View Full Version : LS1 Based Engine Tech
- I need some help, 1/4 mile ET's
- Most Reliable, Respected Torque Converter???
- What do you think about this Bellows????
- oil pressure
- Pilot Bearing Replacement
- Car Noises (WTF!)
- Free Mods...
- Aftermarket Hurst shifter adjustment
- Using GM top engine cleaner
- PCV Valve change on 98 Z
- Engine coolant has crud in it!
- The New guy with the usual new guy questions
- hooker lts
- Need Help with valve seals!
- Z06 LS6 Clutch compatible with Z28
- Clutch Problems
- Clutch Problems on Z28
- Friend looking to buy a '98 LS1 M6, what to look for?
- LS6 heads and a TR220 cam
- Good install guide for headers
- Check Engine Light Is On
- Stupid Oil Change Question for Novice
- Is my lid on wrong?
- Newbie
- Cylinder #8 Misfire after cam swap?
- Need help bleeding Brakes
- Just weighed the Z
- what is the .lb injector for 99 ls1's?
- Aftermarket Synchros
- want to fix up my SS. HELP ME!!!
- PIC's of Borla Systems on CAR
- help deciding on an ls1 or a lightning
- Wheels fitting please help
- 10's
- How much HP/TQ can the 6speed withstand?
- Does anyone make a Bellhousing for...
- Gear Ratios in T56
- Air Box Base, Modable?
- Best way to wire in LED?
- Diff. between stock MAF and SLP MAF.
- Performance exhuast question
- FTRA +lid Or Volant intake????????
- Kumho Tires
- Is This Normal?
- Driving habits...and eating oil....
- Where to buy chrome lug nuts?
- 17x11 and panhard bar and rear end leaning
- Loud vibrations on cold start after cats
- Where to find Jet Hot Headers?
- upgraded to a ls1...a couple of questions
- intake on 98 LS1
- Oil
- 3.73's????
- Average Running Temp
- suspension
- recall on Pontiac ABS?
- Ratchet shifters
- Carbon remover to reduce piston slap? Anybody done this?
- Brake, service eng, and ABS light all on, and the TCS does not work. (99 T/A 6M)
- What the heck does P0122 code mean?
- Is this a bad idea for my drag radials?
- Make LT1 Catback fit on LS1???
- Buying my 4.10s this week
- Part # for stock DRL bulbs?
- 160 thermostat
- Trans am guages in camaro?
- Where to find a tranny
- My First Mod!! Flowtech cutout!!
- advice on next mod
- Cylinder 1 misfire, whats wrong with this thing??? 2002 Z06 PCV valve???
- New Owner Here!!
- ta hood on a camaro
- Differences between 94 & 2000 check engine lights
- Traction control turns itself off
- Mobil 1
- Ordering these Parts soon, Tell me what ya think
- Help!!!!!
- Anyone with a similar set up??
- K&n Filters Vs Airaid Filters
- Considering buying a high mileage 98 LS1, should I be concerned?
- How to program keyless entry?
- what are the difference between the corvette LS1 and the camaro LS1
- Torque Converters
- weird rattle noise?
- Induction mods
- n00b Question
- Question of Reliability...
- Jet-Hot Headers
- Sound clips please =)
- Changes to the Z28 / 98 and up
- Anyone know if it would be hard to smog a 74 vega with a LS1?
- supercharged ss
- Stock Z28/SS numbers
- help me figure out this noise
- Z28 / Z28 SS - Difference?
- Who's running FLP's please come in...
- Places to Buy LS1 Pats
- what does P0135 mean (autotap)
- Stroker ?
- water pump hoses...help...please...
- model paint
- Aftermarket Ram Air
- Odd springtime start up problem - DISCONNECTED BATTERY, CAR WILL NOT IDLE
- waiting for loudmouth
- Symptoms of Warped Rotors
- Went to the track and ran a slower time, but I think my car is faster!?!?!
- Indiglo gauges
- what are the differences between a 98 Z28, and a 98 SS
- LS1 engine oil cooler
- Run without air filter afraid sand got into engine
- Leaking taillight
- oil change light
- What do YOU think?
- hello all newbie here
- Z06 MAF, Any Good?
- Which brake pads are better?
- Engine is very noisy for the first 5 to 10 minutes
- Pulled MAF today and it looks like someone put pot pouri in it
- Rust flakes in oil ??
- Offset
- Need help on 1LE springs
- Rear End Leak
- Anybody ever get a Cam installed from RP in Atlanta?
- What should I be getting at the track?
- Bolt Pattern for Wheels
- ground effects
- how do you guys stick a 325 50 15 drag radial under an f-body?
- Mass Airflow Meter Question
- SLP or aftermarket MAF install question
- Anyone use Comp. Engeneering Shocks for daily driving?
- Fillins
- wheel adapters
- Just got back from the dyno
- Removing shifter in Z28
- Help get me in the 12's.
- Gotta do some maintenance on an LS1, enlighten me, LS1 folk!!
- Bad Alternator???
- what's team stikshift doin at Speed Inc???
- Heads....bolt pattern???
- Thumping or clunking sound from rear!!Please help.
- Recommended REAR SHOCKS
- bad smog test
- A4 guys with 3.73's
- what color wire on the pcm to hook up a air fuel gauge?
- Carfax needed please!
- exhaust question
- WS6 production numbers?
- transmission conversion
- Converter Feedback
- Rear ABS sensor in differential out at 13K miles :(
- Corrosion on the axle
- Need help with purchasing gears!!!
- Q's abou the smooth Bellow....
- Part # needed!!
- Dumb converter question
- Buy ls1 with heavy mods and76k?
- Buy ls1 with heavy mods and 76K?
- Tranny gearing (Stay out you perverts!)
- Change Oil Light????
- Oil monitor and 160tstat on 00 and up
- Are changing the spark plugs worth it?
- Cutout Question!
- Dumb questions but need answers?
- Oil Changing
- Mod Help!
- AIR and emissions question...
- Problem with cutout and SES
- Life expectancy
- Stupid but necessary question. LS1 brake pad
- Question for those with 4.10 and M6 LS1
- Injectors ?
- If i dyno this, about how fast should my 1/4th be?
- Cam position sensor problem
- Got my FLP's on today(Dyno'd)
- Cost of Heads/Cam Install
- Engine sounds
- Where to Find These Wheels.....
- NEED OPINIONS auto VS stik......
- Stock LS1 rockers
- 3rd Gen or a 4th Gen
- Need help with clutch choice.
- ls1 vs lt1
- sports clutch for 00 TA
- Lowering an SS without killing the shocks
- Ordered new cam. Programming???
- Weiand/Lingenfelter intake
- Is a 160 degree thermostat wise?
- Help squeaky door
- Engine and Boost
- Shorter belt to delete the power steering...
- Help driver side blinker doesnt blink?!?!?!?!
- gut cats or not
- Where to buy a ram air hood?
- Pen magnets????
- Will these things void the warantee?
- LS6 conversion
- Dent in my glass!?
- Cartek Clutch
- Aluminum flywheel
- Which cam to buy?
- Was the 345hp option available in 2001?
- Opinions please...
- mecham hoods
- 17" X 11" rims
- Solid Roller cam
- Where to get a good heavy duty rear end?
- Why do my brakes suck?
- Went to track.. Tested Stealth intake..
- Quick help on LS1 heads
- Long tube headers
- what is it with our tranny's?!?!?
- Why exactly do A4's need tuning w/ a cam and M6's don't?
- looking for a Z stock exhaust
- po300 missfire code help
- t handle on manual
- Eclipse vs 02 Z28
- What is the TRANS/LOCK
- SLP parts maintain warranty?
- 99 Z28 running ruff!!!
- Best spark plug wires
- back up lights
- Who makes the best replica Z06 wheels?
- What size bolts for the rear girdle?
- 93-02 Firebird/TA Parts Manual in PDF
- tranny f'd up ??? q inside
- Restoring SS
- Removing my Catback System
- LT1 to LS1?
- Best install shops in WI
- Questions about gears...
- Heads/cam or supercharger
- Any tips on installing SLP's LID?
- Is a Mallory Hyfire VI compatible with an LS1?
- Clutch hydraulics replacement
- SS badges
- Went to track for the 2nd time... beat a ZO6!
- FYI: 93-97 rearend swap to a 98+ car
- TR224 112LSA cam w/ stock heads/manifolds
- Really loud ANNOYING screaming sound
- G5X-2 cam
- oil filters
- finally got some dyno numbers
- Whats the biggest cam/most power with stage 2 heads and full bolt-ons???
- Mac Headers....need help
- Loud chirping from engine.....
- gears 4.10 / 4.56
- lots of questions?????
- Help before I take it to the Stealership... Read end noise
- Best gap for my plugs...
- Wiper Blade Replacement (dad f$#% up the whole thing)
