- Air Lines
- Cat delete...smog inspection help
- Car shakes and vibrates!!
- 85 LG4 Z28/90 L98 GTA , which is faster???
- Does LT1 throttle body work on an L98 motor?
- Fuel line questions
- carbed 383 help
- strange ticking noise...???
- Please Help!!!!!Car Problems
- When to replace ignition module?
- 91 rs
- L98 Prom
- when is it too much rust?
- Looking for a part!
- engine running rich
- 1987 L98 question
- 1987 L98 question
- 1987 L98 question
- 91 firebird-form tpi 305-5sp stock now tpi 350 help! problems
- What upgrades can i do to my suspension??
- exhaust
- can someone help me out with this? compression ?
- confession
- HELP ME!! My car idles too high!
- Spacers for SS/ZR1 Rims on a 3rd gen?
- is it a 305 or 350?
- Vapor Locking My LG4
- New Exhaust set up on my 92Z28
- IROC Steering Wheels
- 1987 IROC Test drive video!!!!!!!!!!!!
- German 3rd gen bodykit
- IROC & 355 Engine Parts FS
- anyone tell me about this cam?
- Radle Problem????
- who wants to play guess what fell out of my motor?
- Starting Problems
- How to get out Anchor Pin bolt from rear Drums?
- Replacing fuel injectors... please help
- What color were my emblems from the factory?
- Why no oil pressure? COuld use some suggestions... PLEASE!!!
- Wiring Harness
- Help me clean my basement!
- 145+ stock?
- New Wheels
- Roller Cam Help
- Wierd sound...
- flywheel problems
- 32V heads!
- Relacing 305 in 1991 RS
- Intermit. starting problems
- Help me with my flywheel
- Firebird formula hood bulge decals
- Engine Problem
- What type of wheel stud do I need to buy?
- Question about 85-86 TPI engines
- Bad fan switch I assume?
- got my 90 GTA YAY!!!!, got some questions
- l98 mods
- 92 l98 z
- what heads for 383?
- How do I change my coolant in my L98 engine
- best roller rockers
- Voltage drop when A/C is on
- 3 gen question
- Carbed 305 in 89 RS
- Help! Can't get out my driveshaft with Nylon U-Joints!
- 3rd Gen Camaro 4x4... No Sh!t
- Best way to reach computer on 87 Trans Am??
- Parting..87 Iroc 350TPI..Parting
- 87 Iroc 5.7L 350TPI
- Heads weak link in TPI?
- LG4 or LB9... Does It Matter?
- code 33 how do I test my MAF sensor?
- Power locks and mirrors dont work
- Dual Snorkel...
- At a standstill with fresh 383 HSR problems...I'm at your mercy
- i was wondering
- Edelbrock Exhaust
- Oil leak
- air compressor!
- Which Knock Sensor to Use
- LT1/LS1 Swap ups and downs....and prices
- TRue dual side pipes
- High Idle, no brakes. Loss of vacuum?
- Need info on Heads for 383
- Auto Trans in an 1988 Trans Am
- 89 RS Left Front strut tower
- my camaro is a freak of nature...
- cam help
- (Another) Cam Selection .452/.465 vs. .503/.510
- how much can my transmission handle?
- Gas smell
- Brodix for 1000$ or Vortec for 600$?
- Poor 90' RS got wrecked today
- since I only post in this section
- Open air element
- running rich
- Bolting a 6-speed to a 350tpi
- which injectors?
- exhaust setup
- question 1982 camaro
- help! best course of action for multiple fuel related codes?
- headlights
- 1990 IROC 305 TPI 5-SPD Wont Start
- Supercharger????
- Cleaning MAF sensor
- Gta
- Convert to serpentine belt
- 2-series carrier & 3-series carrier 9 bolt
- What's your opinion of Torsen Differentials?
- Starts and stalls/ rough idle
- Cooling Problems
- KTRE 12 bolt for 3rd gen Camaro / Firebird
- Free 1986 Trans am rear hatch near Tampa,Fl
- 305 build up
- 90 RS TBI Problems
- Supercharging 91 Z28?
- How much gas can you put in?
- car idles like ass on startup only need help
- maf burnoff relay
- How To Install????
- Need some suggestions
- AIR system
- Where can you buy new wiring harnesses?
- 350 rebuild
- Charging Sys problems 87 IROCZ
- How do I test for a bad distributor?
- Speed Sensor question.
- My SLP headers have FINALLY arrived.....
- Idle is a bit rough...New Catalytic converters
- Setting Engine Timing Using Inductive Light Question
- 1988 9 Bolt onto a 1989 Drum 10 bolt
- Is there ANYWHERE to get factory floormats?
- Dual Snorkel PICS????
- weird starting and idle
- How do I tell what compression I have?
- Fuel Injector Clips?
- need help with ac compressor clutch wiring
- What type of rearend spec does a '91 Z28 have?
- Ok guys.. T minus 2 and a half hours until I leave...
- Ignition BEEEEEEP and dash light problems. HELP
- dying camaro
- Anyone running long-tubes with a single exhaust?
- Need a trans. mount for a TH350, know where I can get one??
- Cam selection for L98 with LT1 intake conversion?
- battery gauge sensor
- Exhaust question...and possibly more
- Flowmaster Race muffler on 3rd gen??
- Summit TPI Cam and Lifter Kit - Any Good?
- Z28 won't start today - its raining...
- not a camaro, or even a chevy, but i need help
- 1982-1992 F-body Turbo II Wing
- Help! removing IAC
- '85 Vette with 350 TPI, I need some help!
- WILL 4th GEN EXHAUST FIT 3rd ???
- egr and smog nox
- Can someone help me decide what motor to build?
- is an l98 prom the same as an lb9 prom
- headers
- 1991 air conditioner recharge/upgrade
- Idle problem, please help!
- superram or stealthram on a 383?
- Falling on its face
- RPO codes
- Please answer my question real quick!
- Engine Shuts Off
- fixed fan issue
- low charging voltage need some ideas
- low or mid mount alt bracket?
- Need help with my 89' iroc 350 tpi
- fuel rails???
- 89 iroc 305 tpi gas milege and tank size
- DTC 32 EGR Valve
- Monster cam in L98 TPI setup?
- swapping out my 305TPI for a 383 stroker
- Are 87 IROC gauges mech.????
- Rear Disc Brakes/ Lines Frozen
- how to disable fuel pump
- plug wire question
- Identify Speed Pro Hypereutectic Pistons?
- ZZ4 lifters
- intermittant shake while accelerating
- Hard to start
- Ignition wiring need help ASAP!!!
- STUPID fuel pump question?
- help with diagnose L03 problems
- Check engine light
- Check engine light comes on
- Magnaflow 15620 on 3rd gen
- parts car
- Please Read!! Best Mods 4 my 89 camaro???
- 88 IROC 305TPI trouble code 36
- 89 Iroc-z
- Which cam will run best with stock intake
- For any of you's that don't read the loung: I am shipping out June 26
- modifying my 383..need some advice
- Mechanical VS. Electric gauges??????
- 92Z Dual Cat setup questions
- Need Help with Removing my Power Steering, Anyone??
- flywheel for gm crate motor
- Melted Connector
- IROC Question
- rear disc conversion
- Rough Idle, help
- Suspension Ideas
- cooling
- I need help!
- Vacuum Lines
- engine swap
- Can I bypass the Crankcase vent to throttle body like this??
- Problem with e-brake cables on rear-end swap.
- Scoggin Dickey Vortec crate TPI project
- which is better?
- ZZ4 1/4 times?????
- Those of you with aftermarket cams...
- 3RD gen shifter choice
- Edelbrock TPI
- Edelbrock TPI
- IROC Z song video! LOOK!!
- Cam Swap question
- Stock Front V8 Springs Needed for 91
- Can it fit
- LB9 305 cam, I know it's big, but will it fit and be safe?
- Dynomax Muffler
- can i flat out swap these parts?
- Ford Mod Motor injectors work on '88 305 TPI???
- Valve Lift Queston
- Flywheels
- front end....
- Long Tube For LT1 swap 3rd Gen
- 1986 iroc z28 cooling fan relay prob
- 1991 RS V6 to V8 Swap
- car wont move forward
- How to Remove Pick-up Coil on '89 305 TPI
- Need Help With A 83 Camaro
- Delco Bose radio
- EGR valve How do I test and Replace it L98 engine
- Replacing the fuel pump
- RCI poly racing seats
- Looks like I'm replacing the timing chain. What else should I do while I'm at it?
- This is a 92 z28 with 10K miles. Question
- 1978 350 into a 1986 z28
- Should I add more unibody support for 400H.P.
- Rough Idle. Been working on it over a year. Someone smarter than me please help!!
- New T56 retrofit Xmember to clear Hooker Longtubes
- Torque question on 87 L98!!!!!!!!!!
- Magnaflow Exhuast
- Hooker LT's. Coated or not?
