View Full Version : V6 Tech
- Does Anyone Know Where I Can Find A T-top Kit
- Local Help with Installation
- pistons will hit the heads, right?
- Why won't my car go into first gear?
- 427 camaros
- Lt4 Vs. Ls1
- Please help...stutter problem
- Need pipe sizes ASAP
- help me, odd erratic/consistant idle
- Gauge Needles
- what cc's are my heads?
- 1.52 or 1.6 rollers?
- place to buy stock v6 rear springs?
- B&M ShiftPlus
- T Top Conversion Houston Help!!
- Question on exhaust manifold part? ECG?
- HELP voltage gauge going down
- Taller cam or more cubic inches?
- White gauges....
- Anyone have a tangled seatbelt?
- Wheel Width
- 3.1 bretta vs. camaro 2.8 swap
- Roller lifters for 3.4's
- Camaro DIED!
- Exhaust?
- i need help finding whats wrong
- Stock radio..urgent help
- Cam
- stuck door lock
- exhaust swap
- problem with rpm gauge
- overheated/head gaskets
- problum with speedo
- where can I get 3800 decals?
- msd questions
- 3.4 to 3.8 swap
- 3.4 Valve Cover removal?
- The Camaro in Snow - What's the deal?
- 9.25'' clutch for 3.4L
- semi-hot starting trouble
- Check Gauges
- Bolt pattern ? I need answered
- RPO Codes
- maf screen
- Anyone put TA ground effects on a firebird??
- ?'s about the 3.4
- Buddies 3.8
- Need Lots Of Advice
- brown antifreeze?!?!?!?!?!
- Can I....
- any1 buy 17degree incline ramps from wal-mart...w/in
- ABS INOP...thank you 4 fix camaroz28.com
- Stall converter problem.....
- Z28 or SS exhaust
- 3.8L stumbling
- Brake stands
- update to my previous problem, car wont start
- 3.8 troubles
- RK Sport SS hood question
- rear main seal
- What are some things I can do to my 84 Camaro?
- Camaro Chugin!!!
- v6 to a v8
- fuel filter
- help please...
- Where can the 2.8 plentum,3.4 manifold be inproved.
- anyone have a 3rd gen w/3.4 swap
- Sound clips
- Lowering
- Bolt-Ons
- a/c blows cold mist
- Free V6 and rebuilt trans 'Come get it!!!'
- New owner
- headers cat and pipes
- posi?
- i just got new springs what do i do
- T-top conversions
- Is this worth it
- CAI for a '96
- Fuel pump hiss?
- Direct Port Programming
- manual box gear oil
- How long did your power window motors last?
- Changing tire sizes
- Please help me out
- looking for some winter storage idea's
- big question....
- putting mobile 1 in a V6 worth it?
- What do you use
- What do you use
- 3800 MAF Spacer?
- Is this normal
- tires?
- 120MPH to 150MPH Instrumnent Cluster
- Takeoff Exhaust
- What kind of ignition does my car have?
- Exhaust
- old gas
- hard start problems
- cruise control
- just to make sure
- Does the RS have two exhaust tips?
- bumpsteer?
- just a question...
- OEM Brakes???
- Power
- Anyone?
- cam and rockers?
- ehaust
- payback
- Best Blown 6cyl
- 3.8 stroker kit?
- new alt, new starter, car is POS, please help!
- How fast are the imports?
- goin from 3.4 to 3.8
- exhaust clamps
- flughing coolant system probs
- Dumb Street Racers
- drive shaft maybe
- a/c help
- ignition question
- mass air flow sensor...guys help me out!
- Oil Pressure
- Where do I check Manifold Vacuum on the 3.4???
- 3.4 or 3.8
- taking stuff off the engine
- Paint Code
- Removing a V6 engine.
- exhaust
- What do you think
- 3.4l expectations w/rebuild
- got my best milage EVER
- AC clutch
- Faster & Faster
- Exhaust question
- whats the ride gonna be like?
- Sub Frame Connector Question
- supercharger question
- Question about 18" tire size??
- Heater problem
- Since I haven't posted in awhile, FMIC pics
- v6-v8 swap, do i need a diffrent gas tank?
- Porting the 2.8 heads
- Valve Lash - please help
- Crazy noise from rear diff.
- Car for sale...and cleaning out the garage
- AC Help- quick question
- need more v6ers
- short shifters
- Define: "drifting"
- Broken Engine? Need Help Please
- Should I use used A/C evaporator core?
- installing a new driver seat
- fastest v6
- 3.8L is misfiring (I think that it is not plug/wire related)
- engine swap troubles!
- wantabee
- New Forum
- fuel pressure
- www.eriespeed.com
- 3.8L turbo kit
- Water pump and timing belt?
- The power/intake chips
- When will my 3.4L Die?
- programer for a 98?
- B&M shifter install
- Hello v6 World, whats new?
- top speed?
- Water Pump Install HELP!
- RS owners...
- gain question inside please
- URGENT! Please help!!!
- reprogrammer for a 96
- 2.5" B&B triflo exhaust (v6)
- how much boost can a stock v6 take?
- feul injectors
- what is a tac code?
- tempted to get some bolt on SFC
- gain?'s
- 3.4l Rebuild
- What octane should I use?
- security dash light
- hope this is where to post this.. brake problem
- Magna Flow
- Strut Tower Brace Question
- under the hood blower
- goveners
- Running badly -- rich?
- Uncoated pacesetter headers
- Question about 1989 Camaro RS Fuel or Spark
- 01 Z28 exhaust on a 97 RS?
- Monte Carlo Z34, what to do??
- What is the FAW and RAW weight
- Car light question
- hesitation and pop when cold
- Gee Thanks Rich
- Home made CAI for 3800. Any of you made one?
- Anyone bought or sold a v-6 f-body lately?
- need detailing advice! please help
- turtle wax... safe?
- fuel economy
- y87 package?
- V6 front coil springs and shocks
- Girlfriend's buying '97 V6...grinds in reverse????
- V6 to LS1
- paging Tiago
- V6 Insurance rates...is this bad?
- HELP please
- slp cai noise
- False OR Valid claims?
- Oil Pressure
- polished heads
- What Intake, Headers, Exhaust, etc...?
- Buick 3.8 Supercharger
- rear seat latch problems
- does anyone know?
- Engine Stutters when accelerating
- New Sticky Threads Posted
- Major Power Adders
- Engine Swap Thread. V6 to...?
- Nitrous
- Late night and we are empty
- clutch pedal squeaks
- Just installed LT1 one piece.
- 3.8L to LT1 swap
- 38 lb.hr. injectors to small?
- Locations
- how does a cutout sound on a 3.8?
- engine swap
- STOCK 98-02 1/4 times
- Is there a power wall with 2.8 intakes?
- do not buy from ammperformance.com
- Dimensions of Bolt for Brake Caliper
- tail lights
- replacement automatic shift knob
- Synthetic vs REg Oil
- 91 R/S 3.1 Eletrical problumes
- Is this for real?
- When I ran carfax my car came up as an RS..confused?
- 3.4 water pump different from 2.8,3.1?
- Everyone who has dealt with Tiago, inside please!
- "camaro"
- Radiator fluid leak (help please)
- parts car found...any issues to look for
- Way to check if I have Airbags?
- LS1 Swap in 95 3.4L FireBird... Input??
- more cheap modifications?
- seatbelt guides
- Exhaust question...yes another one
- can i chip my 98 V6?
