- Keyless entry add on
- 91 firebird 400 project
- 81 malibu vs my 83z???
- Ignition upgrades
- 305 tbi to 350 tpi Help!
- Th200 to Th350 swap.
- Anyone using remote starter solenoid????
- 700r4 to T-56 swap
- 87 Z28 Camaro $3500 Good Price?
- stock exhaust size??
- K&N vs. paper filter on near stock enigine?
- High RPM Grinding
- Gears question
- 1990 5 spd tranny???
- Name The Problem
- long tubes headers???
- SLP runners?????
- Are Vortech heads compatible with pre 87 block?
- Bad Vibes, high speed
- 3.73 gears
- dead battery?
- What do you think of this smoke? (video)
- Why does the radiator look this bad?
- umbrella valve seal orings
- new to polishing.
- How do I make six speed trans work with my 91 speedo?
- Anyone got some pictures?
- which wheels?
- Tranny Question
- Need new stock steering wheel
- Continuing Coolant Problems
- ATTN: anyone using/may use a "PowerAid" TBI spacer
- driveshaft length th350 swap
- emissions
- Rusted undercarage??
- project 91 firebird400 get swapped to project91firebird409??
- does MSD 6al bypass ignition module???
- 4th Gen Console
- Way to test IAC valve?
- Which bilstein shocks?
- Disadvantages of 350 TPI?
- Header Install
- Can I use an LT1 starter
- what to do with 383
- jet power pulley
- Building A Bad A$$ Motor, Let me know what you think!!!
- Power door lock module....where is it?
- Smog legality of engine swaps?
- Exhaust-oil pan rubbing
- What is that big black "bulb" for under the driver's side front?
- Can I adjust idle speed?
- Cruise Control?
- borg-warner
- Best chip burner for 93 LT1 and earlier cars is?
- How Can I Display My RPO Codes
- Dumb Question
- cross fire injection, truly crap??
- Crossfire injection
- 3rd Gens w/ 4th Gen COMPLETE interior
- Emissions
- Best way to ! Knock sensor
- Car wouldn't go into overdrive, now it does
- Engine Idle Will Not Stay Constant..Up and Down...Almost Stalling
- Engine bogs and "whoosh" sound
- Need Help!
- New car...looking to modifie
- 2.8/3.1 Rejoice
- Do I need charcoal canistor???
- Who's in the 12's?
- Gen Differences?
- I expected somwhere in the range of 120HP and 250TQ
- 20" IROC Rims
- need help with emissions
- lowering springs
- I call BS from a third gen owner...
- Never ending ping
- U joints need opinion asap!!!
- rebuilding an engine for my baby, suggestions?
- Car will not start, Air bag??
- HELP Coolant Leak
- KYB Shocks
- IROC vs. Import
- 69 ZL-1 427 in 69 base camaro with spun bearing is it worth rebuilding???????
- White Smoke at Startup
- Removing cat
- Turning over 350
- spicer u joint
- oem side markers
- oem side markers
- !!HELP!! heater core box
- crap times at track
- Converting to r134a
- how tight for the oil drain plug
- What all bolts on from 4th gen to 3rd gen
- is it normal for my 700 R4 to do this
- Vortec Intakes
- Where can i ?
- Need Help Desperately!!
- quick steering wheel adapter question
- Ring and pinion carrier??
- Puzzled.....:(
- 9-bolts and slicks, any luck?
- Best place to get factory decals for 90' Formula?
- 82 or 83 Z28 Convertable,heard of it?
- Smoking under hard acceleration...
- Early shifting problem.
- LS1 Swap
- Exhaust
- Awesome Book!
- Tach question
- ok, so where is the coolant temperature sensor?
- Problems with exhaust detonation
- Seatbelt problem
- Understanding Lift Flow Figures
- Weather Stripping
- Way too much pressure/heat in gas tank
- MiniRam
- =( problems
- Possible to swap gears from 87 posi 9 bolt to 89?
- Fuel Pressure
- Looking at buying a 1991 3rd Gen Camaro
- 91 firebird 400 project help need a cam????????
- 90 FB Wierd Electrical Problem
- Rebuild 700R4 tranny?
- Alternator won't charge
- Lights, Radio, Alarm, ALL WONT WORK!!Help
- Service Light
- HELP tuning issues
- IROC-Z idles rough, stalls when hot
- Dash lights not working INST fuse
- help help help. windshield wipers!
- T-5 Labor
- Clutch Pedal
- Aftermarket Gauge Cluster
- cam vs. stall
- Tach adjustment
- 2.25" Spacers for 4th gen wheels: $100!
- name that part.
- anyone running different gears???
- do these track times seem right??
- why does only one fan work???
- porting 305 heads
- rpo codes
- Reinstalling the shifter for my 1989 Firebird automatic
- How to bore a cylinder
- Has anybody have
- Where can i get a used T-56???
- a bunch of problems
- Any '92 Z-28's in here ?
- hood insulation
- where can i go to learn about rear ends?
- 700r4 Question
- rear end is shot, what are my best options?
- help which cam guy's???
- strange hose unplugged
- Hey My 87 Z-28 Has A 335tpi Stroker
- Engine swap q's
- Simple question...
- 84 single fan car( fan intermittently dose not come on)
- Spark plugs
- Low RPM miss
- Timing on TPI
- squealing belts
- underdrive pulley for hp
- spun on the lawn
- what size stall should i get?
- electric fans on 98 degree days
- noise from #8 intake valve or???
- Why is my timeslip so lousy? Help needed.
- what parts should i scoop?
- SLP vers. AS&M runners
- old heads/intake gone, new ones ready to go...but...
- Having ALOT of trouble with vapor lock
- leak...?
- 5.0 to lt1 swap
- need help
- taking off front bumper
- Weight of a stripped down 3rd gen? (race ready)
- computer problems
- Wheel Lock
- Brake Light & Check Engine Soon Lights
- What do I do?!?!!?
- Lightbulbs for 87-89 style spoiler mounted brake light???
- motorized hatch
- MSD noise - HELP!!!!!
- ALDL and TPS problem
- swapping in a manual transmission into my auto 89 iroc
- roll cage vs sfc's
- slugish after tranny swap
- Bmr Trak Pak?
- What octane gas should I be running?
- im confused...true duals
- Trunk Dont Open
- oil pressure guage
- 350 Heads vers.305 Heads ZZ4 vers. L98
- Guage Pod For convertible
- Open Top Sites
- Power Window Motors
- Ignition module need help
- Fuel pump/pressure problem
- WTB: Badges
- v6 to v8 problem
- Running out of ideas!! :'(
- LT1 Swap won't Start
- Good place to buy rims online for a 90 Iroc-Z
- Race with '87 Iroc-Z
- O2 problem
- rebuilding a holley
- Making my Z28 faster
- Quick Alt question guys!
- Audio Wiring
- cable-x / vss wires...
- how to get a rusted out brake bleeder screw out?
- performance chip skeptics/proof
- OK to take off my cat?
- How to get dist. rotor off??
- Spend all on car, or not?
- Rebuilding a 700r4
- '83 Z28 clutch
- She's Coming Along
- ignition timing
- H-4 headlights
- Ya'll post some video's , please
- Power Window's rattle
- Do slp CAI help?
- Airfoil on L98
- Drag Wheel/Tire setup
- what are my options?!
- 85 to 87 slp cia help?
- Help!!!!!
- pulleys and high watt stereo
- Stock hp for 87 Trans Am?
- older camaro guy needs rear help
- older z28 guy needs help
- How do i found out if its 5.0 or 5.7
- Polishing a Stealth Ram
- V8 Swap into V6 Camaro
- LT1 or Stealth Ram?
- GMPP TBI Intake Manifold Vs Edelbrock Performer RPM?
- Water pump = overheating
- Do I need Bigger Injectors?
- towing question
- C5 front brakes on a thirdgen
- 350 to 383 streetability
- pictures of slp 85 to 87 cold air
- good or bad idea
- Swapping PBR rear disc system to 87 non pbr 9 bolt
- Cheap Easy Mods? IROC
- Lunati or someone else???
- New Mach 1 in Neighborhood
