View Full Version : V6 Tech
- My 1997 Camaro V6 3.8
- car sputters at highway speeds
- change oil soon light
- Pulled my motor
- Mods Onto 3800 V6.
- 3.4 leaking antifreeze out the exhaust
- Hidden rpo sticker
- Need some brains for my v6 3.4's issues...
- from a v6 to a v8....
- Compare and contrast. HELP PLEASE
- what trans to use on 96 v6 camaro
- p1406 and p0102 error codes
- 3.1 Overheating
- Schrader valve
- Tapping lifters....blown headgasket??
- SES and stumble
- Valve Covers
- dtc codes
- what would cause this
- need help 3.4 will not say running
- 97 camaro Headlights? WTF?
- Alarm trouble...Help
- AC probs :(
- take a guess
- stupid question, but it's for a jeep
- bought car with siezed 3.4, which route to go?
- 3.8 firing order help
- Fan problem
- fog lamps?
- Car is going nuts...
- V6 Engine Diagnostic Trouble Codes Lists.
- Lifter swap!
- Break Light/Signal Electrical Problems
- rack and pinion question
- broken egr bolt
- Compressor
- Overheating?
- Do 98+ have headgasket problems?
- Oil pressure question?
- '97 3.8 misfire problem - help
- transmission problems
- Alternator swap difficulty?
- How can you tell it's a blown h/gasket?
- oil pressure problem
- In need of sum major info.
- Someone knows
- Weep hole location on 3.4L V6 waterpump
- Multiple Misfire?
- evac sys wnt pass smog
- tranny flush...
- advice needed
- sad sad sad
- 02 sensor
- trouble code camshaft bank 1 sensor
- Throttle problem?
- LIM Gasket
- Throttlebody Spacer
- once again
- Can someone help me diagnose this code?
- EGR valve
- Carb'd Small Block
- New member saying what up
- 3800 series II dependability
- car missing please help cant find the problem
- SOrry to all the people i offended
- Smoking need help new here!
- lol step up and get a V8 some real power!!!!
- camaro 2000 problem code p0300
- Is a 1995 3.4l Speed Density ?
- Auto Trans?????
- P0336
- !cat questions
- not much knowedge of engines.....
- tranny ???
- Beehive springs?!
- chrome intake tube
- TT 3800 F-body
- V6 Tubos
- Water in engine?
- Detailed instructions for bleeding 95 camaro clutch!
- Hypertech Power Programmer
- Where to get uncommon parts??
- camaro rs
- v6 power solution
- 55 more hp?
- Rear End swap troubles....HELP
- Summit Racing
- maf and O2 sensors. issues
- V6 Turbo question?
- 3.8 V-6 engine pics
- tranny mount
- auto -> 6 speed
- 1997 v6 Camaro 5-speed
- Magnaflow catback review
- 4-6 hours for 3.4L head gaskets, no way!
- valve covers
- the owners manual
- twin screw supercharger
- putting a 5.3 vortec in my 00 camaro
- intake 3.8
- Oil spout leakage?
- Interior Fuel Odor!!
- rocker arms
- Blown Headgasket. New Engine? Which One?
- poping while turning?
- Need a new transmission
- Oil Pressure gauge quit working
- Looking for a camaro
- Looking for info on turbocharging a 3.8L series II
- the beatst is back..... and better then ever
- security light on
- Anyone ever gone from a 3.4 to a 3.8?
- Intake question
- Blown HG, cracked head/block???
- coolant temperature sending unit
- Engine misfire/trans stutter/o2 sensor problem?!?!?
- 98 3.8 Stalling problem
- pushing limits on mileage
- "Security" light? what for?
- grommet
- CIA--SLP vs. Whisper lid??
- Help, need help with redline
- The best oil
- what is normal oil pressure for 3800 v6
- check engine light
- 94 engine swap
- hvac
- help with o2 sims
- Help!!
- fuel related problem
- Valve Cover Gasket Installation?
- Pacesetter Y-pipe rattling
- how do you add a photo to a thread???
- Oil Pressure
- fuel line trouble....HELP PLEASE
- 3.4L engine rattles? help
- 3.4L V6 Misfire at Idle
- Car is Breaking up top
- 4.11 rear?
- V6 heater problem
- anyone out there ever install a big block in a 93-97 camaro
- 95 Camaro 3.4 HELP
- 1
- "check Gauge"
- 1997 3.8 5-speed handling
- LS1 Lid on 3.8 Firebird
- 95 3.4 Won't start
- V6/LS1 Conversion
- ls6 or ls2 engine swap
- MAF part number for 2000 v6
- misfires on cylinder 6
- 3800 series injector size?
- v6 mustang clutch question!!!
- Since I can't post on camarov6.com yet.. trans question
- Pictures of 3800 bellhousing/5sp bellhousing
- High Idle and Wierd Hanging RPM
- Rebuild in the future
- clear headlights
- LT1 Swap
- Strane gas mileage consumption and performance.
- 94 Camaro Fuel Injectors
- Ls1 Swap
- Quiet Muffler/Exhaust Recommendations for a V6?
- Is there a way to reprogram the V6 PCM for 3.73 gears
- V6 rear end and driveshaft question...
- Ignition Control Module
- I need some information please...
- I need your guys opinion?
- catylatic converter
- SEAFOAM cured pinging!!! VIDEO!!
- After Lt1 Swap Did Any One Change The Stearing Colum
- programmer for 96' 3.8
- i know this is off topic but......
- Is this a good deal????
- 1989 V6
- experts help im stumped?
- Starts but dies
- Tuning my 3.8 with my laptop?
- Is the 3.8 v6 governor limited?
- 3.4 exhaust
- Belt tensioner removal '96 3.8?
- check engine light question
- MSD wiring
- How to spend $1000 on a V6 3.4
- how to make v6 3.8 fsater
- My V6 to LT1 swap (PICS!)
- FTV6 Southern Clash: ***event***
- old gas!!
- OH GOD ...HELP ME! Another code
- ecu & ecm
- Cold Air Kit
- 2001 Grand Prix starts hard when hot PLEASE HELP!
- reprogram ECM for gear swap
- 3.8 rattling like a rod knock
- 3.4L OHV parts
- odd noise
- heater problems an radiator gets hot
- Help 98 -2000 Springs- Same Or Different
- Car Running Like Chit
- How would i make my 01 v6 go atleast 170
- does anyone have pics or diagrahams for this
- hard starting 3.8
- Fuel Pump?
- power windows
- Whats the best exhaust
- Need help wiring LT1 '94 dash harness to '96 v6
- Service Engine Soon
- bearings going? 3.8 with 90xxx miles (sound clip)
- guide to removing wing
- Won't Start
- Camaro with Bose System
- Camaro Suspension Help
- I'm new here...Can someone help me out?
- SES Light...
- Please Help ASAP
- Coolant pipe on a 3.4
- heater core
- Belt tensioner out of alignment :(
- question...
- Dtc E504, E545, 7700, 7900 & 8100
- new exhaust pics!
- 2.8 to 3.8 S\C swap
- trans....sux?
- lifters?????
- Guide to Installing rear disk brake conversion
- the pictures out of my magazine (new 2009 camaro) v6 lol
- Starting/transponder Problems?!?!?!?!
- Stock A4 3.4 V6
- See if you guys can figure this one out..
- starting prob
- My 1997 v6 5-speed strip video 1/8 mile
- converter and trans 3.4l
- my 1997 v6 is pretty fast
- k-member
- Will 3rd gen d/s work on 96 RS
- coolant leak at rear of motor
- Need to know what bellhousings will fit a 94 3.4
- Lost to a supercharged grand prix with some stuff done to it
- clutch problem, please help!!
- Anyone have pacesetter headers and a catback exaust??
- Full throttle V6 southern clash
- new clutch
- Remove Black Hood Liner??
- Random Stall Out and Won't Start!! HELP!!
- Bad trac times
- misfire and no code?
- Coil Pack & dielectric grease
- RPM is too high, help
- New Cat, now getting code 420
- camshaft sensor? for 3.1
