View Full Version : LS1 Based Engine Tech
- 2002 Z28 0-60 MPH time..
- Which one of these inside cluster panels is correct? Details inside
- Power window problem
- Cowl Hoods for 98-2001 LS1's?
- Dustless brakes?
- making a Fbody handle like a Z06?
- What all needs to be upgraded to add a supercharger?
- mixing GAS...100octane with 91
- Fuel economy on new SS sucks!!
- B4C = NO BIG E
- I just read this comparison of Camaro-Mustang
- Loud noise from the rear, please help
- i know this sint REALLY camaro but.. huge engine...
- Who makes this!!!
- Heads and Cam ????
- Z06 question
- 6.0 liter Camaro 1994
- Is the MAFT version 4.0 OK?
- Tranny cooler lines?
- M6 Shifter?
- Strut Tower brace?
- Window Motor Replacement - Any Tips?
- SLP Smooth Air Bellow
- what are pullies worth?
- $28,000 for 2002 loaded SS
- Cracks in rear end housing
- Will this part work for my car?
- New to HP
- b4c police camaro-worth the money?
- Break in period
- Help Needed w/ Clutch/Slave/Master/Flywheel
- Having engine work done - what do you think?
- who sells scatter shields
- 2002 Z28 35 aniversity HP rating and rear gear ratio
- Random tech exhaust tips?
- pics of lowered firebirds with GFX needed
- Production #s of Firehawks
- MTI b1 cam shaft? Cam Newb here help plz
- wierd clunking noise
- piston ring upgrade????
- gears and ac questions......
- FACT: Stock 99 SS rims are 9.5" wide
- why is 3rd gear grinding?
- Trouble code P1639 ?? HELP HELP
- Knock coming from somewhere
- Free Mods, Warranty question!
- free mods
- Headlights
- This sounds like a good price too me.....
- Do I need a new fuel pump? It screams when doing hwy speeds. - Confsued
- No sound deading material = hotter inside temps? My Car is hot as hell inside!
- A/C not kicking on, what could it be?
- long tube header question
- Best bang for buck mod for low end torque?
- Spectacle Solutions SFC's
- Helms worth it or not?
- Heat / AC Vent Flow Question
- Planning some upgrades, need suggestions.
- New car pix...new seats too!!
- Turbo Kits....
- Should I disconnect battery after new aftermarket parts installed?
- need hooker y pipe # for jegs or summit
- Exhaust Preferences?
- Gas shocks or not?
- Question about Clear corner lenses
- Installing a tstat and exhaust
- Larger Oil Filter for LS1's and the new truck engines.
- car popping and loss of power
- Shopping for 02 WS6
- What to bolt on next????
- warranty question
- I testdrove 02 SS w/ 26 miles should I buy?
- Underdrive pulley?
- wheel question
- Clear MTI lid questions.
- LS1 hp change from 1998 to 2002?
- Where to buy Grot Headers
- What is a good '02 SS price?
- SFC install help?
- Hypertech or SLP????
- Need bulb info
- knocking engine....
- 98 Z w/ 8000 miles
- My SS, Factory defective roof panel paint, dealer agrees to re-paint
- Headlight problem, help!
- Traction Control Questions
- HyperTech Questions
- SLP is a horrid horrid company...
- What should I expect......
- GM sticker
- Stage 2 heads, and cam
- LIGHTS OFF?
- What is the ratio in my rear?
- what are you bolt-on LS1 guys getting for rwhp hp/torque?
- 2000 Piston Slap?
- Cheap goodies on ebay. Shocks and T-top
- 2000 SS Concerns
- My time sucked!!!
- Installing Hooker LT and ypipe tomorrow any advice? (installation site?)
- Suspention help
- Slp CAI, how well does it work?
- Cat modification?
- Vig 3200 install problems
- Need a rear end for my 96Z28
- Weight of LS1 Z
- Help car wont start
- Flushing Rad
- Tapping noise from engine
- LT1 catback on a LS1
- Need help with HPP tuning. I can't figure this out for the life of me. AUUGHH!
- help low idle wont hardly turn the wheel before 4:30 7/03/02
- Picked up new SS
- Driver's Door control panel is loose!
- Important exhaust question
- Ride height in 2001 Z28 .... what are the stock options?
- Does anyone have info on the 99 LS1 302 camaro
- Skip Shift Eliminator
- TR 230 installed, seriously depressed
- Hypertech problem.....need help
- hello all
- 2000 camaro ss vs 1999 lighting
- best headers
- Please Help me!!!!!!!!!!!!1
- Sugestions on Suspention
- Anyone have a Super Sucker?
- 2000 LS1 vs. VTech Integra
- What year SS to buy?
- exhaust question
- Eradispeed?
- Opinions on Mufflex 4" exhaust?
- Top Speed of Z06
- Problems with Eibach Pro Springs
- Bassani catback exhast
- Free OBD2 Scan Tool Software
- I need help getting a 110 mph trap speed!
- GREAT SLP "Loudmouth" GP
- Holley or BBK TB???
- Which one would u choose?
- Need part#'s for LS1 & LS6 Crate Motors!!
- Setting REV. Limiter higher???
- Anybody here ever hear of this tuner?
- Any NHRA Edition TA/Formula owners here?
- Gift
- do the the massair meter ends work?
- Looking at buying a 2001 WS6
- 2002 Camaro Transmission!!!!!!!!!!!
- Tranny dipstick --- stuck (on a wrecked car)
- Hypertech powerstat & regular thermostat, any difference?
- WS6 number......
- any recommendation for a good chevy body shop
- Flows and warranty
- Post up pics only if you have done cosmetic work.
- Performance Axcel
- Whisper or SLP?
- Head and Cam Install, in progress!!
- Corsa and Y Pipe
- who's got a grannetelli 255lph pump in there plastic tank LS1 car?
- Where can I get an Off Road Y-pipe?
- Panhard Rod Question
- Lower Control Arms... Which ones do you guys think are the best for the price?
- B&M Deep Transmission pan... Good or bad Idea?
- dyno in nebraska?
- SES light on (O2 sensor help)
- Need Some Suggestions
- what would it take to run high 10's?
- What GFX and Hood is this for LS1 Camaros?
- Anyone ever build an LS1? Question about LS1 pistons
- Shift kit?
- got catback, now need more!
- DAMN third gear ... DAMN IT TO ... *burp*
- WS6 Airbox?
- Trouble w/o2 simms and hooker LT's!
- 98 LS1 Z28 Stock K&N Replacement Filter
- Opinions and Experience with Cat-Back Systems
- 01'head flow #'s
- LS1 engine price
- Ls1 and the LT1- is there a big difference?
- How reliable are tire plugs?
- tink from the rear......
- Looking at 2000 T/A WS6 --- opinions needed
- Opinions NEEDED...
- Corvette LS1..... $$ ?
- cut out question
- oxygen simulators
- New Person, Old Question
- exhaust install question???
- Question about A4 shift kits
- LS1 MAF Question
- Highest Horsepower on a Street Car
- Would it be worth putting a LS6 intake on my car?
- Has anyone heard of a WS-7 hood?
- Looking for pics of a WS-7 hood???????
- True Horsepower of LS1 in F Body
- difference between aluminum and steel street twin setup?
- What's a good clutch for an LS1?
- Help with Street Twin..Please!
- How much $ to Gut Cats?
- 18" C5 rims on a SS??
- What should a used OČ sensor be ? Tan ? Black ??
- Brand New '02 SS
- Tires Rubbing against bumper jounce spacers
- Anyone used the Super Sucker?
- Wheel mounted stereo controls on Z28?
- I need help removing my front grill.
- Air filter question?
- Problem when driving over 75mph
- LS1 Edit different for 98-00 and 01-02?
- v6 to a 385 hp?
- oil pressure
- recall affecting the 2002 Chevrolet Camaro & 2002 Pontiac Firebird
- Mobile 1 15w50 Synthetic Oil
- fitting 17x11"
- Used Loudmouth
- Where can I get:
- Trans Fluid and Differential Fluid
- Can I fit 315 sized drag radials on my stock 9" SS rims?
- will afs z06 18x95. all around fit my 98 SS?
- Please see link - has anyone here ever had unexpected acceleration ??
- help vortec or pro charger
- What's my ratio?????
- E-brake felt like it broke
- Does K&N make a good oil filter?
- ported and polished throttle bodies, are they worth it???
- Has anyone with an A4 and stock 2.73s broken their rear? If so...
- lookin for the "right" camshaft kit...
- Engine "Q" from downunder.
- 02 sensor question
- Subframe connectors, which brand?
- Multiple Misfire Codes
- Anyone Using a Tazzo or something like it?
- Help with WS6 suspension tag codes and numbers
- dumb cutout question...
- Should i get hypertech?
- What mods to buy, where to buy them
- ne 1 got a procharge supercharger on a lsi
- Multiple Misfires
- will slp dual/dual mate up to my current magnaflow 3" I-pipe?
- Funny Noise & Tire Pressure
- Need help......
- How much does an empty T-56 weigh??
- Installed cutout yesterday
- Link exchange?
- New Autotap software coming soon! (long)
- Anyone remove their gauge needles?
- check out the deal i got on my 2000 Z
- If you have 2.73 will it show 1st gear in the gear selector?
- Can anyone identify this exhuast? *video inside*
- Backspacing?
- silver anniversary SS?
- Part # Request Please
