View Full Version : LS1 Based Engine Tech
- Which one would you recommend???
- New transmission
- Bolt-On or Weld-On Subframe Connectors?!?!?!
- how???
- LS1 - Heat Extractor mod
- M6 Technical Service Bulletin?
- Strange gears?
- What springs to use with the LS6 cam?
- Friends car having gear problems...
- Shift Kit
- Power-Down Windows
- Lous Short Stick on the Ripper?
- quick question. C5 and z06 brakes are identical?
- Slp Loudmouth + SLP Headers = ???
- LS1 Loudmouth Video
- tire and wheel combo
- y-pipe
- 1/4 times with Cam, APS, and S2 TB
- High Flow Cats
- rear end question inside
- Dyno Results
- Can you get an LS6 intake with an EGR provision?
- Car makes an annoying squeal when cold!
- Whats the most power anyone's gotten with an unopened LS1?
- still cant decide : auto or manual
- How do I tell what build number my SS is?
- Help! I was an idiot!
- SS or WS6 ?
- Torque specs on knock sensors
- Tire question
- Removing the O2 sensor
- Rear options...
- Anybody use Z28 for Touring?
- Wheel spacers in houston?
- Will the Vette shift knob fit a B&M?
- auo shipment
- LS1 Swap
- mac's with loudmouth any good?
- Best Year of the LS1
- Gears
- What Mods Next?????
- Cut Out Placement
- tach output for shift light?
- Quick cutout question??????
- Alternator question
- East Tennessee Guys (and Gals) inside!
- IAT sensor question
- Warranty Gold Still ripping me off... sorry if in wrong section
- Thoughts on the LS1.
- what RWHP gains have you seen from lid and cutout?
- anyone else grind going into 2nd?
- Where in the Hell???
- dimpled rotors? Any draw backs?
- Power steering fluid - corrosive???
- check engine light
- Z-rated tires
- A4 question
- opinions on plates borla people
- Help Me Plan my Car's Future
- What Brand of 3.73's?
- Random Technology high flow cats
- Lookin to order Pacesetter LT's asap....
- What RPM's does everyone shift at on the strip?
- C5 1/4 Times?
- Ported heads on stock LS1?
- Well.....isn't that some S**T!.....
- I need some help with my AC
- 95' 10 bolt into an 02'?
- brake calipers that has camaro or trans am on them
- What kind of oil do you use in your LS1?
- What I need to get to 12.5 or lower
- convertible leaking???
- M6...3rd grinding
- What else do I need???
- car troubles, help appreciated
- Should i buy this SS?
- LM Performance has me scared!
- Automatic vs Manual in longitivity?
- What to plug hole in lid with?
- Tire Size HELP FAST!!!!!!!!!
- bought wrong rear.. What are my choices
- Mods and Power Programmer Questions
- WHy is the car running so hot!
- Back to the Dealership
- Which gears?
- lower control arms vs. adjustable lower control arms- what is difference?
- Vert gears
- so my friend hit a 13.55 today...
- Speedo Glow Gauges
- Cheapest STAINLESS exhaust?
- Installed SLP lid and wont start...
- love the tach lag
- Whine from under the hood, alternator?
- TH-350 and LS1 Questions
- Gears and the 1/4th.
- dumb question - cut out -
- SLP Long Tubes?
- A Little Help Please, Car Problem, What's Up.
- Bad clutch diagnosis help
- LS1 Cam Swap : How Difficult is it?
- Swaybar question....HELP!
- Autometer A/F ratio gauge question...
- guy's who have removed thier AC?
- How does a cutout function?
- PCV part # question???
- 4L60E Drain screw?
- Dielectric Compound
- Cutout and SES light
- help!
- Warped rotors, go figure.
- Installed Pro-5.0
- SLP LT Clearence Pictures
- Where can i get a midwest torque converter
- Z06 PCM in a 99Z28?
- Getting my WS6 sat-coming mods:
- Where can i get a stock exhaust hanger?
- Tell me what you guys think
- Help with P 1416
- I have a ?
- Diablosport predator
- best bang for the buck
- Z06 Cam
- Hooker LT's
- All You M6 Guys Come On In?
- How to get knob off A4 shifter?
- Question about bolts on Hooker Shorties
- What size converter on a 98
- panhard bar or lower control brackets
- do i really have to disconnect battery to change fuel filter?
- got cam in and dynotuned
- Z06 cam specs?
- engine wiring harness?
- question about superchargers and intakes
- Where can I get a ZL1 grill?
- taylor plug wires?
- nitto 555r 315/35/17's
- Stupid dealer screws up temp gauge.
- LS1 Tune-Up
- LS1 handeling comparison?
- ready to dump flowmaster
- 160 Thermostat
- Are A4's all 2.73's
- American Thunder Cat-Back?
- Will this sensor compliment my FIPK??
- Loud Driveline noise...Whats wrong???
- Can anyone help troubleshoot knock/ping?
- 98 ram air vs. 99 Z28?
- Smoke
- my buddy has a question
- TB porting same as EGR pipe removal?
- Cat Back Question
- option code sticker
- 18'' wheels tire combo slp ultraz hood
- Need help for Price vaule of used FLP Header package??
- Clutch problems - need a new one soon?
- Vacuum leak
- ported MAF on my 98 a4?
- Faint rear end whine @ 57-60 mph. Anyone else?
- th350 behind ls1?or early 4l60e?
- Z06 parts on camaro
- cutout video
- engine idle problem
- LS1 Doctors - please look inside...
- What the heck is this wire?
- which electric cutouts let you go to midway positions between "open" and "closed"
- Rim size and how they effect the computer
- pro 5.0 shifter ?s
- cutout placement
- Who's making 450rwhp or more...what are your mods?
- M6 Gets stuck in 4th gear sometimes
- Paging Raughmmer's Pepper.
- Help!!!!!
- HELP!! Have 18 barrel shaped bearings on oil drain plug!!
- High flo cats or just Y-pipe and let the next guy deal with it.
- temp. reading accurate?????
- what size fernco bellow
- Mufflex 3.5 Cat back
- 31 Mpg!!!
- strange noise after lid install?
- Car is Running WAY to Hot Hot Hot......
- Egr 99-00?
- stupid question about slotted rotors...
- Clear air lids?
- Loudmouth with Dynomax muffler
- Ok, is it the battery? Or the alternator?
- new rotors-links on install yourself?
- 10w30 oil alright?
- Rear End Oil
- woo hoo
- How much for T56 rebuild?
- Q for u guys, about nos
- Basic Performance Upgrades ?
- Piston Slap question
- Anyone had MTI engine work?
- Spec Stage I lowest price???
- Cams.. Need Help
- Hhpiii?
- Headers banging on floorboard...remedies?
- FLP LT's
- Radiator Dimensions for 98 Trans am...
- Source for Pacesetter LT's
- converter in my 1998 z28?
- Least expensive long tube headers?
- True dual
- clicking sound in 1st
- Steering
- Tires on an LS1 SS?
- high flow cats
- Best street clutch...Spec, Centerforce???
- what the best brand of 373 gears? and who carries the best price for them?
- Why won't my car go straight?
- Replace stocke muffler with Spintech?
- biggest tire size on 18s
- A4 guys.........with 3.42:1 and 3.73:1......inside
- I can't find anyone that sells true dual setup
- mayb u guys can help
- changing springs??
- converter question
- can you reprogram a LS1 pcm?
- need a new clutch, which one?
- What gear do i have in my 98LS1 M6?
- In your honest opinion 3:73 rear
- Is Piston Slap that common? If it is should I not buy a camaro?
- post: what kind of exhasut should i get?
- 99 Cluster
- Clutch stuck to the floor but now woking fine
- Mobil 1.... Please HELP!!!!
- where can i buy 02 aniversary ss rims?
- Rattle from exhaust?
- is it necessary to get tuned after a converter is installed?
- Engine stutter at idle HELP
- How much do LS6 intakes usually go for?
- I actually gained from an aftermarket MAF?
- Torque Arm removed, but axle is now tilted up?
- Dammit...was looking at an LS1 how to site before and cannot locate it now.
- Just picked up my new car!
- Rear End, Bent or Out of Alignment
- Elevation and 1/4 mile times?
- Belt noise on car
- Just bought me an LS1
- What's an f1 zamaro?
- hydralic line removal
- Corsa + y-pipe
- Your opions- please
- Stainless Steel OR Ceramic Coated Headers?
- Jet-Hot LS1 headers & Y-pipe - INSTALLED!!
- Possible to run 12.7-12.9 with just lid and loudmouth exhaust?
- how does a bent pushrod cause a loud tapping noise?
- Problem with my new ported throttle body
- 3:42 gears, why did GM bother...
