View Full Version : LS1 Based Engine Tech
- Catalytic Conv. bad
- Need a New Clutch?
- Rear end problem possibly? HELP!!!
- Black Box Datalogging - how do I disable it?
- Oil and diff fluid
- Ls1 Conversion??? How???
- Cat Back ( whats best ) ?
- Going LS1 hunting this weekend, what to look for?
- Do 17 " rims affect a cars performance?
- What do u guys think about this package>>
- throw out bearings
- what are subframe connectors for?
- adjustable rear control arms-what do they do? what are they for?
- Bolt-on stuff
- does this sound right?(BCM)
- Chrome Wheels
- SES light - anyone know this code?
- Help!! Temp Problems
- '03 Corvette LS1
- Resurface flywheel?
- estimate my et and horspower
- breaking rear ?s
- What kind of gains with the stealth??
- Lous short stick
- LS1 gurus in the house?
- What kind of spark plug is this?
- Break-in period for clutch?
- Which master Cylinder, Ram, McCleod, Stock
- new tires
- Got Headers... Diagnose this sound...
- Mass Air Flow Question?????????
- Yet another header question?
- What converter are you 2.73 guys running
- Dyno Questions
- Gears??
- Twin Turbos
- What Is Faster
- Nitrous and the 1/4th...
- Exhaust Dilemma (Does it ever stop?)
- Diameter of stock tailpipes?
- LT's with LoudMouth
- CHECK GAGES issue with temp gauge
- can u guys run 15" wheels up front ?
- I need serious help
- Sway Bar rubbing TA rear end cover!!
- SES light, Problem??? PLEASE HELP!
- Guys running true duals, what kind of DS loop
- LS1 Stock QM Times
- Hooker or SLP Headers?
- Pulleys or ORY Pipe?
- installation price!?!?
- new wheels tire now vibration, need balancing??
- Need Stock underbody pics of your Exhaust system
- Hey guys, Need Opinion for a Car
- Syncros????
- SES came on, have code, what is it?
- A/F Gauge hook up???
- A.I.R. Pump system
- what fuel pressure
- TCI 3200 with 2.2 STR torque converter, opinions...
- Slave Cylinder
- warped rotors (warrantey)
- 98-99 and 00-02 Dash Interchangability
- Question about diff vent tube???
- GoodYear High Mile hoses
- Headers newbie question
- NEED HELP!!! Got water in the LS1
- Ram Air Cut Out
- Porting for Dummies
- $300 to spend
- Ticking Sound?
- Ported MAF results at the track
- cut out
- 2002 Z28 steering problem
- best aftermarket spark plugs for ls1?
- Will FTRA work well with Stealth??
- Header Question
- A4 guys/gals...what rpm at 80??
- Electrical fire....
- Well going to pull a boat with my---
- SLP complete intake package by afterthoughts auto
- What should i do first??
- Exhaust price?
- Exhaust price?
- 4.10 / 4.11 gears
- Curious what happens if you stall when in gear...
- What gear ratio do I have?
- Ls1 to Ls6 SWAP! in Trans Am!
- K&N FIPK VS Lid dyno test, with hood CLOSED
- Installing SFC's
- engine power washing
- Concerning "Greddy" oil catch can
- Syncros install help
- typical gains from lt headers
- Need some info on A4?
- Exhaust Blueprint?
- Service Identification Parts List
- New Here!
- Standard Shifter vs. Factory Hurst Shifter
- Midwest, TCI, or TSI Converter?
- Need Help Please!!
- EVIL A/C compressor noise
- Rototech Rotors any Good?
- Does anyone here have a shop manual for a 99/00?
- What do I do with remaining airhose
- Ok. What Next?????
- Torque Converter On Everyday Car?
- Can you run Real Duel Exaust With 1 Exaust pipe Comming From each header?
- Do I have a Miss?
- Top Speed Calculator
- T-Tops and Armor-all
- New Gears and no ABS?
- 383 on a budget
- Very Happy with 410 gears!!!!!!!
- thermostat install
- Wet kit nitrous users?
- General SS ans WS-6 Question
- what would you do?
- ES transmisson mount torque arm bushing
- strange smell when accelerating
- How much does the TPS cost, AND.....
- Y-pipe?
- Need Auburn Differential PN
- satisfied customer
- ok just got 3,500...
- Does anyone know...........
- Damn This Works!
- What goes wrong with the Rear end the most.
- E/t Streets What size rims
- Tranny/PP bolts
- Polished Holley aluminum intakes in stock
- Premature shifting A4
- Ls1 Vs Ls6
- Royal Purple Oil??????
- Mac's vs. JetHot headers
- What does this mean? (cam related)
- torque converters and snow
- Bolt-ons for a Z06?
- Valve Train Noise
- Exhaust question
- Mods UNDER $400
- Mini-tubs
- Supercharger Questions
- A different kind of vibration...
- MAF-lid NIGHTMARE
- Stock run at 13.25
- Opinion question
- Tracking down thud after lowering
- Is it possible?
- SS Window Sticker Copy
- did i put my clutch in right or what?
- Coolant light wont go off?
- Got a Holley Air Today
- '00 SS rear end....what size....
- OH NO, Camaro suffering..slowly falling apart...weird problems...
- Thinking of getting a 1998 camaroSS
- MAC offroad y-pipe + cutout?
- Odd Sound From Rear
- holley powershot air filter
- What do i need for 330 RWHP
- air filters
- Gear Swap
- Suspension/chassis/mod advice
- New Guy Here
- Loudmouth installation
- Best way to shift this car
- TB Bypass
- Zo6 motor conversion
- Cutout?
- Introduction (and 2.73s)
- ZL1 Camaro
- my car "should" have 3.73's
- Annoying Squeaking from Rear Driver Side
- What to do, What to do
- New here!
- 4.10's Rock!
- What's the best service manual for a 2001 Z?
- High Speed Braking Problems, Car Feels Like Its Floating
- Did You Know!?!?!?
- F Body Salvage Yards - nation wide
- "SERVICE ENGINE SOON" light after new exhaust
- Gutted cats + cut-out = big smiles
- 3:42 to 3:73
- Voltage Gauge
- RPMs at 70 MPH?
- After doing dyno question
- sub frame connectors
- SS and Z28 cpu's, THE SAME??
- what lid to buy and where to buy it?
- Has anyone installed the SS exhaust on a Z?
- New to the board!
- Anyone tried the Barry Grant RUSH Air Filter?
- 2001 Trans Am WS6 production #'s?
- How many tengths gained from cutouts??
- crazy
- Manual to electric
- ws.6 help need it fast!!
- ss125 and Lm
- how to tell my gear ratio
- Problems with my LS1
- new car and some ?'s
- LS1 Oil Change
- What are the best tires to buy???(traction wise)
- LT1 guy with a question
- E-Brake light and ABS
- police interceptor
- ? FOR Those who removed windshield washer bottle
- cam installation?
- 4.10 4.11 Gear strength
- WTF Coolant overflowing Dipstick neck??
- SLP/Yank 2600?
- Cheap place to get LS1 engine block??
- Port and polished heads and stroker motor in tampa florida ????'s
- how fast are these cars?
- Do all ls1 cars come wth an aluminum driveshaft?
- 10 bolt question???
- Natural Engine Brake???
- Which Ported TB???
- Homemade Secuity Switch (My Idea)
- Dual-Stage Nitrous Dyno Results: 729.9 RWHP!
- SSuperchargers
- Knocking From Diff After gear install!!
- 2001 hypertech question???
- Better year LS1?
- Will C4 rims fit an LS1 Camaro?
- Center console part numbers:
- no more 3rd to 2nd misses EVER
- loose turnsignal lever
- A couple RPO Codes
- My LS1 is alive!!!! **Last night's track times inside!**
- Concerning water & trans temp guages
- Need Z06 clutch part #......
- My cats died....
- O2 Sensor Question
- Shifting question
- low dyno #'s??? (ChrisLS1Bird - check this out) and others too.
- Fuel Pressure Guage Question
- 98 trans am wheels
- Reset ECU after Mods
- Removing Washer Fluid Bottle for More Air
- which exhaust
- dynoing with an M6
- Trashed the rear
- Dim spot on speedometer?
- Noisy hydraulic lifters???
- Z06 Computer tuning for my SS
- My stiff clutch
- Which SFC's to buy?
- which trans cooler for 98-02 Camaro
- Screeching noise
