with 100 shot
- Who sprays with their exhaust un-capped.....
- what kit on this car
- Plugs melted to heads.....
- do headers make a difference with nos
- Spraying through shifts
- Nitrous UH-OH
- For you all that think forged pistons are unbreakable...inside
- Dry N2O jet size
- Wiring Questions using the NX Maximizer
- Aftermarket Micro switch
- high compression or low compression for n20
- hypertech programming and spray good or bad?
- How much of a difference...
- Fuel System w/ Wet setup question
- Anyone running Large Amounts of Nitrous???
- FS: MSD8982 used for a week
- question about cams
- MSD Start/Retard Control
- first time spray
- How much Juice?
- What jets for 100 shot?
- What is a good nitrous set up for a LT1??
- 377ci LT1: dumb idea? or durable monster :)
- any1 have zex nos? is it safe?
- Install price
- Teach me about N20
- NXL kit for sale
- nitrous 100 shot-not overly impressed
- nitrous line gave out!!!
- Ls1 Kit 5177
- 10 PSI Tuneup?
- wet or dry
- What Nitrous Kit for my car?
- Are carb plates created equal?
- Dry kit users... Nozzle mounting question inside....
- Accel Timing Computer...
- LS1 Wet System Nitrous Jet Sizing
- Whats my shot?
- Window Switch?
- Useful life of N20 solenoids?
- is 4an line enough for this?
- Installing used 5176 N20 kit on LS1
- NOS Progressive Controller question
- N2O / FUEL line hose
- Nitrous HP Camshaft
- Installing N20
- Compression ratio and nitrous
- Going to track for the first time with N20, couple of ?'s...
- How much timing to pull while spraying??
- NOs brand Plate system for a LT1??
- visual differnce between a wet and dry kit??
- Ram Air + N20?????
- 175-200 shot on stock bottom end?
- Nitrous Bag kit
- 175 and or a 200 shot sizes
- Braided line sizes
- Has anyone converted their NX single to a dual?
- NOS wet brand kit made to fit 98 Z28
- racetronix fuel system
- Running lean on a 50 & 75shot. NX
- rpm window switch/W.O.t switch
- NX TPS WOT switch issues....
- anyone with experience running the ZEX WET KIT?
- nx not working relayt question
- Mallory ignition
- nos opener, what kind of switch
- Finally made a pass on the spray
- Keith Black Hypereutectic pistons and Nitrous
- Looking for a kit. opinions needed
- NX Gemini Quad
- Medical nitrous
- Nos
- Knock problem...HELP!
- Mixing nitrous components
- Nitrous not "hitting," where to start looking
- 125 shot of nitrous, 10LB bottle - how many runs?
- Paging 'Mike Comp T/A #57' /NOS Dry kit Q
- nos bottle heater
- Total Cost
- wet or dry nos
- NOS NOSzle EFI direct port kit....possible GP in the GP forum, let get some buyers.
- Noticed no discussion on what kits are prefered?? i wanna know!
- TNT F1 solenoid bracket?
- fuel pump
- Surging With Lt1 Dry Kit
- how does nos work?
- The New Car Craft, 900 RWHP
- how much can i spray with this setup?
- Nitrous Fuel System Questions......
- how much n2o on stock lt1
- Nitrous and the F.A.S.T. pcm
- NItrous fool
- compression ratio with n20
- Track legal to run nitrous line through interior?
- New to the juice Need a WOT switch
- Track Results with 100 shot
- fuel pressure safety switch question
- need some fogger tuning advice...
- Just got my Fogger installed...Gonna spray the Life at it what will I drop?
- question about e.t
- nitrous works lt-1 kit
- N20 + race gas vs timing??
- Nitrous and Miles
- ZEX #82018 LT1 Dry Kit $441.96, + postage from JC Whitney!!
- Plugs and gaps on a 300 + setup
- plugs and nitrous question?
- NOS Jet Size : Horsepower Ratings for Wet LT1 System?
- Dyno HP curve on a nitrous engine
- How much psi can a fuel solenoid take?
- Pressure Transducer?
- Nitrous Pressure Gauge Question
- Hows this for a n20 cam
- Diy Lt1 Wet Kit
- Track Results with 150 Shot
- Spark advance and Knock...
- Anybody want to estimate how much lower my ET can go?
- Compression Ratio and N20
