View Full Version : LS1 Based Engine Tech
- Would an X-Pipe fit under these cars?
- California Emissions
- need advice on driving 6spd
- 1999 Z-28 Gas Pedal Sticks...
- What type of epoxy should I use when I port my TB?
- SLP mass air flow sensor?
- Oil consumption Q? 500mi/quart?
- Injector cleaner
- Just got DynoMouth Installed
- warranty
- Guages?
- Saw A Monaro (GTO) Yesterday...
- aluminum driveshaft w/ performance axel?
- 370 HP on stock Trans AM?
- Differences between 2001 and earlier LS1's?
- I need a big favor from you guys...
- gas mileage decreased after installing Airfilter & Lid?
- Anyone make bolt in O/R Y-pipe for 00' (stock manifolds)?
- Cartek: anyone running their engines?
- Cost to Install Rollbar
- Cheapest place for tires?
- Posting for a friend, PLEASE save him from himself
- LS6 Heads ???
- 2002 LS1 Cam Specs
- New to me DRL disable actually works!
- SLP Engine...
- Who makes this part for the F-body? I've only seen it for the Vette's.
- Does a lean mixture cause detonation when.....
- 03' Cobra info....for those who want to be informed.!!
- Cost of changing rear end gears in Philly area?
- Air Lids
- LS 6 crate engine !!!!! Where to get?
- TB bypass
- Anyone have the A-piller guage pod in thier F-body??
- How much more do the convertables weigh?
- '03 Mustangs still slow
- Need a few tips/help with SLP LTs
- HP with these mods
- Antitheft Radio Code
- SLP Air Temperature Module
- is the clutch going?
- What's Wrong With My Horn?
- very odd problem, hard to describe-98Z28
- How often do you have to add oil?
- Axle Ratios
- Need help Bad!
- Looking for a dyno
- Help, SES after SLP Fan switch install.
- clunk in back when lettin out clutch upshifting in new car
- Is this normal?? >>>>
- Edelbrock?
- LS1 or LT1
- SES light after body work and exhaust
- Is there a REV limiter in neutral?
- Can you have too little backpressure?
- yellow grease on ac accumulator
- Low voltage on MAF?
- EGR Block-off kit? Is it worth it?
- SFC's
- MAC Mid-Length Headers
- option codes????????
- Power gains with ARE Stage 1 Heads+Cam Package?
- HELP!!!
- Will an SS 'smoke' a Z28?
- 35th Anniversary 0r SS 10 spoke wheels
- 98 Z28 - A4 - FIPK / K&N Flowmaster
- GW Trac-link setup question
- Pro Performance heads. Urgent, need some type of contact info.
- Will an aftermarket throttle body help if i have a TB Bypass?
- Factory CD player problems
- Need help with T/C lock-up switch
- do ASP underdrive pullies affect driveability?
- Long tube headers: FLP vs. SLP
- OK.. How much damage did I do...
- Anybody here block off EGR and AIR??
- Look what I found on AutoTrader -->
- Dynomouth Question
- hooker exhaust
- Tired of the knocking
- NEW PRODUCT - Timing Tuner
- Granatelli MAF.... 10-15 RWHP??
- Why does my computer reset upon most startups?
- Phantom oil pressure sender...
- How hard is it to change your gear? I have 4.10s and want to go with 3.73's.
- anyone have pics of their rear brakes 98+??
- LS1 HotCam Package Owners?Opinions?
- Exhaust question
- stall????
- Exhaust ? SS SLP Dual Dual or Loudmouth ?
- Shifter Spins Around Part II - Not a hoax
- What should this run
- Most powerful LS1 Cam?
- How much are my gears hurting me?
- Confused, Need Some Input!?!?
- Whats involved in putting on a new muffler?
- Need wiring diagram for Silverado
- can someone run a carfax file for me
- Daytime running lights - any way to disable ?
- Lid Questions SLP,Whisper,Ect
- Timing computers in stock NOW!!!
- what would it take for an ls1 to make 390rwhp?
- difference between crank and underdrive pulley?
- 1998 T/A vs 2000 T/A
- This normal.......
- Mcleod street twin owners come inside
- My drivers side window doesnt work - has this ever happened to anyone else?
- Corsa Cat Back
- Who sells a TB Bypass kit?
- Anyone know how to get rid of detonation?
- Major problems with my LS1, need help badly...
- New Guages
- Do these numberst sound right?
- Floor Jack for Lowered Car
- which rear end gear do I have?
- what should this car run..
- does the LS1 have roller or flat tappet lifters?
- Fidanza Aluminum Flywheels
- Need Some Tire Advice
- SLP LM Legality Issue
- pin stripes?
- Loose Doors on Camaro with window down
- gear question...
- Crome-moly STB....Worth It????
- Electric water pump...
- Differences between Formula/Trans Am?
- Front End Rattle
- Car shakes/wobbles slightly when slowing down
- just got in my SLP Lid & Holley Powershot filter.
- air lid question #4873649873742397
- Sway Bars or Subframe Connectors
- Qtec electric cutout owners in here
- I am stuck about what to do next
- 2002 SS LE
- Z28 -98
- What mods can I do that wont void warranty?
- Anybody want an NGK spark plug sticker?
- Fidanza Flywheels
- Two Things I really need answered
- Oil change question
- I need your advice on selling my 99 Trans Am
- Will a new shifter help me?????
- LS1 & T56
- 360RWHP with bolt ons, is it possible?
- Runnin Lean....
- Will i gain any horsepower by switching air lids?
- Advice needed....Should i get gears(4:10/3:73), or will i break them??
- Girls have nice cars too!
- STB's And SFC's
- new tires
- Goodyear Tire question
- What would an LS1 dyno on an engine dyno?
- Some jerk keyed my car
- Move Coil packs to Fire Wall?
- Anyone know someone selling a Camaro?
- What size fernco pipe?
- trans am vs. z28
- Insurance Rates
- HELP bad gear experance
- Wrecked Y2K SS..Should I Buy?
- vortec
- Quick Question
- shiftskip eliminator question
- help!
- What is "Special Service Vehicle" mean on new window sticker?
- Short throw shifter makes noise
- Spectacle Solutions???
- Air Box Lids
- Intake manifold style supercharger
- Where exactly is the thermostat?
- C.A.G.S just in automatic or manual trans also??confused..w/in
- How can I clean my fuel Injectors?
- Gtech - Tazzo numbers....?????? What U got?
- tapping noise up front ? Lifters?
- Next gen F-body (If you had your say so)
- Yet another fuel economy question
- Anybody here swapped a '98 instrument cluster into a '99 up ?
- New Exhaust for my Z
- How much for this car?
- Does this insurance rate sound right??
- Whats the difference between the 98-00 & 01-02 LS1's?
- Where can I find an SS grille insert ?
- Gear Shift Spins Around !
- Aftermarket ECU choices
- LS1 durability/How to convince parents
- HELP WITH TUNING
- g2 springs&slp bilstein shocks
- Ported MAF=lean=will throw code right?
- buying a 2000 trans am
- TA/Firebird Clear Front License Plate Cover, Replica of GM Painted one at....
- Money on Z28 boost or C5???
- Anyone know anyone in Florida (ST.pete, clearwater, Tampa, branden)
- HP on 2002 Transam
- Hypertech???? Or Chip?????
- Woo Hoo! Look what I did yesterday!!!
- gas mileage woes with brand new car
- Where does your alternator gauge sit at?
- Need help with LS1s! Friend wants to SLAP on a blower
- Looking for a 2000 T/A
- SS vs Z28
- Best Exaust for 99 T/A
- basic shift light ...
- Converter lock-up???
- Easiest Way to Gain 400HP?
- 2001 Center Mounted Exhaust-problems?
- exhaust tick on 01 ls1
- SLP LT owners inside please.
- has anyone heard of these performance mods
- Grrr, more turn signal woes
- Transmission Questions - should it do this?
- what rear end fluid to use?
- help! i need some info
- Slave cylinder?
- Powershifting!? From ls1.com's FAQ
- What is a cutout?
- Need help....Trans is screwed
- fipk pics
- SLP springs.
- I want to know where this got got one of these! LS1Edit?
- Need Advice For next Mod!
- Gauge faceplate ... identical in Z28 and T/A ??
- Rear End Making Clunking Noise... Please Help!!!!!!
- Gauges
- I have been gone a while...this has probably been beat to death
- my foolishness...
- Is there a way to do the bumpstop mod w/o one of those special tools?
- diferences in seats
- Weight and Handling
- Dynomouth Installed: Comments.
- Flowmaster 80 Series into stock WS6 tips?
- Where to buy a Magnaflow locally?
- what would these mods get me?
- Instructions for springs.
- Are NGKs the best spark plugs?
- Anyone drive around with the cutout open all day?
- Clutch stuck half way? Please help.
- There is a 35th still for sale in Texas!
- How much should I pay for a new '02 Z28?
- Dynoed my T/A for the first time-nubmers inside...
- 325 rwhp from a lid and Dynomouth!
- Gutted Cats
- How much to tie-rods cost? I think mine are going out...... not sure though
- Difference between LS1 and 1LE aluminum 4th gen driveshafts?
- What exhaust for loud but not raspy?
- SLP Loudmouth exhaust
- ride height?
- How to install coverter lock up switch?
- This is dumb.. Wipers don't work--suggestions?
- Pics of Dynomouth!!
- HELP PLEASE Who would have MSD Injectors Part# 2013 in stock??
