- third gen camaro turbo v6 typhoon engine prototype
- New Motor Dial In Problem.....
- 305 v 350 poll
- Car problems
- 4th gen exhaust on 3rd gen
- Big Block recommendation
- Will someone help me with finding piston rings?
- Will this "non-performance" gasket set work?
- Which gasket set?
- 1986 Engine Decision!!!
- My new 3rd Gen
- Why are center-bolt valve covers so f$%#^g expensive?
- Weird burning smell
- exhaust rapping on my subframe connector
- squeeeeek in back
- Gmmg
- My odometer is out of control! How do i fix this?!?
- What does it take to get a Tuned port transam to put down 400rwhp
- Snorkel Intake
- New BBK TPI Intake???
- just failed smog! results, what do you guys think?
- got some pics of my camaro
- Low RPM Surge...
- My "new" third gen..
- got another tranny
- '88 2.8, Fuel Pump/Gauge Sending Unit?!?
- Trans Dipstick Issue
- installed headers on 305
- Low Idle Speed
- oil pressure sending unit
- Tuning an edelbrock carb !!!
- 88 iroc gauge problem
- Who's the better carb.....Edlebrock, or Holley??
- tranny slipping
- Cam / Lifter ?
- Emissions Help !!!!
- god damn 3rd gen! problems!!!
- Extremely high idle
- Fuel Pump
- pics of my truck (hope this works)
- How much for a FULL diagnostic
- What do you think of this 3rd gen!
- Wieand 144 or 142 Superchargers
- Frozen Locks
- how do i put up pics?
- Coolings fans
- my Camaro is in the shop
- How do i fix a broken temp. guage?
- I Got $2000..what can I do?
- 455 CID in a 3gen ...possible?
- Very stange problem, hard to explain.
- car is choking any1 got any ideas?
- Guys,I need help car wont start after cam change
- need help on my 350 sbc
- Help, Need info on my new 89 WS6 formula
- head flow numbers?
- TPI Question
- Need to tune at all after changing to dual snorkel?
- Iroc project coming a long.
- 88 posi?
- How do you Break in a Motor?
- Am I better off just buying another 3rd Gen?
- LS1, or LT1
- Who makes a good Y pipe?
- 350 TPI from '91 Caprice police cruiser....
- anyone looking for a 388 or 383?
- what the common prob?
- 3rd gen, mucsle vid/.
- Holley Stealth Ram
- LT1 in 3rdgen f body. Anything I need to know?
- 86 to 89 Engine Help
- Tpi Replacment
- new to board
- L98 TPI to carb?
- Power Tpi!!!!
- Dynomax mufflers
- Tranny took a Crap After Lucas additive!
- 305 5.0 TPI in 94 camaro
- cooling system help
- FUEL PRESSURE 2 high at startup
- CODES 34 & 44 PLEASE HELP
- Will this dual-exhaust kit work for me?
- How To Make 5.0 A 5.7
- How to gut airboxes
- Need some suggestions...
- Gasket part # request
- Stock-ish L98 Auto times/mph?
- Is the "HOT" cam a decent choice for my combo?
- 84 CamaroZ28 L69 HO motor...i want speed!please help
- got a 350 with 305 tbi top end
- 383 or 406????
- Best sounding/preforming exhaust
- Wanted: 275 RWHP
- 69 010 block in 87 iroc z help
- carpet...
- My 91' 350TPI 5-speed for sale :(
- Stealth Ram AFPR
- Tranny Line Question...
- Where to get 80 series cat-back?
- How much could I get for it? :-(
- crate motor?
- Need some Help
- Need help with getting right exhaust
- Serpentine Belt issue Please Help!!!
- TC problems after engine install
- V6 rebuild kit
- FUEL PUMP REPLACMENT PART No ?
- 91 Z28 engine question...
- StealthRam upper rad hose?
- FAN SWITCH< THERMOSTAT
- UK OWNER 92 Z28 " WONT START " *@//**
- anyone have twisted wedge heads
- Transmission cooler
- TPI MoRe PoWeR!!!!!!!!
- LT1 upgrade
- Headers, Exhaust, Nitrous, Sub Frame Connectors
- who has Fastburn heads?
- v6 in a 305 tbi car?
- Stealthram Vacuum lines
- 700r4 rebuild
- 1987 camaro z-28 intake specs?? Need help
- Pics of Weld Wheels! Lets see em'
- exhaust manifolds get RED HOT!
- Push Buttons Start Install
- injectors on a TPI
- 4th gen fuel tank
- 305HO or NOT???
- aluminum bumper support weight savings
- Smog stuff removal?
- How To Free Up Horeses For Free
- Fuel Pump Voltage 7v
- Anyone have 87 l98 vette Engine Specs?
- need headers for 3rd gen for a bbc bigger than 1-7/8 tube's where to buy
- 400RWHP 355, how does this setup look?
- TV cable hookup & converter lockup on TPI ?
- what eninge is a god replacement???
- Vaccum Controls
- clearance of full length headers and header mufflers?
- going rate for a 9bolt???
- Need cam for 383
- 3970010, What block do I have??
- Do they make cold air intakes for 3rd gens?
- Floor pan
- Which computer came???
- Battle of 3rd gen vs. 4th gen
- Drivability Issue with new 350 in 1987 iroc
- Mystery Misfire '89 Iroc Z
- Engine pull???
- Body help !
- TBI to TPI Swap Help
- 305 build up.
- who would win?93 mustang notch vs. 91 camaro swapped 350Z28
- 1984 Z28
- 305 tpi went 13.55 today!!
- headers, no emission stuff, what should I do?
- Will I have to re-jet if i...
- 420 cid 400 block Limitations
- At which Lift or duration does your idle get lumpy?
- HELP Camaro is vibrating. Suspension??
- well, you want to be like that?
- Brakes practically on fire..
- Are my heads to big
- Roller rockers - 305 - 1987 center bolt valve covers
- Some People*Some advice needed*
- 305HO help
- Anybody installed a elec. exh. cutout
- Compression test to Compression Ratio
- Anyone used Tokico HPs? (or Tokico shocks/struts in general)
- Are 3rd and 4th gen alternators interchangeable?
- Headlights acting up.... Please help
- Wheel spacer ?
- IROC Wheels on my Z.
- long tubes on an 87 camaro with 5 speed???
- t5 to t56 swap ????
- choke light on
- Strong odor of fuel
- Umm.. Help?!..
- broke my steering gear
- Fuel Pump Died.....HELP!
- No TV Cable...need some help here
- I jerked the ole' 305 out, NOW WHAT?!
- Is it Worth $2,495 ???
- ** VIN Check Please ***
- should I by 89 305 tpi formula $2100
- SES Code HELP!!
- What kind of Air cleaner?
- What to do about the tranny?
- True dual exhaust, no cats, this kit, is it possible?!?!
- uh oh! What do i do???
- Performer intake and Carb
- Exhaust Manifold Doughnut Gasket Replacement
- Help, noobie needs help with replacein a engine
- Temp Gauge
- Need help quick
- Fuel Regulator
- Should i build my iroc 305???
- Trunk motor broke-How to close trunk???
- gears! 9 bolt
- 3rd gen HVAC Question
- I fianally picked out a setup for my 383 tell me what you think
- Shoot Flames from your exhaust????
- Running Rich w/ Rough Idle
- Not starting after tranny swap
- Dual Exhaust?
- where to buy cat-back exhaust 3"
- Transmission Fluid Level
- What size injectors did 305's come with?
- Everyone in! 1/4 mile times and cheap parts
- Which bolt to use on main caps?
- Carburator?
- Swapped LT1 Question
- Spark Plugs
- 88-90z28
- oil press dropping off
- Where can I find secondary DR rods
- Fuel tank Question
- dumb question
- Tranmission Coolant Lines
- Overkill?
- Just got 3.73's....Im liking it
- hatch question
- Helppp
- 88 Firebird 700R4 help speedomeater
- '94 Silverado 1500 5-speed in a Camaro??
- eh, damn terd gen......wtf??
- Ses
- Temp Gauge
- What could be the prob?
- Installing starter!!! Help Please
- ECM vs. Mechanical readings?
- Problem with the IROC
- Questions about the 5L TPI
- looking for engine to replace stock 305
- Homemade SFC???
- Fog Lights
- tpi wiring harness
- Code 54 on 87 2.8 V6
- how do i remove the rear ground fx piece, I hate rust
- Airdam Mounting Hardware, And a ?
- Deep Exhaust Note......Straight pipes or Muffler???
- Reverse Side Vents...POSSIBLE??
- 36, 38, or 42 lb Lucas injectors for new 383?
- Engine Swap Questions
- Which timing chain and gear?
- Ok guys.. the engine is officially ripped apart!
- few $100, 88 camaro won't start
- Taking off the door panel
- selling my 86 iroc-z
- Carb guys looking for more air than stock...
