View Full Version : V6 Tech
- Oil dipstick question...
- 94 v6 camaro trans
- car just dies after 10 min
- conversion
- Turning a camaro into targa top
- Car did not run for 4 years.
- v6 camaro fans
- v6 wiring harness
- 5 PCM codes w/red. engine power light! Please help!
- will 245/50/16's work on my '96 V6
- My modified M90 in my rear drive Shelby Charger
- Need a set of 3.4 pistons
- ? about rebuilding a 98 3800 V6
- 94 v6 to v8 i know i know search but please help
- 4l60 tranny
- 3.8 rebuildable
- 3800 injector size? 1997
- New synchros for reverse?
- in dire need of help
- Another question..
- 3.4 vs. 3.8
- SGS Switch Wires
- 91 3.1L Starts and dies!
- Some kind of knocking when engine starts?
- 3.4 temp sensor for gauge
- 1997 3.8l v6 camaro misfire
- Can't pull my wires off...
- looking for...
- Anyone ever put dual cooling fans on a 3.4?
- Car just shuts off, won't restart for a while
- Can't get a reading from OBD1 port
- Any help would great again =/
- questios on iacv
- #2 coil missfire!
- Please any help would be great =/
- 93-95 GM 3.4L L-32 Complete Engine Rebuild
- Broken Balancer pulley bolt. PLEASE HELP ADVISE
- 3.8 Swap
- I have a 1989 camro that back fires through the exhaust
- Help! RPMs high all the sudden!
- pulling 3.8 problem
- GEN 1 3.8 vs Gen 2 3.8
- Tranny too low after Poly Mount Install
- Starting and Stalling Problem
- 3.8 M5 versus 3.8 swapped T56
- 1999 Camaro 3800 V6 - # coil packs?
- V8 Tank on V6?
- Clutch issue, please help
- ls1 fans
- 1998 Camaro V6 3800..Need suggestions
- Transmission issues.
- Intake gasket change and now doesn't run right, HELP!
- 98 3.8 engine leaking coolant plz help !!
- Wont Start
- What do I need
- 1994 v6 camaro
- 3800 v6 rod knock
- Gutting my 96
- rough idle and backfires, why? please help
- v6 MOTOR SWAP
- camaro vs civic si
- Engine running rough and rotten egg smell
- Replacing a 3.4
- 94 3.4 vs 97 3.8
- camaro ac bracket
- Removing/reinstalling a 3.4L in a '95
- cammed 3.4 !!
- 2.8 headgasket
- Low Oil Light
- Motor swap ques
- Oil Pressure Trouble
- HELP Firebird will not stay started
- 3.73 gears
- Blown Head Gasket or Leaking Intake?
- P0172
- 2001 V6 Transmission Question
- How can you verify if the cam chain has jumped?
- 1995 3,.4L no-start... Fuel Pressure issue??
- 91 3.1L v6 camaro in need of help!
- swap 94 3.4 v6 camaro with a LT1
- 1993 camaro with a backfire.
- carb lt1
- 1995 camaro no start
- intake porting
- 99 camaro 3.8 rebuild kit
- Misfiring, rough idle, undriveable.
- 95 3.4L Camaro Convertible eats gas!
- V6-LT1 swap question
- Got a ? plz help
- lt1 help
- Dropping engine out of the bottom
- 2.8 Search
- want to step up on my injectors
- v6 swap to ls1
- 6v to lt1 conversion. Changing speedo?
- Check if EGR is getting signal.
- Wiring Harness Replacement
- Looking for advice on 3.4L/3500 hybrid project.
- Question bout 3.4l throttle body
- Which V6 for 1996 RS Camaro?
- car doesnt crank
- 93 Camaro 3.4L won't start
- 94 camaro wont turn over
- back end
- V6 to LT1 V8 conversion..?
- engine swap
- 2.8 v6 bird
- Need help, car starts then dies!
- Noise & hesitation problems
- Chip ?
- 3800 series cam swap
- oil pressure need help plz
- best exhaust suggestions!! need to know!!
- 94 v6 5 speed EASY POWER with 200$
- Fuel Pump options?
- 94 Camaro 3.4 Cool System Prolbems
- Emissions Failure - NOx
- 1994 Camaro will not start???
- November Issue of Camaro Performers 2008
- LS1 Radiator in a 3.8 V6
- Engine replacement
- Heads up to those changing plug wires on 95-99 3.8 V6 F-bodies.....
- 94/95 v6 to v8 swap
- bad engine ground connection!!
- Dash Vents
- engines
- 95 Camaro won't start
- 1995 Camaro 3.4l overheating
- all bad = not good
- Transverse muffler vs universal??
- Fixed starting problem!! Woohoo!!
- need help turboing my 3.8
- 98 Camaro 3.8 P1153 code problems, please help!
- driveshaft....car is broken down right now
- Rad drain 1993 3.4
- 96 rs camaro
- 2000 3.8L V6 wont start
- Anyone ever clean their own fuel injectors?
- Camaro running/starting problems????
- Question about V6 performance
- Camaro keeps dieing
- Loud ticking noise?
- Cars been misbehaving lateley
- P0420 Code that keeps coming back
- 93 Camaro Transmission Issue
- Sputtering issues
- crankshaft pulley removal
- 1996 lt1 Harmonic Balancer help
- Harmonic Balancer help
- '97 3.8 Hard Start
- Tuning for a 1996 V6?
- Fuel pressure 36-37 PSI on 3.4
- Here we go again after 7 months
- low oil pressure problem
- weird electrical problem possibly
- Exhaust Manifold Comparison
- v8 fuel pump in a v6
- A/C Compressor question
- Which slave cylinders are interchangable with 3.4L
- 3.4L Rebuilt/Reman Engine
- 3800 Pictures
- Fix'n friends camaro, lil help?
- starts runs 15 min and dies 1991 3.1
- throttle body
- does anyone have
- The upcoming 200k mile time to tune help
- 3.4 makes a racket through the CAI above 2500 RPM
- Coils keep going bad
- compression
- light throttle surging
- 3800 rebuild
- Ignition Coils
- 99 V6 Code Issue - Cooling Sensor?
- Different fans/radiators?
- hydraulic roller and flat tapped lifters
- Radiator leak?
- car will crankbut wont start
- 3800 motors from what cars will work in 98 bird?
- RPM Stutter on acceleration
- Shock Sensor? Car Alarm?
- 99 3.8 ASR module tripping and engine stalls
- My custom stainless steel setup? Let me know what you think and if it will work.
- tranny removal
- Just got a free Camaro
- accelerator cables?
- oil pressure drops
- Blown tranny from a shifter change?
- Idle problems 2 questions in one.
- code reader problems
- 98 3.8L Performance help
- differential oil
- #11 fuse keeps blowing
- Water pump oops. Help!
- intake plenum / fuel rail removal
- Car died, now wont start.
- Has anyone tried hacking the 94 3.4 PCM?
- Coolant leaking from behind motor...
- For those of you who've done LSX Swaps...
- i know its not a chevy
- the used car saga continues...
- code p0358
- the correct tool
- Alarm disables electrical system?
- problems running compression test
- Oxygen Sensors
- 3800 spark plug help
- Freeze plug spraying coolant ?
- has there been a computer problem with 97's-2000's??
- ticking upon startup, goes away <15 seconds
- fuel filter/spark plug wires
- car wont start.. can someone help.. heading out
- your gauges
- Am I SOL?
- I think I have an exhaust leak... and a ticking injector...
- Help with a 2001 v6 3.8 with a rough idle.
- 3800 + AEM stand alone, anyone else?
- replacing water pump
- complete lt1 6speed swap outta a 97 z28 forsale
- birthday/car not starting
- 96 3800V6 with 120k weird Oil Pressure... Goes to 0 At idle sometimes...
- cheap horsepower
- Is the 3.8L in the Camaro the same as the 3.8L in the Grand Prix?
- 99 3.8 swap to 96 LT1...possible?
- Cam Swap, What do you guys have in your car that works?
- 3.8 bearings
- piston slap? rod? knocking sound please help(video inside)
- free rear lowering springs
- 99 camaro 3.8l blown head gasket
- 2001 LS1 V6 engine to 99-02 Corvette LS1 V8
- pulleys
- Exhaust manifold gaskets reusable on '99 3.8?
- a/c unit
- 91 FIrebird w/3.1 V6 problems
- Somethnig really Wrong HELP PLEASE
- starting problems anyone i mean anyone
- my car has been over heating lately
- 1997 Camaro connundrum
- Looking to buy 99 firebird with rod knock. Have several questions.
- 97 camaro pcm re tuning
- 1993 camaromwith a 3.4 any problems??
- ready to drive it off a cliff
- Oil In The Radiator?
- evap purge valve solenoid
- pos didn't pass smog
- speed chip for 96 3.8 camaro
- *Compression Results*
- rear main seal
- Reprogram computer for a different year trans
- Firebird 3.4L problem! Help!
