View Full Version : LS1 Based Engine Tech
- New Purchase in the UK
- how long will it last
- Head/Cam info
- 11 second daily driver?
- knock sensor bank 2
- Lid Fitment
- 160 thermostat help
- Name that smell ...
- this any good?
- Trying to run 12s...
- TPS sensor questions.....weird readings after TPS replacement
- struggles to start
- Easy Mods
- comp cam and 5.3 heads
- Introducing The Golen LSX Peformance Engine Series!
- Detailing 2002 LS1
- My LS1 Z28 Needed Water And I Didn't Put Any
- Lid
- oil psi question
- Futral F14 cam questions
- LS1 cars getting completely trounced by LT1 cars...
- Engine knock when cold
- car issue... smell gas, and was bogging down
- Cleaned K&N FIPK now I have an engine code!
- Heads are in
- LT motor compared to LS motor
- ls1 headers JBA
- 5.3 heads
- help please
- 95 LT1 swap for 99 LS1 guide
- Excellent and free tuning advice
- What spark plugs does everyone use on their LS1?
- ok got some questions
- AIR - Is it necessary?
- Build-up Specs
- Oil Pressure Gauge
- Normal for some smoke @ high rpms?
- installed pro kit, now which header's
- next mod?
- Ricer question
- Frustrated - AIR codes won't go away!
- Moroso Blue Max wires???
- AIR pump ??
- flashing SES light
- underdrive pulley and lightweight battery?
- Ls7 $12500 Delivered
- getting hypertech today
- Put the car on the dyno yesterday
- spark knock
- help, car going crazy
- P0300 Random Misfire #2 and #7
- what are the free mods for ls1?
- Air Injection?
- Throttle response...power surge after initial lag..HELP
- 2000 silverado 5.3
- Head/cam questions...
- LT1 to LS1 conversion..
- car to slow
- low Antifreeze light comes on & stays on
- DTC codes?
- BackFiring?
- After header install, rough running
- ported tb
- Advice on Head
- ls1 in 92 mustang
- ACDELCO 41-985 plug gap question?
- any one port heads in so cali
- bank 2 knock sensor
- Comp Cams 918 spring failures !!!!
- GM's new LSX block
- camaro build at V.R.E.
- acceleration problem please help!
- Own a 98 Camaro or Firebird?
- stock LS1 worth dyno tuning?
- guys whats an M6?
- Flickering lights Check Gauges Rpm spikes??!
- heads and cam ?
- Is this a good price to have all this installed?....
- needing advice for my ls2 stroker
- Just off the Dyno
- scared to dyno the car
- What Headers/Cats will fit SLP exhaust?
- LS1 engine numbers location
- Anyone running this cam
- oil pan alignment and torque critical... see service manual
- running bad
- Which Oil Pump?
- 2000 Camaro Z28, M6, gear upgrade opinion
- nitrous and spark plugs
- just a little info
- Flowtech LT
- Sounds like a good deal to me...
- Best cam for a daily driver/6 speed with bolt ons
- oil pressure dropping to zero and stalling
- High Oil Pressure
- I'm back
- Diagnostic connector pin-out help
- Pulley
- longtube headers
- Whats the size and length of our radiator hoses?
- question
- MAF code and both rear O2 codes?
- I need some help!
- strange sound
- ls1 to ls6
- charging issues
- Crane Cams Gold-Race?
- Fluctuating oil pressure
- First performance part
- Flex Fuel
- 2002 z28 is ticking
- LS1 Capability Questions
- Need some help PLEASE
- 2002 z28
- Head Gasket Questions:
- Trouble Codes. Bad cat?
- Welcome to the LS1 Based Engine Tech Section!
- over-revved v. what could I have broken?
- v6 to z28 engine and trans swap
- low/rapidly changing oil pressure
- Looking into a WS6
- Driving but knocking.. Advice please
- Best oil?
- ...ls2...
- QUESTION on gears?
- Automatic versus 6 spd longevity?????
- 6,650 for a 130,000 mile mystic transam
- LS2 intake on a LS1
- miss fire and i need help
- Another LS6 install question
- Stupid Question... Oil Pressure Switch
- sts turbo
- another hp guesstimate
- Weird sound
- hypertech powerstat wont fit????????
- Two Questions regarding "un-stocking" my car...
- how does spun bearing cause oil pressure drop??
- throttle body bypass
- Got your custom LS1/LS6 programming yet?
- Can a Tach be corrected
- When does the F13 and F14 power band end?
- Need Help
- LS7 crank... can you change the tone ring?
- 402-408 LSx mileage
- 400 hp kit
- Corsa + LS1 + LT's; Sound Clip?
- How does the air filter go in?
- Where Am I Going To Find It?
- Cam Bearing in the oil pan ???
- engine idle
- 228/228 .588/.588 112 Comp Cam??
- Cutout pipe size question / help
- AC delete
- How many...?
- Big savings on LS1 custom programming - save up to $50
- FTRA Sale - Wednesday Only!
- Piston deck height(LS1)
- Ah! Horsepower..is fading..
- whinning noise
- defeating spark knock?
- Lunati Voodoo cam vs. all other cams
- Comp Cams versus Thunder Racing Cams
- Took my car to the shop.
- Replace LS1 rear main seal
- oil missing?
- I think I need a retune.. Levels off at 3k RPM.
- Bad Engine Noise
- 2000 ws6 not starting
- ls1 oil pan
- Anybody running the Patriot 226 cam?
- How Do I ID a set of SLP heads?
- Ticking... (MY car this time.)
- Carbed LS1?
- shifting techniques w/A4
- Starting problem when I refuel
- 6.0 L camaro?
- LS3 engine specs released today... 436HP
- what gear ratio
- Car Hesitates
- how much gain yelded with true duels on stock manifolds?
- Knock Sensor
- what Y-pipe to get?
- LS1 Engine Diagnostic Codes Lists.
- Will I need injectors and a pump?
- strange ticking.. but not piston slap
- Stupid Header question
- New Air Intake Problems
- Another O2 Issue
- Engine oil and Coolant
- Hot headers?
- Oil leak help
- Fuel System Problem
- Replace LB9 to LS2
- Couple Vette Vids I Took Today!
- oil leaking from trasmission
- Need help on my next mod
- G5 cam. input?
- oil pressure prob. please help
- anyone using these lifters?
- Price difference
- Good Deal for these Heads?
- opinions on TSP Torquer V.2
- Asp Or Slp
- LS6 intake mani
- ported and Polished Shaner Throttle body
- oil capacity?
- When is it nessacary to?
- Starter Removal
- Best Head/Cam package
- Whislte or humming sound?
- FYI.. TSB For Oil Pump O ring.
- tapping and ticking sound
- Air Filter Oil
- Figured out noise
- Need Help!!!!
- Difference in SS LS1 & Z28 LS1
- need some info
- replaced cats, SES light still on
- E.t.
- Which cold air intake?
- Belt Issues
- Coolant missing in 2000 Z28?
- TB bypass on a LS1?
- Problems with my car...I have the codes...plz hep
- Another oil problem
- Newb Question: What can I expect from this Head & Cam combo (idle, power, etc)?
- Cleanup LS1 engine and compartment
- So what gas mileage should I be getting M6?
- F14 High Lift
- Few cam questions...
- New cam but no 12's
- good ls1 tech websites?
- LS1/LS2 engine builders
- SI6 vs FM15
- Whats a fair price on a stock low milage ls6
- Possibilities?
- 640hp Camaro SS (vid)
- MS4 Lifter knock SOLVED.. Oil concerns SOLVED.
- 80mm BBK TB...worth it?
- Confusing oil issue...
- The bottom end just let go.
- upgrades
- Gouged block deck - repairable?
- Hydro problems...
- putting offroad y-pipe on 99 ss some ????
- hard starting causes
- Help with performance upgrades
- LOUD MOUTH ON 99 SS ?? will i keep my original hp? go from 320 or just stay at 320 ??
- how much does a new LS6 cost?
- What about GorillazChip?
