- Just thinking out loud about 305 upgrades
- hei coil
- second gen driveshaft?
- Gear drive or roller timing chain?
- dad's '77 RS. looking for aftermarket valve covers/air cleaner for father's day gift
- Seized chevy 327
- Hypothetical Engine build...
- Nylon Radiator hose covers
- Raced my 73 Z/28 last night
- 3rd gen rear end
- Comp Cams "Nostalgia Plus" N+L79H OR N+30-30H cams?
- electric fan CFM needs???
- Cam blowing exhaust out the carb
- Carb Question...
- Help with my 267
- Casting numbers
- Big block
- Big block
- What type of engine
- 1st Time out!!!!! well kinda.....
- Video of my Nova winning the local burnout contest
- ls1 swap or not
- WTF?! what motor mounts for a 69RS with a 454Big block?
- Front End Swap On A 1975 Camaro
- V6 conversion to V*
- Dyno'd my 73 Z/28
- A/C Removal
- How to set static timing on a ECM-controller distributor?
- Headers and gear box question.
- Strange engine temperature issue...
- Rebuild or buy new
- old school 355 in 93 camaro, Please Help!
- Parachute Mount
- a few 355 question
- 1969 camaro ss
- Lifters
- Head suggestions (runner volume & valve sizes) for 327.
- Power Window Problems
- 350 into 95 fourth gen
- roller rocker q
- 1st Gen Headers - What brand fits best?
- F/S 67-69 Lower air dam NEW!
- 327 Engine
- Help find 67-69 Camaro
- Who modifiys carbs?
- 81 camaro rear bumper?
- help with misfiring
- fuel line size?
- Seat Removal
- anyone know
- found a '75 camaro LT. how much is it worth?
- Identify this transmission
- 2.02 vs. 1.94 intake valves
- 67 firebird, disc brake conver?
- Dash Harness
- 1971 Camaro electric fan radiator
- interior to a 67 firebird
- What carb to get
- What do you guys think of this color
- '77 Camaro RS LT vs '98 V6 Y87
- ZZ4 vs. Yearone Powercrate 350 vs...?
- Where do you guys get your interior parts?
- Semi-Restoration
- tremec TKO
- Timing Trouble
- 383 harmonic balancer help.
- higher rpm issues
- Lifting a lowered ride
- Electric Cut-Outs
- Vinal Tops
- Bowtie heads...How good?
- Video Of The 81 Z At The Track
- motor mount bolts
- burning Up Ignition Modules!
- help lots of stumble
- Best mods for a 67 RS
- help! need some more low end torque out of 302
- require a tune?
- Starter setup
- Can anyone Identify these heads?
- 6 hours left. Thoughts?
- help with 350 timing
- 327 rods?
- starter question
- best factory head and intake
- What is this???? located on firewall behind the distributor
- What is the width on a 2nd gen rear end?
- Total timing advance?
- Restoring 1979 Trans Am
- Torque Converter Reccomendation
- Decoding motor again...PLZ
- help me on my 750 holley.
- 455ci Big Block Question
- Getting my engine home
- HELP!! I have no vaccumme!!
- HELP new motor, runs like crap
- 454 Big Block for sale
- got a question on pistons
- I want to change my seats!
- Who makes good quality rear quarter panels?
- Pitman Arm wont come off!!! Help!!
- Performer RPM Heads On A 383
- Question on my 67! What do you call.......
- Cam Help!
- 1979 z28 starter
- trans cooler install??
- Best place to buy heads?
- question about a 350
- Need some carb/ignition tuning advice.
- Timing chain q
- Question for the experts
- 73 trans am
- Im buying a 400 SBC, question about combo & what heads to use.
- How to remove Cam bearing/seal?
- 500-550 HP out of a 383
- Gasket Ported Stock Heads or....
- 454 Buildup Help
- Holley carb flooding out
- Bent pushrod?
- confusing 70 nova ss starter problem!!!please help!!!!
- Budget Project 350
- 1969 camaro serial number
- starter help
- 1969 camaro 454?
- What exhaust is best?
- need some pontaic help
- what should I tell my friend?
- Just got a 68 RS few ??s
- mech. or eletric fuel pump?
- help camaro glass trim
- Chevy 400 question
- This thing is really going to SUCK!
- Mods for a 67 RS
- Transmittion Fluid Leakage
- Gauging interest in new Bird hood
- why?
- Are the 305 and 350 blocks the same?
- Inline fuel pump with mechanical too?!---
- need help please??
- Will the AR 103 plugs work in my blown 327?
- has anybody ever....
- Need Another Brain!!! Please Help
- pipes
- cam selection question
- '69 Z/28: New and need advice
- 69' Camaro with a T-56 Question
- 327 engin out of a 67 RS.
- Gen1 454 BBC Short Block Weight?? need a rough estimate.
- How much power?
- New heads and cam suggestion
- 68 Camaro-- Dash lights went out!!!
- what you think.
- Seatbelt on a 79 Transam
- Do I need 7/16 or 3/8 studs; 327 ; r. rockers
- Non roller motor, can I use roller rockers or lifters?---
- will 454 fit in 80 camaro?
- Help with my 327
- 700R4 in a 2nd gen
- 6.6L Trans Am needs some engine mounts
- Need 302 parts....
- Low zinc in todays oils = flat tappet wear?
- Cal-tracs for street.
- Need help IDing my camaro
- Starter bolt problem...
- ? # 67 Z28 convertable's
- anybody know
- rebuilt 350 won't start..help
- Help for someone who sucks at carbs (me)
- sbc cam q
- 8100 Vortec into something carbed. How?
- compression
- got a shelby alarm n i love it
- quick Q : power for 10's lol
- How to clean and Prep Block 4 paint?
- Does anybody want some chevy parts?
- What Small Block?
- Who has front bumper guards on 68 Camaro?
- Scoggin Dickey or Sallee Chev.???
- Reuse oil filter for second oil change....ok?!
- WHAT is the ci of my motor lol???
- power guess?
- e/t
- 355 street/strip suggestions
- SBC rods and pistons one each only
- cracked block. Is it fixable?
- rocker arm swap gains?
- What kind of heads are these??
- no oil to the rockers?
- 1982 Z28 street/strip
- What's a good second gen board?
- I'm confused, need help quick
- Edelbrock fuel pumps
- Distributor #1111500
- 350 Engine
- autometer gauge on 327 SB
- oil pressure problems
- Cam Choices..
- Picking up a spare block
- Power steering pum parts?
- Dart Pro 1 heads & matching intake for big block Chevy
- Power Steering?
- Small Block Shootout
- Exhaust Backfire
- Trying to locate a 400 oem pioneer flexplate
- i have a 69 and 97.... what will fit?
- Guess that 383 stroker power numbers?
- Why is one headlight dim and the other bright?
- What are some good 1st-Gen-only message boards?
- Torque sequence and specifications for '69 or '70 350?
- Want to build a BLOWN & SPRAYED 383. NEED HELP!!
- little fun in the driveway
- 1981 turbo trans am smog pump question
- easy help
- yet another kid Q
- head numbers
- kid needs help wit SB
- just got my new intake in for the BBC.... i want to cry
- Any advice for this set-up to gain more power
- 383 370 350 327 Which One?
- Need help with infp on 400sbc heads
- More Trouble...
- dz302
- Problems with header install on 70RS...
- Question on Intake Manifold
- Has anyone have this happen to them
- question about casting number
- secondaries flooding carb
- Motor I.D. help..??
- Post pics of your 1st gens, and second gens!
- Replacing the rear shocks??
- '67 327 to buld... need some performance input please
- Question about 350 in my camaro
- Buick 455 Parts?
- 86 iroc-z
- Best carb for a sbc400?
- your thoughts?
- 69 Camaro rear
- 6 speed in 69 camaro
- what temp ???
- cooling system problem ideas please
- speaking of a 67 RS vert
- Got some questions about 350/383 engines.
- another cam question
- Where can I find a good twin plate clutch for a Chevy 350?
- 1967 Camaro RS stats
- What size diff would be on 78 Firebird Formula?
- 1967 camaro questions
- 68 ticking and leaking
