- Battery???
- What is wrong??? suggestions???
- tpi zz4
- Is this a good price?
- Question on Compression
- want 91/92, 350, stick, and t-tops...
- repairing a fiberglass hood
- found a 350!
- gear suggestions
- Bad gas milage out of TBI
- APC Steering Wheels SUCK!
- more on 88 Iroc Power Adders
- The real "Fast and the Furious" F-Body's/How fast are y'all's?
- 6 Speed shift pattern logo...
- Paging ChevyKen...
- Choke Light Still on, need help
- Turn Signals/Emergency Flashers
- Requesting pic's of airbox gutting
- Sounds like a diesel
- gears!
- Labor costs?
- 305 TBI noise
- where to find?
- lt4 intake?
- 88 Iroc power adders
- What's this noise?
- need some help
- opinions on the holley systemax 425 horse system
- Simple questions
- Posi Rear
- Milodon pan fitting...
- ls1 in a third gen
- reinstalling a tpi motor ??????
- do I need limited slip additive?
- lt4 hot cam too much for stock valvetrain?
- supercharging an 87 Z
- engine ?
- Doors
- Check out my ROH Snypers!!!
- How much will it cost (est.) to switch from an auto to a 6sp tranny?
- Cowl hood
- Baffled gas tank on E-bay
- K-1 styling kits
- 90 FB 3.1L 700R4 Tranny Q
- HELP! determining ring gear size
- Gutting air box. How do I do it?
- MAF screen removal
- Pics of Irocs??
- 700r4 Question
- After how many years is a car considered a classic?
- Whats wrong w/ temp gauge
- BORG WARNER tranny any good?
- 350 slower than mine (k block???)??? please read
- Air cleaner
- problem with speedo
- For those who want 6-speeds...
- Z28.com Event
- Anybody W/ The Stock Intake From A TB 305 Car!!!!
- running rich...tryed simple stuff...need help
- Want a new hood
- exhaust
- New Rear gears
- How much canit handle
- Can the frame take it?
- 15" IROC wheels
- Are the accessory mounting holes the same on pre '87 and '87+ cyl. heads?
- Need fuel lines...
- Wheels....
- I'm glad my pop-up stopper works......
- Where can I pick up a L98 motor?
- tubular front
- somethings up with the clutch
- forged internals
- Pic of My Paxton SN-92 Supercharger
- Is a rebuild worth it
- 86 305 carb diagram
- alternator and power steering?
- accessory brackets
- 4barrel to TPI 305 conversion?
- Airaid
- car hesitates...why?!?!?
- Need a Complete Exhaust
- Finaly found out why it's been idleing funny!
- List Of Problems
- Choke light on
- Bleeder screw is leaking,Got the brake lines and all the air out but now what please
- tire ?
- Heads up on Gas Tanks for 3rd Gen F-body
- What To Switch To Rear Disk Brakes
- Cam button
- Ecm
- TPI Throttle Body
- lookin for an 86-89 Iroc Z.
- 6sp conversion kit
- Fuel pump problems
- Stock Lt-1 cam specs?
- What's wrong with my car?
- Size of TPI Throttle Body
- I need an experiened opinion
- 88 MAF 2.8 work with 85 2.8?
- New Delphi 130 amp alternator will fit on 3rd gen V8 serp accessory bracket!
- can a paxton blower made for 88-92 TPI work on an 87 TPI?
- power mirror ?s
- really nasty idle
- motor question
- major exhaust questions
- Help with rebuilding 350
- Anyone have the Jet Hot 2000 Colored header coating?
- With a carb does the stock IROC hood have the clerance to run a regular fan?
- 305 needs more power
- 383 to a T-5
- '91 wheels...
- H.O. Dual Snorkle Air Cleaner/Make it fit?
- Unicorn's Do Exist.. I guess..
- i want more power
- T56 wiring...
- Accel Super Coil TPI For Sale
- Trans help needed
- big block SS hood or IROC turbo hood?
- i need help finishing my motor swap
- cosmetic exhaust
- I got an Iroc!!!
- I need More help!!!
- Need some help with finishing off the engine in my IROC
- Be carefull!!
- Corvette Converter good Idea.
- 305 ?'s
- please help me!!!
- compression test on motor outside of car
- Questions about stock suspension layout?
- More Supercharger/Turbocharger info..
- Which carb would you use??
- Need your help!!!!
- Art Carr 700-R4 Trans-Brake. What do you know?
- Drop E.T
- 87 TPI heads, angled?
- confused
- Need guages
- Reverse Light not working Need Help
- car is whinning... HELP?
- Engine won't stay started??
- 350heads on305
- Would Suicide/Diablo Doors be an easy/cheap idea?
- What CAM to get for MAP 305TPI car
- Blown Head Gasket
- More Exhaust Questions
- tires, what will fit using 17" wheels
- High Performance Ignition Pieces
- will this work?
- Drop Spindles for 3rd generation Camaros
- Wonder about the condition of my current engine?
- 6 spd in 87 iroc
- what are some causes for ignition modules going bad?
- smelling problem
- T-5 Shifter??
- Flowmaster exhaust/ interior sound and performance?
- B&M Mega Shifter install????
- Best online store for 3rd generation parts.
- paging mrr23
- Chips and Ecm and Home Prom Burning
- Supercharged TPI 1/4 times
- Chip
- help help!!
- tps sensor
- Need some opinions on this one
- Why is a Turbo better then a Blower?
- who knows about tire sizes?
- 18" wheels? likes and don't likes?
- Tires
- Smaller Bearings????
- think i could get into the 13's??
- Bulb replacement
- motor ?
- Tremec 3550
- Rear end woes.
- show me your 4in cowl hoods
- oil pressure
- torque converters
- 1991 Rs
- 3rd gen suspension vs. 4th gen set up...which is better?
- Anyone know where I can get a T-shirt with a 3rd Gen on it?
- 4th gen rearend into 3rd-gn: Q on ride quality
- Need Help With Motor Project?
- leak down test?
- How Fast can a 3rd gen go?
- EdelbrockTPI or LT1 intake for 383...
- have a look
- valve covers
- caster/camber plates?
- Very quick question. (noob)
- Nitrous express kit or Procharger kit?
- idleing woes see also my post in wanted section
- 86 Iroc-Z
- 305 TBI 1/4 mile times? mods?!
- are firebird and camaro fenders and 1/4 panels even remotely interchangeable?
- What size tires
- No Choke Carbs?
- Need More
- fuel pump or ignition module?
- For those of you that have Keith Black pistons
- Who has a electric exhaust cut out or dump.
- Smog pump problems?
- I just need to rant about stupid designs on the third gens
- '72 - '78 305 block in a thirdgen?
- Help for a friend.
- Do you need to reprogram for a LT1 cam?
- New engine
- Do we have angle plug or straight plug heads?????
- Running on 6 cylinders
- Turbo400
- 4th gen Dash in 3rd gen
- How to take my Shifter nob off, its stuck
- Intake
- Head sizes
- Where are a few good places to buy floor pans?
- 87 Iroc-z
- What's your opinion of clear euro tail lights for third gen's?
- radiator
- 4 Fuel Injectors Offline!!! Help!!
- New to suspension work need help!!
- Synthetic or MaxLife oil
- Cam
- Mid-Lengths?
- k-members?
- EGR ?'s and Power adders
- Couple of questions
- Jet Stage 2 Chip
- How hard is it to put in a cam?!?!?!
- anyone run a CC304 in a 305?
- Tires
- Where can youC buy hip Burning Software ?
- 305 tbi/ there's hope!
- two questions....
- borge warner 9 bolt
- A serious Problem, Needs advice ASAP
- Roller cam in old style block
- fumes
- sell prices
- Weatherstripping
- Got my RS today........but
- Just Put A 670 Cfm Tb, On A Tbi Setup And Its Running Sluggish
- LT1 Guyz in here..
- Wheels, whats your favorite? opinions?
- Bosch 4+ spark plugs
- A/C Compressor Compatibility
- Cold Air Intake?
- Car Wont Start
- proper valve lash?
- Mag Articles on IROC Camaros
- The 2004 GTO link
