- Any interest in 3rd gen turbo kits?
- crate engine companies that build SPECIFICALLY for the TPI?
- 85 Iroc-z engine upgrade lots of ?
- eradic idle and missing through out gears
- Vss question?
- 327 tpi
- 305 TPI to 383 stroker carbed
- Hood Clearences with Victor Jr. intake
- Finally, gears for 9 bolt L98 cars
- Technical Auto Parts Swap Meet Part Question
- 1994 work truck 350 TBI, STUMPED,
- octance recommended for 12:1 compression 357ci sbc
- 89 IROC L98 wont start cold
- Where to find Hooker Headers?
- Code 45 running rich
- 1985 camaro Z28 Finnally got codes
- Help me ??
- Electric fan problem
- Backfires......
- 1985 Camaro Z28 5.0 TPI stalling/cuts out
- Engine that hasn't been turned on in 2 years...
- Timing on a 92 L98 at altitude?
- 87 z28
- 10 bolt strength->98Z28
- Trying something New
- Quick Question
- Recommendations to increase HP?
- 92 Z28 issue
- Any new best ET's this fall?
- 86 ta 305
- Question about engines
- what are the stock injecters for 1986 z28
- 91 rs
- Horsepower rating
- Tpi and tbi serpentine
- cheap solution on the t-56 electric to cable speedo?
- Running Hot Issues...
- an ls1 /t56 swap
- cost of a t56 swap
- trans swap
- new swap? Had an idea.....
- Finally finished carb swap
- Value of 1986 Z28
- TPI or Carb?
- 1985 TPI IROC issues...
- post pics of Lt1 Conversions
- Lt1 intake on L98
- Timing cover help..
- Golen Engine 450 HP TPI: Streetability?
- TPI or LT1 for 67 Camaro?
- Notice: Installing SLP runners. They don't work with Edelbrock intakes
- Help Adjusting TV Cable
- Won't start hot
- Custom large tube MAF sensor for TPI
- Need 87 Z28 305 Vacuum Diagram
- 1987 z28
- 89 RS Restore & Mod
- drivers door problem
- 1988 Firebird fuel system help?
- 383, AFR heads, HSR, BRE cam dyno'd
- Fuel delivery
- Vibration over 3000 rpm
- 305 tbi with 350 crate low on power
- Fuel injector clip
- Carb & Timing issues
- Under drive pulleys
- Crate Engine Repl for L98
- wierd tranny problem. maybe im losing my mind
- paint and style
- prompaq?
- BBK TPI intake
- Smog Equipment & Years ?
- An LSX 427, for my 86
- somebody explain torque converters to me.
- Im new and need help
- 1984 camaro rear end
- z
- Does this Granatelli MAF for TPI adjust A/F mixture
- Are they temp security to that prevent starter to go ?
- Are they temp security ignition ?
- Vortec TPI to carb. set up ideas
- what's the best HP combo for a 350
- Wicked Electrical Short
- 1982 Camaro Z28 CFI Engine Swap
- Voltage gauge problem?
- 92 Z stalls out
- Door handle nightmare
- What holds the 305 back!
- 92 Z28
- Just bought 86 z/28, problems?
- Long headers
- Door hinge correction feasability ?
- steering column help
- Exhaust issues
- 3rd gen with bad gas mileage.
- Decisions?
- 1LE or not?
- Car Wont Start Or Crank
- Looking for the right exhuast
- looking to sell 1986 z28
- what is my car worth? 1992 350 G92
- knocking when turning?
- 91 Z28 Overheating...
- Starter to change ? and other problems
- My new 92 camaro
- camaro thats afraid of the rain?????
- Own a 3rd gen again. 91 RS w/ 305 looking for some help.
- 1988 305 tpi slow to idle down problem
- Talk me out of DD'ing a low mile 3rd gen
- 305 stroker
- Looking for L98 Replacement
- 700R4 speedo gear?
- Heads Too Big?
- 700R4 won't downsift but upshifts HARD into 2nd.
- digital dash
- tranny shift points off
- 1991 bandit II
- Source for replacement parts?
- 91 Z28 Problems, running rough.
- What should my redline be?
- erratic idle
- 89 Iroc running rough
- Trying to locate strange oil leak?
- 84 z28 oil pan leak
- temp gauge 86 z28
- drivers door handle 86 camaro
- What the hell happend?? I thought I would never be in this forum
- I'm Back and w/ Dyno results!
- Need Help!!!!!!!!!
- 52mm t-body or something similer
- Low Compression Issues
- Please can you help me?
- SLP runners
- adjusting the tv cable
- Hello all!
- 1991 Z28 Camaro Owner
- Great Motor Combo?
- changing tranny mount
- New Here
- tire pressure
- Need reliable 3rd gen in Chicago area.
- Cooling Fan
- Lift limit on factory rollers.
- New To Muscle Cars. Need Engine Help!
- cold air intake
- Cold air Intake for 91?
- Borla exhuast and electric cutout?
- Show me what you got REVISITED
- Stephanie's getting a makeover...help please
- TPI timing or TPS adjustment question....
- 305 tbi to 305 tpi question
- stalling problems
- Fans not running...
- 89 TPI water pump, long or short?
- Has anyone fixed a code 43?
- wiring info needed
- Axles for my 84
- coolant temperature sending unit
- Removing The Thermostat: 305 V8
- pain in my a$$ a.i.r tubes
- vacuum diagram
- Driver side clearance issue.
- A.I.R tubes question,,
- lt1 swap ?
- removing the oil pump shaft?
- Here goes Nothing,, PRAY FOR ME
- accessory mounts
- Problem when going full throttle
- need advice please
- External Fuel pump location help!!
- My 383 stealth ram build
- anybody wanna help me spend my money!!!!!
- any advice??
- Do factory runner bolts fit SLP runners?
- Hi rpm stumble
- school bus turbo?
- i have a 89 z28 it wont start when its cold out side
- Educate Me
- Cam ? for TPI
- should i buy this car?
- vibration help??!!
- posi question
- Idle mysteriously at random revs over 7000rpm when braking
- 1992 Camaro RS 305 TBI Cheap Mods that add performance?
- Giving away 82-92 light saddle headliner t-top cut out
- I need help with getting my 1988 tpi TA to run into the 8"s in 8th mile ?
- cylinder head opinion
- some questions about headers
- Losing oil pressure under a load
- Help!
- 84 Z28 timing trouble about to set it on fire!
- tach peged
- no acceleration?????
- engine stumbles
- carpet install
- piston trouble
- 52mm TPI throttle body
- Just wondering?
- long tubes and a complete dual?
- cant find this part anywhere
- how to get correct speedo reading
- Any Body Have An Engine Simulator??!!
- Loud mouth fitment?
- Cold Air for TPI
- Motor mount shot?
- HELP My 84 Z28 WONT START!!!
- 87 t/a motor
- Engine for sale 85, 305 TPI
- Fiberglass conversion
- S & W Race Cars Sub-Frame connectors?
- '89 IROC will not idle
- lt1 in 3rd gen
- weld Drag lite
- Mystery Eibach Springs
- im trying to twin turbo an 86 camaro
- Converting To 383 Need Ecm Help
- weatherstip kits?
- Dyno Tuner in California????
- Engines
- drivers side gfx bracket
- Routed my LT1 ECM harness behind my 3rd gen dash
- Any 3rd gen starters interchange?
- Are these heads any good?
- Hood question
- Blower Motor Plastic Housing Removal??
- Headers?
- Bought a 85 Z/28, need info.
- Newb
- Modding my 83 305 with CompCam & kit
- Lt1 Swap Throttle Cable Question!!!!
- 350cid distributer help
- springing leaks everywhere..why?
- Cheap Performance Mods
- New
- I need some insight with a cam for my 305
- supercharged 305tbi
- Digital Gauges??
- Lt1 Conversion Into 87' Z-28 Wiring Help Needed!!!!
- SBC with geardrive
- Big Block Street Project
- ESC (Electronic spark module) 305 to 383?
- 92 Rs 3.1 V6
- about to buy a RS
- My 5.7 Just Barely Failed Inspection!! DAMN!!
- Oxygen sensor Q: How far from head??
- 195CC AFR's vs 195CC TFS vs 113's.
- Starter problem or Flywheel problem or what?
- problems need help please
- Engine Swap 305 TPI to 327
