PDA
View Full Version : Classic Engine Tech
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13
  1. Not F-body Tech but still Classic Tech
  2. fuel cell question
  3. Advice
  4. How do you jack up a 2nd gen firebird from the front ??
  5. Biggest valves on a 305?
  6. A new Camaro maybe??
  7. What do you think ????
  8. 1967 RS Headlights Not Working
  9. 1967 camaro 8 track player?
  10. Need info on 1970 T/A
  11. What size Holley on 396?
  12. Tough engine choice
  13. need help- oil pan/girdle clearance
  14. help decode this motor
  15. Stroker Kit Sale
  16. So my choke wasn't hooked up...
  17. exhaust water
  18. 1973 Z28, Hedman Header installation, not even.
  19. Cam selection for a 383 stroker
  20. Mi Z-28 1981
  21. My current Project 81 Z28 Big List
  22. clone SS
  23. engine combo
  24. I want to build a Z28 engine
  25. Saginaw Linkages???
  26. Anybody restoring a 1st gen 327 Camaro coupe?
  27. What would it take for me to convert my 67 camaro
  28. How much power should this combo make
  29. Lost horn wire
  30. Motor and body number match 75 T/A
  31. Anyone ever used/heard the Comp Magnum 292 cam?
  32. heavy 74 camaro, need help
  33. 76 SBC iron head ??s
  34. Holley Specs Needed
  35. 72 camaro stering upgrade?
  36. Power Steering Bracket
  37. Fuelie Heads
  38. Need Valvetrain Help. Located in Eastern Ohio.
  39. 69 Camaro lowering questions
  40. Final decission; a Blown 502 from Scoggin-Dickey....
  41. help with march pulleys
  42. 1970 K5 lt1 swap
  43. a Blown 540 or a N/A 598???
  44. How much is this car worth?
  45. Could someone ID this engine for me?
  46. What kind of power should I expect?
  47. Building a New Motor.
  48. Late model pedals in a first gen?
  49. 400sbc questions..
  50. Pontiac 301 turbo
  51. engine out put
  52. 1979 trans am mod question
  53. for those that have swapped in 4l60e's
  54. Stall, Gears, Tires?
  55. 15x8 Draglites w/3.5 BS in For Sale section
  56. rust in cylinders, what should I do???
  57. have a newbie carb question
  58. Storing Aluminum Heads
  59. Cam for 454
  60. stock springs
  61. Freakin Taillights
  62. Camaro engine in this Corvette?
  63. 83 z28 with 79 305 wont fire...
  64. How to Tune for emissions?
  65. 1968 Camaro headers on 1981 Camaro?
  66. B&M shift improver kit
  67. Old Shell, New Engine
  68. Commander 950 problems
  69. Bell Housing Casting Number
  70. Oil System and Valve Train Experts Please
  71. advice on fuel pump...
  72. need help with conversion
  73. Does anyone have......
  74. '79 Z28 Help
  75. Do we have a 327???
  76. blowing oil filters off?
  77. head gasket
  78. compatable 78' & 71'
  79. 305 Intake???
  80. 1970 Chevelle
  81. Pictures
  82. selling my once-was project car
  83. Drawback to large fuel line?
  84. SBC powered Foxbody Q's
  85. body blues
  86. shifter reply
  87. shifter
  88. 2" headers with 4-4 1/2" collectors
  89. Holley carb help please!
  90. 455 pontiac in a camaro?
  91. bought a used intake
  92. camshaft question. Please help
  93. LS or ZZ383
  94. Can you replace the hub on a water pump?
  95. How do I remove the ignition switch?
  96. Motor Mounts
  97. What size carb
  98. small block numbers
  99. 327 power
  100. holley carb identification
  101. 1st Gen Camaro forum???
  102. Odd knocking/ticking sound
  103. Big Block zz502 for '69 Camaro? Should I DO IT?
  104. Which water pump do I have?
  105. BBC in a 81 Camaro
  106. I hate header gaskets!!!!
  107. 1971 gasket thickness
  108. Got a cam question
  109. '68 Valve Lash
  110. Can you turn a 327 Block into a 383
  111. Question on converting to serpentine
  112. choke keeps flooding the car....
  113. Tachometer location
  114. supercharger and hood clearance ? ? ?
  115. upgraded rear brakes for 79 z28
  116. Is this 750 going to be too much carb?
  117. sbc into 71 olds cutlass supreme
  118. 1965 Corvette 327
  119. Building a 406 need some info..
  120. Need help 69 camaro auto to m20 conversion
  121. hood clearance with high rise
  122. '68 RS Brakes
  123. Oxygen Manifold
  124. 1974 350 engine questions
  125. How to tell between aluminum and iron water pump?
  126. Would a Camaro driveshaft be the same as a Nova?
  127. Valve Spring Tech
  128. Is this ebay Dart 434ci too good to be true??
  129. Anybody running the Holley Systemax package?
  130. Need factory crank specs for 67 302 small journal crank
  131. From Automatic to Standart
  132. water pump pulley shims
  133. 487X - Truth or Hype
  134. Lt1 intake on 1980 format engine
  135. First time out with new Predator carburetor
  136. pulley shims
  137. Budget Motor Build
  138. Race Motor Timing
  139. Old School cams?
  140. 327 Fuelie SBC
  141. Kickdown cable to the carb!
  142. 73 camaro with 700r4 what do i need to make this work?
  143. T56 in a 71 Camaro what will i need to make this work?
  144. Timing Problem
  145. How to make more HP out of a ZZ430??
  146. 250 to 350
  147. Spark Plug Wire Placement
  148. What type of engine...
  149. Pics of my 383 stroker progress!
  150. motor mounts for BBC in 79 Z
  151. 454 0r 383 will it fit?
  152. 383 stroker motor
  153. spark plugs
  154. Engine timing
  155. valve covers
  156. 1980 camaro
  157. lifter difference
  158. water pump
  159. Piston to valve clearance problems
  160. 454 Bbc
  161. What could cause a motor to just sieze?
  162. carb trouble
  163. whats a 69 with a 307 worth?
  164. Anyone had a smoke problem with a zz4?
  165. Need help with starter!
  166. Exhaust suggestions
  167. Oil for my engine...
  168. 79 Z28 starter need help
  169. stroker questions
  170. Pics of the 383!
  171. carb selection help
  172. The 383's coming along. Got my rotating assembly last night.
  173. Whats your favorite Carb?? Holley, Edelbrock, etc???
  174. where can a guy find a radiator for a 57 chev?
  175. What brand makes the best header for BB chevy?
  176. Oil system flush for a 327.
  177. Pypes ?
  178. cam question
  179. Old engine big problem (please help)
  180. Where can you get 3inch stainless exhausts?
  181. Opinion of this car?
  182. CAM question
  183. crate engines
  184. Second (& third, & fourth) opinions please...
  185. Feedback carb question (problems)
  186. Is this engine a 396 / 375hp?
  187. is vin# 136370K135032 a 70SS Chevelle?
  188. 69 Camaro With 93 Z28 Drivetrain
  189. Best place to start.
  190. New sts kit on 67 camaro??
  191. Quick Ratio Steering Boxes
  192. motor wont start
  193. you guys build my motor
  194. 69 camaro
  195. Need an extra 1/16" clearance on valve covers
  196. stock motor specs on 79 z-28
  197. How heavy is it?
  198. 454 chevy block question
  199. suggestions for my Small Block
  200. Can a cast crank take 450hp?
  201. Anyone use Tri State cyl head Pro Topline knock offs?
  202. small block problems
  203. pontiac 455 vs buick 455??
  204. some of my 68 camaro stuff im starting to sell more to come
  205. Rebuild Opinions & Suggestions? Cams, Pistons.
  206. 69-74 z28 valve covers
  207. what my interior and hood is worth?
  208. Identifying My Pistons
  209. First Generation Salvage Yard
  210. has anyone here ever flowed the old chevy
  211. Transmission Mount
  212. ?best stock sb heads and intake
  213. Fuel line questions
  214. Engine Dies under hard breaking
  215. starting problems
  216. Is a 69 10 bolt and a 81 10 bolt the same?
  217. 1977 Trans Am
  218. '97 Silverado 454 in my '67?
  219. 81 Z28
  220. H/C Pkg:
  221. t56 into 1970-81 camaro
  222. 1969 RS headlight problem
  223. Cam help
  224. I can't turn my car off!
  225. 68 Z28 fuel question
  226. electrical problem
  227. turbo engine?
  228. Rack and pinion
  229. 302 cam question (69 camaro)
  230. i got a nasty squeek in the back and...
  231. 427's still around?
  232. massive blow by
  233. putting an lt1 in a 68
  234. Will this transmission work?
  235. NEED help WITH '74 z28 "Type LT" interior
  236. DS question
  237. Pontiac 301 V8 Question....
  238. 327 rebuild question
  239. 67-69 camaro owners ever used a 93-97 ..........??
  240. Interior question (couldnt find specific forum)
  241. aluminum pulley's wanted for sbc small water pump
  242. ls1 swap in to a 67 camaro
  243. Need help with rebuild info
  244. Any HP gains from using COOL CAN ?
  245. Jegs high flow 220 alum heads
  246. WHO Has Fast burn heads? RWHP #'s
  247. Compression Test - what is "good"?
  248. What would you put under my hood?
  249. Alternator help....
  250. Widest rims for a 78 camaro?
