View Full Version : LS1 Based Engine Tech
- LS9 Technical specs released.. pics
- bad engine noise..
- Help, what goes here?
- Anyone know O.D. of stock LS1 valve guides?
- Florida Gas with 10% ethanol??? Good or Bad?
- Anyone running the fast 78mm intake?
- which one?
- threw a code today
- plug gap on F-13?
- Vibration after water pump install
- Oxygen Sensors
- parts for heads and cam
- Imagine these heads on the upcoming ZR1.
- LS1 Heads
- How Much Would It Be To Switch From A4 To M6???
- heads @ cam
- harland sharp rocker arm install problems
- TB difference!!
- Did I miss the small things?
- Casting Numbers? 241 casting heads
- Pressure washing an LS1
- So is a lid worth the 80 or so dollars?
- LS9 Info!
- LS1 intake
- How long is the dipstick?
- LS1 vs LT1
- Help, help!! Pacesetter passenger side instal, (PICS)
- GMPP LS1 GT-2 Heads
- roller rockers?
- something gone wrong with cam swap.
- Help Please!
- i know i know...next mod before retune?
- 2001 z28 with 93000 miles...buy it?
- Ever heard of this manifold??
- affects of degreeing a cam
- check your LS1 A/c belt tensioner!
- Manifold for CNC-Ported LS2 Cylinder Head
- Project Turbo GTO @ VRE
- Which one will I see more gains with? LS6 Intake vs Ported 853 Heads
- 6.0 Head flow numbers? 317 Casting
- missing crank bolt
- ASR and SES lights on after LS6 intake swap
- Royal Puple
- dyno runs on the 408
- Lunati Rotating assembly
- Can't tell if it's leaking Antifreeze or not...
- Would This Help
- Pilot bearing replacement
- how do you put springs on with the heads still on?!
- Cheap N/a 700 rwhp
- DD Setup??
- LS1 swap officially started, stage 1 pics!
- I need help customizing my 2002 Camaro SS. Please Help!!!
- bolt broke off in crank pulley
- Is this too risky?
- I need some pinouts of these 98 LS1 connectors (c100, c105, c210, c220, c230)
- Squealing + Coolant Issues
- Need help with my LS1 in 1996 Z28!
- lt1 to ls1 swap
- Question regarding L76's
- I know....another code thread..
- cam & heads confusion
- Help with error codes, 01 Trans-Am
- Mild cam and Stall converter HP gain
- Z28 To SS Conversion
- Vette LS2 and GTO LS2 Differences??
- Air Box Lid
- My car wont turn right away? Video Inside
- which intake
- what would a ls1 sound like if a 918 spring was bad?
- Great fuel milage, what happened?
- Pics of TB Bypass?
- 1/8 run
- Changed out idler pulley, problems.
- Max RPMs with heads/cam??
- Engine Swap...
- LE1 heads and cam = 10s
- Coated main rod and cam bearings?
- Maximum rpm for oem lifters
- What kind of power is a Full Bolt On m6 ls1 putting down?
- misfire?
- thinking about a LSsomething in the jeep
- valve tap? Higher Octane??...read.
- overheating & a/c issues
- LS2 manifold fit LS1 maybe? ?
- LS1 Oil Pan Gasket...
- 4 SES Codes at once all of a sudden?
- service engine light on!!
- Engine Coolant
- 2004 GTO Powersteering on 1998 LS1?
- Drvier side coil bank misfiring no SES light
- P0507 code and 2000 RPM idle
- Cometic vs. GM MLS Head Gaskets
- 2000 LS1 Oil Pressure Sensor on a 1998 LS1????
- What is the measurements of the LS1 Oil Pan bolt?
- Factory engine temp accurate??????
- So i kind of have a problem, engine wont start...
- changing oil today,what should i get? 61k ls1
- LS7 cam specs?
- SES Code P1416
- LS1 Cam Swap Vid on quickperformance.com
- Timing Chain Tension!!!!
- How hard to change plugs and wires on LS1?
- How much of a gain should I see?
- Record breaker PaceSetter LT install!
- need help getting oil filler neck off...
- 98 Racetronix Plug N Play Kit
- Whining noise?
- Dynatechs?
- Cheapest place to get LS6 Crate ?
- Caddy racing hyd roller lifter question
- cam specs
- Pick me a camshaft...
- Idle question for cammed untuned LS1???
- First mods for a 07 Z06?
- Lsi Throttle Cable Failure
- 98 LS1 vs 99-02 LS1
- How to check PTV Clearance w/ Play Doh?
- 99 LS1 Z28 with high idle speed
- cams....
- True Dual question
- k&n fipk
- easy free mods
- Homogoneous Charge Compression Ignition
- Question on LS1 Pacesetter/ Cat Y Pipe
- What gear ratio do i need??
- msd 8.5 wires
- What do i bore 5.3L to, so i can make 5.7L?
- Clogged Cat/Random Misfire
- LS1 in my 96 / LT1 Gauges on LS1 Engine??? Adapter??
- Loose starter bolts?
- Where to look for block
- 100k Tune Up
- '98 LS1 or '00 LS1 ? Choose 1
- Anyone running bbk ssi 85 intake and throttle body
- LPE:Lingenfelter
- obx longtubes
- which should i do????
- Pulley bolt?
- 1 Owner a.t. black mint 48k miles 10g's Good Deal?
- LS1 Water Pump, How difficult is it to replace?
- good head cam package
- 2000 headers on 98
- how to delete tube in air box?
- LQ4 Drop-in question, can i use 98-02 Wiring harness and PCM?
- 99 SS Power Steering Pulley
- What size bolt to put LS1 on engine stand?
- I have a strange hose in my engine bay.
- hottest cali legal cam
- SLP Heavy Duty or LS6 Oil Pump
- 500 Rwhp Possible?
- Stock oil pump for cam? & Timing Chain Q.
- First order of business
- Whats the best choice
- LS1 Hot cam or TSP 224
- pcv valve
- Aren't LS1-s Head gasket failure prone?????
- what heads to go with
- 671/871 Blowers for LSx Engines
- Head Flow #'s.. FYI..
- GEN V direct injection 6.2 L92 well north of 450HP....
- Help,i hurt the T/A, i need new heads,cam
- Any interest in a throttle body dress up plate?
- Lifter Noise
- How much wear do mods really put on you car?
- Extra $2,000 What should I do?
- I Want Alot Of HP Gains On My Stock Z28
- Finally did the TB coolant bypass
- Bassani y-pipe
- car turning off
- 98-99 lid on an 02?
- Voltage problem...
- Tune?
- EFILive
- Power and Gas mileage?
- 2000 z28
- LS6 swap into lt1 car?
- High idle after cars warm/driving
- car got hot yesterday
- Car has problem starting! bad alternator?
- HPE S2 cam?
- Throttle body Water Bypass Kits ?? ID
- 408 or 418
- EGR Delete now too lean
- About to purchase 99 Z28 ... Thoughts please.
- LE2 heads/cam?? Who's running them?
- Possible the oil pump could be goin out?
- FAST intake and TB
- MAF Pops out of lid?!?!?!?
- Ls7 Ecm/pcm
- what can I do for more HP
- LS1 Silverado? LT1?
- fan question
- How hard to Install Exhaust???
- Who makes these headers? *link inside*
- Difference between 1999 Camaro Z28 & 1999 Camaro B4C Z28????
- 1998 Z28 shuts down at random moments...
- What would you spend $300 on?
- LT header install
- What size injectors in a 1999 LS1?
- New motor: oil pressure low at hot idle
- whats next
- Brake, ABS INOP, and service engine light
- Best exhaust gasket?
- LS2/L92 buildup questions
- "The recipe for 500 RWHP." - LS1Tech thread! WOW!
- Cheatr cam
- No oil pressure
- 0w-30 Synthetic Oils
- Does anyone have an LS1 That doesn't have a squeaky belt???
- 01 6spd z28 surging when going through the gears
- Help me pick a project!
- Gen III 5.3L Vortec Block Question...
- Gtx
- Look at local LS1 t/a
- what intake did a 99 corvette come with
- Who has Hooker 1 7/8" Longtubes?
- Soon to be LS1 powered, questions
- Would you buy it?
- LS1 Intake question
- 35th anniversary Dyno results
- Dyno results from a Patrick G tuned TRAK cammed car w/PRC LS6 2.5's
- Vacuum Leak - part numer request
- Noise around Water Pump area
- Regular Stock 98 Z28 Whats Tha HP On That
- TR-5 vs. Tr-55 Plug
- How much HP can 346ci produce? Full internals and boost.
- just got a slp ss hood, airbox options
- induction ?
- Racing fuel???
- AIR / EGR whats what?
- Pennzoil vs. Mobile 1
- slp cai, rubber seal install ???, help!!
- Airbox elbow hose question
- Cam ?
- Who say an LS2 (or any LSx) can't look nice
- Stupid question
- Burning Lot's of Oil!
- Camaro's playing mind games with me...
- 2 new alternators and still no charging
- Differences in 98-02 z28
- 87 octane on an LS1?????
- Best Year for C5 Vettes?
- just did the header install...
- coolant ever leak out of headbolts?
- t/a exhaust
- Low coolant light
- Corvette Vortex air induction on an Fbody
- Best way to get 500rwhp out of my new LS1.
- PCM Error or am I looking at trouble down the road?
