- 305 TPI to 327 need help!
- New rims, what the size/dimensions?
- holley 52mmX2 2bbl TBI throttle body ?
- Engine Question
- Fuel Pressure Regulator?
- Need Help Please!
- engine codes 22 & 32
- 1982 berlinetta gas leak
- lt1 cam?
- Car Not Cranking Over - New Battery, No Codes
- What should my combo be good for?
- 305 TBI swap to 350 TPI
- 1985 fuel pump relay 5.0
- annoying misfire. can anyone help?
- wiring a carburated LT1 in a 1983 camaro
- L98 355 Supercharged combo ???????
- fuel pump replacement LT-1
- Anyone use a Megasquirt fuel inj. system??
- best sound and looks for cat-back
- carb to fuel injected....
- 377 question? compression? streetable?
- NEED help choosing cam for tow truck
- Idle Help please..
- Saggy doorZ
- Good Platform
- need some HELP lt1 in 3 gen
- engine bogging when stepping on gas
- Camaro wouldn't start!
- what's the best headers???
- dual gate shifter in a 3rd gen?
- Trap door fuel pump repl. in a third gen ?
- 97 lt1 swap into thirdgen using 700r4
- 406 SLP TPI Intake questions....
- whens the best time to set rockers?
- first year for a roller cam?
- L98 Engine Problem/Question
- spacer size for 4th gen wheels
- questions about my 92 firebird
- Thermostat leak and tick/clicking noise?
- I have a ignition question for my IROC
- TV cable adjustment
- Descreened MAF today
- 1991 Z28 46k miles leaking antifreeze into the oil
- Mat Sensor
- wanna add 1.6's to my cam..whatcha think?
- Best head/cam setup
- 1983 355ci small block
- Correcting Speedometer
- 305 to 305 TPI
- wiring diagram for a 86 iroc
- 84 Z28 HO Tranny Trouble
- can a 305 be built like a 350?
- Dynoed tuned 305 TBI on the GAS
- backfire...help!
- TPI running rich
- 1989 Iroc diferent motor need help
- valve springs help
- Massive Detonation!...or something?..HELP!!!!!
- 1985 IROC z-28 "350"
- idle problem
- what is this engine?
- Need some pics of IROCs for a Kocky Shirt....
- which spark plugs & gap for my stroker?
- Cable attachd to ignition switch in '85
- Rust Around Back Window
- e3 diamond tech
- emissions bypassing???
- Power windows sooo slow
- Rear License Plate Braket Problem
- Help Needed
- What happened to thirdgen.org
- What else can I do
- chip burning
- What to do.... What to do....
- Spark Plugs
- Rings or Valve seals
- Rough Idle
- Transmission
- Vacuum diagram?
- Speedo calibration??
- 91 Z28 5 Speed G92
- what cam/head package should I get
- Charging system problem??
- Whats a good rear end?
- Over Heating and Ticking Noise
- idleing high?
- Guage mounting ideas....
- running remote solenoid
- 1986 Iroc Z question
- Need help with code
- 92 camaro rs 25th anni. parts
- 5-SPD swap on L98
- 32 code
- Starter problems
- Car overheats with a/c on.......... please help
- rebuilt/new engine wont start
- need a stronger rear
- L69 sending unit and in-tank pump help
- New Motor Swap:problems! Help!
- Who owns this S/ced Red Camaro?
- Need OE drive shaft measurement
- Installing U-joint
- Ticking noise
- New Rearend
- 92 Camaro RS help
- Got my new crate install home
- blown after ~3,000 miles!?!
- Any Suspension Experts?
- Pedal Assembly
- motor mount question?
- how to replace spark plugs in 92 camaro rs?
- t56 swap problem
- Rockers for afr 227
- Key'd Hotwire..where? for heated O2
- prom chip holder
- Coolant prob
- weird exhaust noise
- Thinking about getting "another" thirdgen
- pegged oil pressure? why?
- Starting Problems 91 L98
- Hatch Pull Down
- FE3 preformance package
- Do these headbolts go through waterjacket?
- Vortec LB9
- What heads for '87 5.7TPI?
- Smooth Bellows
- engine swap???
- Cylinder Heads?
- dart pro1's in place of edelbrock rpm heads?
- Dead
- fan temp
- Which intake and carb combo to get
- RPMS high in all gears - Idle at 6000RPM?!
- juss bought a 86 z28 carb..need HELP!!!!
- Super High Idle on Start up
- March Power & Amp Series Pulley Set, 3pc alum
- 1989 Iroc Z 5.7 Automatic
- OEM Leather seats?
- 5 speed help no reverse continued with video!
- oil pan and pump for stroker motor?
- Whats the best intake manifold??
- what is this? not normal is it?
- max power for stock TPI pump?
- Help me seal the oil leaks!
- Motor swap
- Help!!!
- brakes
- 1990 L98 hp increase?
- Front Caliper mounting bolt
- Whats the point of a V-6 Camaro?
- zf 6 speed swap
- 91 5.0L engine upgrades?
- where is the map sensor?
- Starting problems - 89 5.0 RS Manual
- I cant find a good cold air intake anywhere!!
- info about..
- Vin number help
- need guage help
- L98 in a 4th gen
- ?? about wiring a 88 camaro
- Did my hatch motor burn out?
- Need help w/ vaccum hose diagram for a 85 Camaro
- 1987 iroc needs help
- Pulley speeds
- cold stall, rough runnning
- few pic`s from memorial day
- no thirdgen.org right now?
- hey guys....
- Oil / Antifreeze Problem PLEASE HELP
- Anyone know what could cause this?
- Looking to sell 1986 z28
- junk electronic technology!
- Project: Grey Turd (pics inside)
- Need master cylinder fitting sizes
- will LS1 LM fit with 3rd gen
- burnt bands?
- Car stalls when you put it in gear!
- Got the car Dynoed today
- twin turbo question
- Power steering pump-pulley
- Anybody using ARP Perma Loc Rocker Arm Nuts?
- A/C Clutch Swap
- Mileage affecting decision
- Replaced intake gasket on LO3, now rough idle at start up??
- symtoms of heat soaked starter?
- Which car weighs more, 91 RS or 94 Z28
- gas tank sump
- 91-92 door trim
- radiator question
- Rebuild My 305 or Swap for Used 350
- there has to be a good shifter
- 3rd Gen Rear Hatch Won't Close
- 86 trying to run hot
- Gas fumes
- Antifreeze in crankcase
- Car is running too hot
- how important is the PCV oil baffle?
- 3rd gen shifter options
- oil problems
- oil problems
- Looking for 3/4 Shorty SparkPlugs?
- 1986 Camaro Z28, 400 Small Block Project
- Engine rebuilt, Mild Cam, and Headers = LOSS OF TORQUE ???
- 3rd Gen Dual Exhaust?
- Power steering pulley removal?
- 89 Iroc no power to fp or injectors
- help car dies 1st -2nd shift?
- Where does this connector go?
- my 87 irocz28
- edl tb for iroc (pn) ?
- someone help please im so annoyed!!
- tbi trouble
- 83 Trans Am
- Need TPI hex bolt in Houston
- What is my car worth?
- Pic of my IROC
- 91 Z28 Ls6
- What causes puffs of smoke on decel?
- GMMP accessory kit
- 87 2.8 to 350
- No Front headlights
- So, I just bought a 1991 Camaro. . .
- Not sure what to do....
- 2.8L v6, possible performance upgrades?
- Fuel injector question
- This is a neat reference for 3rd gen cars
- Fuel tank question
- Timing on carbed 350
- Sbc 406
- Power windows on 92Z......yep.....they died.
- 383 stroker flexplate starter issue
- top dead center...
- what do you think of this combo?
- TPI MAS to MAP conversion HELP!!
- Changing steering gear box
- will stock tach work with HEI?
- Timing
- Running Rough
- 305 TPI to 350 TPI. I need help
- 91 Z28 Ignition Module
- 1988 formula ws6 m5
- tpi idle adjustment suggestions
- Engine idle rough. Need help.
- timing problems ?
- Heater core?
- 1989 Iroc-Z
- hey to everyone
- DADDY,S GIRL my camaro is such a sweetheart
