PDA
View Full Version : V6 Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18 19 20 21 22 23
  1. ??'s about a V6..
  2. Could my Check Engine Light related to exhaust?
  3. Electrical problems, car alarm related..
  4. Comp Cam for sale 3.8 V6
  5. Magnaflow & Z28 I-pipe
  6. Weird noise
  7. cleaning with b-12
  8. ATF vs. Seafoam
  9. Quieting Loudmouth
  10. Headlight and Fuel Cleaner
  11. Questions about 3.4
  12. 117cfm, unacceptable
  13. no "pull" at high RPMs
  14. Full Tank...of WATER!!!!
  15. IAT sensor on 95 camaro
  16. hypertech?
  17. What do I need for my swap.
  18. 1997 V6 Speedo/Fan Problems
  19. Waterpump
  20. 1990 Firebird....engine cranks, but wont start! HELP!
  21. Looking to buy
  22. Oil Pressure
  23. How much will a cat run me at the dealership??
  24. Best plugs n wires for 95 3.4l?
  25. Lots Of Stuff For Sale!!
  26. 3.4 short Shifter???
  27. belt tensioner
  28. 00 3.8 hesitation/shift problems
  29. what to do with $1000?
  30. Replaced EGR/cleaned tube...still getting SES
  31. how do i set the clock
  32. Trans mount
  33. Bad Acceleration
  34. Which line lock for a 96?
  35. EGR problems
  36. UhOh SES Light
  37. window motor
  38. any takers
  39. vacuum hose routing?
  40. Overheatin
  41. V6 MPI ---> 2bbl/4bbl carburetor??
  42. 99' 3.8 wont start?
  43. rear end swap
  44. 3.4 PCM reprogramming option?
  45. my bird just started to tick!!
  46. best camshaft for 3.8
  47. Is a computer necessary to change spark plugs?
  48. 97 3.8l
  49. V6 - LS1 interchangeable accessories ?
  50. a few basic mods
  51. Just signed on
  52. 3.4l, slightly different application
  53. any ideas on my problem?
  54. Calipers Paintn'
  55. Chips
  56. what rockers for the 3.4
  57. V6 to V8 swap!HELP!
  58. 93 v6 firebird front roters.
  59. Low Oil Pressure after Camswap!! Need Help!!
  60. Brakes / Rotors
  61. Oil Change
  62. will lt1 and ls1 injectors fit in a 3.4??
  63. worn timing set?
  64. firebird is runnin real rough after sprayin!!!
  65. what cam for my 2.8l?
  66. 3800 series help?
  67. firebird 2.8-3.1 maf
  68. People with automatics in here please
  69. 99 Firebird Owners Question
  70. heads/cam
  71. puttin kinda clapping sound
  72. Belt came off going down the road
  73. glasspack
  74. more airflow maybe?
  75. 18 inch rims
  76. Can you increase idle speed?
  77. V6 to V8 Swap?
  78. supercharger times
  79. engine swap
  80. Gears and Nitrous ?'s
  81. Fuel problems?
  82. Anyone have a pic of their RS badges?
  83. Newbie!
  84. Best exhaust for a 3.4????
  85. Weird question, help if you can.
  86. I need tips on timing
  87. Codes 42,33
  88. code p0102 MAF sensor low input
  89. time set
  90. Anyone have a good write up for a take off SLP diff in stall on a rear disc brake car
  91. my sixer for sale!!!!
  92. What the gas milage on a v6
  93. got some times with the firebird!!
  94. Where to buy a tail light assembly?
  95. not an f-body but have a question
  96. New best, 12.1 at 107 w/ 1.5 60 foot!
  97. stock fuel pressure on the 3.4
  98. What the hell is wrong with my car?
  99. Hitting 90K Miles
  100. Aftermarket coils for 3.8L V6?
  101. Wanted: 93-95 Cam/bird 3.4L V6
  102. Please help ASAP!
  103. thrust bearing on my 2.8L
  104. My new (and first F-body)
  105. New front brake pads and rotors are making a mess of my wheels!
  106. Where is the EGR valve?
  107. need headlight help fast
  108. Rough Starts and Falls on its face
  109. SS Exhaust on a V6?
  110. emmissions
  111. What are the symptoms of a bad coil on a 3.8L V6?
  112. Car misfiring?
  113. hypertek power programmer 3
  114. Upgrading V6 - The Most Asked Question In This Forum
  115. begining research on LS6 swap
  116. sad
  117. Chip for 94 Camaro???
  118. How to change a fuel filter?
  119. e brake problems
  120. transformation
  121. HELP!!! For The Love Of GOD!!
  122. Issues w/ Stock Flywheel
  123. Dash lights......
  124. Exhaust Noise
  125. What are the differences between a v6 and a v8 engine?
  126. gas, your git'en screwed
  127. suspension
  128. computer tuning
  129. Computer Code V6
  130. getting a free v6.
  131. What clutch should i get
  132. burnouts!
  133. Confused about a wiper problem!!!
  134. disassemble the steering column
  135. OEM V8 springs and shocks on a V6?
  136. 2 questions!!
  137. just a question
  138. im keeping my V6 and speedautomotive
  139. Injectors
  140. rpm drops & idle...Help please
  141. valve cover gasket
  142. running lights on a 94 camaro
  143. anyone know of a sound clip like this?
  144. >>Water Pump install help?<<
  145. what spark plug gap?
  146. what and were 4 gears
  147. horsepower
  148. urgent need of some car help here...
  149. Gauge modification?
  150. Coolant leak.....
  151. Cluster swap
  152. V6 Times?
  153. American Revoulution.. sorta
  154. can you clean the EGR valve on the 3.8?
  155. How much to get an exhaust put on?
  156. engine swaqp
  157. 3.4 liter oil pan level sensor
  158. Trans jumping..
  159. what gears do i have
  160. So I took my car to a mechanic yesterday...
  161. Rear End Gears Racing/Performance
  162. Strut Tower Braces
  163. idle issues...
  164. heater hose quick connects
  165. catalytic converter
  166. Car wont start !
  167. problems
  168. What's up with an RS?
  169. Manual Tranny Groan...
  170. LS1 Swap
  171. shifter problems
  172. too wide?
  173. Where to look up parts
  174. supercharged 6 cylinder!!!
  175. need new front rotors....suggestions
  176. Drum to disk swap info
  177. Fuel pressure regulator?
  178. longtubes for 95-97 3.8 camaro/firebird
  179. lowering springs
  180. temp problem
  181. Have you noticed?.. (Fuel)
  182. cooling fan problem
  183. Need the firing order and plug pattern for my 96 3.8 rs
  184. Can I use a Jumper Wire to pull code on 96 3.8
  185. Looks like camarov6.com is dead 4 now
  186. New Hurst shifter
  187. 95 Camaro 3.4 vs 3.8
  188. Is replacing a fuel filter easy?
  189. Cut-out or exhaust system?
  190. Where to buy a new radiator????
  191. SLP cold air kit and FTRA owners
  192. dumbest question *ever*
  193. ASAP: fuel pressure regulator install help!
  194. ASAP: fuel pressure regulator install help!
  195. update
  196. high pressure power steering hose?
  197. Speedautomotive
  198. installing catco cat
  199. For Sale : Flowmaster Mufflers
  200. 3.4 valve springs
  201. Are You In The DETROIT area
  202. Fuel tank
  203. Whats this i hear about a loud moth knock off
  204. 89 rs
  205. Answer this q??
  206. Rough Idle, power loss and smell of fuel!
  207. Cruise control woes
  208. Here is the 3.4 SUPERCHARGER KIT
  209. driveshaft carrier assy. blew up!!!
  210. Possible Head or Intake Gasket Replacement
  211. My first dyno on 3/6
  212. Heater blows cool air
  213. 95 camaro 3.8 liter v6
  214. question
  215. thermo
  216. Check out this 6
  217. Rear end
  218. question about TA exhaust
  219. Shift Knob
  220. Windshield Wipers
  221. No power Loud whistle 3.4 Gurus please inquire within
  222. 88 harnes and ECU in an 85.
  223. 98 + WS6 exhaust fit my 3.4?
  224. header question
  225. Throttle Body
  226. sequencer kit for 1993-1996 Camaro
  227. Intake system for 87 2.8 V6
  228. I think I got a problem *Low RPM hesitation and sputtering*
  229. stock gtp vs. stock y87 v6 f-body
  230. Head porting
  231. electric fan
  232. headers
  233. HELP!Stereo too heavy! Car bottoming out!-----
  234. supercharger
  235. Help on blowing fuses
  236. Gas Tank Size
  237. Dynoed the v6 bird :)
  238. sputtering and loss of power
  239. should i get resinated tips??
  240. Turbo'd 3.8 Dyno numbers
  241. no low end
  242. Lookin for moy power out of my 3.8
  243. spark plug gap for 2.8
  244. 1998 Camaro V6 chip?
  245. 4th Cyl Misfire
  246. Stock Exhaust
  247. 2000 3.8 full tune up!!!
  248. manual conversion
  249. AC into TB?
  250. P&P exhuast manifolds???
