- Cruise Control
- Baker Electronics VATS bypass module: Have you used it?
- 160 or 180 thermostat
- Should i pickup a 90 T/A for 500?
- FS: 83 Camaro w/350 small block
- few new pics of motor swap and new paintjob
- Many Problems Needing Much Help
- Ground wire question!
- QUICK HELP NEEDED! Fuel Injector question!
- adapter plate
- test pipe??
- Alum vs. Stock Driveshaft??
- valve cover
- This is weird
- all sorts of problems
- 89 RS camaro strange noise
- Where'd this vacuum line go?!
- Manuel brakes on a 91 RS
- what kinda trans should i go with?
- Serious problem after replace distributor with new Mallory one.
- passing emissions
- SLP loudmouth
- 350 fit into a 305.....
- edelbrock header leaking where the 4 pipes come together? I ahve afew ? about fixing
- chip questions...
- supercharged tpi
- 89 rs 305 normal oil press?
- LT1 cranks and starts but wont run.
- timing
- I need help with posi question.
- What causes a tach to be inaccurate?
- Is the LT1 MAF the same as LB9?
- Not sure if this is the right forum...
- code 23 on TBI 305
- more questions about my 383 motor!
- Urgent...What caused this????
- code 23 on 305 TBI 89RS camaro
- BW T-5 Rebuild
- 383 stroker cam?
- Help!
- Help!
- how common is this spoiler??
- '91 rs not startinG? help ASAP
- C5 brake upgrade complete
- Cooling Fan Problem
- just bought my first camaro:)
- LT1 Swap: How do you hook up MAF?
- Radio Power
- Shocks for my 1991 Z
- 91 305 TBI swapped to 1990 305 TPI = No cranking
- are all GTA`s WS6 cars???
- What engine do i have
- SLP cold air intake
- How Many Revs = Too Many?
- Stainless Steel Roller Rockers
- 91 Z28 Rear End Gears
- Engine Questions
- A/C Cooling Fan
- 305 tbi to tpi or carb?
- Arcing Sparking
- ATTENTION 91/91 Camaro's with TPI 305 OR 350
- 305TPI Rebuild
- need wiring help
- 350TPI Prom
- 1985 v6 to v8
- anyone have pics of a 400cid sbc
- NEED electrical help!
- water pump..how to tell if short or long style
- Using the stock radiator with LT1..
- knocking noise?
- "Best" Engine Upgrade on a 305?
- will i have to change my push rods?
- How fast are the 1990 GTA`s in the 1/4
- where to buy a 3' cowl hood?
- Higher Octane Worth It?
- crank in 305
- Alternator wiring question, kinda odd
- car stopped running, help!
- 305 TPI vs. 350 TPI
- Exhaust?????????
- oil on spark plugs
- Where so you get chrome billet grills for 92 camaro's?
- Exhaust Manifold boltz
- 2.8 mfi to 5.7 tpi conversion question
- 4.7K resistor IAT mod, a question
- Car won't start....HELP!!!!
- Will 3rd and 4th gen seat brackets interchange?
- Went to the track for the first time
- I need deeper gears! Are all 3rd gen rears interchangeable?
- 1990 Gta
- Any reason i cant put a solid cam and lifters in my roller engine?
- Recommended Carburetor?
- questions about headers + y pipe for my 3rd gen
- Smog delete?
- what do you guys think
- Centerbolt Question
- How big of an engine will fit?
- Interchange
- finding top dead center
- A/C head pressure, A/C and fans?
- What wires to splice for the LT1?
- 350 engine
- Car wont start
- fuel pressure problems...
- Installing air/fuel gauge
- Timing Chains
- Cheap speed
- What coolant mixture w/aluminum heads?
- 305 carb to 350 carb
- Factory 383 3rd gen
- 94Z door panel go on 86 iroc?
- 92 Camaro - TPI - EGR Replaced, LOSS of power??
- Can factory baseplate be used??
- HELP...burning oil dont know why :(
- brake light problem
- Ok, getting 20 inch iroc wheels for my 92, SO
- heads??
- L98 Heads
- Decisions, Decisions (Part Deux)
- 89 rs / 305 bad computer? 66,000 miles
- whats the width on a 3rd gen rear?
- LT header install. Help!
- centerforce clutch options
- Starting Problem
- Cool third-gen video from 1982!
- LT1 wiring problems.
- Any options on replacing 700r4
- New Motor is in
- MSD 6A benefits?
- camaro engine install with headers,need advice
- Fuel pump on a C4 corvette?
- "Hencho en Mexico" Blocks
- Decisions, Decisions...
- RPM's running high, loss of power
- Stock 7.2 pushrods
- Light Problem
- gear drives
- Rocker Arms....guideplates or self aligning...
- What's the most cost-effective way to increase LG4 horsepower?
- Where did you mount your LT1 computer?
- alternator trouble with lt1 swap into 3rd gen
- Tbi ? Please Help Aaahhhhh......
- Tire size question?
- Need help with car stalling.
- vibration on deceleration
- 90-92 Gauge Cluster
- Short Throw Shifter
- MAF and header install
- Car wont start, NEED HELP
- LT1 intake mod need help
- TGO's new look...
- 305 TBI Power
- Can I use any 700r4 or are their camaro specific ones?
- Need help Identifying camel hump heads
- engin help
- edelbrock carb and 700R4
- 4th Gen Dash Swap ?'s
- Anyone with a LT1 and T56???
- 28" tire fit?
- Late 80's early 90's bowtie heads?
- 1989 Z28 5.7lt Tune-up!
- Scam or an ULTRA rare car??
- 25th anniversary Z28
- 305 TBI fuel/air mix
- TGO is down again (maintenance/upgrade)
- LT1 Swappers inside please!
- Borg Warner 9 bolt gears???
- Getting the most from my engine.
- cam install
- Big block 84 firebird
- iroc on ebay with tbi
- 305 Crate
- What in the world have I got myself into.....
- Vette oilpan on Camaro?
- 89 RS 305 TBI with California Emissions
- backfiring 87 z28
- Rattling Coming from Catalytic Converter Area I Believe...
- 496 into thirdgen underway.
- Team3rdgen hacked?
- Will LT1 cam and heads work on a L98
- TGO *appears* to be back up!
- HELP-coil placement on a trans am
- 91 Z28 TPI failed NOX test California
- Cam questions
- parts off a 88 Iroc z
- anyone have a vacuum diagram 4 a 89 rs stock 305
- need TC specifications from a Z28 350 TPI
- Anyone need a driveshaft safety loop?
- k&n filter for 92 Z28
- Installing headers on a 3rd gen
- Need Help Fast
- Starter Problems...
- Water pump return port?
- Paxton SN-93 Supercharger help.
- Converting my 350 V belt system to serpentine system
- HSR and LT4 hot cam
- Plug wires question
- handling info?????
- Third Gen Trans Am speedo question
- thirdgen down?
- Wanted to know what others think...
- What is stock horse power for a 350?
- Aftermarket oil pan?
- 4th gen door panels
- 1989 Camaro Not starting
- what do i do with my car
- A G92?
- 1991 Camaro Idling Issue
- 84 z28, go 383 or no?
- 383
- Stock Compression???
- G92 vs 1LE
- car just dies & wont start
- 305 TBI to 350 TBI....Anybody done this before?
- LT4 Hotcam
- V6/454 swap, need info.
- Help Get Thirdgen Models Made!!!
- Choke and Voltage Drain
- Last minute checklist for LT1 install!!
- TPI to some kinda intake question.
- 350/30 Corvette Engine
- Want to spray a TPI 305...need some expert opinions
- 88 tpi iroc - is 286hr too much?
- vats in an 88 ?
- TPI Combo Q
- L98 Regulator Diaphram
- Speedometer doesn't work
- Build or Swap?
- Combo estimate hp an cam selections
- Car turning but not starting
- LT1 to LT4 on 3rd gen
- quick ?
- What to do?
- to swap, or not to swap
- need to ID a zz9 or zz4 cam...
- 89 camaro fuel pump?
- L98 heads on LB9
- Now That we Figured that out...
- Felpro 1205 to a AFR 6820 ???
- Is My Mechanic Nuts?
- header time
- WTB Firebird Formula 350 dual cat-who owns one
- Help me solve my mystery
- Need 85-89 350 TPI ESC Module Part Number
- Acronyms
- Modify Thermostat on Race Engine?
- Engine cutting out, need help please.
- help please
- Please Help
- lt4 in a 87
