View Full Version : LS1 Based Engine Tech
- Thinking about switching 2 a pony
- NOS system vs. Supercharger
- Here are finally some pictures of my car!!!
- where can buy hookers for payments??
- Is this a great deal for my 02 ls1 z28?
- Car Covers
- Bosch Platinum +4??
- New GTO and CAGS elimination?
- Last Camaro made has been sold
- "old school" billet grille
- SLP bellows.... Worth it?
- Faded leather seats, need replaced under warranty, Questions
- Let's spend some $$$
- exhaust install
- Good Exhaust?
- HAZZY HEAD LIGHTS
- TR 230/224 reverse split cam?
- What size are the bolts provided with the pro 5.0 shifter
- A question for V6toZ28
- Car wrongfully towed!!!
- Engine ruined. Where to buy crate engine?
- Just installed SLP LS6 intake
- HEED HELP FAST!
- Newbie here
- 'Last' Camaro Sold for $71,500
- another gear question
- FTRA question
- Bad synchro?
- I'd kick my car in the balls if I could. I'm sick of screwing with this prob. HELP!
- Rear wheels rattle
- Can someone run me a CarFax please?
- cam question for bolt on car!
- air filter
- What am I getting in to??
- SFC's?
- Battery Relocation?
- LT1 Or LS1... Need Your Input..
- GMMG
- S2 or Thunderracing Throttle Body?
- Reliability of a Procharger?
- Which brake pads?
- Hurst or stock 6 speed?
- SLP Ram Air Kit, does it really work?
- How much would a cam do for me
- CAGS.. why does it bother some of you so much?
- How much for 2002 WS6
- T-56 tranny
- Z28 or SS
- Who makes a Billet Aluminum fuel door for Z28's
- Shopping for Stall
- Does the factory Hurst shifter have?
- air intake opinions
- Supercharger, or Heads/Cam...
- Stall Converter Questions
- Ram air question
- 02 SS Trouble Codes
- Z28 Questions
- Need exhaust
- Acura NSX Challenge
- Hooking up the postive lead and negitive lead on a Electric cutout
- Hotchkis strut tower brace on 02 Z
- Sound of Borla w/ open plate vs. Loudmouth
- Need more power!!!!!!!!
- Compare LS-1 SS vs. LS-1 Vette
- Joining the Dark Side...
- Expected gains from TR220 and TTS LT's
- steel braided brake lines
- Mac's vs. Hooker LT's
- Electronic Cut-out???
- need help fast----trans dipstick tube ?
- What is the -first- mod you would recommend - 2002 SS?
- Recommended tire pressure?
- Bf Goodrich G-Force T/A KD or KDW
- Ported MAF Ends or SLP Smooth Bellows
- Smooth belows for $25
- Z06 Gauges for F-Body?
- T-top shades????
- Factory stereo plays CD-R 's ?
- What is the best interest rate GM will give me on my lease vehicle I want to buy?
- Gauge cluster dead part II, next stop $$$dealer$$$
- What will I loose if I remove the ABS
- Identify this rubber plug?
- Finding out SLP options
- 03' Mustang Cobra vs. 02' Camaro Z28
- How to make up for elevation?
- Need Help with ls6 intake and no egr on 98 ls1 !!!!!!
- Hypertech Programmer Pinging
- Lights Flikering - has anyone had a similar problem?
- Clutch acted goofy....
- at the track, do you?
- Clutch Pedal Gets Real Hard Under High RPM Shifts??
- Tranny temp guage install Q
- new to board
- Non t-top Formula $'s
- Switches
- Dynomouth quieter than the Loudmouth?
- oil change question
- How do I adjust the horn??
- Not your normal Clutch Question
- Aluminum Flywheel?
- Any tricks to taking out the gauge cluster ??
- How can I make my SLP dual-dual louder?
- how accurate is the gas guage?
- True duals...help and opinons wanted.
- Y pipe welding
- Best headers that are emission legal for best price?
- anyone have a towing hitch installed?
- APHR ball end fitting ?
- Coin holder? Did you car come with one?
- Need help........fouling 1 plug????
- Free mods?
- LT4 or LS1, give me your opinion.
- oil pumps on the LS1
- How much will 3.73s help a stock LS1 in the 1/4 mile?
- best cat back
- rate the difficulty...
- relocated coil packs
- GMMG customer service not good
- Autometer Air/Fuel ratio gauge not working...
- What is the fastest stock bottom end LS1?
- Amsoil
- How hard to install a torque converter?
- GM Factory Replacement Gears?
- LS1??
- Which year LS1's have the truck cam?
- How many miles can I squeeze out of stock clutch?
- X Pipe
- Grinding Noise
- Gears vs. Power
- Cutting out two cylinders?
- SPARK PLUG CHANGE
- How many more horses with a muffler change?
- Chirpin cricket under my hood.
- G Tech Pro times
- SLP vs. FLP Headers
- Anyone know what kits works to put freon in the compressor?
- Who here has a Magnaflow exhaust system?
- Newbie
- ASR (traction control) troubles
- Plain old Corsa??
- fbody hideout?
- Anybody heard of Shandy PRice
- Good High Flow CAT?
- Rearend help!
- EGR on LS6 intake?
- Just bought a '99 Z28 with 10,000 Miles!
- Anyone with aftermarket pulleys?
- Mac Headers???
- Is porting the mass air flow housing worth it?
- Okay guys, help me pick out what springs to get...
- air box lids?
- those with Lou's short stick
- Do you guys run stock tires at the track?? you have to read this...
- Metal Shavings on drain plug
- Ford 9" Questions and observations.....
- Anyway to have a battery checked?
- flasher unit
- Help what is the stock offset
- Holley Powershot or K&N?
- How do I find the build number for my SS?
- Differnec in c5 and fbody cams?
- Anybody running a Charged Air radiator?
- How smart is the PCM ? Can you have engine/tranny (A4) "burps" & NOT throw codes ?
- install cat back on a 99 ss
- Lids.... Looked around.. Made decision...
- Z06 engine in a F-body?
- Stock Shocks with a 2" Drop
- Is this worth it?
- Does this sound like a good deal? 98Z28 for $7200.00
- any other good places to meet girls besides the bar scene
- NEW CAR
- what to use to hold the rear ground effect
- how do i remove the E brake handle
- I need help...Anybody have an LT1 front clip on an LS1?
- sweet just got an LS1
- Oil question
- Stock shocks (what are they)...
- How about a MacMaxMouth exhaust!
- Mobil One Synthetic Oil Pricing Error
- Removing the pass. side floor hump
- Lowering springs???
- is an air lid worth the money?
- Yokohama YK420 V rated tires
- i love this car!!!!!!!!!!!!!!
- Did your 98 pass its first CA smog check?
- What would you GO?
- what lid is this?
- Remove the baffles on the stock air box????
- Shifter installation
- Stubborn Oil Filter
- B4C interceptor? Questions?
- ? on the Hurst shifter
- Anyone put a 99-00 cam in a 01-02??
- Lifting car
- Stock timeslips for my mustang buddys to look at
- Stock location of shock sensor?
- How long Will LS-1 TAs hold their value?
- best stock dyno #s?
- Cam Install!?!?!?!
- lowered car need help!!
- Chiltons for 1999 camaro?????
- Smoke.........
- What cam provides the most power, and is it useable on the street?
- Loud Mouth
- Grand Opening/Dyno Day at NEW LPE SHOP!!!!!
- The Last Camaro?
- manual lock up
- mods that won't void any part of my warranty/
- 85mm MAFs: SLP vs Z06
- help ! any here with the slp factory quad exhaust on their ss camaro?
- Needs help
- Dynomouth installed!!!
- help with walbro 255lph INLINE pump!
- '00 Z28 Suspention
- 1st to 2nd Grinding
- Need cam suggestions...
- Just tried out my Mcleod Street Twin!
- Track problems
- Problem with long tubes?
- Need advice on choosing plugs & wires
- need o2 sims
- I need Ls1 Edit
- Lingenfelter Intake by Holley sold in Jegs
- Oil Pressure Sender/Gauge
- stock sway bar endlink question
- SLP Lid and MAF question?
- Good set of ramps
- Header Preference??
- Tranny Mount?
- Thinkin about plugs.. Can I do it myself?
- Anyone from st.louis?
- Trans-go shift kit ?
- SLP Loud Mouth or Borla Cat Back?????
- Do all 2000 camaro SS's come with slp exhaust?
- New SS
- Thinking about purchasing 2002 Z28...
- I finally saw a GMMG and Corsa.
- Hey, I have an idea
- What is this car worth?
- Where to race in Northern Virginia
- Z28 -98 vs vette 71
- Free computer dyno and dragstrip. It models LS1s too!
- FS: Stage 2 ported 99 LS1 heads MUST SELL!!
- Desktop Dyno 2000 - LS1
- Anyone cheaper than Thunder Racing?
- 2002 Flow numbers
- VIN Breakdown
- Do I have to break-in the engine?
- Going to the track on Friday, what should I expect?
- Hooker LTs and Eibach Sportlines
