- Need serious motor advice.Plz help b4 I go nuts.
- Need Help, running REAL ROUGH!!
- changing oil pan
- Replacing a Fusible Link With a Fuse
- Transmission problem
- I'm Not Sure This is the Right Forum for this Crank Question
- need a lil help
- Carburetors and emissions.
- Engine swaps?
- Buildin a car...
- Putting in new floors
- Anyone have a detailed motor suffix list?
- 85 camaro with fresh 383 not going into closed loop
- putting together TPI for 82 Z28
- Cam & Crank Timing Question
- beehive valve springs 26918 or 26120's
- L98 Intake Leak
- I'm looking at a 3rd gen...
- more power needed
- got my Iroc running well kinda
- TPI mods, complete w/MISFIRE that WON'T QUIT!!!
- Headgasket Headache
- 87 camaro
- WTB cowl hood for bird
- Need GEN 6 DFI Tuning in New Jersey
- Ecm Or Icm Problem?
- 1989 gauge cluster into a 1990 camaro?
- tpi hogh idle problem
- Popping fuel out of carb, why?
- alternator issues
- Digital Dash question?
- need a lil math help here
- transmition issue???
- lt1 manifold vrs l98
- Just sent out an email about a camaro for sale
- ALDL OBD1 Cable - Anyone use one of these??
- Starter Solenoid -- "S" or "R"?
- Engine codes?
- Engine Hesitation after stopping - Code 44 Just Popped Up
- my new TPI crate engine is popping and wont idle
- 305 and 350 same or different knock sensors?
- Engine Hesitation after stopping - No Codes
- What gives? NO #1 terminal labled on HEI distributor cap?
- Complete torque listing for 350? This Chilton's sucks.
- Night Photos
- Tachometer Help 1988 FireBird.
- 91 RS. Engine trouble.
- Auto to manual tranny swap, possible?
- 1987 Z28 auto
- URGENT: Help to Select the RIGHT CAMSHAFT
- Manual fan switch
- Major undetaking AKA project resurrection!
- Can someone tell me what this code means
- 305 TPI or 350 TPI
- bored, reading up on 4th gens, cooling prob???
- shock time,, with slicks what do u recommend, what u runnin
- Cooling fans..
- What will this combo produce?
- Timing Chain Replacement - Oil Pan Removal
- Suggestions: Upgrading L98 Engine
- New suspension design, new exhaust fabrication pictures
- Fuel pump ?
- regaining some luster and shine????
- Oil Guage locked between 375-400
- honest opinion on body and looks of car
- hello my old friends, im back, trashing the fuel injection
- fuel pump stoped need help
- could this be a le1 car?
- Exhaust Size and Engine Temps
- Cold Air Intake
- good god
- what I would need to swap a 400 into a 87 tpi 305 car?
- need help with timing
- Starting problem?
- lt1 swap questions
- help with wiring AC delete box?
- Will I Get More H.p From Long Tube Or My Edelbrock Smog Shortys W/ Y Pipe
- harmonic balancer guestion
- Covans Classic complete dash 3rd gen
- Dashboard
- 82 camaro help!
- Just f'ing wonderful -- POS autozone tool broke in the crank.
- One Month Ago Yesterday...
- What spark plugs do I need for this engine?
- 305 tpi on a 350
- Bought crate 350, I need a timing pointer; options?
- Gears & Carrier For Car, They Fit?
- Engine rebuild kits/ 305tpi
- Carbed Engine ??s
- What You Got? Show Me.
- L98 vs LT1
- Just got 86 iroc , light yellow in color anyone know the paint code ?
- 91 z28 firing order
- post a pic
- Long Tube Headers etc...
- Comp Cams XFI268 Results
- 4th gen b pillers?
- serp belts
- Older Intake on Ceneterbolt Heads
- what needs to be done?
- what do you think of my engine?
- 1985 Corvette TPI Starter Stays On
- 1985 Corvette TPI Won't Start
- 305 tbi to 350 carb swap
- rear axle
- IROC facts/figures book
- Aftermarket Cam With Stock L98 Heads?
- 700r4 vs. 383
- My Car is in Camaro Performers
- Chevy 5.3L in 3rd gen. Has it been done?
- Mac Catback Exhaust Blowout Sale
- 91 camaro nitrous
- cold Air intake
- Drum to Disc Brakes
- New Sponsor - Fast Toys Performance
- Filling my irocs bay with an LT1
- A4 to M? in 88 camaro
- 91z stalling out
- 89 iroc with code 33
- head gasket
- Weekend Work, want input. GTA Cherry Popping.
- 87 l98 and 92 l98
- Having problems with my car starting
- Headers???
- My Cheap engine build! OPINIONS!!
- 9.5 Inch Rim width on 3rd gen??
- oil pan & timing cover ???
- L98?s
- 88 to 91 ground effects
- Need a little help Putting a carburated 350 in my 88 Firebird.
- Need Help - Oil Pan Replacement
- 87 305 camaro
- Lack of power when accelerating
- Need Help My 1991 5.7 Z28 Is Running Like Crap!!!
- How can I tell which engine is in this car?
- 1991 GTA Trans Am
- cts or tps help
- Come on 3rd gen owners, post!
- What to set timing at?
- 305 to 335 stoker is overloading help and won't start easily
- Eagle 383 rotating assembly question????
- Convert to MAF Type System
- car dies under accleration
- I need new tires
- car starts but that's it !!
- L98,s Fan Cooling System Inadaquicies!
- Fan Temp Switch to work with 180 thermostat
- wheel 3rd gen -to- 4th gen???
- turbo charger for 1988 camaro
- How to choose cam?
- guage cluster help after motor swap
- Cam lope?
- Porting an Edelbrock TPI base (pic's inside:56k warning)
- Edelbrock is officailly the only aftermarket company making a TPI base...
- new mod decision
- Shift kits?
- Car won't start
- Head CFM v valve lift question
- L98 w/ ZZ4 H.O cam
- TPIS Mini Ram WARNING!
- TPIS Mini Ram WARNING.
- Long tube header choices
- offy intake
- New Third Gen Interior Plastic
- More Swap Questions
- Enigne cranking from boot release
- Major TPI Guys Look inside!! Need Help!
- Can you get 500 rwhp from a '88 5.7 TPI?
- stealth ram for sale
- removing A/C bracket
- Egr
- cust at high rpm
- Help choosing induction for a stock bottom end.
- got mechanic?
- Third Gen Issues... WTF!
- Donuts?
- SBC Rear Main Seal Extender?
- 383 Miniram questions.....
- what makes horsepower?
- Indexing front springs..where to put them?
- Hooker Long tube headers and mini-starters?
- tpi 350 prom resources?
- Tuned port injection
- Help!
- Pics of Custom Fabbed Lower Radiator Mounts
- 1992 Firebird Odometer help?
- KYB gas-adjust to AGX? shocks/struts
- 88 305TBI No Start
- LT1 cam??
- LS2 wire harness!
- Need quick tips -- what to check on a used 3rd gen when buying?
- Valvespring recommendation?
- beehive valve spring question?
- free mods??
- not happy enough with fresh engine cam selection.
- Any idea on this
- tpi 350 what to do?
- INTAKE please help
- 454 suburban to irocz
- idle problem
- piston ring question
- what kind of cam???
- help!..removing bolt from block
- Does anyone make Mudflaps for our cars?
- Tpi And Lobe Seperation
- amazing news!!!!!!!!!!!!!!!!!
- I have a question-
- taking the steering column apart.
- having problems with 305 tpi
- 383 stroker swap?
- wiring the TCC
- If you had $3000 to spend how would you spend it?
- Christmas Present for my Dad
- 3rd Gen Exploded View Diagrams; Exist?
- Question about certain cams
- Under 1000 dollar HP gains
- tranny won't shift, WTF???
- Harmonic balancer install
- 2 Questions
- TPI build help ..
- throttle bodies?? whats best?
- vid of the new motor!!! check it.
- What do i need to do to go to a non CC carb & dist?
- Need Help! 91 Camaro RS with new 383 engine. No Injectors, No Fuel pump.
- AS&M Runners. They have arrived.... (56k warning)
- cam
- Am i missing anything?
- timing
- Why do my cooling fan wires keep frying?
- '82 pace worth anything?
- ECM/VSS troubles
- Dual Fan Set Up Question
- Any chips for a 91 tpi350??
- but its JUST a 3rd gen..
- O2 conversion
- Upper Plentnum Question
- L98 swap into 83 grand prix
- What kind of cam to buy... Please help
- Junkyard Crawl
- sbc
- Harwood 6 inch cowl hood
- 91 RX-7 vs 88 iroc
- Z28 TPI engine problem
- project hate me
- Camaro ZF? On ebay
- How Much Is It Worth 92 Z28 Convertible Heritage Edition
- CS144 alternator - what bracket ?
