View Full Version : LS1 Based Engine Tech
- Have you ever wondered how GM's LS2 V8 fits together?
- Help me find a thread...
- Bad Misfire
- Difference between these UDP's??
- LS6/T56 swapped S-10
- Uh Oh... Serious issues on the horizon... More than what I at first expected
- Replaced the Water Pump.. Still leaking Antifreeze..
- Greetings!
- Heads and Cam done; got some questions
- LS1 Number
- Denso O2's, please help
- Left bank not firing (LS1)
- Smoke related to headers?
- mufflers....
- Need some sites for performance parts
- LS2 w/ APS Twin Turbo- Twin Intercooled Kit
- EGR questions with PICS!!!!
- Need to go faster for around $5000?????
- Sne
- p0137
- California Emissions??
- People with FAST intake/tb
- how hard would it be to...
- Rev limiter....
- Fuel Management Technology-----??HOMEMADE???
- LS1(98) to LT1(97) Cluster Wiring.....
- 94 1LE or 98 z28
- Overheat Question
- Its not often you hear an LS1 like this..
- question about gears
- Squires Turbo System
- Introducing The All New 1 7/8" TSP Long Tubes!!
- WS6 Ram Air Intake question
- differences
- 6 Bent PR's and play in the crank bolt...
- SS3600 or SS4000
- Car wont idle with the clutch in.....
- Boggin! But why?
- just bought an 02 z28! fuel question???
- What springs are these??
- P 1415 error code for 98 z28
- Engine backfired, now the car wont start??
- gas cap code
- Pulled 4 codes lastnight
- 2002 z28 vin question
- Quick Identification Please
- Best converter for F13?
- Can someone show me the difference between vette and f-body fuel rails, valve covers?
- I'm ready to start a build... now what???
- L92 vs AFR heads
- air duct
- Maf
- New car and lots of mods!Cam?
- 408 problems
- 224/230 .581 .592 114 Lsa
- help needed locating LS1 oil leak
- Finally got my block back..........
- need help IDing this
- 02 LS1 Cam Question
- finally back in it
- Headers?
- Need some good advice and to introduce myself
- Carbon pistons?
- CAM questions
- 5.3L intake vs. LS1 intake...which is better?
- Engine Noise
- 2002 ws6 problem
- L76 intake fueling questions
- 200cc/62cc, 3.900" head Q's..
- 2001 SS Oil pressure
- Quick corvette question
- Car died when driving.... different thread & conditions
- Opinions on MagnaCharger?
- tall deck lsx block.
- Please help with P0355 code 2002Z M6
- Help
- What fuse is this? Anyone have the numbering for LS1 fuses? C105
- LS1 information website?
- Extra things that don't come with QTP headers and ORY-pipe
- Thinking of getting a 98 Z28...Need some input.
- I need pictures of the LS1 fuse block.
- What Supercharger to go with
- revving at 3000rpm when idling
- Car died while driving.........
- Where to install wideband bung?
- Pacesetter LT & Texas Speed catted Y pipe
- Hi To All, New guy from Colorado and LS1.com
- should i buy
- Need a smooth idling cam
- Specs on stock 26 lb LS1 fuel injectors?
- Help me pick a cam
- AI setups on LS1 anyone?
- what will or should i expect in the 1/8th mile with my setup?
- lost oil pressure, but it came back at restart
- TFS LS2 225cc vs L92 heads
- 2002 LS2 Camaro Vs. 1969 396 Camaro....
- oil change light wtf?
- LM7 build up?
- 160 degree thermostat
- TSP 370 6.0L instead of 408?
- LS1 coil pack question.
- What will my Car run in the 1/4 mile?
- obd
- Just a Quick govenor question
- whistling noise
- 2001 Camaro Z28 - Common Air Leaks?
- QTP headers and ory-pipe
- HELP!! Can't figure it out. Thanks.
- LS1 to LS6 Swap
- 2002 ws6 trans am
- hot cam or crane cam
- Spraying out of the hole.....again
- Where/what is a good 383 kit?
- Oil pressure problem 40 psi????
- Thinking about buying a LS1 SS.......
- What is that noise?
- difference between ss 325hp an ss 345hp
- valve seals for dual coil valve springs
- Low idle out of the blue, IAC?
- Road Racing and 1/4 Mile Results:
- little help please
- t/b bypass ?
- check my cam card out , tell me what you think..what should expect?
- Need some help in picking a camshaft, any ideas will be helpful.
- oil pressure?
- ticking noise...
- Help me find: Scraping/Grinding Noise
- How much oil and what weight for my 98 LS1?
- This seem like BS for a tune?
- Brand New 383 Problem
- 'Quiet valve springs" for .650 lift?
- Just bought an 03 vette, mod questions
- Mounting an LM7 motor?
- tps code - please help!
- Whining noise
- edelbrock LSX heads
- head opinion needed...
- Stupid question.. ADJ Rocker Arms and 7.4 PR's??
- Coolant leak - Waterpump?
- Motor Oil
- L92 Rocker Arms?
- 98 Z-28 questions bout mods.
- Broken bolt / water pump HELP!
- New CAR VIDS!
- would this intake and these heads work?
- Hotcam for an LS1?
- egr mod ....
- quick question re: belt replacement
- Where in the world is that PVC valve? 99 LS1
- LS1 backfire (VIDEO) what do you think?
- advanced induction
- Newbee Questions
- egr mod help!!!!!
- 02 sensor?
- Anyone adjusted their intake runner length?
- what should i expect?
- FINALLY!!!!!!!!!!!!!!!!!!!!!!!!! New buildup inside!
- how hard should a motor be to turn over by hand
- am i missing something for my crank
- AC Delco oill filter
- where can I get SSRA?
- Upgrades
- headers and Y pipe
- Questions regarding longtube install.
- k&n filter question
- HP for mods!
- does anybody make a gated shifter for the t56
- New tune today at Norris
- engine whining noise
- should I get this 98 formula 11 sec car $8500?
- Ms3
- Water pump Noise???
- Cooling System Flush with Dexcool?
- Ls6 intake
- need help with cammed trans am
- Need Help with an 07 TBSS
- No Start ~ Random problem
- Vaccum leak.....
- Wrecked Z
- 2500rpm stutter
- Comp Cam
- Help!! Quickly Please!!
- ground clearance
- Need a part number: upper engine mounts
- Turbo ls1
- need more HP...
- Whats the poundage on a stock LS1 fuel injectors
- what kind of headers and y-pipe?
- Which will be cheaper and easier? (LT1 to LSX)
- ses po107 and asr inop light on?
- Idle skip/miss
- opinions
- Mother****in Hydrolocked My Motor:
- TTT Putting my injectors back in
- Best place to get an LQ9 block, L92 heads, etc?
- Comments/Concerns on choice of heads/cam
- SLP harmonic balancer
- Factory Govenor or major problem?
- Question from over the pond, please help
- Corvette C6 Destroyed by NC Tuner
- Ls6 Intake
- Gen 3 injector sizes
- Heads and cam
- Looking for advise on turning my Ex daily driver into drag car.
- Finally got another LS1
- swaping my lt1 for ls1
- differential help
- Z28 or SS?
- Alternator ?
- Just a stupid question about idle
- LS1 help?
- Awesome ***NEW***cutaway pics of the ls9
- Actual mileage increases with Fast Toys or Austin Ram Airs?
- Torque Converter...
- Engine Temp sensor location....
- coolant hose clearance
- Rough starts?
- What scan tool or code pullers for OBD2?
- odd electrical problem....diagnosis please
- What HP do you think my combo will make?
- stock bottom end potential
- Did Comp Cams update the 918 Springs??
- help, can't get pulley off.
- Altenator squeeling?
- tame 400-450 rwhp
- Intake help
- Is an aftermarket water pump worth it?
- LS3 into a 1993 LT1 Camaro
- 40x Build
- What to do next
- Purchase Advice?
- Problem and Idea, need some opinions...
- dyno #'s
- Do LS1 intakes have no EGR???
- Z06 Mass Air Flow Sensor
- how many miles is too much?
- I need a used Ls6 Intake
- pcv
- Z06 with LS1 intake??
- Ls1 oil leak
- what is needed to do a Ls6 intake
- How to wire up my LS1 coolant temp to LT1 dash?
- Ls1 Intake
- Help!!! LQ4 motor install..
- LS1 question
- To all LS1 owners.....
- Cam guru's.. a lil help please
- What heads to go with
- PCM resets itself, not sure why
- Fuel Injection Service
