PDA
View Full Version : Classic Engine Tech
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13
  1. Basic 350 Build with 98 Vortec heads
  2. Severe driveline vibration
  3. Pop clutch magic
  4. 67/68 water neck
  5. 454 and 396 just purchased. Have some questions.
  6. Carb problem
  7. ac belt without smog 1980 camaro z/28
  8. Questions on 75 LT 4-Speed Resto
  9. help with my 69 camaro
  10. the first off road Z28 off road cam
  11. 350 block help?
  12. Camaro on blocks in shed 20 years.
  13. 79 camaro t56 swap
  14. 67 z28 motor MP code for sale. short block only
  15. Poor gas mileage...??
  16. 454 block help
  17. Help with Measurement in Engine Bay
  18. 69 camaro with small block 400 build ideas
  19. 79 z28 project
  20. Carb question
  21. '67 Headlight doors
  22. 640HP Smallblock
  23. 79 z28 shifter probs
  24. 69 302 spark plug size
  25. Deuce deuce
  26. 73 Camaro P/S
  27. 67 rally sport head light, consul gauges wiring
  28. 69 DZ302 Coolant Overflowing
  29. Where to start?
  30. Ignition stuck 1979 z28
  31. Purchasing a 1972 camaro
  32. 67-69 Z/28 engine difference???
  33. 94 firebird security system
  34. mystery engine problem
  35. New Power for my 1967 German Camaro
  36. 1979 Stock 350
  37. engine decoding
  38. My first Camaro
  39. 67 Camaro engine questions...
  40. L98 heads and weisco dome pistons, 302
  41. Block stamp numbers
  42. 454 block id
  43. want a 1967 camaro project car
  44. want a 1967 camaro project car
  45. 383 build
  46. interchangable carb question?
  47. Looking for a 'reputable' carb rebuild service
  48. autometer gauge question
  49. help with motor!
  50. TH350 shifting question
  51. 80 RS camaro - Failed emissions..
  52. Carb advice
  53. 388sbc dyno results
  54. How to improve a 1967 210hp 327
  55. intake/carb help
  56. 67-69 302
  57. engine mount question
  58. 1972 402 TKB engine
  59. sbc 400 component matching
  60. 350 chevy motor info
  61. RHS heads any good?
  62. Need help with 350 4bolt main motor (casting numbers 1066036)
  63. Smog pump
  64. SBC Marine Duty Engines...???
  65. Steering Column Question.??
  66. 1971 Camaro Z28 LT1 Engine for sell as we speak
  67. 79 Z28 suggestions for any buildup at all
  68. Holley Projection or Street Avenger ???
  69. Big Block Pulleys
  70. Fired the old girl up today, got some work to do
  71. 1974 Z/28 GM part number for carburetor ?
  72. transmission leak
  73. 2000 camaro engine swap ideas
  74. alternator pulley info help needed
  75. project to build a 1000 hp 454 - all advices welcome
  76. Z28 sat in garage for few years
  77. small journal crank into large journal block???
  78. 1970 Camaro LT1 swap
  79. Rod length, piston height questions
  80. 1969 Camaro Fuel Filter question
  81. SS396 rebuild won't start backfires.. Suggestions?
  82. timing problems with 1980 z28 need help
  83. 79 camaro 5.0 305 cam suggestion
  84. Serpentine Belt Drive Help
  85. choosing a cam for a 355
  86. building a 355
  87. Muncie 4 speed in a 67 camaro
  88. 68 Conv 6cyl looking for direction
  89. 82 Engine And Trans Into a 79
  90. Help Identifying intake manifolds.
  91. Good heads for a tunnel ram sbc
  92. car backfired under start up, now misses under load
  93. barely used 350 small block
  94. 1972 Reliability?
  95. I have a few questions. 350 small block related.
  96. Cylinder heads for -0010 block
  97. Intake Choice?
  98. Best Setup for '67 Camaro SS
  99. 1967 Camaro SS (possible Supercharge)
  100. help finding out if i have 67 302 or 327
  101. bbc head torque specs
  102. i need tips for performance
  103. labor time help/survey
  104. Aftermarket Ignition Questions
  105. Engine help
  106. Freshly rebuilt 350 knocking! But...
  107. 89 iroc wont start
  108. Starter trouble
  109. 78 camaro frankenstein engine
  110. 383 stroker,4speed
  111. 355, 282 stroker, or 406 small block? Please help!!!
  112. Headers/Tranny suggestions for new motor?
  113. 327 Engine replacement
  114. 1969 Camaro: newbie needs help/advice
  115. 1969 Camaro: newbie needs help/advice
  116. 400 heads on a 350
  117. SBC rebuild question
  118. In need of 434 SBC twin turbo advice.
  119. Need Frame Builder with Surface Plate.
  120. Thread pattern on this shift knob?
  121. 1981- pennsylvania emissions
  122. 1979 CAMARO 305 SMALL BLOCK questions
  123. newb carb question
  124. Head's up on a special from P-S-T on Super Front End Kits for 1969-1981 Camaros
  125. HEI Question
  126. small block suggestions
  127. engine enhancment
  128. Engine color
  129. Nicked rod journal
  130. 350 build questions
  131. i just got a new camaro, tell me what you think!
  132. 454BB over heating, any ideas?
  133. decode my rear? is this a 8.5 10 bolt?
  134. Alt. Brackets for eletric water pump
  135. help with my starter and fuel problem!
  136. LT1 To LS1 swap
  137. Moly or Cast Rings?
  138. Bang for Buck, LS1 vs 350
  139. trouble ordering a stock 327 piston.
  140. Question about oil capacity on a 350
  141. Need Help!! New
  142. 80 camaro toeboard
  143. electrical
  144. 400 Block vs 350 BLock sbc?
  145. 350 SBC Ignition Help
  146. Engine swap question
  147. 79Z need to put it in DD mode temporarily
  148. Big Block over-heating Need HELP!!!
  149. Where to start?
  150. I might be getting an 81 Firebird for free. Might plan a budget build
  151. what is so good about vortec heads?
  152. How do i remove tha ignition cylinder on 1978 camaro z28.
  153. which headers 1978 LT with AC?
  154. Help me get my Camaro running!
  155. New motor and tranny help! please
  156. Bit the bullet and brought a tranny!
  157. I don't know nothin'... BUT I NEED to know...
  158. Why three dipsticks????
  159. 79 z28
  160. 400Head
  161. 350 questions
  162. 1977 400sb
  163. Tpi on 383 problems
  164. BBC Power
  165. Houston Muscle Ca Shop needed!
  166. Engine Block Codes
  167. lower dipstick tube?
  168. Starting a poject need help with lay out
  169. I"m trying to make some power, need some input
  170. difference in 250 and 292 chevy i-6
  171. Just bought a '69 Firebird, best 1st gen forum?
  172. For those who know Quadrajets...
  173. Ramjet 502 in a 68 Camaro
  174. Idle Trouble
  175. Braided Radiator hose
  176. 79 305 Engine oil chioce
  177. 71 350 mods
  178. Dz 302 3956618
  179. engine swap in a 93-95 v6
  180. Battery Issue
  181. 350-350hp
  182. Problem with my car ... ignition switch ???
  183. Break in question...
  184. Piston to valve clearence?
  185. Project car
  186. chevy 262
  187. 6al or digital 6?
  188. Aftermarket Aluminum Heads
  189. Anyone with a Gear Vendor OD?
  190. 383/t56 mileage
  191. New SBC
  192. 350 or 400?
  193. 81 Z28 Emissions
  194. cam choice in a 327 in a 67 camaro
  195. 69 camaro Z28 head casting #'s
  196. New Motor!
  197. L31 head question
  198. Converter for my tranny. What stall to aim for!?
  199. Smoking 80 Z???
  200. 81 trans am turbo
  201. What do i need to do?
  202. help with block id
  203. dyno
  204. Correct Timing on 383 Stroked
  205. 1965 327 Oil Capacity?
  206. Guess what this 73 firebird should run.
  207. 1981 tail light need
  208. Whats the best electric cooling fan...
  209. throwing some ideas around for my next trans for the 67'
  210. Could use some help...
  211. big block in 80s caprice
  212. Tuning carb - advice
  213. 69 cross ram intakes
  214. Big Oil Leak -383sbc
  215. 2ND GEN guages
  216. OIl presssure fluctuation/valve tap/vibration=???
  217. 73 firebird engine swap.
  218. Stall converter
  219. Does this sound like broken valve spring problem?
  220. 69 camaro oil leaks
  221. cam size help needed
  222. Speedo cable issue
  223. replacing 305 heads with edelbrock 350 64cc heads
  224. Car surges after hard acceleration
  225. 454 Flywheel
  226. 81 z28 water pump casting numbers 101
  227. dyno
  228. gear drive VS timing chain
  229. putting my 77 back on the street... how do i keep up...
  230. What exactly will stock stall do on my comp xe 274h cam?
  231. 350 Cam Question
  232. 350 Cast Crank MAX RPM
  233. chevy 355
  234. engine power issue with my 81 z28
  235. built 350?
  236. Well the 302 is cracked
  237. In line electric fuel pump issues
  238. how 2 run carb w/tbi harness
  239. question about heads...
  240. want to build a 454
  241. Starter troubles
  242. Stupid water pump question
  243. 355909
  244. No spark?
  245. Electrical Problem?
  246. Supercharger or Turbo?
  247. do you know this code? 355909
  248. info on smoking engine/exhaust pipe
  249. 1973 vette ?'s inside:)
  250. Can i take off my ecu on 92?
