- How do you pull a plenum and runner set? How much are they worth?
- Can someone explain the intake system of a V6?
- Pros and Cons to the Holley HSR
- perimeter style valve covers which gasket method works best
- >>>Post your times with full exhaust!<<<
- Third Gen Info?
- is their supposed to be a seal or grommet that goes around the pcv valve
- if i check a couple spark plugs for their condition do i need to re-antiseize the thr
- starting problems
- low RPM problem
- Leather Seats
- Can a 3rd generation coupe be made into a............
- about how long does it take to do a v8 - V8 engine swap
- Need tips/help on cooling my BBC 3rd gen
- why so hard to find convert?
- Ticking noise comming from SVO's...
- WHAT kind of distributor caps are these?!
- 89 firebird gta info
- if you want pics of true duals on a 3rd gen click here
- 3rd gen firebird info
- Low Pedal
- 383 guys, need header help!!!!!!!
- Quadrajet Leaking?
- Fix Taillight w/ Covers?
- Having trouble with coolant, help?
- the engine for the most power and speed?
- rearend question
- compression question
- 89 trans am GTA
- TPI Fuel PSI, how low is too low?
- What is stock FP for a TPI?
- Anyone start an LT1 Swap building everything from scratch?
- Grant Classic Series Steering Wheel
- new car pics
- spoiler gaskets
- Thinking about an 82 for 2400
- Q-jet or Holley??
- 305 H.O heads on 350 block
- clutch problems
- Any tricks on changing the heater core quickly?
- hood help now!!!
- Is the 3 Row Radiator worth it?
- Valve Cover Leak
- lots of smoke
- need help 1985 Trans Am
- Why won`t my Zed start??????????
- thinking about a 350 HO
- Steering Column Loose
- forth gen steering wheel in my 87?
- just won some rims
- mystery hose unplugged for cruise control
- Steerign column switch firebird to camaro
- Cluster muck
- Overheated and now ive got smoke comming out the exhaust
- Anybody in the PA NJ DE MD area.......
- ready to buy and install my hatch motor
- Easiest way to take this power antenna out
- Just scored some headers!
- Braking distance 3rd gen ?
- 350 H.O. Kit GM
- Door frame weatherstrip OER ?
- L98 T56 computer
- A/C help!!!!
- Cross Fire Injection?
- Best Positive Rear end for a 305 4bbl.
- Didn't all 91 z28's come with tpi?
- New Rebuild, ECM Problems
- Ran my daily driver at the track...
- Not able to start car
- harmonic balancer
- can i bleed the master cylindar while its in the car
- Will someone please help me w/ finding brakes?
- Low Clutch Pedal
- 3rd gen SPOHN tranny mounted Torque Arm owners inside please!
- Engine break in
- pilot bearing
- New
- Tranny Gear Ratios...
- rear view mirror placement
- Black smoke under WOT, smells rich, bad MPG....
- lingenfelter
- Anyone got this combo?.
- Dying battery
- HELP! Market value on '88 convertible??
- test drive question
- Custom build
- 1988 2.8 V6 Camaro to 350 TPI
- New Tach
- Trying not to wreck my dash
- Radio wont pick up signal...
- Part number needed, 3rd brake light
- New Brakes
- Bad Torque Converter
- What do u think of my pitman <-- chk out the video
- 1 problem and a question.
- Head Gasket Coolant holes?
- L98 vs. 1955-1986 small block
- Subframes on, framed tweaked
- hoping this is the battery only
- Tha Berly! Needs A few Mods
- engine rebuild
- 78 350 fit into an 83 camaro?
- Dual Fans on 92 - 350...Are we there yet papa smurf??
- Most Potential?
- what would cause this?
- cam installation
- I need help big time
- Fog Light Bulb Number?
- Pitman Arm - Idler Arm - Labor Involved - Any Kits?
- Cruise/HSR problem?
- Whats a good performance distributer
- 82-83 Fiberglass Hood
- Input/ help required
- My car revs itself!
- Ram Air Hood
- Found why my check engine light was on.
- brakes on a 92 rs
- wires with headers question
- TPI off for motor pull...right?
- help!!!! Engine Wongt Start!
- Finally some 1/4 times! Whatcha think?
- Doug Nash 5 speed
- Speed sensor on 700r4
- Corvette 2 IROC
- chirping second, and a hatch motor
- GMMG chambered on a TPI
- Best vendors for 3rd gens
- problems...
- BBC exhaust
- 9th Injector Elimination
- Headers Install Question
- overheating
- need to replace fuel pump
- breaking problems, proportioning valve???
- what oil do YOU use?
- Compression Ratio 350 TPI
- Where can I find info about engines in general
- new rotating assembly??
- from one motor to the next
- RPM Issue
- Water pump did the wierdest thing...is it broken again?
- Lots of heat soak
- Transmission stuck to block...Need help
- Slow Turning Start,whats the deal
- 350 building
- CD Player help.
- Adjustable pressure regulator on HSR
- Check engine light?
- 3rd brake light issues.
- My firebird is Gone
- speedo
- Just aquired an '89 IROC, has some problems
- 454?
- TBI to carb Q's
- what tranny should i use
- picture
- still overheating...high idle
- cold air intake suggestions?
- can somebody walk me thru this window motor install
- GTA cloning bird cancelled i want my GTAS stuff back!!:-(
- not about a camaro but plese help
- Dyno Tuning
- coil overs
- 5 way harness help
- What temperature should I be running?
- Value ?
- 1le
- HSR help
- 700R4 To Turbo 350 Swap !!
- shift kit help plz!!
- 305 Heads and 350 Heads
- ROH RT wheels, Finaly on!
- Radiator Help... Big block
- Firebird Taillight Wiring Diagram Needed
- Thnkn bout puttin a 350 into a 89 RS
- Burning a chip or buying one?
- car running hot
- help
- Lt1/Ls1 swap in 3rd gen
- 17x11 rears
- Going Old School with a 92 RS
- Need a cat for a 87IROC
- Top speed with 2.23's?
- Newbie With 2 Thirdgens
- Electronic Fuel Pump
- Question about the 5L TPI - LB9
- 04 Z06 rims on 85 IROC?
- cooling fans not coming on help
- Engine upgrade advice
- Best type of SFCs
- Didnt know I was that fast
- new hood
- finally got my first 3rd gen
- New headliner.
- adding a tranny cooler
- Hedman Headers question
- 305 TBI mods
- How to remove Center Caps on wheel
- TPI problem, tb is wissels.
- Recharging AC- where are the high and low lines?
- Replacement for a 350 turbo?
- wierd shift question
- oil pump drive
- Where to get valve covers
- Fuel Injector failures
- 89 camaro gears
- code 32? help!
- well i went and bought another iroc after a vette
- rpm at 60
- GMMP or Corsa?
- 305 oil capacity?
- What's involved in swapping 4th gen rear end to 3rd gen?
- cooling system
- scan master
- clunking during semi-heavy throttle
- 350 Q's
- Does anyone know the flow rate of the TPI cold start injector?
- C-4 brake
- Long Tube Headers?
- 9 bolt gears (where to get them asap)
- carb which one to use
- Quick tranny swap question
- Cooling Fan
- 82 to 92 big block camaros
- Can you run 3.73 rear with a 700R4?
- vacum line
- Haynes auto manuels suck.
- window problem
- 82 Z28 engine question
- T-56 swap into 85 camaro...
- clips for 87gta spoiler
- distributor problem?
- front coilover setup?
- Update on my 305 rebuild
- Engine Stripped.....Injectors?
- Could this cause a timing problem?
- another tranny question
- QUICK HELP NEEDED-holley 255lph intank pump ?
- 6.0 liter swap?
- Timing and distriution
- will traction bars solve my torque arm problem?
- Which would you do?
- 88 Vette In 88 Camaro
- Soon to be a new 3rd Gen owner
- 305 Redline
- convertible questions
- 2.90 to 3.73 gear swap-what do I need to change?
- '86 z-28
- coulda of roasted a mustang gt 88-92 on the highway (still got him)
- Redoing front brakes. brake lines?
