View Full Version : Classic Engine Tech
Pages :
9]
10
11
12
13
- T-56 in 69' Camaro
- junkyard intake manifold and headers
- tranny swap question
- Timing Tab?
- leaf springs=>what brand is a good choice ?
- hood question?
- 69 Camaro Fenders
- Will performer RPM airgap fit?
- Possible to stuff 295's on a 67?
- Distributor install
- Holley Street Avenger question(s)
- firing order on a 1999 350
- 2nd gen drop
- 79-81 gauges
- which manifold?
- Wheels and Tires on 1978 Z
- F/S SB 400, 6 speed, Muncie 4 speed
- what would my car be worth?
- 81 camaro hood scoop
- ? on heat riser install- 68 RS
- net vs gross hp
- what intake and headers??
- Demon Carb tuning help!!!
- I think im running to rich.. help
- Edelbrock Air Gap or Weiand?
- Compression Ratio and cam questions
- MASSIVE Overheating Problems
- Which would you rather have?
- Old style Trannys
- What to do first?
- What Heads/Intake to use?
- Speed Demon help!!!!!!!!!
- will 275's fit in a 2nd gen?
- What intake manifold for 12's ?
- Going to Dyno: Is There a Standard Process?
- Will this hurt my engine?
- Whats my Compression Ratio?
- My Engine (look!!) Help Me Out!!
- Edelbrock EFI kit users come
- 1981 Camaro Z28 FOR SALE
- F/S MUNCIE aluminum flywheel
- opinions about Strange engineering
- Clips that hold in headliner needed
- Dart CNC 227 and felpro 1205 gasket?
- Arrgh! Clutch/Super T-10 Probs
- 350 heads
- Lt1 In My 69?
- Trying to get new engine running - backfires through carb
- 67 - 69 frame
- Front end rebuild
- 69 dash help
- kickdown cable for a TH350
- 69 1/4 mile times?
- I know it's not camaro related...
- PlastiGauge?? aargh!!
- Spindles?
- ? about shackle
- disc brakes on a 67 camaro
- Valve train geometry question
- Please Help!
- 10.8:1 cr too much for pump gas?
- My Friend Has A Question
- Anyone use lead additive in unleaded gas?
- Pacecar question
- How much more power with bigger carb??
- 79 to 81 taillight seal questions..??
- Put in new speedo cable speedo still acting weird!!??
- Th350 and shifting problems?
- From points to HEI conversion
- Air bags on a 1967 camaro.
- Building a 307
- have 049 heads fallen from grace?
- Split Bumpers
- 1/4 time and shift rpm questions..??
- Timing question on my auto car..??
- Recomending timing on my 327 with the new cam
- Engine Build Help
- blowby question
- Anyone using gear drives
- 69 Z28 302 question
- Quest for a Rear for my 2NDgen TA
- All you fellas with the 17's on your 69's..
- Anyone have a holley carb interchange book? (or know the double pumpers well?)
- exhaust leaks
- Int. manifiold prob
- Window seals
- lot of HP with monoleaf springs?
- 60ft times,second gen cars..what times and what setups..??
- Weldwheel weight questions and opinions..??
- 69 camaro SS
- '88 Camaro Rims and Tires
- question about rear suspension on camaro
- Still can't decide which shocks to get..anyone running the ce or summit racing ??
- What to clean 80 ta dash with..
- Installing 3 point seat belts in my '69
- Is this a fair price?
- How much horsepower big block and 6.71/8.71
- Car won't start?
- How much power gain from 1.6 rockers
- San Antonio Texas folks...
- Composite leaf springs good or bad experiences..
- What makes for quiet gears.??
- Is the rear end ratio marked somewhere on outside of case or something.??
- T56 install pics from 68 Camaro
- wanted: 2nd gen driveshaft!
- Ok guys running the summit or ce adjustables on the street.??
- 2nd gen fbody parts for sale
- What's your 350-400 CID carb size?
- th-350 or 700-r4 ??
- Need to know color of the underside of original hood 68 RS
- Vortec swap
- Looking for people that have swapped a SBC into a 4th Gen
- disc brake conversion
- DAMN EXHAUST LEAKS! suggestions???
- tpi setup for sale, cheap!!!
- coilovers on a 68????
- Fuel Pump Problems
- New converter got me 12's
- My Speedo is All Messed Up.
- Cant get heater fan to work since last owner took off air system.
- Indash gauge pictures on second gen tas..
- Should I got with 2.5 inch dual exhaust or is my 2 and 1/4 good enough..
- What springs for front end of big block second gen..??
- south side lift bars..or ce trac bars..??
- shocks to get for street /racing..??
- Looking for mkt value on a Grade a '67 Firebird
- 78-79 driveshaft length?
- do i need a torque converter or just not producing enough vacuum
- 2nd gen parts for sale
- Can anyone scan me a fuse box picture for my 80 ta with power eveyrthing..
- New.. lots of questions for you guys..!!!
- f/s tuned port inj. kit, accel dfi
- Holy cow ... painting is expensive !!!
- questions on 81 z28
- clutch linkage
- What's up?!
- Connecting Rods Most Important Part?
- Seeking info on M6 install in '70 Z28
- Transmission or Differential? Need Advice..
- Gulstrand & Herb Adams suspension parts fs
- Rancho GT3 leafsprings for sale
- Cal-Tracs for sale
- 572 crate motor?
- I need a trany dipstick & tube for a 68 Camaro w/a TH400! Help!
- Recomend a STRONG tranny?
- Big Block Chevy heads and valves FS
- Trying to find out if its an SS or not
- First gen questions for a soon to be owner
- If you put 350 heads on a 400 do you have to drill the extra holes in the 400 heads?
- Is the EFI MULTIPORT KIT worth the money?
- restoring a 69'er
- How Much...?
- Speed Demon 750cfm Carb vacuum sec. Question
- Need opinions on carburetors
- Starting Problem
- color codes?
- HELP!!! dropping a lt1 in a 67 camaro
- f/s 70-73 parts
- Shift Kit and Rear-end Install
- Hi!
- Keep 97Z28 or Restore 67RS/SS?
- new leaf-springs for the drags
- I am about to Purchase an "original" 69SS
- Building a stroker hopefully
- cowl tag
- help- need a water pump bypass hose EBLOW
- ? about body bushings
- 00 Trans am Rims on a 79 Camaro?
- TH350 temp gauge sending unit, where?
- 67 Camaro rear window resto
- got a 94Z and a 69 sitting side by side...
- Seats
- 1969 z28???
- 68 Gas Tank... How the Heck?!
- Finally thinking of building a 2nd gen Help me out here
- tubbing halfback system.
- Need a new Carb???
- Correct Headliner for 77 SE
- New pics
- ? about leaf springs for a 68 camaro
- 69 Z28 JL8 resoration pictures
- 68 Camaro brakes swap
- inner fender wells
- 67-68 Z28 Water Pump Question
- Terrible gas milage outa my 67
- Synth or Natural Gear Oil?
- I just joined the club! A few Q's for you...
- "self-aligning" roller rockers on World Heads
- Hey guys, I need a refresher
- camaros
- 68 firebird clutch fork
- BBC head casting
- Restoring 67 Camaro
- Rally II wheels and chrome exhaust tips for sale
- rear end
- Got A Tranny Question
- HID's
- Decisions....
- Z28 Auto Vs Gear
- Running to hot.. cant bring it down.
- Front End Swap Possible on this car? Help!
- What causes fuel pump to leak oil?
- What wheels do you have?
- 81 camaro 502 BBC swap?
- muffler stuff
- Headers on a 1975 Camaro
- Rack and Pinion
- Rear Susp ??
- Car sags to the right..
- Centerlines
- Please Help!!! Disc Brake Conversion
- Down on power...
- Engine Stalled
- Same Cam, different engines?
- 1980 Project Car, what do ya'll think??
- wiring harness install quetion
- Hurst Competition Plus mechanism...
- Front Shock Lower Mount Nuts
- Building a 302
- 2nd gen 12 bolt
- Mallory unilite replacing HEI
- Doesn't look like I am going to be able to keep the 69 after all...
- 4.10 rear end
- running straight pipes...
- Questions about a 1974 Camaro
- Looking for 68 roof or parts car!!!!
- big block or small block??
- '78-'81 Suff Sills?
- need link - who was it that was doing an LS1 swap into a green first gen?
- Electric Fuel Pump?
- Terminator/Afterburner mufflers...
- What intake???
- lower springs went higher !!???
- Gear change = quicker ET???
- Help with my lights...
- What happened to nastyz28.com?
- 350 casting year
- Best Street/race Carb??
- Cam Experts
- Best Distributor???
- stock exhaust manifolds vs. headers
- Very odd gear ratio question
- 2nd Gen vs 3rd Gen seats
- pinion angle
- 400 a big block, or small block?
- Not starting after 4 months
- 79 Z is dead,looking to rebuild (budget)
- AHH... Dieseling help!!
- Paging all 1st gen Z28 owners!! exhaust question
- holley help
