View Full Version : V6 Tech
- 3.8L Mods
- trans issue 3.8l
- 94 3.4 T5. Out for the season/ Battery terminal junction
- 1998 v6 car wont start
- P0171 & P0174 codes at the same time!
- 96 RS issues
- 3.8 work in a 3.4 tranny?
- 96 camaro question on engines
- 95 camaro power issue?
- code reader
- Can Some one Please send Me A link for the power dyne supercharger for the 3.8l
- 5 speed Camaro v6 making noises
- timing cover replacement
- Starter question..
- Another 95 camaro that wont start!
- 3.1 Wont Run Without Start Fluid
- Fuel in oil?
- 3400 overheating
- 95-97 CAI on 2000?
- Damn starter removal...
- 3.8 to 3.4 engine swap, newbie.
- Ohio newbie, engine swap
- P0306 code
- 95 3.4 missing lik dropping a cylinder
- car won't start until tomorrow
- 2.8 Doesn't Start
- '02 V6 Camaro tranny issue?
- V6 Camaro 99 TUNE UP software
- I need a better understanding of Performance chips?
- v6 performance questions
- t5 tranny pics please
- Fuel Pump/Relay Issue
- Transmission Bolts
- performance chip
- Throttle position sensor question
- Need some help on my Camaro. Lend a hand?
- Low Oil Pressure! Need Help!!
- Car won't start after replacing clutch
- faild emissions today
- 94 camaro v6 swap????
- v6-lt1 conversion????
- servise engine soon help me
- New Camaro
- 3.8l Engine died
- Dead Water Temp Gauge
- OIl/watery leak
- CPS Problem???
- Where do these sensors go and what and where is this part
- too many problems and i dont know where to start HELP PLZ!!!
- Exhaust Picture but i cant find part number
- How to Tighten the throttle cable
- How to remove Valve cover on passenger side camaro
- will a LS1 fit in a z28 with a blown LT1?
- Spark plug order
- Best to to go to jump start Car
- 3.4 acts like missing under load, not much power
- Black bracket
- Oil Dipstick Issue
- Blown head gasket question
- overheating... i think
- 95 3.4l v6 camaro wont start, cranks over but wont start
- Harmonic Balancer removal?
- bad tps and bad map sensor symtoms
- car idles like it has an aftermarket cam but doesnt. too rich
- any advice On spark plug wires rubbing against Manifold
- LT1 missfire and backfire
- Too good to be true?
- What pin is the diagnostic enable on PCM #16184737?
- Winter storage question
- HELP Car wont stay running
- 95 Camaro SES / issues
- Belt Squeal
- High Output Alternator at Idle problem
- 3.4 to a 327 from 69 impala
- 3.1 v-6 1991 fuel question
- Is the 3.8L V6 in the '98+ a good engine?
- MSD Ignition Coils Or Accel?
- exhaust sytem
- 3.8 wont start
- what motors will fit my 98 camaro
- 97 v6 high idle w/codes
- Clutch Pedal
- 3.8L Emissions problems
- 3.4 spewing white smoke and misfiring
- Reading codes?
- Homemade cai???
- Service engine light NOT blinking with scanner
- 94 3.4L V6 Firebird Starting Problems
- Add a turbo to a stock 95 3.4L
- Oil Rings OR Piston Seal Issue PLEASE HELP "Low Oil" Light
- Question about stock plastic intake manifold
- cheap hp tuners for a 97 v6 camaro on ebay
- Rislone vs. Lukas Oil Stabilizer on the 98 Camaro
- Coolant System Part
- stripped oil drain plug
- odd start issue
- what parts should i fix first??
- odd acceleration
- Is the 3.4 this much of a dog ?
- Is my tensioner shot?
- I hate engimes with electronics!
- I hate cars with electronics!!!
- engine heat issue
- v6 3.8l camaro prefomnce parts
- weird problem:think:
- help with tune up options
- 1998 V6 Camaro Rough Start
- ASR w/o Switch
- problems when car starts cold
- need some help here!
- 95 3.4 V6 Camaro Engine Swap to Gen 1 327.
- car gives problems when starting cold helpp!!!
- resetting obd1
- V6 questions!
- Engine codes, looking for information
- Turbo or supercharger?
- water leaking from timing cover 95 3.4
- v6 injectors
- Questions about test pipe and code throwing...
- Urgently Need Answer about an Engine Swap question.
- 3.8l overheat = water in the oil now back together and running like under heavy load
- Noisy fuel pump?
- Help on a bad miss, V6 experts come in
- 99 camaro v6 3.8 rattling noise when ignition ON, before starting
- electrical problem
- 93 - 97 Service Manual?
- camaro 1994 3.4 auto
- How do I match a keyless remote to my camaro?
- Getting ready to do the ol 3.4 to LT1 Swap
- 3.8l v6
- How big are my stock injectors?
- lt1 swap into a 95 3.8l camaro
- 93-95 swap
- Would low oil cause car to not start
- How can I jump the AC low pressure switch?
- ac problems
- 1994 v6 3.4 camaro problem
- you tube video
- fuel pump and guage not working 97 z28
- mods
- 3.4 to 3.8
- 3.4 v6 wont start when warm...
- Do our Cars have trans coolers?
- What kind of Additives and Treatments do you Use?
- Fuel pump no power 97 camaro 3.8L
- Any hope for '94 camaro?
- Will any engine covers fit on a 3800 Seres II from a camaro?
- need help: 1992 V6 3.1 camaro
- 94 camaro 3.4 v6 problems
- Engine Harness Help.
- 3.4 V6 Tranny Problem 4l60e
- Crazy Squealing noise and possible air leaking problem, HELP!!
- Light Vibration when i accelerate from 0mph to about 30mph
- How to remove crankshaft from 3800 series 2 v6 in 98-02 camaro ?
- Do you think i have a blown gasket?
- 94 LT1 into 98 V6 body
- how much did you pay for your v6?
- 3800 Casting number help please
- 2000 camaro will not start
- draining radiator
- 95 firebird 2nd gear start?
- How hard to fix inner tie rod on 94 v6?
- 2000 v6 slow start
- OBD1 codes
- Painting my berger panel today. Tips?
- I just had a crazy idea.
- horrible idleing problem help
- engine swap
- What is the best muffler for a 1996 camaro v6?
- lt1 swap into a 99 v6
- idleing problem and rattling help!!!!
- RPM won't go above 3 but the feel lower
- EGR tube
- Cold Ait intake Questions for a 94 V6
- Replacing water pump on 3800L
- what to look for on a used v6 bird 96 or 97
- No hp
- Please help!!about 94 v6 Camaro
- Can I shift a auto?
- SLP exhaust from an SS on a 94' 3.4L?
- No Power
- 98 3.8 m5 knocking then not knocking?
- connecting rod
- dies after 10 min.
- coolant leak
- not sure what next?
- catback exhaust question
- What is the difference?
- 3.4L Cai
- Rough running 1998 Camaro
- towing?
- this site sucks
- Starting Issues
- what will I beat in a race?
- 2000 camaro ck engine light on car won't accelerate
- 4th gen v6 swap
- v6 to lt1 swap help
- S.O.S. Engine Won't Start
- p1441 on 1997 V6
- temp gauge
- how do i know where to cut the access door for my fuel pump
- Help!
- A/C issue...
- Exhaust problems
- 1996 Camaro 3.8L V6 Engine Hesitation
- missfire with engine light flashing
- will this dual exhaust fit my 99 v6?
- need help 91 camaro 3.1L misfiring
- pcv air in tube causing high idle help
- Need help on reassembling a 3.4...
- 97 camaro wont start no security light
- 95 Camaro
- 1994 camaro 3.4
- Need help with possible transmission problems.
- 4l60e trans
- need some help on v6 firebird
- biggest possible engine
- Huge brake line problem
- rough shaking and noise when idleing
- What to upgrade on 4th Gen Daily Driver
- 4th Gen V6 swap
- blown head gasket ?
- Trany will not engage?????
- Fuel pump bad 2000 camaro?
- Need a Transmission for 95 3.4
- 3.4L V6 Leaking antifreeze from the back????
- Oil pan gasket-Pull the engine???
- Bad 3800 series II misfire
- 3.4 hard starting when cold (NEED HELP)
- v6 manual to lt1 or 6.2..
- Rattling under 99 camaro
- 98 Camaro v6 clicking noise when starting
- Stop leak
- Help Putting HeadGaskets on 3.4
- Home Made Fuel Injector Cleaning Machine
- Stalling and won't turn on
- 1994 3.4L fuel pump
- 95 camaro 3.4
- burning fuel pumps...help
- vss wire
- horsepower
- need info on 3100 sfi
- 1999 V6, Air conditioning not working, compressor not clicking on
- b-coleman
- new head gasket
- weird problem
- rough idle
- rough idle
- 96 overheating
- Excessive idle problem after radiator hose burst
