PDA
View Full Version : 3rd Gen / L98 Engine Tech
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49
  1. Best place to find a new dashboard?
  2. 87 iroc-z 355 tpi temp question.
  3. Completely Stock L98
  4. 2000 3.8L V6 Throttle Position Sensor
  5. 305 h.o
  6. my 92 rs camaro
  7. 95 z28 misses on the road
  8. 700R4 TV cable on 6-71 blower????
  9. Transplanting 305 TBI
  10. tv cable!
  11. How much horspower can a stock TPI air filter housing support?
  12. how fast do u think?
  13. 91 camero idle air control
  14. anyone have an extra
  15. Swaping a 92 RS's 305 V8 for a 95 3.4l V6
  16. In desporate need please help
  17. manifold coolant temp sensor
  18. buzzing ignition coil?
  19. What should I do next?
  20. No fuel problem
  21. Just bought a 1986 IROC, power question.
  22. code?????
  23. Whats a L98 w/ 88K miles worth?
  24. starting project cat that has been sitting
  25. My LT1 swap ta
  26. Engine vin location?
  27. racing question
  28. NJ emissions inspection - Failed HC's
  29. Gear question
  30. dragstrip
  31. L98 in a G-Body carbed
  32. HUGE STARTER PROBLEMS - This will be 7TH STARTER IN 2 YEARS
  33. 89 Formula 350 code 34
  34. What should be the correct Idle RPM?
  35. gear question?
  36. lunati cam
  37. Need a new L98 long block...
  38. does my 85 305 tpi have a?
  39. stock chrome 99 z28 wheels
  40. Overheats!
  41. 5 speed swap
  42. loads up on fuel..why!
  43. rear end
  44. Hard to start
  45. Doesn't anyone make 82-84 TA fenders?
  46. Won't rev past 3000 RPM
  47. Aftermarket gauge location in 3rd gen...
  48. Getting heads tested for leaks
  49. why were the 3rd gen V8's such dogs?
  50. Relibility of 3rd Gen Powertrains??
  51. 89 Camaro RS Stalls when making turns
  52. Fuel filter location?
  53. Fan Switch Location
  54. 89 iroz z with 5.0 tpi throwing 3 codes
  55. Buying a Camaro
  56. 1987 Iroc Stalling
  57. Transmission Leak
  58. Stalling in drive as soon as I step on gas.
  59. 1984 fan switch
  60. 84 z28 H.O. Overheating
  61. v6 to v8 conversion
  62. Need Help. 305 + cam +heads etc.
  63. Lt1 cam pump lobe
  64. Water Pump replacement
  65. 305 vs 350
  66. Reprograming 89 Camaro after major engine upgrades
  67. Do I need pro tune for these mods?
  68. How hot is to hot
  69. 89 camaro tbi wont turns but wont start
  70. engine misses and sputters
  71. 4th gen rear end, in 3rd gen
  72. service engine light!!
  73. 89 iroc wiring issues
  74. Help With Engine Swap???
  75. 5.7 EPROM needed.
  76. 86' Firebird engine swap, 2.8 Ltr to 305 H.O.
  77. I NEED HELP BAD surging and running like crap problem
  78. Car turns over but won't start
  79. No injector signal
  80. right air fuel fixture?
  81. please help fuel pump not turning on
  82. 88 Iroc dies at stop
  83. next performance step, 350 tpi
  84. 84 Trans Am HO
  85. Engine choice
  86. 1988 Firebird V8
  87. 1987 IROC 5.7 vbelt
  88. y-pipe question
  89. unusual vats problem
  90. 86 TPI cold start sensor
  91. block swap
  92. Difference between LB9 with auto and manual trans
  93. 85 z28 tbi
  94. Help my 1986 Camaro Iroc
  95. Car dies at wide open throttle
  96. fan motor help, 1990 camaro rs, 305.
  97. brights, wipers, trunk, and security questions.
  98. 89 IROC-Z, fuel line question
  99. 88 Z28 bearings out on the crank
  100. best L98 nitrous cam
  101. 91 camaro not firing up
  102. LT1 cam for my L98
  103. Ball Joints... are they all the same?
  104. tpi supercharger
  105. What size cam?
  106. 77k 305... what would you do?
  107. Removing Water Pump Cant get PS bracket off
  108. smog and AIR pump question
  109. Buying a TBI formula
  110. Waterpump
  111. FS auburn posi unit for a 3rd gen
  112. Where the heck can I get a valet chip?
  113. How do i find TDC?
  114. Open Dif.
  115. tail light bulbs?
  116. BBC into 1986 Z28, Front Springs?
  117. lt4 hot cam install
  118. need help
  119. 1986 Iroc
  120. True Street Coverage Finally!
  121. Electrical Issues
  122. Anybody know...
  123. 406 SBC Cam Choice
  124. AFR heads for sale.
  125. Need help on which gear is good for me?
  126. 92 idle problems
  127. Need helping locating tags
  128. Plugging the oil cooler adapter
  129. Need info on stock heads????
  130. "clunk" when trying to crank,
  131. Distributor Gear/Cam Match Question
  132. need help finding a cam
  133. Rod to Cam Clearance for 383
  134. 87 z28 code 22/23
  135. tpi no start!
  136. Help me ID this cam
  137. 87 t5 TRANS swap into a 91 350tpi?
  138. Stolen Pace car in 1986! haha
  139. Want more power out of 350 tpi?
  140. Removing Cooling Fan Switch. 91 Z 5.7
  141. HELP!! 87 Iroc build
  142. Clutch aand shifter
  143. 87 tpi Distributor help
  144. oil pressure drop
  145. holley stealth on stock camaro tpi heads
  146. TPI Intake Install - How Did I Do So Far?
  147. slp runners on after market base manifold
  148. how to change motor mounts on a 3rd gen?
  149. TPI or CARB?
  150. I need some things cleared up
  151. 87 Radiator Cap Question - running warm
  152. just bought a GTA, could use some help!
  153. TPI cuts out
  154. 3RD Gen won't crank. Design Flaw?
  155. Can anyone help identify this GM cam?
  156. 91 rs running issue...
  157. 87 305 tpi to 91 350 tpi swap
  158. accel 350 tpi wont start
  159. 1983 "Crossfire"
  160. overheating
  161. Head Question
  162. 1988 Iroc 305 tpi 5 speed runs rough when cold????
  163. fuel injectors upgrade.
  164. Torque converter on 92 Z
  165. Engine sitting for 3 years
  166. Considering a 91 RS
  167. vacume line diagram for 1987 5.7 TPI
  168. Getting more power out of a tbi 350
  169. 1988 350 L98 2 Bolt Main Torque
  170. Code 54
  171. Leather seat option
  172. some advice please
  173. What cam would you run?
  174. valve guide oil leak
  175. Knock Sensor Swap?
  176. A little help, please...
  177. smog delete
  178. Desperate for distributor knowledge on 1985 T/A
  179. Loss of power :(
  180. is o2 sensor needed with mechanical carb?
  181. aftermarket tach
  182. 85 z28 newbie with questions
  183. '89 Intake To '88 Block: Questions Arise/56K Beware
  184. im changing from a 305 to a 350 will i need.....
  185. have a few questions
  186. Building Twin Turbo 400ci SBC, Need Advice/Opinions
  187. Cleaning MAF Question
  188. 305 TPI 700-R4 TV/detent cable
  189. 87 Iroc-Z Thermostat question
  190. Cleaning MAF 87 Z28 Question
  191. surgeing idle and stalls
  192. 3.42 0r 3.73 gears
  193. Failed Smog, Please help.
  194. Goodyear F1 GSD3 vs Firestone Wide Ovals.
  195. Extremely low oil pressure after oil change
  196. 87 IROC-Z not starting
  197. 1991 Firebird Problems
  198. 383 tpi
  199. clutch Ques.
  200. I'm Back in a 3rd Gen after 13 years!
  201. Help! The Z caught fire on the dyno!!
  202. 88 GTA, sitting for 6 years, won't turn over
  203. Gutting air boxes?
  204. knock sensor
  205. code 22 and 44
  206. Firebird power headlight motor
  207. Scoggin Dickey Crate Motor Springs
  208. Older 350 in 91 Camaro
  209. need help
  210. LT1 vs L98
  211. Code 54 Hard to Start in the Morning
  212. AFR Eliminator #1040's!
  213. which clutch for t56 in 2-piece main seal 350 block?
  214. code 12 and 43
  215. code 30?
  216. question?
  217. code checking
  218. next step
  219. 1989 iroc z with a 305 tpi
  220. check engine light
  221. I need chip help.
  222. tpi headers
  223. tpi heads
  224. 6-speed in 3rd gen
  225. Buying a 305
  226. 305 TPI to ...?
  227. power steering pump removal
  228. exhaust choices for a 305 tpi
  229. L-98 code 34
  230. cam/rocker question L98 mod
  231. Fuel Problem
  232. Direction Needed! - Help - L98 - Teardown
  233. IAC Question
  234. 305 tbi to 350 tpi
  235. Can Throttle Position Sensor be cleaned?
  236. 350 tpi swap into 91 rs
  237. E-tec plugs
  238. 305 TPI Issues
  239. 87 Iroc 305 Sputtering..on throttle
  240. msd box trying to find tach wire's
  241. L98 350 TPI - Fuel Pump PSI rating?
  242. budget 406ci build
  243. diverter valve for the heater core lines
  244. GEN 1 engine in a 4th gen?
  245. alot of problems, but no answers.
  246. K&N Ait Filter & Air Hog Air Filter Users Anyone Hear that Oil Clogs MAF's Etc?
  247. what year?
  248. 85 camaro Z-28
  249. '88 TPI Intake Manifold - Bastid Year?
  250. Solid roller for late model block.
