- Need some new Pads front and rear, Advice needed.
- 86 Z28 350 Carb, What Fuel Pump should I get?
- RPO code help
- 350 roller/vortec heads/xr270 mpg
- Tachometer
- Help with eng
- 1982 Z28 with Crossfire TBI
- What will she run
- 84 transmission shifts hard
- 82 Z28 Engine Size Question
- help with general maintenance for my 83 Z CFI
- Motor swap question
- tpi question
- My S-I-L bought this 82 Z28...
- 84 camaro question
- Fan question
- 92 firebird
- LT1 cam in 1991 305 TPI ?
- 350TPI help please!!!!
- New Carburetor
- magnaflow or Flowmaster
- 86 Z28 rough idle / oil gauge goes nuts!
- Throttle linkage info
- knock knock
- tpi 350
- Engine Oil Help, What is good for a Flat Tappet Cam?
- 91 z28 305 tpi big probs help !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!
- Vortec 4200 6 Cylinder Swap into IROC-Z
- 95 LT1 into 83 camaro
- 305 heads on 350 block
- Master Cylinder squirting?
- Carb and HEI recommendation for a 350 5 Speed Combo
- Are 3rd/4th gen trans crossmembers interchangeable?
- 1991 camaro z28 wont start
- LT1 Top End
- 1993-1997 GM F-Body G-Load Brace - Red
- 1979 Z28 Camaro problem
- Cam and header suggestions
- budget headers with y-pipe
- Ls1 to 3rd gen swap?
- Just bought my son z28, help!!
- automatic transmission valve cable 1983 CFI
- disconnecting fuel return lines and fuel inlet lines on the throttle bodies
- 1979 305 camaro help!
- disconnecting throttle cables located on centerblock 1983 crossfire camaro
- removing wiring on throttle body
- 1983 Crossfire fuel injected gasket swapping
- Supercharged tpi 88 iroc 305
- worth swaping to a lt1?
- overheating
- Hard start,sluggish loss of HP
- 1982 indianapolis 500 camaro HELP!!!!!
- crossfire no go
- Have a camshaft question..
- I need help with a Battery.
- 1987 camaroz28 5.0 Headers back
- computer controlled igniton to hei non computer
- synthetic transmission fluid
- 95 350heads on 305block will it work? help me...
- L98 Swap Questions
- 2012 Thirdgen Roundup
- need help cutting weight
- New Houston, Texas area Forum-car club
- vortec pcm and harness, with tpi
- PLEASE HELP 89 tpi blowing oil out through dipstick tube.
- Power steering pump issues
- tpi injection on vortec 350????
- Engine or tranny swap help me out
- Good deal on a steering box?
- Horrible Misfiring! Tried almost everything! Need help!!!
- tpi mystery canted valve heads?
- 350 tpi??
- 1992 camaro z28 6spd swap???
- 1988 Iroc-z good deal?
- 355 in my 84 z28
- what happen to this site for thirdgens?
- intermittent brake lights
- MAP sensor
- a few tpi questions. no power, runs hot
- 87 iroc z tire fitting question?
- Help !!
- engine vac pressure question
- How to make a 2 BAR MAP work with a GM 8D #1227727 ECM?
- How do I make my 1984 Z28 faster?
- Going to an LS series motor next year, maybe early 2013 before it's complete.
- 305 tpi runs starts running on 4
- Age Old Question: Which Headers?
- Transmission problem.
- 1991 Z28 Fuel line/pump issues??
- 91 TPI fuel problem
- Smog pump
- Speedo isnt working
- camaro Idling to high??
- Questions on a 5.7l TPI
- 355 camaro timing i think? just can not get it right help please
- 89 iroc with LS1 swap have question
- 88 camaro hard start/runs rough
- timing/tuning question--91 5.7
- Does This Sound Like Valve Seals ?????
- Transmission: WHAT does this plug into?
- Short video of the IROC
- Bad fan switch or relay?
- 305 TPI No start
- yet another non starter
- timing questions
- Tons of Questions bout 84
- 700r4 shifting questions??
- rear end gear help??? cant find any
- 87 Iroc sputters When I Accelerate
- No rear sensor on 3rd gen a/c compressor
- 89 Charging system
- Little more power out of a little 305
- 5.7L TBI shaking at certain throttle positions.
- Car has been sitting for two years
- shocks and struts?
- 305 TPI Rough running questions
- T-Top Shattered
- Firebird rear hatch question
- 84 camaro z badged but not 28?
- Yet another starting issue.
- '92 Z28 L98 TPI CT Emissions Test FAIL. ( PICS! )
- Rear end suggestions
- Cam Swap??
- convertible z28
- Windshield Wiper Problem??
- Torque Converter???
- 91 camaro rs keeps shutting down
- 305 TBI to 350 Carb swap help
- newb with tons of stupid questions.
- new to the Camaro world
- 305 TBI problems
- Can i use an 87 iroc z exaust on a 91 z28
- fuel pressure issues??? Holley 3 port regulator
- Failed Smog Help.
- need help.
- stupid question im sure but im new to carberation
- 1991 z28 manual trans swap? from 84' camaro
- Strange engine problem.
- fan wiring, relay problems 1987 iroc first one, off to bad start
- Low compression in engine
- correct rmp
- Anyone have Crate engines
- Transmission Question
- engine/trans swap.any helpful tips??
- 305 TPI Engine Temp Sensor?
- has oil pressure but no oil on top end.
- clutch wont disengage
- Starter won't turn, battery has power
- My brother is having problems with his TBI car? suggestions??
- newbie question
- quick questions 1987 iroc-z tpi 355
- intake help
- Traction issues....
- 1979 Camaro Engine/tranny swap
- My 1986 Camaro
- need help
- Building a "Modern" 302 from shelf parts??
- Best place to find a new dashboard?
- 87 iroc-z 355 tpi temp question.
- Completely Stock L98
- 2000 3.8L V6 Throttle Position Sensor
- 305 h.o
- my 92 rs camaro
- 95 z28 misses on the road
- 700R4 TV cable on 6-71 blower????
- Transplanting 305 TBI
- tv cable!
- How much horspower can a stock TPI air filter housing support?
- how fast do u think?
- 91 camero idle air control
- anyone have an extra
- Swaping a 92 RS's 305 V8 for a 95 3.4l V6
- In desporate need please help
- manifold coolant temp sensor
- buzzing ignition coil?
- What should I do next?
- No fuel problem
- Just bought a 1986 IROC, power question.
- code?????
- Whats a L98 w/ 88K miles worth?
- starting project cat that has been sitting
- My LT1 swap ta
- Engine vin location?
- racing question
- NJ emissions inspection - Failed HC's
- Gear question
- dragstrip
- L98 in a G-Body carbed
- HUGE STARTER PROBLEMS - This will be 7TH STARTER IN 2 YEARS
- 89 Formula 350 code 34
- What should be the correct Idle RPM?
- gear question?
- lunati cam
- Need a new L98 long block...
- does my 85 305 tpi have a?
- stock chrome 99 z28 wheels
- Overheats!
- 5 speed swap
- loads up on fuel..why!
- rear end
- Hard to start
- Doesn't anyone make 82-84 TA fenders?
- Won't rev past 3000 RPM
- Aftermarket gauge location in 3rd gen...
- Getting heads tested for leaks
- why were the 3rd gen V8's such dogs?
- Relibility of 3rd Gen Powertrains??
- 89 Camaro RS Stalls when making turns
- Fuel filter location?
- Fan Switch Location
- 89 iroz z with 5.0 tpi throwing 3 codes
- Buying a Camaro
- 1987 Iroc Stalling
- Transmission Leak
- Stalling in drive as soon as I step on gas.
- 1984 fan switch
- 84 z28 H.O. Overheating
- v6 to v8 conversion
- Need Help. 305 + cam +heads etc.
- Lt1 cam pump lobe
- Water Pump replacement
- 305 vs 350
- Reprograming 89 Camaro after major engine upgrades
- Do I need pro tune for these mods?
- How hot is to hot
- 89 camaro tbi wont turns but wont start
- engine misses and sputters
- 4th gen rear end, in 3rd gen
- service engine light!!
- 89 iroc wiring issues
- Help With Engine Swap???
- 5.7 EPROM needed.
- 86' Firebird engine swap, 2.8 Ltr to 305 H.O.
- I NEED HELP BAD surging and running like crap problem
- Car turns over but won't start
- No injector signal
- right air fuel fixture?
- please help fuel pump not turning on
- 88 Iroc dies at stop
- next performance step, 350 tpi
- 84 Trans Am HO
- Engine choice
- 1988 Firebird V8
- 1987 IROC 5.7 vbelt
- y-pipe question
- unusual vats problem
- 86 TPI cold start sensor
- block swap
- Difference between LB9 with auto and manual trans
