PDA
View Full Version : 3rd Gen / L98 Engine Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49
  1. 305 TPI with tranny
  2. Emission Hose Routing
  3. 89 camaro rs
  4. Best heads
  5. ?? Air/Fuel Ratio gauge Install ??
  6. vaccuum leak and startup
  7. Just another dumb TBI Q?
  8. 91 305 TBI - roller block?
  9. !! Pulley Setup !!
  10. 3rd gen LT1
  11. Can i bump compression on stock heads?
  12. Header intallation
  13. F.S 92 camaro drag race rolling chasis
  14. fuel ques for a 350 carb conversion
  15. Speedo question
  16. What Tires do you use ?
  17. overheating still not fixed!!!!!
  18. Really Free, vehicle history reports??
  19. KIlled My Rear last night at the track!
  20. value of my 400 turbo, i dunno....
  21. Engine code
  22. TBI 2bbl for 350H.O. what will work
  23. Engines knocking..
  24. Distributer Gear
  25. DO i have a Dana rear in my car
  26. overheating
  27. Tire + Rim size
  28. Throttle Body Sticking
  29. ? about timing & timing tab
  30. Early 90's radiators?
  31. Did I get a deal??
  32. Trouble with waterneck-
  33. Sensors...sensors...sensors!!!
  34. Monte Carlo Messageboard?
  35. Best bang for the buck intake
  36. tbi to a carb help please!!!
  37. TFS heads / pushrod length
  38. Cracked frame 86 TA
  39. i need cam help 3rd gen
  40. White buildup on underside of Cap....
  41. Hooker Lt Y-pipe
  42. Help- TPI Feul Trouble- Need TPI Expert
  43. serpentine help
  44. 305 performance?? can i run high 14's
  45. T-56 Swap question.
  46. 86 Vette ~ No Start
  47. 305 TBI open element
  48. I need an engine for an IROC-Z
  49. factory plugs or different brand?
  50. Corsa Exhaust????
  51. 145MPH Speedometer Swap
  52. Foose Lusso Tires and Rims
  53. Rear end question
  54. Pushrod size
  55. 88 Iroc acting funny
  56. Mystery switch/sensor??
  57. '86 GTA RPO locations?
  58. after WOT oil leak
  59. SLP runners. Are they worth it?
  60. Wiring Diagram
  61. ECM fuse keeps blowing???
  62. Headlight conversion?
  63. Nitrous
  64. Please help me put my car on a diet!
  65. My 84 l69 H.O VS 88 305/tAm Gta WHo will win?
  66. Z06 Rims
  67. Converting rear drums to disc brakes?
  68. New to the forum and Camaro world
  69. stock exhaust mfld
  70. Is VATS system governed by the ecm?
  71. Painless wiring questions
  72. Battery keeps going dead...
  73. 3rd gen. engine/tranny combos
  74. Need To Pass E-check!
  75. GMPP Fast Burn Heads question
  76. Overheating 86 camaro
  77. firebird wheel sizes
  78. 88...305 5sp
  79. weird idle.... 86 camaro
  80. Dipstick tube seal on 700r4/Leaking/is it common?
  81. Ametech Engine Restore Oil??
  82. Cold Start and Flooding Problem
  83. Anyone know where I can get block info?
  84. Chip Dyno tuning North East March 12
  85. 83 z28 air induction on stock hood,questions please??
  86. HELP!!! 92 RS V6 Wont Start!!!!!
  87. Theoretically speaking, how much improvement will...
  88. '84 LG4 carb prob.
  89. Engine Wiring Problem
  90. Msd Boots Hitting Slp Headers
  91. supply vs injector pressure
  92. engine finally going to the shop
  93. esc code 43?
  94. ok im getting ****in pissed
  95. Heated O2 sensor
  96. Choke light keeps coming on...(no it's not the alternator)
  97. Looking at pistons
  98. Cel
  99. White foam in the Coolant Bottle, whats causing it?
  100. Anyone have a CSI Electric water pump that they could measure a dimension for me?
  101. Help my friend choose...
  102. 17x9.5 front / 17x11 Rear ZR1's on a 86??
  103. 305 To 400 Tbi????
  104. failed smog for the second time
  105. Severe Hesitation/Studdering
  106. will these fit???
  107. performance of a 305?
  108. I mean seriously...what in the freak is this???
  109. EGR Delete
  110. Superram Vortec -- Why I "upgraded"
  111. cam specs ?
  112. Track pictures of Iroc
  113. New pictures of my 6 speed Iroc
  114. TBI Conversion
  115. 4:10's in my 84 l69? Good or bad idea??
  116. Roll cage?
  117. camaro '87 V8 few questions...
  118. Oil Presure... need some help!
  119. Opinions on this cam/setup please
  120. 1990 RS-1/4 time?
  121. 90 305 Tbi
  122. Smog pump delete?
  123. Fuel Pump issues
  124. HELP! pulling aluminum headed engine
  125. Whats the best way to clean an engine while its in the car?
  126. SS Hood Air Box
  127. pics of 82-92 with 10 point cage?
  128. single exhaust with two spiral flows
  129. Who's running 315's on your rear's?
  130. i ran my car on the g-tech
  131. replacing ecm on my 86 Z28
  132. H-pipe for camaro
  133. Dyno tuning
  134. 3rd gen Rear Gears
  135. Holley Stealth Ram
  136. Anyone interested in a 85 with BB?
  137. How many temp sensors on an 89 L98???
  138. Free mods
  139. i need some imput here
  140. verify parts in pic please
  141. Heating problems
  142. ??? Fenders for 86 Iroc
  143. Holley DP Issues
  144. broken rod bolt
  145. Drag guys on stock wheel openings inside
  146. Power Steering Pump compatability???
  147. Harland Sharp 1.65rr on PONTIAC heads - clearance?
  148. Computer Reaction To EGR Delete
  149. How hard to change the Cam myself? (L98)
  150. need info on single or twin turbo BBC
  151. LS1 guys quick question
  152. 1/4 Times on my 305l69 H.O motor in Bradenton florida?
  153. hood won't latch cannot figure it out?
  154. 1990 Iroc project update.
  155. For those with weak heat!
  156. AFR versus Trickflow
  157. Question about wilwood prop valve...
  158. Need feedback on this engine.
  159. S-m-o-k-e!!!!!
  160. Vacuum issues....only 8" ;(
  161. should i upgrade to this engine?
  162. Engine Swap
  163. stock dual elelctric fans on 91 pull how many cfm's??
  164. Hmmmm...what will happen if i.....
  165. After all my work !!
  166. Anyone else not able to get on thirdgen.org?
  167. looking for True Dual Website
  168. Quarter mile times for '87 formula
  169. cc306 equivilent
  170. Vortec heads
  171. 87 GTA 1/4 times?
  172. lg4 upgrade to l69
  173. Which one os better?
  174. Problem with throttle cables.
  175. plug wires
  176. 89 RS 305, TBI to TPI???
  177. 3rd gen true duals
  178. Starting an L98 car after extended garage time?
  179. What comes with the H.O. (L69) thats not on the regular LG4
  180. for sale!! 3rd gen 305-350 performance cam kit
  181. new chip for my 85 and power
  182. Shift Light Question
  183. cold cranking
  184. Price for complete TPI setup?
  185. cold weather and power?
  186. Best high flow cat???
  187. Extend heater controls?
  188. Plans for a 305
  189. Fuel pump question
  190. Valve Cover Choose- Hieght
  191. body reliablility on high hp
  192. LS1 swap LTs
  193. EFE aka Heat Riser Vacuum Line Routing
  194. 40 series flowmaster on 91 rs???
  195. Ultimate Small Block?
  196. question about Ram jets
  197. Holley or Demon
  198. Any interest in Aluminum Iroc center caps..great for those with polished Irocs!
  199. Please Tell me more about my L69 motor/ is it worth saving?
  200. COLD AIR INTAKE for TBI V8's
  201. Kandied91Z
  202. DFI over SD and MAF
  203. MAF system tuning? questions about the scott book.
  204. I think my holley is shot
  205. looking for 3 inch mandrel bent pipe for 91 RS v8
  206. computer question
  207. No Spark
  208. Ac Delete ????
  209. 92 rs tbi-tpi
  210. Help finding rocker-arms please...
  211. Dyno Tuning
  212. Overheating problems
  213. serpentine belt question
  214. 87iroc 350tpi supercharger?
  215. so im FINALY....
  216. TBI Help... Sensor?? Harware?? Junk??
  217. factory airlid?
  218. Rear Spoiler
  219. What To Look For?
  220. best looking cowl hood
  221. 88 iroc problems
  222. new motor startup problem
  223. shifter issue
  224. 92 rs to 350
  225. help with 87 IROC with tpi and six speed
  226. Did all IROCs have disc breaks????
  227. What is the best Distributor i can put on my 84 Z28h.o?
  228. motor temps
  229. mid to high 11's
  230. stock heads CC's
  231. Getting TC bolts off on a seized engine
  232. Cooling fan switch for a 3rd gen f body
  233. Any gains from Race gas On a Stock 5.0ho Z28?
  234. Installing distributor
  235. Engine setups/dyno results/proven combos inside
  236. cast hp rating?
  237. Headers???
  238. Job Done New tranny installed!
  239. TPI porting
  240. 91 RS 3.1 Wont start at idle
  241. vortec heads??? help please
  242. 1986 IROC I'm buying
  243. Here We Go...350/305heads/.030/10/10 Turn/elgin Rv923p Cam,
  244. Corvette Tpi Or Camaro Tpi
  245. iroc question
  246. replacement tranny in
  247. fowled plugs
  248. won't hold and idle..
  249. Who makes a stroker kit for the 305's?
  250. Never Produced F-bodys?
