- pricing rear end with gears
- Drop Spindles wanted--NEW or USED(1986 IROC-Z)
- clicking when attempting to start
- traction
- Entire RPM range miss (or something)
- harmonic balancer question
- 86 IROC High Idle help!
- frontbrake
- Where to Tap for TQ Converter Drain Plug (700r4)
- Tranny / Torque converter questions
- What else could be causing bad gas milage?
- 305 TPI 5 Speed Cars?
- Best places to look for a 305 or 350?
- Where does the volt guage take its reading??
- gonna beef up my 305 a bit
- Vortec heads...machine ?'s.
- Need help
- Does Anyone Have POLY/SPERICAL LCAs and PANHARD
- Car Wont Start HELP ASAP
- found the power draw in my car... need help
- not starting when heated up
- Got the Rockers, Springs, and seals! Anything else?
- Why does everything have to be so tough?
- LT1 with T-5 trans, which starter?
- Anyone Seen a 84 TA For Sale Lately??
- polishing wheels?
- timing cover for 383
- Can I remove my heater core?
- Let's Talk Coil Springs
- favorite camaro stores
- My IROC is in Speed Style & Sound
- Improve handling?
- Supercharged 383
- Adjusting IAC
- Fuse Box?
- Car dies after 5 minutes, is it the Computer??
- 91-92 dash in 86 iroc
- Ease Diagnostocs software...
- Distributor wiring order..
- Car dies in reverse
- Where can I get a fly wheel for a...
- inspection plate on T56...
- Car died in reverse, now wont start!!
- SS 10 spoke Chrome Rims...
- tach/speedo ???
- Adding HP to a T top f body, this a problem?
- Throttle Body upgrade questions
- Holley Fuel Pump??
- T-56 swap
- I need your opinions on this seat ASAP!!!!!!!!
- put my 91 SC z28 into a wall....wondering cheapest way to fix
- Tranny Help Within The Next 15 Minutes Plz!!!
- DUY LT1 intake conversion
- What wire for TACH?
- new manual transmission
- 9-bolt ratios
- Cleaning Brake Light Covers
- Weight of car
- Question for people who have done a t-56 swap.
- Engine Rebuild
- Anyone have pics of aftermarket seats?
- Dual Snorkle on TBI
- wheelbase
- Getting rid of cat
- I think I broke the hose for my new oil gauge?
- ARHG! Need some help here folks!
- 82-92 Dana 44 Wanted
- 236/242 too big for SD?
- what to do, broken wheel?
- estimated outcome against 94z28
- T56 swap kit
- Bad Distributor?
- Ram Air Pics
- Smog pump question
- IAC ?default? position?
- What's the wheelbase of a 3rd gen?
- What Blower; what Boost?
- R these guys bsing? Or do y'all think there's merit 2 the setups they tested?
- What open element to get?
- Brand new 89 Camaro Owner
- Transmission up grades
- Objects in mirrors are Mustangs
- cam select and speed density?
- MAT relocate
- Anyone know the rearend width???
- Sevice Engine Soon Light--EGR Valve?
- Operation Rally Stroker
- OK...fast and CHEAP! What do I get??
- Are stock Snorkles on TPI's restrictive???
- Just guesses would make me happy
- Cooling issues
- What kinda carb should I be looking for?
- Increase horsepower to 85/Z28
- Duel Snorkel setup?
- Where is the vats module
- options
- what color?
- Attn: Guys who converted TPI to carb. How did you do the throttle linkage?
- Gauge switch
- hooker super comp long tube headers
- Hooker Supercomp. LT Headers
- L98 questions
- Stock MAF and limitaions?
- What is IAC and how to adjust TPS
- Iroc will not idle after it's hot
- Cam installed, now car shakes
- preference and questions about eaton/auburn posi unit
- 12 bolt question
- HELP! Engine will not rev past ~ 2200 RPM...
- rear end spindel #
- rides
- 115 to 145 gauge swap
- Idling too HIGH
- 17x11 zr1s
- Z28 Gauge replacement
- different distributor?
- What could happen if i..?
- How Much to get into the 11's?
- Question about fuel pump...
- cat converters?!!
- Finally got pics up!
- Twin Turbo Set-up on 305/need help
- Manual Tranny w/ 350?
- Front Spring Replacement
- Tranny gurus inside
- Please help. Red hot primary on new motor
- 91 rs rear end question
- 4th gen wheels on 3rd gen
- lets talk cams
- ideas needed
- Using Diffrent size tires?
- LT1 or LS1 heads on ex-tpi...
- T5 trans
- Steering column loose
- rebuilding a 700r4 yourself
- shocks and struts
- 7/16'' Stud or 3/8'' Stud
- how much $ to fix this?
- 3rd gen camaro
- Objects in mirror are Mustangs
- What size bolts?
- upgrading front suspension can u help???
- Help! Code 32 & tranny shifting too high of RPM's
- Best mods for TPI 305 - whatcha guys got??
- Please help...Size of O2 sensor nut?
- anyone run a patc "raptor" converter ?
- Quick.....does a 90' TBI have just 1 O2 sensor?
- cheapest pro 5.0 shifter?
- I sure hope that 2.02 1.60's will fit in stockers
- pics of my 383...
- what size stall
- Starting problem
- Hp
- 87 Iroc
- Requesting Blue Camaro W/ Black Stripes
- engine/transmission swap advice
- want to buy a cowl 2 1/4 hood for my 92
- Block ID #'s on 305, where are they?
- tire width
- Mid 11s, what is your combo?
- My rear 4th gen conversion(Warning, Lots of pics)
- AC delete...
- gauge cluster
- cheap + Easy mods
- 87 TA for parts
- computer chips
- 95 Vette LT1 into 92 RS?!?!?
- Aluminum Driveshaft
- Center caps for 5 spokes?
- 305 horse power ?
- 85 z28
- z28 fog lamps question.
- Looking For A 92 Z
- tranny troubles
- spark plugs
- How much is a 3rd gen Formula going for?
- Victor Junior Heads
- port and polish intake
- Fuse Panel & Other Probs.
- electrical problems Help!!
- Wanting to Remove A/C and Powersteering What Alternator Bracket to use?
- A.i.r??
- Stripe kit for 1982 Camaro Berlinetta
- questions about the 84 and what i should do(i'm a newbie)
- ignition boxes
- aftermarket oil pan???
- Am I getting ripped?
- What To do Guys? Engine Is Toast. Literally.
- Rear end ?s
- Question regarding gear swaps
- exhaust ?s with lt1 and 3rd gen
- will this work?
- Ethylene Glycol VS. Dexcool
- scoggindickeytpi base
- what to use 84 or 90
- muffler!!!
- !982 Indy Pace car OWNERS
- Headers for LG4 ????
- heads and a cam
- Fuses
- Have the option to get a 350, do you think its worth it.
- 700r4 Problems
- mail slot tail pipes?
- anyone have a guess as to the power of this combo?
- rear shocks
- 350 tpi mileage???
- New chip, where's my timing at?
- Motor
- timing
- which intake ?
- LS6 into 3rd gen
- Hood for RS
- 305 TPI Hard to start and runs rough?
- Smoke on cold start?
- Buying a 3rd gen
- buying a L98
- Replacement carb for 82 camaro
- head quostion
- Alernator Belt Screaming
- Which manifold to go with. Opinions apreciated
- FS 86 Z28 in San Fran Bay Area
- Help needed. Which fuse to pull for Fuel pump (92 camaro)?
- rear end ?
- Update on Project Ugly Duckling
- whats wrong with my friends engine
- tpi on a 305?sup
- Alright 3rd Gen'ers...Help With A Carb on My 84 TA...
- Good Deal??
- Need "Driving" tips.
- Tranny Help!!
- Heads on a 305 tpi
- 1987 IROC on Ebay. But... I have a question about it..
- Show me your Wheels!
- lt1 conversion ?s
- Cable driven speedo w/ t-56
- stock guages and lt1 motor
- Knowledge Please!
- What Cars Can I Find A 9Bolt Rear???
- Help me choose springs!!
- What Damage Can a Bent Panhard Bar Cause???
- Problem's??
- heater hose question
- Big Plans, Need input
- rear latch
- Mini-Ram
- rear out of camaro possible
- Changing Speedometers?
- Winter's over soon, I need plans!
- trans am ssa???
- Mpfi
