- Is it possible to have ram air and cold air induction
- Need help fast with mom's car
- How much is a 2002 Y87 V6 Camaro worth?
- heater/engine temp problem
- help with power
- i need help with a 3.4 help fast
- TB Bypass for 3.4?
- No Power...what Do I Do?
- Option Code Questions
- Starting probs after runnin for awhile
- v6 trembling...need help
- "Security" light won't go off!!!!!
- How do I change the fuel filter
- starting hesitation?
- UPDATE: RK Sport Header Lawsuit
- 2.8L specs
- 3.1 to 3.4
- RAT Stage 2 TB/MAF
- Another metting in CA
- Stock tailpiping for dual duals?
- Will a bigger i-pipe make my exhaust louder?
- Somebody with a V6...Help!!
- HELP!!! Broke a stud on my rear "drum" brakes!!!
- what about this intake setup?
- oil gauge problem
- turbo v-6
- B&m Transpak????
- Installing Power Windows?
- 120mph gauge scan
- Help!!! Just Lost To A Jeep Cherokee
- engine dies
- crazy oil gauge
- GTP supercharger
- v6 free mods
- What will a cam and lifter do for me?
- 95 camaro 3.4 noises
- K&N air filter
- Coil questions
- 3.8L Exhaust setup
- 2.8L muffler
- What type of rearend is in my car?
- Jet Chip
- trannys
- Torque specs for 3.8L V6 water pump?
- Is this a good deal?
- To all 3.8L guys.
- What is the Camaro lug offset 5x????? (nt)
- Cat
- Help Diagnosing Car Troubles Please!
- Comparison of Cat-Back Exhaust Systems
- Cheapest Dual exhaust?
- Catalyic converter
- flywhell, pulleys etc...
- how much hp?
- Front wheels lockup when braking
- fog lights
- IS this an LSD?
- How much power can a stock 3.4 bottem end take?
- Sea Foam!!
- 4l60e slipping out of gear.
- Y-Pipe = Power Loss?
- squealing brakes
- 3.8L Turbo Update
- looking for some parts
- Wierd electrical problems
- 3.73 or 3.42
- posi? LSD?
- What is wrong?
- reverse gear HELP PLEASE
- Shift Cable!?
- What gears come in 02 3.8 Coupe w/ posi??
- hypothetically..
- ABS Inop light??
- MagnaFlow catback exaust for 02 V6???
- Won't let me shift into Park!!!
- Need new computer, have some questions.
- new v-6 f-bod
- Where can I find a TB & Mass air sensor for my 3.8L?
- whine whine whine
- thermostat help....
- Clutch Pedal Makes a Clicking Noise
- What year did the V6's start coming standard w/ AC?
- I went to autozone
- motor will not rev past 3900/4000 rpm's
- 3.1 Plug Wires
- Camaro decals
- Ca Clunk
- SLP CAI vs K&N FIPK
- rough starts
- Well the day has finally arrived!!!
- kumhos
- How fast do you turn your 3.4?
- PLEASE READ!! RK Sport Header Lawsuit
- High pitch squeal ?
- 3.8 into high 13's low 14's??
- 93-95 3.4 V6 specs
- 98+ 3.8 V6 q's
- What do you THINK I could run
- Removing speed limiter
- Bad plugs and wires, now have questions
- Eaton M90/112 Blower project
- TB bypass and 160 stat.
- B&M Shift kit for V6!
- Does anybody know what the word "Camaro" means?
- In my defense.....
- V6 3.4l N20
- Camaro making a squeeking sound
- CamaroV6.com a total disgrace... read within
- 2000 Hpp3
- Larger injectors
- new motor
- a few questions
- How much can be safely sprayed on a v6?
- LS1 NOS kit with lid into a v6?
- P Codes Help!!!!!
- P codes
- 4th gen V6 top speed
- $300 Tranny Mount
- How good are 4th gen V6's?
- Larger throttle body 3.4
- My mom is getting a camaro. PLZ read
- V6 to Z28 buildup
- clutch replacement
- How much should I sell for?
- oil gage problems? 96 v6
- V6 burnout
- My 97 3.8 Camaro
- ls1.com ram air mod???
- pro car parts gauges
- MagnaFlow Exhaust
- This kid is out of his mind right?
- putting a 2001 4l60e trans. in a 1996 v6 firebird
- Help me with gears please!~
- Check out my car
- Cheapest way to make a Y87 muffler look respectable?
- m5 tranny fluid change
- A Few Questions
- Anybody heard of a Luke Clutch
- What exhaust ....98 Firebird v-6???
- Finaly Took a Few Pics of my Car!
- Ses light when I brake?
- What will i run?
- Anyone had there 3.8 start knocking?
- 97 camaro puter
- Low Traction
- intake/ram air question
- Engine transplant
- Rear end weight?
- hey check out my onyx camaro
- How can this work?!
- Just finished modding my six..Dyno results
- Maintenance at 13,000 miles?
- 1999 v6 puter programmer
- Fuel pump
- Posi in '96 3800?
- HELP! Computer keeps resetting!
- Car making a weird sound again
- Proud Trans Am owner
- Backfiring
- Mini Cooper S
- Lean O2?????????
- traction control....
- someone sell me your stock springs!!!
- V6 Rear End/Drivetrain Questions...
- well spring is here...time for the engine swap...ideas
- security doesn't allow me to start my camaro
- Retarded timing with 87 octane
- Turbo 3.8 completed
- Front Crankshaft Seal
- B&M ShiftPlus
- under drive pulley
- Retained Accesory Power Module
- Update On buzzing noise with the Clutch in after car sits
- 3.8l rwhp?
- Anybody Care to Post 1/4 times???
- sputtering
- are our steering knukles the same as the lt1
- Im giving my engine away!! Chicago area
- '97 Rs
- Any of you guys have some springs?
- modding my 6
- weight?
- I think my cam is to big.
- Same as Power pack but only $869.72
- Higher mileage engine ??'s
- DRLs on the '99 Camaro
- 160 degree stat
- V6 to V8 Swap
- Cam for 3.4l SFI-DIS Engine, Need Advice
- Water leaking rear passenger side, please help
- Gas
- Power Pack?
- top 5
- Help me stop this guy from becoming a ricer!
- V6 Questions
- Hooker Catback Exhaust
- convertable top
- Which side is the starter for 3800 engine
- torque converter?
- broken tranny mount
- Transmissions
- where to get a socket for theft lug nut
- wont be....
- New cam video inside
- Exhaust Cut Out Size?
- Removing MAF screen?
- Seafoam question???
- My DRL's are not functioning
- Video: Listen to the CAM in this v6
- Will 99 firebird v6 rims fit a 94 formula?
- Drum to Disk Brake Conversion
- Instrument Cluster Change-over Q's
- Whats better the Edelbrock or Flowmaster cat-back system?
- what is normal oil pressure for our 6s?
- Flashers Problem
- ?Brake Calipers?
- whats a good websites for rearends?
- Aluminum driveshaft
- Attn: Rich97w68
- Full Posi
- lt1 m6 conversion
- cheapest whisper lid
- How much would this cost?
- engine dress
- How Do I SUPERCHARGE?
- Shift kit or Electronic improver?
- How do you change the %!&*# fog light bulb??
- Squeaky Sway Bars
- the ram air sys
- 10% off Loudmouths for the month of April!
- car runs rough, plugs wet with gas,all help appreciated
- Just installed my Dynomax muffler
- Are 96-98 TBs the same?
- Slp Loudmouth?
- Hollowed Out Cat
- ECU Programming for Turbo
- Are they + or - cc's and deck clearance
- Gas Mileage
- Finally got a timeslip
- 3.1L ignition trouble (93 Lumina)
- My Review: 2.75in I-pipe on 3.4L V6
- 2.8 to 3.1 ... 3.4?
- thanx for the jinx
- brake locked up
- can someone run a carfax for me?
- 0-60?
- Exhaust Tips
- the whisper lid intake?????
- Block off for EGR passage
- Ses Help!!
