PDA
View Full Version : 3rd Gen / L98 Engine Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 [22] 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49
  1. lt1 with 4l60e trans question?
  2. big block in my roc
  3. Pics Of My 92!
  4. Fuel pressure
  5. what wheels do like?
  6. 88 Camaro 305 115,000 Miles
  7. I hear Camaros rattle themselves loose...
  8. V6 Intake Pipe
  9. is there anyway to find out..
  10. Suggestions on changing the plugs
  11. anyone wanna touch this?
  12. Buying a camaro... is a 305 worth it?
  13. Adjustable MAF for TPI, now a reality.
  14. will these sfc's fit?
  15. 4th Gen Wheels on 3rd Gen
  16. Help me!! Please!!!
  17. 87 drum to 88 disk
  18. I Think This Falls Under MAJOR Tranny Problems...
  19. What size and type Pushrods to get?
  20. Proportioning valve
  21. Fuel Filter Change
  22. 3.73's?
  23. explain gears to me
  24. Aftermarket Oil pan for stroker, what fits?
  25. looking at a Z28
  26. heres an idea
  27. taking off egr
  28. TBBP kit for '92 350
  29. Buying an IROC... could use some advice
  30. So I just ordered my Vortec Heads and Intake
  31. Question About Computer
  32. Finally changing rearends!
  33. Parts from a 305 to a 357
  34. New SuperChevy issue on TPI
  35. good 305 cam
  36. speedo question
  37. Tranny leak. Too much pressure?
  38. Cam For 305
  39. Check Engine Light question
  40. How can I find damper diameter?
  41. Tranny in. now i got a new problem...
  42. 3rd Gen salvage yard in Canada ?
  43. Bosch Injector # 0280155931 ????? what are they???
  44. ring gear
  45. just got my camaro
  46. Piston part number question
  47. 383 Stroker Damper/Flywheel ??
  48. taking off my driveshaft
  49. T5 and T56 Trannies
  50. Throttle Body Question
  51. 92 camaro on ebay
  52. Injector question
  53. zz4 or something else
  54. 350 question
  55. Verifying a 305 from a Crate 350
  56. Starting Problem!! Please Help!!
  57. Help, I think I broke it....
  58. 88 IROC, New member need help!!!
  59. component sizes for 350
  60. 350 TPI Cam
  61. Tuning options for tpi?
  62. 88 RS 2.8 Power Adders
  63. guage pod in place of ash trey?
  64. Turbo Mufflers..Any good?
  65. Tokico Lowering springs
  66. bogg's and wont idel
  67. rearend question
  68. Gauge Help
  69. Question about 700R4 in 305/350 '87s?
  70. Bogs, misses after 3000 rpms
  71. converter help
  72. 2 quick videos of my Z
  73. No Engine or Drivetrain
  74. track rules????
  75. Lug pattern
  76. T-56 swap question
  77. Power window gets stuck
  78. help with my iroc-z rims
  79. Another Disc to Drum Question
  80. wireing help
  81. 305 tranny
  82. Power steering help
  83. Help Please Tach Bounce Pwr Loss
  84. Kumho Ecsta ASX tires??
  85. Prothane suspension kits
  86. HELP! Hesitiation...
  87. code 43 after rebuild
  88. Auburn or zexel torsen, which is better?
  89. paintjob?? ideas??
  90. Whats the best way to put on an intake???
  91. Fan Relay
  92. couple questions on what fluids i should use
  93. Exhaust sytem????
  94. few Q's about zz4
  95. Hypertech Fan Switch!!!!
  96. Driveshaft Length
  97. oil leak help
  98. ordered my rear rebuild parts today
  99. An Idea for the Future...
  100. Demon Carb + Kickdown cable. Geometry Help needed.
  101. the big apple circus is here(time to change sprak plugs)
  102. lt1 super ram or stealth ram ??
  103. Easiest Tranmission Swap
  104. TH350 short/long tailshaft
  105. Need expert help!
  106. Are there any N/A 300 hp tpi 305's?
  107. push rods
  108. Flex fan or dual electrics?
  109. 17 inch rims for my Iroc
  110. por 15 body work (the restogrip and straitline)
  111. 89 RS Timing
  112. How accurate are the....
  113. Temp gauge going buzzerk!
  114. Many people were wrong!
  115. how do i tell a tbi iroc from a tbi rs?
  116. which trans cable can i use?:confused:
  117. What Headers Should I get?
  118. Camel backs or AFR 195`s
  119. Losing patience with a problem
  120. dyno'ed today...whatcha think?
  121. to Rippin92rs and your 3rd gen camaro
  122. Manual Fan Switch, Dual App.
  123. double roller clearance problems
  124. Nasty WOT bogging...
  125. 1986 Irocz???????
  126. help w/ paint
  127. Parts to Compliment 2032 Crane Cam?
  128. 1988 tbi iroc?
  129. 83 trans am weight??
  130. Springs for vortec heads with LT4 Hot cam
  131. building L98 for midrange torque
  132. searching for third gen. what are o-rings?
  133. Advice on a 92 v8?
  134. Burnout Problem
  135. Powerglide in a 3rd gen??
  136. T-tops
  137. Lifter Question...
  138. 1987 - 305 Tpi - S/r Torquer 305 Head - Cam
  139. Ready for spring???
  140. Rims to get???
  141. SLP LOUDMOUTH on my IROC-Z
  142. LT1 SBC for sale, giving ya'll a heads up
  143. 1/8th or 1/4 times 305's with 2.73's
  144. who does this to a camaro????
  145. Mass Air Sensor Upgrade
  146. tuned port motor for carbed application
  147. Dayton Daytona ZR tires?
  148. Heads/Cam TPI 350
  149. Third Gen F-bodies: why so expensive?
  150. will a gta front end bolt up to a trans am front end?
  151. Hey newbie here
  152. Need some testimonials about mufflers...
  153. Anyone ever seen the flowmaster lookalike Vortex mufflers???
  154. turbo 350 swap
  155. Hypertech Fan Switch
  156. 28 Spline Axles??
  157. 383 Tpi
  158. timing chain and gear replacment interval
  159. 305 G block
  160. Stock 88 305 TBI how to change to Intake Manifold n Carbureator
  161. thinking about getting another camaro
  162. Stolen 88 Iroc-z North California
  163. fuel lines QUICK
  164. High Speed Vibration
  165. Lt1 cam move powerband up in LB9?
  166. Using 84 lights and stuff on my 92 Bird
  167. 87 iroc with 373
  168. 2.73's to 3.73's
  169. What carb?
  170. Scrapes
  171. just put a cup of alcohol in my iroc-z
  172. Is This a Good Price for a 383?
  173. Cutting floorboards to make room for exhaust
  174. What size carb for a 350
  175. Edelbrock STB
  176. Decal placement measurement for IROC
  177. More power froom chevy heads? 350....
  178. 305, 305 HO, or 350 tpi??
  179. I am a member
  180. Wipers and Squiters Died
  181. TH700r4 HELP!!!!
  182. American Muscle Car
  183. Rims
  184. T56 tranny in auto/350
  185. Best Transmission
  186. oil leak - help me
  187. TPI block w/ 400sbc heads would LT1 intake work
  188. Anyone seen a 84 TA with a great body for sale? Complete or Rolling Chassis...
  189. sayin goodbye
  190. 92 RS Idles Rough Any Ideas?
  191. what are the symptoms of an exhaust leak?
  192. Crankcase hole Size???
  193. Exhaust
  194. 2400 stall?
  195. Let's talk more cam's
  196. Need Suggestions for 92 Ground Kit
  197. how do you judge value of a thirdgen?
  198. LT headers and the y-pipe!
  199. 700r4 problems
  200. An easy question for you lot!.
  201. 305 Tpi Cam
  202. cam's
  203. no muffler for the v6?
  204. stock times for 305's and tpi 350's
  205. 1991 Z-28 fuses (under dash)
  206. I want to get rid of my TPI...
  207. what do you think this would run??
  208. fuel pump question
  209. 4th generation 17's on 3rd gen
  210. for aklim 3rd gen ques
  211. Wiring for 700r4
  212. Repaint Time
  213. Where to buy ABS headliner?
  214. angle or straight plug
  215. Crane Fireball 296 Cam
  216. Anybody changed to the Fastburn head kit from Scoggins on your TPI ?
  217. Taking off the upper side skirts suck!!!!
  218. dropping lt1 into 3rd gen, accessories question
  219. Accel Injectors...
  220. Pre 87 SBC, LS1 or LT1 Induction System
  221. just a thought
  222. Code 34
  223. Third Gen Lower Shift Boot
  224. 3rd gen rails with 4th gen seats?
  225. canadian $ value of iroc
  226. I'm new and proud!
  227. bogging at a light cruise
  228. Wheel sizes and backspacing
  229. Timing on a 305 with no cat
  230. drove my first 3rd gen yesterday!
  231. Still looking for a 91-92 Z28...
  232. Tranny shifting finiky
  233. Will 79 rear end fit 92?
  234. LT1 Cam Dowel Pin Q
  235. to all my 87 iroc-z boys
  236. how hard is it to drop the 700r4
  237. iroc bucking when in drive
  238. how often should the thermostat be replaced
  239. Drum Brake to Disc Brake Rear Q's
  240. need advice
  241. Where 2 start on 92RS 305 TBI??
  242. Replacing EGR
  243. EGR Help!
  244. Stranded for a few minutes.
  245. 5 speed conversion
  246. Diameter for exhaust on 5.0
  247. Headers to Get????
  248. This Is What Happens When You Blow A Rear???
  249. Looking for TPI FPR
  250. axles on an 87 iroc 26 or 28
