PDA
View Full Version : 3rd Gen / L98 Engine Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 [25] 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49
  1. Buyin a 3rd gen
  2. carb to TPI
  3. guage problem
  4. TPI on Vortec 350
  5. 88 fuel management
  6. new 3rdgen in my future
  7. Hi im new here too hello!!!!
  8. 89-92 camaro engine
  9. Fuel Injectors
  10. my LG4 is comming along :)
  11. Vaccum leak or distributor?
  12. Problem with my L69
  13. headers
  14. New Heads/Cam Time...Need Advice!
  15. Looking to build a sweet stroker but need some help
  16. Reccommended AFPR
  17. Going From TPI to Carb. Need Help
  18. oil pressure fuel cut off switch
  19. 1989 Camaro Project
  20. Wide Tires
  21. 305 to 350 swap.. what do I need?
  22. Auto trans dipstick
  23. Nelson Racing uses HSR
  24. exhaust
  25. 9 bolt, how much power can it take?
  26. Intstall HSR intake
  27. Hi Im New Here
  28. Hurst Shifter Install?
  29. Paint and Prep Help
  30. 406TPI whats in voled and how much power now muchcost ect????
  31. Timming, help!
  32. Factory Fuel Pressure
  33. New Monte Carlo SS's remind me of 3rd gens
  34. No keys...need to get out of park
  35. oil pressure
  36. anyone ever try to make their own fiberglass(or other material) parts. like spoilers
  37. Gears
  38. 92 camaro project
  39. third gen rack
  40. TH2004R info
  41. Project T/A: It started!
  42. 12 bolt
  43. started my page
  44. Will I need spacers for 17in wheels?
  45. Posi from 83 rear to 87 rear?
  46. Project T/A: Cleaning the fuel tank.
  47. what does it take to get the carpet out
  48. Will I need?
  49. Pro Topline/Pro Action Heads
  50. Wife killed my car
  51. Wow
  52. 3 wire o2 sensor, what kind?
  53. Whatcha guys think about the GMPP Deluxe 350 HO crate?
  54. a/c deletion
  55. Need opinions/advice...please!
  56. fuel line
  57. ss or no?
  58. Hedman LT Question
  59. why do the lowering kits always lower the front more then the rear?
  60. Help!! Glowing Header Tube
  61. holley stealth ram vs. mini ram
  62. how much can a 700R4 handle?
  63. My IROC has a problem.
  64. Holley Stealth Ram
  65. L03, LB9, L98 intake questions
  66. V6 to TPI 350 swap
  67. sluggish ??
  68. Shocks or Struts???
  69. mojave green converters??
  70. Water Temp Sending Unit
  71. Removal of Charcoal Canister
  72. antifreeze aditive tablets???
  73. Do the 6 cylinder Gen 3s have same rearend as 8s?
  74. Oil pressure sending unit
  75. Long tube, 6-speed guys look in here
  76. My Project T/A
  77. y pipe help
  78. I need Help Please?!?!
  79. I Need Help?!?!
  80. syno results from HSR swap
  81. subframe connectors question?
  82. OFF BaLaNcE
  83. Engine Mounts Do Not Fit
  84. Well they brooke into my car
  85. Spintech sound clip
  86. Fix your door hinges!
  87. what year did TPI come in vettes?
  88. Ahahahahaha
  89. Cat Price: How possible?
  90. 1992 Camaro Z28 Tpi, Mods???
  91. 383 Horsepower Estimates
  92. Mobile Syn. Blend
  93. water temperature sending unit part number PLEASE
  94. Header Size
  95. I finally got my 383 home guys with big cams in here
  96. Wheel spacers for 17 inchers
  97. black charcoal canister
  98. My Hatch motor....ARGGH!
  99. Which headers to get for an LT1 going into my thirdgen?
  100. LT1 Cam swap and porting Questions!!!Need HELP!
  101. Hyper Pistons
  102. 92 Rs ???
  103. Car runnin Rich
  104. Wheel offsets?
  105. what next
  106. 160mph guage cluster?
  107. how not to get your radio locked out
  108. Where does one get an IAC adapter for the TPI throttle body?
  109. Code 15, doesnt rev past 2200rpms
  110. My brakes are bad...
  111. custom exhaust
  112. i hate my cuz
  113. New rims, any performance difference?
  114. RIP to my L98
  115. OEM V8 radiator part #?
  116. 1992 Camaro Transmission/clutch problem
  117. L98 + bolt-ons = 12.80's!!!
  118. Urgent Question
  119. Header Wrap
  120. still veering right after alignment?
  121. spindles
  122. 180cc heads on a 355
  123. 305 Tpi
  124. K-member help
  125. Lowering
  126. mechanical (non electric) remot operated cutout
  127. LED Lights vs. Bulbs for instrument Panel
  128. lt1 swap..
  129. Need opinions....please help.
  130. ok this TBI = No performance
  131. hey guy's
  132. LT1 or L98
  133. Water Pump - what to go with??
  134. How to internally balance a rotating assembly
  135. How much power can a performer intake make?
  136. Picked up an '87 IROC-Z with an L98 today.
  137. 13yr old stock springs
  138. electric water pump on the street?
  139. hydrolic clutch help
  140. Car starts then dies help!
  141. '96chevy 1500 350 engine question
  142. 500 hp @ 6500rpm, 350 lb-ft at 2000rpm
  143. wheel squeaking
  144. Fuel Pump Help
  145. People with subs in the hatch
  146. Ordered myself some Christmas presents...
  147. Looking for Y-pipe for my Hooker LT's
  148. Do you guys have manual fan switches???
  149. Pro Toplines non-centerbolt?
  150. Overlap and optimal cylinder head flow range
  151. no heat in my LT1 powered Z, hellllp!
  152. Found a 92 Z28 5.7
  153. Modifying the Mass Airflow Sensor
  154. parts
  155. Braided Fuel Lines???
  156. Automatic vs. Manual. = Reduced HP?
  157. Which ECm is the one for SD?
  158. guys that have done a TPI to carb swap in here
  159. Anyone running ZZ4 + TPI?
  160. Underdrive pulleys
  161. any seggestions?
  162. cutting/connecting fuel line
  163. 89 RS Ignition Problems?
  164. t5 flywheel ?'s
  165. Problem with IROC rear. Can Someone Help?
  166. Holley TBI
  167. Looking to build fast 350TPI, any suggestions??
  168. What are the symptoms of a miss?
  169. 400 BB in 3rd gen
  170. Gauges
  171. Mech. Fuel Pump
  172. retro fit hyd. lifters for 87+ sbc
  173. Can a hydraulic roller be used with flat tappet lifters??
  174. TPI to Carb swap, fuel pump?
  175. '87 Tranny Q need help
  176. Ricer's got ahold of a 3rd Gen...
  177. Y-pipe manufactured for hedman long tube headers?
  178. OH NO! Car died on me! Need some help
  179. Adding functional Ram Air to the ASCD SS hood
  180. 87 Stang GT vs 89 Formula WS6
  181. anyone with an ASCD SS hood...
  182. High or standard pressure fuel pump?
  183. LT1 cam in an L98
  184. why are sparks created when the battery is reconnected on a car
  185. 4th gen brakes on a 3rd gen
  186. ZZ4, lt-4 hot cam users help
  187. Owners of 9bolt rearends please check this out! Sponsors dealing with 3rd gens too!
  188. 91 Formula Price
  189. Changing The FUEL PUMP !
  190. What needs to be done to cut the cat's?
  191. true duals
  192. Rear end gears... which one to get?
  193. Doors won't lock
  194. vacuum
  195. anyone know how much an intake weighs?
  196. Stock Iron L98 heads on 383
  197. rocker arms
  198. wierd signs from my iroc-z
  199. Xmas/ Birthday presents from my husband to my car
  200. I picked up an 84 T/A for free!
  201. Alternator wiring prob...
  202. building for SilverState Challenge
  203. 1992 305 vs 350
  204. it's time to upgrade
  205. IrocZ Gears
  206. 1987 trans am hp #'s
  207. Raptor rebuild in tranny and now.........
  208. TPI 350 modification
  209. Running Problems
  210. cams n' stuff
  211. bad fuel pump....
  212. restoration time
  213. How Do I Know What I need For My 700-R4?
  214. I need to insulate my spark plug wires from my headers
  215. dual cat down pipes
  216. factory fiberglass hood not just on the 82's?
  217. Headlight options
  218. '87 ECM in a '92 RS
  219. 3rd gen chassis stuff
  220. aklim, whats your opinion
  221. Now What?
  222. Car runs rough at idle, and backfires after header install. Why?
  223. Car idles rough and backfires after header install. Why?
  224. 1LE Oil Cooler??
  225. 700R4 bolt up to older SBC right?
  226. Making the Stealth Ram emissions legal
  227. Hesitation from Reverse To Drive
  228. 86 2 lt1
  229. Anyone else have a loose steering column?
  230. What differences do wider wheels make?
  231. What Kind Of Gas Do You Guys Use?
  232. I have a full edelbrock exhaust, iwas just wondering what you think of the system?
  233. 58mm tpis throttle body
  234. Tick Tick Tick Tick, ahhhh sh*t
  235. 85 TPI do they have speed or revv limeters?
  236. So what is it then?
  237. Sweet!
  238. Spring help
  239. 1996 Impala SS vs 1992 Z28 5.7
  240. help car caught on fire
  241. 2.8 to 305
  242. 95 neon for 86 t/a... fair trade?
  243. 2 leaky tranny questions
  244. wheel locks
  245. Valve cover gaskets
  246. Code 36!!
  247. 1988 z28 convertable rare?
  248. rear end parts list
  249. TBI questions...
  250. Stock L98 numbers
