- TBI Cold Air Intake
- draw and high idel
- ALL L98 owners....please respond
- Car doesnt shift at all when started?!?
- AHHH!!! Lady Camaro won't start!
- carb or fuel injection
- Berlinetta, good bad, ugly?
- Dual Exhaust Kits???
- New to Camaros... Questions
- Fuel sending unit wiring question.
- Need vin number
- HELP! Trans won't stay in park
- 91 Z28s equipped with ABS?
- Hood clearence on a 3rd gen--LG4/Q-Jet....
- Price Estimate for 5 speed swap
- door panel swap
- Switching from mass air flow to speed density.
- Bad Gas????
- Air Foil, Does it make any difference?
- Questions about DFI...
- 1989 WS-6 Firebird Formula for sale
- L98's get no respect!
- Hotchkis SFCs
- Carburetor?
- head gasket blown
- 03 Cobra injectors work on Camaro
- Help. newbie looking to start a 3gen project
- Help on Timing a 350....
- superram VS. miniram
- Vapor Lock Problems
- wiring for tpi to carburetor help.
- flat spot
- New exhaust??
- pulled intake apart and now car won't start!
- First mods for 350 TPI
- Smog Stuff
- Need help/opinions..car is running EXTREMELY rich!
- R.I.P. My LB9...Help me find an L98..
- Build Sheet for '92 ?
- Need axle shaft for 86 10-bolt disc
- MAF Sensor Problem
- Is it time for new brakes??
- Don't think the car is running on all cylinders
- Air Filter
- Stupid noise
- 3rd Gen Noob lookin to buy!
- ws6
- rear end
- Found problem with my car
- new skools pull so hard compared to third gens
- angle plug heads on 3rd gens
- Auto Xray 240 maual
- why is my lg4 doing this
- Finally got another Camaro
- What Cam?
- Gauges..
- 3rd gen Speedo replacement question
- NO gears in 700R4
- Will my headers fit on AFR's?
- Car not starting when hot,, can anyone help????
- Think im Running on seven!?!
- tell my how to get my pinion seal out!!!!!
- fuel system
- bulletproof tranny rebuild
- timing cover question
- aaaaahhhhhhhhhh fire!!!!!!
- AC question
- Good price for a 90 iroc?
- fuel injector cleaning systems
- vacuum with 224/230 cam
- TBI Intake Idea
- Is thirdgen.org down?
- Carb Problem
- Need help with electrical problems
- flowmaster question
- got the k member in some pic`s too
- Horsepower
- 87 wiring harness vs. 88 wiring harness (TPI)
- Alternator Noise
- 383?
- Need A Little HELP
- new trans
- Help me figure out my CR
- 383 stroker swap
- What the hell is wrong with my Holley
- IROC overheated... HELP!!!
- HSR and cam Dyno
- spring isolators
- Rough idle, no throttle
- Motor Swap Questions...
- Speedometer stopped working
- Im looking to get an exhaust need help
- Enjoying the heat is good WHEN......
- horsepower on a 89 gta 5.7 a4 duel cat g92
- 383 computer chip, help please!
- O2 Sensor & Headers
- hood clearance
- anyone know how to tighten the steering wheel?
- adjusting the TV Cable?
- coolant..
- camaro's totalled...
- fuel CALPAK
- Differential Oil
- Compression Test Q & A...
- Estimated HP
- 355 or 383
- Hissing TPI...smog vacuum?
- need a carfax done please
- fault code 52
- 1.6 Roller tip rockers, Will they fit???
- Igniton Amplifier
- O2 sensor came out while I was driving...
- fuel delivery
- How to tell engines
- 305 to 350
- HELP!!! Timing
- ALL MOTOR and No more computer or electric
- injectors not firing/pulsing
- what to grab off a ws6 firebird
- clear side marker lights
- clearance problems?
- Need a chip burnt
- What engine do I have here?
- what is the bone stock clearance of an LG4/l69 in a camaro
- SLP Rims
- sequential turn signals
- i got a question about heads---need help
- HELP!! Motor Problem!
- L98 stock pushrod length?
- Crate TPI/Vortec..help fast!
- Knocking on startup
- headers do i have it all
- Cardomain Updated *PIX*
- Aftermarket Chips
- cool looking headlights
- Sold my 92, Bought a 88 Vette.
- ECM Grounds
- Jumped timing?
- Where to put an open air filter?
- Would I need a Chip?
- Brake pedal swap
- Problems with early 3rd gen F-bodies?
- Suggestions on Heads
- power surging
- Driveability problem
- Car covers
- Installing Edelbrock Headers
- traction?
- milestone achieved on 88!!!
- replaced fuel pump. now whats wrong?
- New Window Motors Help
- tuning input needed!!
- Car doesn't have power under 2500 rpms
- Gas in Charcoal Canister
- what is the best way to fix an oil leak?
- How do I remove my door handles?
- rear end gears
- Loose steering column
- tpi, code 34
- Aftermarket and swap question...
- holley tpi stealth ram
- what are good plugs to use on moderately mod'd L98?
- Alternator for 1992 z28 fit into a 1991 RS???
- rs 90 swap 94 LT4 vette motor and tranny
- Bad Date Impression?? Alternator Dies on Date
- Eagle ESP Cranks
- softseal
- '88 Firebird spoiler option???
- Putting engine back in....Problems
- Oil Pressure Guage Problem
- LT1 intake, or HSR?
- Quickly, how do I remove my front bumper?
- i know this isnt drivetrain, but they dont reply to me
- just new heads or a whole new engine?
- Anyone running a.....
- Which 305 heads for 350
- HSR & Thermostat Housing Issue
- t56 swappers-which cable x?
- why did my rear go up after LCA's
- 4 point harness
- cutting springs
- CD player isnt getting power..need help please
- Sway bars once again
- Suspension modifications
- Carburators..
- What steering box do I have?
- Car not running, need help
- rear end fluid change
- Do convertibles loose power?
- What can I buy???
- Just killed my Turbo - 400
- changing shocks and struts
- washing engine
- first start
- Is my car really a Z?
- gauge cluster!!!
- Manual Steering Box for 3rd Gen
- I bought a posessed car.
- fan relay
- About to pull off rear bumper- what tools needed
- tpi -2- carb.
- Dyno results from LT1 intake swap worth 52 RWHP
- 350 turbo speedo gears...
- Oil Pan Trouble!
- OFF-ROAD, LIFTED 92 RS CAMARO, how much do ya think?
- how do things just go out of adjustment, like timing or carburator
- Throttle body intake question
- air cleaner help
- hard starting the Z???
- Magnaflow
- These are the right tools for the quadrajet
- Crash
- Noisy Brake Hardware??
- still low RPM problem...
- Parting out mint 87 gta w/mods
- LG4's have a MAP sensor?
- Posi Question
- Is a Duel Fan setup for the Radiator the way to go?
- smog pump bull
- what is the stock LG4 thermostat rating?
- speedometer conversion
- air intake
- True Dual dynomax HELP PLEASE!
- True Dual Dynomax HELP PLEASE!
- Performance differences from 5.0 and 5.7L
- Need Help on Irocs rear brakes
- took off the air horn, gas is oil black??
- Oil Pump
- Bad fuel pump, right?
- Iroc 17 Inch Chrome Wheels on 1992 z28...
- Mystery 3rd Gen Wheels...Any have any clue how to find these
- Condensation in air filter
- 700R4 problem, please help!
- fiberglass fenders
- Underdrive Water Pump Pulley...
- Balncer vs. chain????
- rack and pinion in a third gen
- Transmission toasted....
- fuel system screwy LG4 (pump, filter, bad gas, sensor??) code 21
- question
- oily plugs...
- Oil on valve cover/under car
- Looking for a 3rd gen, have no idea where to start.
- What's a set of aluminum l98 heads worth?
- Buildsheet ?
- My lt4 conversion is gone, TBI cam to match hot cam rumble?
- What battey brand do you use, i need to pick a new one
- Best upgrades for a 305 to get the most power.
- Need to buy an intake elbow that looks like this..
- goautocenter.com
