- temp sending unit/pcu sender
- 93 Forumla - Rear turn signals dont work
- help
- mod to get my 6 for christmas
- V6 Tranny??
- P-Code help
- 3.8 Tpi???
- 3.1 and 2.8 smog legal headers
- tb bypass
- v6 major problem..wtf?
- ready..set...go?
- What gear came in a '95 V6 5-Speed?
- What size tire OEM?
- Will someone please help me instead of just looking at it!
- Engine build up?
- storing the v6 for winter
- so what will high oil pressure do to a 3.4L?
- ASB Light on DASH
- will 25th anniv. intake , air plenum fit my 95 3.4l
- Stock 97-98 V6 exhaust setups
- Harmonic Balancer Position (3.4L)
- Carfax help needed
- 4.3 Vortec High Idle Problem ??
- Can't even get off my road..
- Can I see some pictures of your firebirds?
- strange problem
- supercharger on 3.8L?
- decals
- Starter Recommendations
- Ack help, car wont start
- will brake cleaner eat o-rings/gaskets?
- Windows....
- Is Synthetic Oil OK in the winter time?
- 3.4 Acting up!
- Changing Oxygen Sensors in a 99 3.8?
- question about slp take-off shocks
- Cruise Control
- Interested in getting a 98-2000 firebird for a 2nd car...
- motors and computers
- Well
- Trans Am Gauges
- 3.4L Stock gap
- Thump!!
- Need Help Fast!! Please!
- multiple misfire
- LT1 cat-back
- what auto tranny will fit my 3.4L???
- third gen vortech
- Cut out questions...did search already
- Lowering spring Questions?!?!
- shocks
- Big Tech?
- rear-end squeeling...any ideas? i think brakes
- Water in tank?
- Think the maro is burning oil...or somthing at least.....
- A fuel injection problem?
- Misfiring at normal speed
- shocks
- 3.8 compression psi?
- Misfire Code But Car Doesnt Run Like A Miss Fire Please Hep
- CHIP for a 3.4l 94
- 3.4 to 3.8.. possible?
- Brake question
- V6 Exhaust Options
- V6 Formula
- Keyless Entry
- I need Alt. Bracket pics! help!
- Broke my 3.4L
- spark plugs
- ***`!NEW V6 Message Board!`***
- First 4th Gen V6 in the 11's!!!
- Tell me what you think (pics)
- 2.8 to 3.1 swap
- port and polish head q's
- Fipk
- Intake QuestIOn
- camaro noob with a few ?'s
- question about plug wires
- Throttle Body for V6 3.8 1996 Camaro
- Why is it...
- Battery volts drop to 8
- pro 5.0 shifter
- Why is my muffler rattling?
- Free Ram air mod for a v6 > can it be done ?
- Has anyone put the blower off a GTP on a 3.8l Firebird?
- 228/228 Lunati question
- Hanging Tranny Valve??
- high idle...
- 97 camaro: wacky gauge behavior!
- V6 tuning
- Loudmouth exhaust
- just a few quick ?'s
- Hit by Deer
- Rear Brake Drums..
- Air Flow
- Looking For T-tops!
- ls1 muffler
- 3.4 overheating!
- Mustang v6 vs. F-bod v6
- What do you think my car is worth???
- "Low Engine Power" light wtf?
- sound clip
- RPM's
- what could be the problem?
- whats my cars Weight>???
- 94 stock LCA part number / 98 Z28
- 96 3.8 for sale!!!! cheap
- Help! Camaro running awful.
- antifreeze
- B&M shifter
- Can I......
- 800-700rpms normal???
- Custom Turbo
- pcv valve
- Bad Water Pump
- Throttle body spacer
- where online to get tires?
- Can I use 3.4 K-member in a 3.8
- I'm Selling my powerdyne supercharger kit for the 3.8L
- Power Steering rack length?
- Idle High
- axles
- 94 camaro t-top conversion COMPLETE PICS
- where is my EVR filter
- 92 bird 3.1 engine stall 5k rpm's
- Car Recalls ? do they apply to none original owners ?
- swap 2.8 for 3.1 help.
- clutch ??
- what cam specs?
- Bad News
- Help!!!!!
- headlights n taillights
- Fog lights
- 93 3.4 Help
- ignition switch
- 96 3.8 engine problem
- Overdrive~
- Just did my first brake job.
- O2 sensors
- Mirror Help
- Sick Torque Converter?
- Enigne overheating?????
- wiper motor help please
- Just hit 75,000 Miles
- 3.4 Series II?
- Switching to synthetic at 100,000+ miles... Worth it?
- a few questions
- Fuel Injection Cleaner
- Question!!!
- flowmaster or magnaflow?
- Supercharger Question
- Msd Ignition Box?
- airbag light
- Odd vibrations....
- top end and low end
- reverse problem, new tranny or can it be repaired?
- Rough running
- where to buy 1le tranny mounts
- big problems with polyurethane tranny mount, HELP!!!!!
- Scanmaster
- Ram Air
- starter?
- tranny in manual 3.4 hops. need help
- z28 cluster, speedo not working???
- coolant Q&A on 96 3.8L
- Car Fax
- bird/camaro
- need a t-5 transmission for a 1995 camaro 3.4
- power consoles
- Does the Fbod 3.4L come with roller lifters?
- Clutch/Trans Problem PLEASE HELP ASAP!!!
- So am I to assume
- changing window motors on my 94 camaro
- car wont start
- Im getting a turbo 3.4 kit-need help on a few questions
- LT1 or LS1?
- Makeing my car faster ?
- Is this bad for my Trans?
- Spare Tire
- z28 rearend conversion
- LUNATI-30000 228 228 cam???
- LT1 fuel pump in '99 V-6
- cam videos?
- almost killed by my floormat
- What parts should i get my 3.4??
- question.....
- 94 camaro
- 5 speed Question
- Can't get into the "other" board!!
- Leak on passenger side
- 3.4 intake cam and headers
- Strange Noise While in Reverse
- 1/8 mile time?
- somewhat good night at the track...
- 3.4 camaro driveshaft
- powerdyne and timing retard on 3.8 HELP
- V-6 PCM Reprogram
- Sister of the 3.8, the 3300 gm engine, keeps dying.
- Does anyone here have a shop manual for a 96-97?
- help! hood wont close with homemade cai
- Burning out
- what exactly is this scam?
- Turn signal question
- Brakes??
- GN Motor swap into V6 third gen Anything !
- Engine might be over heating
- Tranny???
- Looking for Headliner Houston for T-Top Conversion
- Powerslot Rotors
- Resetting PCM & HPP3 programming
- my car wont start
- New best N/A
- Removing Fuel Rail
- Should i switch to synthetic?
- rear hatch
- Helllpppp!!!!!!!!!!!!
- I think my V6 is getting horrible mileage
- Laptop
- Port and Polish Heads
- Taking it to the track tonight.
- Getting Out The Gas
- Running crappy
- need advice
- converting base to "z-28"
- posi rearend
- Horn troubles
- Serpentine belt
- Buyer Beware
- first time oil change.
- What is this&how do I get it off
- Couple of ?'s about the Rear end.
- Killed a Ricer last night with the truck....then he gives me the Hazards????
- Port and Polish?
- Need Help ASAP
- Sludge? Throttle Body?
- Cut-Out's
- manual fan switch 3.4L help
- v-6 suprer charger
- Inline Fuel Pump
- V-6 SUPERCHARGED vs. LT1
- can anyone run a carfax for me...help w/in
- SLP CAI install trouble
- Steering Problems
- debate
- What does a stock 98 firebird with 323 run in the 1/4?
- Automatic tranny to a Manual??
- 10% off select V6 products through 10/5
- GM Part #'s
- Overheating tried a few steps any ideas?
- Engine Vibration at Idle
