- headed to the track mid to high 13's
- How to tell if i have a drop or not
- Track results with 150 shot/ET streets/Converter Lockup.
- what do LCA relocation brakets do?
- Supercharger Problem
- Advice on Speed density car
- Idle Problems
- 383 and t56
- can't get steering wheel off
- It keeps stalling...some help...
- Overheating Issue
- A/C delete Pulley
- What's up with my idle?
- Keyless Entry car owners - inside!
- bent pushrods
- Dyno Tuneing 2 completed
- wont start with est bypass connected?!?
- what timing set
- 6spd swap in progress! Questions inside
- Any way to put ground effects or a different front lip on a 1986 V6 camaro??
- 12's or out it comes!
- Do 4th gen seats bolt right up on a 3rd gen?
- Crazy image request for you 3rd Gen guys...
- Front panels missaligned.
- Throttle sticks, only when car on
- I need to rotate my tires, I have diffrent sizes front &rear how should I do it?
- where to buy accel shorty plugs?
- 350 Question
- i need help badddddddd
- Which one
- 355 engine question!?!?!?!?!
- driver side mirror
- Still having an alternator prob..Help~!~
- VSS and buffer box????????
- junkyard trip
- Spark Plug decision
- Design full EFI system for my carbed race motor
- How much of a gain?
- what motor mounts for my 1986 LT1 swap?
- can i use LT1 rods?
- 305 heads vs 350 heads
- My Car wont start
- Rear Gear--> Speedo
- Hatch Motor ???
- Small yellow light under heater vents??
- Electrical Problem>>Parking lights
- Will 4th gen carrier work in a 3rd gen car?
- rev problem
- rev problem
- RE:LT1 4th Gen VS L98 3rd Gen
- computer codes
- 2.73 Disc Posi Rear
- Getting Paint Of The Front Bumper!
- Just bought a car, differential died 8 hrs later
- Ticking?
- Can forged pistons be milled to lower compression?
- How can you find out what size swaybar is in a 3'rd gen.
- iroc-z model
- Tps Adjustment and picking up some extra throttle
- Beefing up the 10-bolt
- Energy Suspenion HyperFlex Kit
- Whats the best...
- Break Fluid Leak
- Comparison and Opinion Time...
- 1990 irocz 305 ci
- '89 IROC backend higher than '92 RS> Spring Rates?
- engine swap questions???
- Antenna Motor
- Shocks/Struts ???
- 89 305 vortech
- Can anyone help with a 1983 Caprice?
- Readjusting Shift Points and Tach
- right cooling fan always on.
- trying to pick up free HP will this work???
- lod slam noise
- temperature sensor wtf
- Speed Sensor Hell
- WOW, talk about a better idle
- Dyno Tuneing 1 results
- Stupid Question
- Oil In Throttle Body And Plenum ???
- Cleaning up the Engine Bay
- Backfiring
- gauges
- Discs on Drum 10-bolt
- Changing out differential for earlier 3rd Gen disc brake rear
- Deciding on an engine combo, needs power estimates....
- What year did third gens switch to R-134a?
- 18 or 20" Irocs
- 396 out of an L98?
- daily burnout
- V6 - V8 Swap. Listen Up Boys
- Does anyone know about the Secondary Air Injection bypass valve??
- free 5.0 TPI long block Dallas area
- LT4 hotcam in 305 TPI
- Ecm Grounds/ignition Switch
- TPI TA having trouble starting
- Brake vacume...etc
- A/C and SMOG pump DELETE PULLEYS
- Is this cam too big
- storage for winter
- 305 smog pump removal
- Vibration at 3500 rpm
- Tpi?
- 84 Clutch Slave alternatives?
- wiring/ignition problem
- Interesting analysis of my car smoking when starting up
- Problems when starting up
- LT1 intake swap maybe?
- t5/wc ?'s
- Update
- Taking door panels apart
- L98 Underrated?
- How much horsepower???
- 2.8 liter/5 speed guys,need clutch opinions
- Fitting Zr1's on a 3rd gen...3 questions??
- Rear Spacers for 4th Gen Rims???
- how do i bleed the brakes?
- 305 tpi to 350 tpi swap
- Smokin on start up.
- Any one place a lt1 cam in a early flat tappet block.
- This is why i hate gm HIGH TECH MAG
- removing alternator
- Grand Caravan
- front wheels hitting inner guards
- fuel gauge issues, help
- Beretta bumper on an Iroc ???
- msd ignition ? on 92 tbi
- idle problems
- Idle problems!!
- What other cars use same rear end as 1983?
- power brake booster
- Pass Key Ii......
- Replacing steering column, questions...
- Where can I get a carsound/magnaflow cat???
- Overheating?
- need history help!
- Just installed new TPS
- Gutting Cat???
- strange camaro/ fuel pump woes
- Going back and forth..sell or keep..KEEP, but need advice!
- Is this cam overkill in a 85 l98
- Home made SFC´s ???
- TPI experts inside
- misfire please help
- People with aftermarket seats-inside-
- 1984 305 longtube headers with emission fittings???
- edelbrock headers
- Its got me thinking
- paint codes
- purchased new mod anybody familiar?
- Water Pump Cost?
- 92 B4C and 1LE package?
- Upgrading rear-end
- code 36 and 44.. help
- How Much Do Trannys Run For?
- License Plate Light
- motor building questions
- You wanna LS1 swao in your 3rd?
- Stupid Question
- Good Prices?
- dissapointed with dyno readings :(
- What Y'all Think?
- Is this a bunch of Bull SH*T ??
- Synthetic Oil
- How about this?
- 86 Camaro - 26 spline rear?
- leave the 305 tpi alone
- Seat Belt
- hood pins only?
- my car is stalling out...
- hot start problem
- have some more for you
- Wheels....and pictures
- What intake should i get????
- What is the piston ring land?
- Installing Power Steering Pump Pulley?
- really pesky idle misfire
- Wanted! Info on porting TPI System
- how do i change the fuel pump in '87 V6
- TBI to Carb
- value of TPI system from 87z28
- 5 speed must go...parts for sale
- DJ Haf
- Need Help!
- berlinetta specific suspension
- MARC 85Z28 Where are you?
- how far could i take my 305
- t-56 install
- 350 turbo in a 3rd gen
- I found a leak but dont know what it is!!!!!!!!!
- check out my mod plans
- 32lb injectors to big ?
- GMMG exhaust GP anyone?
- LT1 4th Gen VS L98 3rd Gen
- *OFFICIAL* LT1 Brakes on a 9-Bolt
- Fan switch
- Engine Removal
- Fuel, I think.
- Odd "ticking" noise at super low speed
- Stock TPI = 4500 Holley SR = ?????
- Fuel Filter???
- Cigarette Lighter
- Blue Smoke at Start
- Transmission Question...
- i need help with a big decision
- think about becoming lordmetalz28-gta
- Suggestions for a new timing chain
- What kind of engine...
- beep beep-horn doesnt work
- Anyone running the 84-92 Borla system?
- What brand of Tires do you guys drive ?
- Found New Block Numbers
- door slam
- Fuel Injection Questions
- Hedman Long Tube Spark Plug Problems
- turbo 350 swap
- 12 bolt into a 90 iroc ?
- 305 TPI into 78 truck
- Does anyone need this?
- Cost of machine worK
- block learn numbers?
- Injectors and fuel pressure
- 85 l98 300hp ????
- L69 to 400SB swap
- cutout question
- PCMforless
- about to embark on repair for 1st time,need pointers
- electric exhaust cut out
- 4th gen to 3rd gen wheels
- Engine knock after changing to open element air filter
- Corvette Rims fitting 1991 RS
- It's track time!
- would anyone track it...
- AFR 195 heads...what do you think of them?
- Is there a fuse for cruise control?
- Going to carb
- 305 tpi to 350 tpi ?
- transmission swaps
- Setting the timing.
- help me clean her up
- strange bogging
- Dyno Run
- Vortec 350 swap
- B4C Car?
- 3rd gen for sale locally
- My car is jacked??
- Good exhaust combo?
- rear defroster
- Best mods to start out with
