PDA
View Full Version : Classic Engine Tech
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13
  1. Car surges after hard acceleration
  2. 454 Flywheel
  3. 81 z28 water pump casting numbers 101
  4. dyno
  5. gear drive VS timing chain
  6. putting my 77 back on the street... how do i keep up...
  7. What exactly will stock stall do on my comp xe 274h cam?
  8. 350 Cam Question
  9. 350 Cast Crank MAX RPM
  10. chevy 355
  11. engine power issue with my 81 z28
  12. built 350?
  13. Well the 302 is cracked
  14. In line electric fuel pump issues
  15. how 2 run carb w/tbi harness
  16. question about heads...
  17. want to build a 454
  18. Starter troubles
  19. Stupid water pump question
  20. 355909
  21. No spark?
  22. Electrical Problem?
  23. Supercharger or Turbo?
  24. do you know this code? 355909
  25. info on smoking engine/exhaust pipe
  26. 1973 vette ?'s inside:)
  27. Can i take off my ecu on 92?
  28. Shifter issue?
  29. 6" or 5.7" rod
  30. Engine Rebuild Ideas
  31. gen1 water pump
  32. rebuilding an engine
  33. how to go roller?
  34. 74 camaro 350
  35. Double Hump Heads 327
  36. Water pump for a 1978 z28
  37. 454 in an 80Z????
  38. Ready to start the 142 blower swap, HEAD CHOICE?! ---
  39. Steering very sloppy. What could it be?
  40. 1987 SBC cam question
  41. How to tell if it is a real 1967 SS
  42. Power door lock problems
  43. Voltage regulater
  44. Ignition Boxes??
  45. so I ran into some problems............
  46. 455 Olds Rocket into '79 Trans Am - Oil Guage doesn't work - Help!
  47. E85
  48. Regards to Grandfathers 63 Chevy
  49. please help me and my 79
  50. 455 or 400 needed.
  51. Gear head Decode
  52. newb trying to intall an edelbrock carb
  53. Looking for
  54. What's currently the best choice for roller retrofit lifters for the SBC?
  55. 1971 fire bird build?
  56. 73 camaro wiper switch
  57. Need advice on my bracket motor
  58. My Pontiac 350 story.
  59. Straight 6 + O.D.?
  60. New motor. 408ci stroker smallblock
  61. Sigh. I had a blowout while driving the other day.
  62. Saw a second gen vert.
  63. 350 or 327
  64. help
  65. Cylinder Head Casting symbols?
  66. Rocker Arms?
  67. More torque from a FI 383
  68. 69 nova rearend question
  69. 95 TBI truck problems
  70. It's alive!
  71. What do you guys think of this Combo?
  72. I want 12.8 timeslips
  73. buying a new motor off ebay, need help
  74. help with a 1979
  75. 950 hp motor parts list.
  76. Intake Gasket question....
  77. How do i remove oil pump pushrod?
  78. Hydraulic Lifters (problem with different lifters smae part number)
  79. help with a loose rod
  80. Best place to get front suspension for 67?
  81. smoke problem
  82. v8 question
  83. how much do i weigh
  84. 6-pack on 77 engine
  85. winters snowflake manifold
  86. Interior Trim completion- 67 Camaro
  87. vizard's max performance on a budget
  88. 1980 Z28 camaro
  89. 400 sbc build up?
  90. What are l31 vortecs worth?
  91. Help me build it..
  92. 350 Marine Block
  93. 69 camaro 427 big block
  94. TH-400 trans performance build up. Any specs??
  95. Excellent and free tuning advice
  96. 289 build up?
  97. 78 350
  98. camshafts
  99. thoughts on engine combo
  100. its done, now I want to make it fun
  101. 2 bolt vs 4 bolt
  102. Anyone have an engine simulation program?
  103. Question about Gauge Cluster 1980 Camaro
  104. 76 400 w/4sp
  105. Cannot Decide On What CAM!!!
  106. power steering adjustment nut leak
  107. Timing Tab??
  108. Rough idle when cold
  109. thinking of upgrading
  110. new engine
  111. I don't know what to do.
  112. convert to V belt or cowl hood? (V6 to SBC swap problems)
  113. Old GM part numbers!
  114. Gasket question
  115. new connecting rod nut?
  116. Car steers itself?????
  117. LT 1 timing tab?
  118. BBC race motor - newest version rocks!
  119. SBC Drawings or CAD Files
  120. 2nd Generation Towing Capacity - Help
  121. Just having fun, theoretical engine build.
  122. 350 build
  123. Fuel Pump on 69
  124. Stock block limits?
  125. help! piston question
  126. Dual 3" exhaust too much??
  127. Need help!
  128. help!!
  129. need carb help with idle mixture
  130. 79 Firebird Dyno Pull
  131. blower questions
  132. 1981 z28 emissions help
  133. wish me luck
  134. New motor this summer, time estimates??
  135. 1981 Camaro need help picking engine parts
  136. help w/ a 396 (grinding noise)
  137. 383 build recommendations
  138. Built In Coil/Distrib. or Pro-Billet & MSD Blaster 2 Coil??
  139. What model serpentine pulleys to conver 69 camaro?
  140. Shifter issue
  141. oil pressure...
  142. Do i really need heat?
  143. which intake manifold to buy - sbc
  144. Weiand 142 on Pontiac 400
  145. Will lt1 heads work on a 72 Malibu 350 block?
  146. truck engine and car engine?
  147. proform 750 carb
  148. Intake Manifold Gaskets?
  149. fuel in oil
  150. procharger
  151. Need advice on head situation
  152. Valve Train for High RPM
  153. Mysterious Valve Tap
  154. Need help with my motor
  155. Good heads/crank for a blown 67 327? ---
  156. 10th Ann. Trans Am
  157. looking for dual exhaust for 81z28
  158. Late 2nd gen TA as a daily driver?
  159. How to Build a 302 out of a 350 or 327 Block
  160. What Cam to use?
  161. What motor is this?
  162. ZZ4 upgrade to 1.6RR Dyno Numbers!!!
  163. help finding a part?
  164. blown engine, what can be salvaged?
  165. 427 Rat?
  166. New Big Block Guy
  167. smokes
  168. Cowl Induction
  169. 1981 Z28
  170. Firebird 326ci motor
  171. Suggestions for 305 SB?
  172. Help Please
  173. need help with setting initial timing
  174. Early 2nd Gen in Bay Area?
  175. LT1 piston number
  176. best oem rebuild kit
  177. Grill for 81 camaro
  178. 1981 z28
  179. exhaust
  180. 1974 Trans Am won't start...
  181. 68 Factory Instruction Manual
  182. how do you make a 377?
  183. lunati cam help
  184. too smal of a carb?
  185. Brake Cylinders
  186. BUILD UP what to do on a budget
  187. Dash Pad???
  188. Need a reliable machine shop in New Jersey
  189. Lookin at some new wheels for my 80 Camaro
  190. "71" 350 into "96" vehicle
  191. retro fit tpi
  192. 350 question
  193. Crank strength question
  194. another 327 question.
  195. 327 , can it use guideplates? ---
  196. 3.08 chevy10bolt to 3.90 moser lost 3teths?
  197. 327 vs 350
  198. fuel injection fuel system help
  199. 327 value
  200. paint question
  201. Carb help
  202. 1967 z28 question ??
  203. Gear Drive Machining---
  204. Question
  205. Quadrajet fuel drips
  206. just joined
  207. Adjusting the Timing
  208. 78 Camaro 350
  209. Good deal to help your flat tappet cam live.
  210. Decoding Engines - Source?
  211. Engine Whistles at Idle
  212. stock valve size
  213. dyno tune
  214. do i need smaller jets? boggs down low.
  215. 80 Camaro exhaust questions
  216. Will a 78-79 camaro run good with a 383
  217. high hp street muffler?
  218. Need help about 69 camaro
  219. Posi
  220. engine miss
  221. Going into uncharted waters.
  222. what gears should i put in the rear? 327/m-21
  223. 1969 Z28 Block Casting # question
  224. how do i make my engine faster for cheap?
  225. NX "Hitman" nitrous kit for sale
  226. 350 Firing order Am I just tired can't remember
  227. new engine
  228. Compression question
  229. Headers?
  230. Intermittent Starting Problem
  231. New to the 2nd Gen family
  232. Port and Polish
  233. Oil pump for a sbc 400
  234. L31 in 85 elcamino and headers.
  235. roller cam in a non roller 400sbc?
  236. Please Help, fuel pressure problesm
  237. engine wont start hot....
  238. Engine not running
  239. Gen I block
  240. New SB & BB Heads
  241. Milodon Bad Part Experience
  242. Headers - 67with A/C
  243. Carby 327 67?
  244. Pushrod length?
  245. which set of cam and heads for my engine
  246. Security System
  247. shifter cable bracket???
  248. New To The Boards
  249. Colors???
  250. Car is BOUNCY after new leaf springs and shocks
