PDA
View Full Version : 3rd Gen / L98 Engine Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 [26] 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49
  1. What would you guess my hp is?
  2. 89 Camaro FREE!
  3. Adjusting "TV Cable"
  4. Oil On Spark Plug 1 and 2
  5. easily accessible exterior transmission filter?
  6. learned something about cam timing
  7. stall converter 700r4
  8. SHOULD I SELL MY 4th gen for 3rd
  9. ! 9th fuel injector
  10. Chirping sound from valve covers
  11. Converting TBI to TPI
  12. Cylinder Head/Intake/Injector/Cam matching
  13. coolent burning
  14. how to stud tires
  15. regearing my blown rear
  16. aluminum underdrive a/c delete pulley???
  17. Still...
  18. Tripometer Stopped Working
  19. 383 lifespan?????
  20. Year One
  21. which head gasket for vortec heads?
  22. do I need the O2 sensor thats in the manifold
  23. How To Tell If You Have An Exaust Leaak?
  24. Interior Ideas
  25. Sounds Like Metal Touching...
  26. inline fuel pump
  27. Spinning a 383
  28. 1987+--> ALL SBC's Hydraulic Roller?
  29. Exhaust Question, want your opinion
  30. rocker arms breaking
  31. Books On Camaro's/ TPI's
  32. Ran my 1988 Formy in the 1/8th tonight, check my results...
  33. Brake Line HELL
  34. baer touring kit?
  35. cold start hesitation
  36. Q about bumper cover
  37. Still working on the brakes - caliper question
  38. who would win?modded 3rd tpi vs. modded mustang
  39. Ebay Ram Air Boxes??
  40. Help!!!
  41. What's the deal with the 3rd Gen?
  42. Flowmaster- Good or Bad?
  43. Stock dyno numbers are finally in....
  44. Comp 983 springs---Worth it?
  45. LT4 hotcam or CC304 in 305TPI?
  46. Which Helms manual?
  47. Will these Vortec heads work?
  48. Iroc-z ??
  49. electrical issue
  50. window motor?
  51. Will the flowmaster 80 series muffler work with my Camaro?
  52. Slow Car!
  53. charging??? voltage gauge???
  54. Lg4 Power????!!?
  55. One cause for flooding TPI
  56. Getting L98 heads ready for Hotcam
  57. has anyone used these roller rockers?
  58. Sound Problem
  59. Hatch Pull Down Unit
  60. PST products
  61. Striped stud on back wheel
  62. Low rear gears stress drivetrain more?
  63. What makes the tranny fluid flow???
  64. Swapping out my TBI for a TPI, what's involved?
  65. transmission swap
  66. more power for my car
  67. What do you..
  68. Drive shaft help
  69. Code 12??
  70. 84 Camaro parting out
  71. rear shocks.
  72. Please help...I'm lost
  73. Need a solid solution....
  74. Spark Plug Suggestions?
  75. Tilt Steering slop
  76. Someone tried to steal my car questions about repair.
  77. Friend is selling iroc
  78. knocking 40 psi of fuel pressure to 7
  79. Anyone ever switch over to Fuel Injection???
  80. Give me Idea's for Future Mods
  81. Starters
  82. Fuel Pressure
  83. Electric turbo/supercharger?????
  84. header ?
  85. Installing Z-28 High Rise Spoiler
  86. Help Choosing Oil Additive
  87. Head options...
  88. What do ya think of TPIS cams?
  89. My first Camaro!
  90. canfield 195's
  91. getting the comp to show any codes
  92. remote starters/alarms/2 way car pagers/window roll up/keyless
  93. opinions on my engine
  94. Specs on a 3rd Gen
  95. Air Foil Question...
  96. Deal on a longblock
  97. 8pt Roll Bars? HeLp
  98. synthetic blend switch
  99. Drive shaft help ASAP
  100. Does that Mr. Clean Autro Dry car cleaner really work?
  101. All 88 GTA's have VATS?
  102. TPI sensors
  103. how does a converted LT1 intake with Dart's compare to stock LT1 motor???
  104. Car Broken Down!
  105. Help
  106. drive shaft and Y pipe
  107. What would it take for my LB9 to get into the 13's?
  108. question, please help
  109. Ported Stock L98 Heads: Quality and Price
  110. How many driving miles do Nitto 555r's last?
  111. anyone try to refinish rims?
  112. Headman Headers?
  113. Update on brakes - Im screwed
  114. Wiring CD Player
  115. Moderatorts please help
  116. hatch pulldown
  117. How much did it cost to build your motor?
  118. trans problems
  119. what do yall think about this setup?
  120. got my new heart for my 88
  121. 1991 Camaro z28 350 v-8 5.7 with only 13,000 orginal miles
  122. Stock bottom end goes 11.6's NA
  123. need help with new motor 86 TA
  124. LT1 Swap into my 84 TA.....Questions for those whove done it or know bout it...
  125. 250hp 305 Can it be done?
  126. RPMS drop when giving gas
  127. Compression ratio & cyl head cc
  128. shavin the handles?
  129. Speedo Blowout picture
  130. mid range sputter...
  131. What size injectors?
  132. everybody says to do it but how hard is it really?
  133. Rearend Gears
  134. Which Fuel pump?
  135. New Camaro Owner needs some ?'s answered
  136. Trans-Go shift kit, StageII anyone?
  137. '84 v8 305 5 spd
  138. GMMG exhaust anyone?
  139. Ignition Upgrade
  140. what spare tire?
  141. should I put a cam in...
  142. help with Torque Arm
  143. Removing Shifter assembly
  144. T5 to T56 swap in an 87 IROC
  145. Can you get paint codes from the VIN?
  146. 14.8X on stock LB9(almost)
  147. Is speed density worth it?
  148. Fan will not come on and overheating
  149. I need a door hinge
  150. Put on new carb = OMG
  151. roller lifters from summit in lg4
  152. Car Shut Off And Wont Start!!!
  153. 2000 s-10 wheel offset
  154. lets see whos lighter the Firebird or Camaro
  155. Might be getting an LT1!!!
  156. Crankshaft Problems
  157. Check this out!
  158. New Question on my 87 gta
  159. FIREBIRD RADIO POD, ALL THE SAME??
  160. 88 Iroc Convertible Detuned????
  161. I PROMISED!!! true dual pics
  162. 4th gen to 3rd gen radio swap
  163. AFPR going in, question about fuel pressure
  164. no speedometer
  165. Taking Out Shift Kit
  166. question about leavin in computer
  167. whats a 305 bird run??
  168. Somebody Hit My Car!!!
  169. Which Torque Converter?
  170. Brake noise - videos
  171. anyone have pics of a 92 bird interior
  172. What type of oil?
  173. congrats to roy!
  174. Alternate ways to hold up hatch
  175. Wells MAF ?
  176. 1985 IROC for $500.00
  177. Which cam on '83 305?
  178. Is it possible? True duel exhaust?
  179. Need Exhaust Ideas...
  180. Stumbling In D
  181. Idle drops when in gear and stopped
  182. HELP!!! Holley Stealth Ram Questions!!!
  183. Odd, gauge reads 10v, voltmeter reads 13
  184. kill!!!
  185. Need opinions ASAP!!
  186. Noise from under the hood
  187. What should the stock oil gauge read at idle?
  188. What is the difference between ECM's with AXKW and AXKT?
  189. My turbo 3rd gen to look at...Forsale also
  190. tranny problems please help
  191. Help!!!car Wont Start
  192. How to drop tenths....fast and easy.
  193. broken transmission mount ?????????
  194. IAC Sticking?
  195. Can you put Vortech heads on a 305?
  196. Somebody Buy This Now
  197. Does anybody know the average gas mileage for a 305 (H)?
  198. torque converter
  199. is this true?
  200. What would you do?
  201. Movies IROCs have been in?
  202. difference in sound from rod knock and detonation?
  203. the 82 Pace in to the Garage
  204. converting to a roller
  205. best shifter for a T5?
  206. What should I get 3rd Gen or 4th Gen?
  207. Oil & Temp Gauge Dont Werk
  208. Shifter Assembly...
  209. Best camshaft without tuning..
  210. help with power door locks
  211. Is it possible to put an LS6 in a 3rd Gen?
  212. 3rd gen stock items
  213. Msd 6al
  214. 1984 lg4 cam swap
  215. 3rd gen, want to make it look like a 2nd or 1st gen
  216. Borrowing one of your V8's for a conversion
  217. Rear Brake Lights in Spoiler All Out
  218. super charge of turbo
  219. Car dies when put in gear
  220. How big can i go for tires on my Z?
  221. Trunk panel
  222. Painting Intake bad?
  223. 4th guts into 3rd body....
  224. Which setup would be faster?
  225. What ECM in LT1 swap...
  226. vette servo and .500 boost valve questions
  227. which tranny mount
  228. Need help with VSS on my gta
  229. Fan Switch and Thermostat
  230. trans swap
  231. fuel gauge
  232. mileage question..
  233. Towbar W/ An '86 Iroc?
  234. could i shrink wrap my car up for winter to keep it dry outside?
  235. Electric fan
  236. Braking Upgrades
  237. Runs better when MAF Disconnected..
  238. walkthroughs or instructions?
  239. Hesitates when I punch it
  240. dj haf and other L98s: what mods?
  241. Choke light always on
  242. Emissions Options
  243. Trying to Replace Power window Motor
  244. L98 dyno sheet
  245. AHH! Banging noise comming from the iroc
  246. Do you think they will bring back the camaro?
  247. Hesitation
  248. 86' camaro z28
  249. '85 Drop Top Z...rare???
  250. TPI to Carb
