View Full Version : LS1 Based Engine Tech
- Will certain trans's fluid's help fix sycro's
- URGENT HELP NEEDED!! -- Lower Control Arms
- Problem Starting Car
- transmission (a4) flush/filter
- Does this sound like good mod or no??
- shifters
- Throttle Body & Pulleys
- Whats wrong? HELP
- C5 Vette vs WS6 vs SS
- ? on true dual exhaust
- Dealer says my gauge cluster is bad...
- GMPP CNC'd LS6 heads
- headers on stock catback
- z28 vs. the SS
- I- pipe 98 vs. 97 ????????
- if i go with weld on SFC's...
- Station wagon Firebird?
- what do you think about this head & cam?
- Need help with CAI>>>>
- 8 cylinder vs. 6 cylinder
- BMR STB Question
- Ignition Modifications???
- Stock Exhaust??
- how strong is it
- Why would I have an LS6 intake?
- Price vs Performance charts?
- No EGR on 2001 SS?
- Ls1 car or supra TT?
- Lookin for big/little wheel combo
- questions on another car :)
- ws-6 hood mods??????
- LCA replacement
- Assistance Interpreting Dyno Results
- whats this......
- Bump Stop Mod
- First Mod
- SLP level 1 kit on a vert ???
- Tach stopped working then SES came on.
- Who's running the Supersucker on their car?
- Getting the LS1 hotcam.....
- Trunk opener mod..........
- SS Axle
- Eibach Springs
- Oils?? What you use?
- 01-02 0owners inside
- Help! SES light is on!
- Bad Gas??? ... help
- How rare are Firehawks? Are they worth it?
- Triple Gauge Pillar ?'s...
- Locking gaas cap for 98's
- Can i reset my computer?
- Back to the dealer for some service
- File named .... z28exhaust.mpeg
- whats a WS6 run? a new one 00' or newer
- what do get next.......
- Pace MAF? Never heard of them. How do they compare to others?
- HVAC Fan Noise
- MACs or LTs
- rear end girdles
- Lowering Package... is this a good setup?
- holley powershot air filter
- Everyone who thinks cutouts sound bad (movie clip)
- ABS INOP light stays on all the time. 98 TA
- oil pressure question
- NEED HELP! Z28 misfireing!
- Question about this SS
- LT headers + no cats = which exhaust to go with?
- Tires
- G2 Package??
- Power door lock
- Dtc P0128 (ect)
- what is a REVERSE SPLIT CAM???
- Need cut-out advice........
- Need help - foglight bulb replacement
- Guys With N20 I Need your Help?
- Many Exhaust Questions
- Handling feels messed up! Help!
- Fuel in oil?
- how much will i dyno?????
- slp loudmouth
- Have you ever heard of this?!?!
- daytime running lights
- Stock Warped Rotors - What should I replace them with?
- warped rotors...covered under warranty??
- A 240SX has called me out! How to prepare for race?
- Buzzing speaker under warranty?
- Exhaust System
- clanking noise at the rear???
- What will I run 1/4 with these MODS? Help!
- ONE MORE question about the rear end/brake backing plates
- QTP LT Headers + Y-Pipe+passing emissions...
- Something wrong with my brakes??
- Weird Noise
- AC Delco batteries
- Very stupid question
- LS1 Mileage?
- How good are stock LS1 brake pads?
- Can you hear the Flowmaster at idle and when crusing on a LS1?
- T56 Problems
- clutch questions??
- How hard an FIPK to install?
- What gains should i expect from SLP lid, smooth bellows, & MAF?
- Gas Or Flash (no2 Or Stall)
- B&M Ripper shifter question
- What rear-end do you think is best?
- Whats next?
- Traction Control Logic Module
- Moser 12 bolt questions
- How to change pushrods?
- Suggestions for Mods
- Engine Temp gauge questions...
- traction control trouble
- best header\exhaust combo
- Help....Looking for a SS LS1 Hood......
- Which trans crossmember fits what?
- Help for more sotp feel.
- Octane
- new camaro
- dynatech headers
- How are these flow #s?
- Air/Fuel ratio gauge ?...
- ET improvement W/ gear
- Volant?
- aftermarket cats
- Service bulletins, recalls, etc.
- worth porting the TB?
- Anyone have an idea what's wrong?
- Fipk Or Lid?
- Best places for tires/wheels?
- Help!! what did i break in the motor?!?
- Help, What Did I Break In The Motor!!!!
- Exhaust Cutouts
- Buying am LS1 car, Auto or M6?
- cast aluminum engine?
- Looking for people with 315/35/17 on 9.5`` rims
- How long does it typically take to install spark plugs?
- My car doesn't downshift!
- suspension help
- 1998 LS1 Cylinder Head Recall information
- Piecing together a 9inch rear end for less than 1200, Have question
- Stock 99 Ta
- Went to the dyno today..
- Torque Converter install?
- Anyone have or seen Bassani or Random Tech. cat-backs?
- Engine Work
- Getting a Camaro
- question about part number
- No Dyno shop here. HP?
- Tire conversions
- Spark plug question
- Sub-Frame Connectors
- Considering an LS1, whats this about oil consumption?
- engine swap
- HELP my horsepower is disappering!!!!
- transmission swap
- TC lock up problems
- How can I tell what Exhaust I have?
- New LS1 Sponsor ... PPC - LT Headers & more...>>
- Question about PREDATOR???
- tires for your LS1
- what are the holes in the front passenger head?
- M6 Syncro/Tranny problems
- SFC install question
- Driving with E-brake on! Uh Oh
- Will my pistons handle 500 RWHP?
- How to install an A/F guage...
- y-pipe rubs
- Speedometer
- LS6 intake
- Upper Panhard Bar
- A question for the ages: SS or Ram Air??
- About to install a Hooker exaust. Any tips or things to watch out for?
- Reliability
- 2001 Ss
- cheapest place to buy the slp ultra z hood?
- Whats wrong with my car?
- LS6 Swap....someone says, why bother...
- Quick LS1 rotor question
- Spectacle Short Stick!!!
- installing o2 simms
- Just bought a 99 Z M6
- Reseting Trip Odomiter
- May I introduce MeSelf.......>>>
- Missed shift - broken valve?
- question about mods
- Well this sucks a$$!!
- grinding going into 3rd an 4th
- Muffler shop won't install my cut-out. WTF!?!?
- New product - 1998-'00 SLP long tubes with NO AIR or EGR fittings
- Knock Sensor Questions
- Do Vigilante's really stall about 600RPM above what they're advertised?
- whos got the most miles??
- DELA X mod
- Q's about A4 w/3.73's.....
- Selling the LT1, BUYING A LS1!!!!
- Who ports LS1 heads ???
- 97 cat back?
- SES light
- Ignitors?
- Drive Shaft Loop for Vert...who makes em?
- Anyone have pictures of their MACs before install?
- how much gear oil do i need?
- 2000-'02 Hooker long tubes available soon!
- Spec clutch
- Stock Brakes Help!!
- Fram vs Holley w/CAI Kit
- 00' Carbon Fiber Hood/Wing
- Blow off Valves
- Next Mod?
- Dual exaust kit?
- Southern Fried Clutch?
- CarSound cat's
- tax return = more mods!!
- O2simm problems - need help
- Ok Whats Next??
- Stock Injector Size?
- headers
- SLP LM vs. Magnaflow (post pics)
- Difference from 2001 to 2002
- On a limited budget...what mod is next?
- 200 shot!?!?
- feul pump help needed!
- cut out?
- Just ignore the SES light????
- Stock Exhaust Question ?
- My car is slow.
- Filling a Hole
- Just ordered my cut-out...what can I expect?
- Stock exhaust ?
- Tranny cooler...which one?
- HELP!!!another bad rear end?
- loudmouth/FLP HOW LOUD??????
- MAF screen removal for A4 o.k. ?
- Sway Bar diameters
- $10,000 Ls1 recipe
- How much should I pay for a WS6?
- Transmission problems (5th gear) experts help
- ported stock mass air ends
- Nittos vs. Kumhos
- which mods next??
- ? about transmission
- Need advice on garaging car for 6 months
- exhaust info????
- Tranny vibration?
- Gauge Pod/Autometer air/fuel, where to buy?
- Flange Gasket?
- Are all 4th gen torque convertors the same?
