- What exactly has to be done to do a TH350 swap from 700-R4?
- Rear offset
- Does anyone have the altitude correction table?
- What size tires should I have in the back?
- Name for the hatch back shock thingies?
- Edelbrock
- Cam size
- shifter help
- Exhaust Help
- Where's the best place to get
- Loose pedals...
- timing cause stalling??
- shorted to ground
- Tuned Port Injection
- iroc-z28 question
- Ticking Noise...Please Help.
- 305 Dyno Numbers..
- New Pics are up on my site
- radiator leaking bad!!
- Not getting fuel?
- How does one center a rear????
- Front axle nut torque specs?
- Air condition Removal?
- Charging problem
- o2 sensor too short
- Seatbelt Brackets ?
- Stock numbers for an 89 L98???
- MAT Relocater kit ?
- Interior questions
- Feed The Beast
- 85 camaro performance?
- Alternatives to Power Steering
- Hooker catback pros and cons
- How much for a Torsen?
- Need help Car keeps stalling??
- T56 Help!!!!
- Z28 Vs RS
- door rubbing fender slightly
- what's this worth? (92 heritage z28)
- Intake Recomendations!?!?
- I'm a dumbass and need help
- Couple of questions
- Back to square one
- Choke wont close/go off
- car wont start!
- 3rd gen parts for sale
- Carb Help...PLEASE
- infamous V-6 to V-8 Swap
- duration/lift of zz4
- Is my 3.08 rear end useless?
- rocker arms
- 7.5'' GM 10 bolt, ring gear bolt size?
- ZZ4 Camshaft Combination Question
- 87 v6 camaro, putting in 350 turbo tranny HELP!
- Intake for 3rg gen cars
- Injector recommendations?
- coolest wheels for the money ??
- sorry, but another heater core ??
- Need Help With Headers
- Which shifter for a T5?
- need mod recommendations for 91 Formula 350
- Gutting the Airbox, Need to mount the air sensor
- where can i find a zz4 cam?
- woo woooo
- Wiring SUCKS
- Tech question of the day
- Wheres my computer?
- T-5 grinds into reverse???
- Anyone Parting Out a Camaro...
- could someone explain...
- those with true duals...
- sagging doors and slow windows
- brake pad replacement
- 3rd gen upgrade madness
- Fuel Injector Size.....How is this figured???
- whatcha think
- Axel question? (# of splines)
- will a cam out of an lt1 fit my motor?
- where can i get the lt4 hot cam kit
- Anyone Seen a 1984 Trans AM in good condition for sale recently?
- T-5 tranny rebuild?????????
- tranny grind
- Gas Tank
- Stupid 700-R4 kickdown cable!!!!!!!!
- A jumble of questions!!
- whats everybody running at the track
- mac subframe connectors
- best cam for my 3rd gen
- disc brake to drums!
- MSD6AL mounting
- lt1 swap/ alternator issue
- will injectors from a 305tpi fit a 350tpi
- 93 octane and advancing timing
- advancing timing problems
- How can I tell what I've got
- Tranny rebuild.???? NEED HELP!
- how do you remove the IAC sensor?
- Wheels
- Porting Template
- Clutch noise
- vss wiring HELP!!!!!!
- adjusting the fuel pressure regulator
- Lt1 Swap Questions
- alternator question need some quick replys
- Wonderbar?
- 5 speed or auto.
- what type of piston are my car!
- car wants to flood out while driving!
- All show NO GO !
- timing
- one of my fans wont work!
- Whats the best exhaust system out there.?
- Will a LT1 stock cam work in a 305 V8?
- Thinking of buying an 87 GTA...
- Mods to a 92 Formula
- accel runners
- large tube runner
- thinking about changing form a 9bolt to 10bolt
- problem with bbk underdrive pulleys
- anyone put a LT1 cam in an 87 L98?
- Change from auto to manual
- stronger rearend...how's a Z06 do it?
- my car wouldnt start this morning
- interest in trading my t56 setup for an auto setup
- Might buy a 92, have some Questions
- how big of a shot can i go?
- 9 bolt
- Gas Smell
- rpo codes?????
- TPI to carb questions!
- engine swap
- lemon finder 2003
- question about posi unit
- A bad day......
- 700r4 Trouble
- FYI Large tube runners vs stock runners
- Cooling fan problem...please help!
- new springs for rear hatch
- car got read-ended this morning....
- new cam!
- More Distributor Questions
- about to install 1.6 roller rockers, what next?
- Distributor Questions
- Help!!!!!!
- Gr-2
- 87 cast iron heads flow #'s.....
- Gauge Cluster
- new ride!
- car
- 92 gta
- Looking at an '86. Few ?'s...
- I have a vibration people, HELP
- Changing A Gas Tank
- Is 3rd and 4th gen rear wheel backspacing the same?
- weld in sub frames and strut tower braces?
- Idle problems
- LCA problems
- bolt pattern on 92 camaro z28???help
- T-5 flywheel with T56???
- Can a 92 Gauge cluster and Steering column be put on an 82-90?
- fuel injectors
- plastic throw-out bering???
- Whats the best airfoil
- went to check out this 92 ws6... tips please..
- pedals for manual tranny
- buying my very first camero!
- heater problems/question
- Front drag wheel bolt pattern Question
- LT headers and 350 conversion
- Slightly sluggish acceleration
- 1990 Camaro 6-Clyinder for 500 bucks, is it worth it?
- ac delete
- Need a posi for the 10-bolt
- underdrive pulleys
- K&N with MAF Question
- Master Cylinder Options
- speed density
- finally got my T56...
- engine management question ??
- electric water pump for 89 Iroc
- tpi units
- code 22 tps
- 350ci installation?
- Has anybody ever?
- rough running
- 87 z28 turn/parking lights
- anyone running a SPECTRE open element?
- A question of money
- 2.73 gears OK with a LG4 motor?
- Will a 4th gen fuel sending unit fit in 3rd gen tank?
- LG4 owners..... Something worth checking!
- sick of being a 6
- T5 Transmission bolt up questions
- bolt on sfc
- fuel pressure??
- timing settings
- idle
- What are your recommendations
- GenIII 4.8,5.3,5.7,6.0 motor swaps
- Heater Core Question
- Aftermarket Hoods Tech Question
- car wont start after it sits for 20 minutes
- adjusting the timing
- T-Top brackets...?
- T-5 slave bleeding?
- Pilot Bearing Grease
- Throwout bearing.
- keep eating alternators ????
- New Rear........
- dom light conversion.
- Gas Tank Dilema..........
- 1987-1992 Camaro Convertible Owners
- Help a n00b out with buying a camaro
- Vapor Canister
- Turbo kit for 3rd gens
- Can anyone identify this engine?
- charcoal canister
- help! no idea what is wrong...
- Torque Thrust II
- emblems???
- Wheels
- 87 305 carb
- 383 oil pan
- Bigger Throttle Body
- 2.8 v6 to 350 v8 swap
- 5-speed shif knob size
- TB vacuum port ??'s
- LT-1 crank in L-98 TPI 350???
- 86 Z28 - Good deal?
- Newbie here, have elect. prob
- Can my motor take it?
- 3rd gen high performance and replacement body and engine parts HERE cheapest prices
- 2 to 4 bolt main conversion
- what are some signs of a 700R4 going bad?
- 350 RWHP + 20MPG combined...can it be done?
- K&N filter installation?
- Stripped Wheel Bolts
- Rear Quarter
- Which T56 to use?
- What harmonic balancer and timing chain?
- 96-00 Vortec heads good on 90 IROC-Z?
- steering column
- cleaning
- shood i sell it???
- fairly serious random problem......
- best cam and computer tuning??
- Gauges
- car idles at 500 RPM when its warm
- SBC 6.32 DFI system
- Inner Splash Guard Wheel Well needed for 91 Firebird
