- Please Help Me!!
- can anyone please help me
- Belt size for 92 Z28 minus smog.......
- gen 2 heads on gen 1 block?
- couple quick ?s
- Fuel pressure or ECM not opening injectors
- temp problems
- More questions
- 1989 camaro
- What the heck is a Camaro ZF!?!?!?
- Header options
- Brace on the rear of the car?
- running rich
- Help with 305 topend rebuild/mild build up
- Delayed Throttle Response?
- Need a picture of how your ecm sits under the dash..
- Where can i get a head light motor rebuild?!?!
- Noisy PCV?
- Is there a good A/C bracket out there for 3RD-Gen LT1 Swap?
- Started the install on my HSR
- DO you need a charcoal canister
- is it possable to TUNE a mod on a tpi at home??
- digital dash
- rear water passage on intake manifold
- LT1 intake manifold on a tpi?!?!?!
- next step up for 350 tpi?
- Cat question......
- 24 Lb Injectors In A Stock 350 Engine
- A/C fix question
- Intermittent no crank problem.. Help!!!
- Replacing injectors on a TPI
- loss of fuel pressure
- looking for a place to mount a msd box
- Wiring issue?
- Holley Fuel Injectors
- Switching to carb, Help!!
- timing is going crazy
- Ya.. so how do I finish getting the brake-booster out?
- tuned 305 TBI
- Ford injectors in a Camaro?
- rebuilt engine won't idle
- digital ignition box...
- whats this wire???
- best choice for l98 replacment
- what are the best pistons and rods for a 305?
- 350 Tbi
- belt size's?!?! is it possable
- 10.20's?
- 200k Miles!
- How much would a cam do
- Full Exhaust suggestions.
- steering cloumn?
- WTF! coolant leaking from my oil cooler lines
- Need Aftermarket Advice
- stealth ram question
- Why not shifting hard enough?
- what 17" tires fit?
- ****in Dammit
- TPI Blues
- 305 to 350 swap
- Muffler advice needed
- Cranks but dies 1988 TPI L98
- motor question
- how to store car and new tranny
- Clicked off a new best
- pulling a seized engine
- missfiring and dying on cold start
- HEI upgrades for Computer Controlled HEI modules
- 87 350 Engine A MESS! HELP
- Cowl Induction
- Newbie Questions about Tranny Accessories
- Alternator / Battery Help
- What's involved in and LS1/LT1 swap?
- Exhaust
- Air cleaner flange size
- 4th gen "clone"
- I need some instruction to fix idle screw set
- No fuel!?!?!?!?!?
- Mysterious valve on fuel rail....
- Wiring up a choke.
- need help- oil pan/girdle clearance
- Trany bad?
- upgrading my computer.
- Dual Exhaust
- Stroker Kit Sale
- Injector size
- Engine trouble?
- Valve Stem Seals
- Throttle Cable TBI
- Engine Stalling
- radiator fan only working when A/C's on
- no start condition after warm-up
- exhaust
- Need help once again
- pulling a 305 out...
- Recalibrating Speedometer
- Anyone know of any Cold Air Kits OTHER than SLP?
- where to wire my electric cutout?
- Was there such as car made?
- who sells mass air flow burnoff relays?
- Help identifying a sound
- How much for a full 3rd gen performance exhaust?
- Can someone PLEASE help me with this noise??
- How do I strengthen my tranny mount.
- Z28 Turbo
- what would be idle for me?[406]
- looking for a hood for my 92 z28
- will fourthgen front sway bar fit my 92 z28
- tpi setup question
- What is involved in putting on a wonder-bar?
- New owner and user with engine question
- Those with rack and pinions in 3rd gens...
- Dropping Rear to Remove CatBack Tutorial (pics)
- I Hate My Car
- Running LT1 cam?
- what all needs to be done....
- My 89' IROC 350's exhaust system, what do you think?
- What size are 3rd gen rims?
- Plug Gap On 89 305 Tpi?
- Shorty vs. Long-Tube header for '91 Z28?
- For all the people that say it wont work
- holley 650 DP
- re-post? anyone seen this on egay?
- can a 305 be a fast engine?
- trans swap
- 305 350 swap
- Starter
- Which do I do? 400+hp 305 or drop in an LT/LS1
- What's this worth? (please)
- believe engine builder???
- 87 Iroc Help!
- 87 Iroc Gears.
- Help!!!!!!!!!!!!!!!
- auto 305-manual 350 conversion
- good deal or not?
- Does anyone happen to know the GVWR
- Does your Iroc do this?
- Key Stuck in Ignition
- new member, got some questions about my car?
- 1987--L98 Discussion
- Car is bogging out bad.
- Problem bouncing up and down on highway?
- 1992 Chevy Camaro RS - V8
- Speedometer Bounce problems
- putting old stlyle heads with my Tpi
- Car is getting painted need to get Stripes Template
- SLP bolts
- Trans cooler lines
- HELP!car died
- Mystery box in engine bay
- Is this worth it?
- Can i take'em out?
- Electric Water pump? good idea?
- Question about T.V. cable bracket on carb'd engine
- i need a tpi intake for vortec heads
- maf not working
- driveshaft
- Help Rebuilt the engine but now........
- question about heads and intake...
- Time to ditch the ZZ-9....opinions pleeze!!
- Question on Holley Stealth Ram?
- new engine
- Need some major advice
- turbo400 or 700 tranny?
- Picking a carburetor.
- flywheel question/problem
- 89 RS starting problems
- Newbie Questions/Problems
- a bolt missing in the tpi runner to lower intake..
- How can yout ell when your engine isn't "matched" properly?
- A few electrical questions
- Horsepower estimation on this setup
- How many Splines??????
- the 700R4's limit
- Getting rid of PCV?
- 2.8L to 5.7L engine swap???
- so glad i dont live in LA
- Fiberglass doors???
- New to the Boards and just bought a 83 Camaro
- harmonic damper install question
- Camel backs, 882`s or 1.94 305 heads
- TCI breakway 2400 converter wont slide in
- Fog Light Mounting
- 350 build up
- extended cranking to startup
- New Motor Red Hot Headers
- Coil...No Spark???
- Converting Automatic Trany to Manual
- Info needed on GM reman engines .
- 3rd gen tach problem
- Electric hatch motor???
- 89 WS6 Dual-cat exhaust question
- Just picked up my '87 i-rocz...
- EGR Help
- Spuddering when trying to accelerate
- Houston we have a problem!!!!
- My new Project
- nitrous
- Engines in!
- Carb help, car sat since 1997
- Ram Jet and hood clearance?
- Intake height help
- enginetech moly rings?
- Tachometer usage
- Oil Cooler hookup w/o heater core........
- cam bearings for cc306
- Factory Oil Cooler Hoses.........
- Fuel System...Please Help!!!
- vaccum lines
- my car(duno where else to put this)
- Just not what I was expecting
- Why do these sub-frame connectors look so funny?
- Need a throttle cable for LT1 swap.
- Which engine mod next?
- motor falls at 5200 what is wroung
- Replace fuseable link for fans?
- QUICK! Easy easy easy question
- fuel problem ?,help please
- carb-nos plate=clearance?
- 27 or 30 spline?
- serious overheating / already used search
- Busted Tranny mount mabye caused more probs?
- Spark Plugs?
- TBI to Carb Question
- Do I need new valve seals?
- probelms with idle on 92 z28
- hatch will not open on 92' z28
- Too much fuel after Ford 5.0 injectors installed?
- Fans not turning on. Need help troublshooting.
- Carb - Running Pig Rich - Engine Shake At Idle
- Engine Compression
- Mr. Gasket Street Scoop Pictures
- Buying a new muffler today... but i need suggestions
- Power steering pump pulley install
- Electric Cutout
- Dyno results, a little dissapointed.
- Horse power and AC unit
- Paper air filters vs. "Special" filters
- 88 Iroc Cutting Out 1500-2500 Rpm
- brake booster swap?
- intake manifold torque specs
- Sticking brakes
- Where should i go to get a nice catback
- Idle, the car and i both confused
- Engine Knocking
- very confused, Alt wiring..HELP!!!
- Time for a dumb question
- Air pump solenoid location
- Rebuilt Engines ?
- Headers
