View Full Version : V6 Tech
- What is the Best cold air?
- Possible Tranny swap
- No cat conv+straight pipe=less torque?
- T/A Hatch F/S
- Do I need o2 sensors?
- What Oil Filter and oil to break in with?
- Is there any need?
- Just bought a 94 camaro 3.4 litre. Need performance tips
- Water in my oil?
- Intake Manifold...
- Wow, INCREDIBAL loss of power!!!
- 99 v6 vs. 94 stock gt
- Emergency Brake Light Stays on
- 3.8 Series II rebuild questions?
- Bigger throttle body for a 3.8 seriesII?
- Starter Removal????
- Tick problem with my 2.8
- my ac compresser for sale
- true duals
- Clutch and shift problems
- Which 3.4L headers?
- Need help with 3.8 detonation issue
- Bolt torque ?'s
- 98-02 front bumper ground effects
- SLP Cold Air Intake?
- Mustang=Dawg???
- 95 3.4L/At for sale in maryland
- Some general questions
- Belt routing
- Weird staring problem with my 01 Camaro
- Camshaft Selection
- Wheel hop
- trans go shift kit with vette servo
- Help..trouble installing TPS!!!!!!!
- 3.4 giving me problems
- best 3.8 exhaust?
- hi guys can you help me out
- BAD Fan!!!
- Help with IAC problem?!?!?!?
- Need Help Fast
- Engine/Track Philosphy Q's
- Rod Bearings job
- What does the "2nd" button do?
- Shift Kit??
- Running Hott
- V6 question
- thermostat
- '94 3.4L..want Dual Outlet, but keep quiet stock sound
- how much longer till my car breaks again?
- help, im lost
- 3.4L Camaro catalytic convertor problem???
- Best muffler for a v6?
- Anyone know where the IAC is??
- runnin hot on my 3.4
- V6 Ported heads FOR SALE
- Buying a daily driver...
- Tampa, FL 93-97 Firebird / Formula / Trans AM body panels
- Coolant Sensor is too Low?
- New to the sixes and I have a stumble.
- Wacky Gauges
- New Exhaust
- did GM ever have a recall on the misfire problem?
- need some quick help regarding struts
- few questions
- 3.1 injector size
- 1982 v-6 questions
- first time at the track.........
- Hesitation/Miss
- Should I drop a LS1 in my V6?
- Anyone remember?
- Import mufflers on v6 camaro?
- 3.8 fast idle
- Coolant Flush...
- rebuild kit for 3.4??
- clicky
- 2.8 bogs bad!
- SES light
- P0133, P0141, P0147, P0300
- service engine light!!!
- What kind of gas do you put in a 4th gen V-6 Camaro?
- 60 Degree Gen 1 Aluminum heads. YES THEY DO EXIST!!!
- 98 3.8L....suggestions
- misfire questions.....
- 94 engine mods
- lost my keys HELP!!!
- Driver Side Seat Adjuster Plastic Covering
- Pro 5.0 with LSS problems...
- car wont start
- Coolant Bypass for 3800 V6?
- Dead Camaro
- any1 know a good exhaust system for a V6???
- ARRGG Lost to A GT!!!!!
- Car is having trouble starting and squeeking?
- 3.8L V6 blowing white smoke after TB ported
- Tune Up Time, Factory or Performance???
- My Turbo 3.8 Camaro!!! **PICS**
- what do you think
- 92 V6 misfire
- 1994 3.4l
- 3.4 to 3.8
- Lightweight flywheel?
- MAFS screen
- Video of me at the track
- HELP!? Many Questions!!!
- Catback exhaust for an 87 w/ a 3.4?
- 3.4 or 3.8 reliability question
- Problems with 98 3.8 intermittently dying ??????????
- how many mods
- More power needed
- 3.8L with severe power loss or slow accelleration
- What are the easiest/cheapest parts to replace to make a '96 Camaro more lightweight?
- supercharging a 3.8
- random stumble and miss
- Is this the "SPARK PLUG" Problem?
- Will a 98 3.8 v6 fit in a 96 Firebird?
- All v-6 f-body fans, please enter
- which
- Has anyone every done a V-6 crate engine swap?
- underdrive kit
- i hate chevy for making v6 camaros.
- FS: 1996 Firebird
- wheel hop
- Mobil 1
- ??'s on 90 camaro RS 3.1L
- get'cho butt in here now!
- Ever heard of this prob?
- Exhaust Cut Out
- Anybody need any 3.4 manifolds?
- Roadmaster Engines Suck
- 94 3.4L Camaro - thoughts?
- 3.4l a/c suxs
- Disable factory alarm
- Can someone carfax this for me please...
- V8 transmission
- Will Z28 exhaust work on a '96 Camaro?
- Tach not reading right
- this is wut im gonna do
- Is it worth it
- Lil' Bro got a '99 Bird--Q's inside
- how much of a difference is it
- How much possible horse?
- 4th gen fuel mileage
- Injectors?
- ses light and detonation
- Help!!!!!
- SES light question
- car problems
- bad idea?
- what's fair?
- 3.1L engine harness interchangeability
- Where is the lowest price for an aluminum DS?
- Problem with exhaust manifolds - should I get headers?
- VIN Decoders and RPO Decoders
- Engine leaking coolant?
- gumball 3000
- i was wondering
- maybe u can help
- this is what im getting
- Double Walled Y
- removing dash
- 95 firebird for sale
- Gears
- Q: Auto Trans to Manual Trans?
- gmmg exhaust
- eibach sportlines
- Noisy V6 engine
- i need help to beat my step brothers...
- Acceleration Problem
- V6 Cooling system. Specifically the radiator and fan/fans
- 204/214 or 216/228???
- Gutted cat vs. high flow cat?
- Question about EGR
- offroad use only?
- v6 lowering springs - eibach 1" drop
- I got a digital camera!
- Help asap !!!
- Ebay CAI Difference?
- HELP! Info on V6 to LS1 SWAP!! (99+)
- Please help!!
- How much can i get out of it?
- Speedo broke need help
- Built up 3.4L or 3.8L...
- Urgent Help Needed *Overheating*
- Cold start hesitation
- I have a 98 V6 Firebid and have a few questions.
- rebuilding the v6
- Newbie here. Great board, but have a few questions (long)
- Help asap
- anyone relocated their iat like this?
- Grinding and knocking sounds loud and often
- 3.4l valvetrain questions....
- Losing Power...
- can I make a engin trans fer?
- y is my firebird slower
- diode/ resistor
- K&N Filters
- Edelbrock Cam Kit
- Any spare front springs?
- 3.4 - tapping noise at idle/low rpm
- tiago's turbo
- will this work?
- Manufacture Control Module, Transmisson
- How many horses can a
- Exhaust W/ No Cat
- Brake Wire
- 02 LS1 Auto tranny into 96 V6?
- did a compression check - got questions
- better injectors?
- Belt Problem
- RPM jumps and rough starts tip!
- rebuild/more power question
- Octane DOES make a difference!!!
- Tightning Interior
- Slow Window Motors
- Need help PLEASE
- Replace 98 Maf with 99+?
- 3.8L Supercharger to 3.4 Engine
- something is really wrong with my car>
- 3.1L coolant leak..
- What all do i need?
- computer swap
- replacing alternator
- Does anyone have a 97 PCM?
- cat converter
- noticed oil pressure little high
- Choppy Acceleration
- I need a block...
- Need exhaust noise Fixed
- Check Engine Light?
- my car is running stronger than ever!
- formula v6
- v6 speed
- Check Gauges
- vacume prob???
- v-6 headers?
- I think I added too much oil
- help me out here...
- Where to get tranny rebuild guide?
- Gaskets for 98 V6
- Where is my water going?
- Question on distributer
- Please Help
- 150MPH Speedometer
- Power gains from this?
- coolant boiling out cap?
- Drooling....
- Get new exhaust tips? gut cat?
- 98 Whisper Lid idea???
- how many horses?
- RPMs jumping back and forth...???
